Hi Curviloft Fans,
some CurviArt variations from a basic form.
Charly
Curviloft (Beta) Plugin Tutorial
• Page 2 of 2 • 1, 2
Re: Curviloft (Beta) Plugin TutorialHi Curviloft Fans,
some CurviArt variations from a basic form. Charly Please, register (free) to access all the attachments on the forums. More dangerous than ignorance is the illusion of knowledge
Re: Curviloft (Beta) Plugin Tutorialvery impressive. thanks for posting these examples!
Re: Curviloft (Beta) Plugin TutorialThanks, Charly. I hope to tame the powerful beast with the insights you have shared, or at least not be consumed by it.
~ Brooke
Re: Curviloft (Beta) Plugin TutorialWhen I've got the transitions previewed (in black), I find I am unable to orbit to really inspect the thing (like you do, Rich, in your demo tuts). If I try the operation is cancelled. Is there a secret?
~ Brooke
Re: Curviloft (Beta) Plugin TutorialCharly,
I have an irregular column shape I'm trying to make using curviloft. Stitching the circle and the shapes together should have worked but it did not. Do the segments on each shape have to be equal in number? also the top of the planter is not flat it should be from with a curve in the z plane. Not certain how I would construct this. How can this be done? See attached skp file. Please, register (free) to access all the attachments on the forums.
Re: Curviloft (Beta) Plugin TutorialLapx
Is this the result you seek? Select the three 'profiles' of edges and run CurviLoft. The initial result might be somewhat twisted, because the top circle's 'start' is rotated relative the the 'starts' of the other curves... but you can easily relocate that point around the curve in the tool.... before committing to the form... Please, register (free) to access all the attachments on the forums. TIG
Re: Curviloft (Beta) Plugin TutorialThe start point may not matter depending on the Vx setting.
Note the black previews which if I orbit during, causes the whole operation to be discarded. The first pics show 1,2,3 from the bottom up. Here from the top down. Please, register (free) to access all the attachments on the forums. ~ Brooke
Re: Curviloft (Beta) Plugin TutorialHi all,
Watching this tutorial, I found the window (red arrow) in the photo. Does anybody know tell me the path to find it? Thanks in advance
Re: Curviloft (Beta) Plugin TutorialSorry,
photo. Please, register (free) to access all the attachments on the forums.
Re: Curviloft (Beta) Plugin TutorialHi Roberto,
you will find it in the Tools menu. Charly Please, register (free) to access all the attachments on the forums. More dangerous than ignorance is the illusion of knowledge
Thank you very much. (I tried to send a private message, but evidently you have not received).
Re: Curviloft (Beta) Plugin TutorialAwesome tutorials
Sketchup 8 pro
Vray Intel Xeon W3520 2.67Ghz 12Gb Ram Nvdia Quadro FX 1800
SketchUcation One-Liner AdvertsArtisan Organic Toolset - a set of powerful organic modeling tools.
Premium Members get 20% discount!
