Dear All,
I was looking for some good solution to get DXF/DWG including text and line types into the SketchUP.
And this is the result.
Standard DXF/DWG Import done in SketchUP Pro
DXF / DWG with text and linetypes in SketchUP !
• Page 1 of 1
DXF / DWG with text and linetypes in SketchUP !Dear All,
I was looking for some good solution to get DXF/DWG including text and line types into the SketchUP. And this is the result. Standard DXF/DWG Import done in SketchUP Pro Regards, SU 'beginner'
Re: DXF / DWG with text and linetypes in SketchUP !so, how was it done?
Re: DXF / DWG with text and linetypes in SketchUP !Can you give us some more information please - is the imported drawing readable as seperate lines and text? or is it more of an image?
How do you do it? etc etc
If this is vector I'm very interested!
Re: DXF / DWG with text and linetypes in SketchUP !This thread need more info. As it stands now it's doesn't really help much.
Re: DXF / DWG with text and linetypes in SketchUP !Looks like the text was exploded into lines that would then be importable [although the file size gets very big!].
It's good idea to edit the CAD file to remove unwanted/unused detail that won't get imported [like hatching], then purge/audit before trying the import. If you save the DWG as a DXF [say r2004] then you can import that DXF's raw geometry [keeping the CAD origin], then use my 'importDXFtext' script to import the CAD text part only, it comes in as 'flat' 3d-text, using the equivalent size/font/style/location/layer/color etc wherever possible. The two imports should then overlay properly; so that then grouping them as one you can move them back to a sensible SKP origin... TIG
Dear All, As TIG said it is a bunch of vectors – approx. 15,500 of them, but it works ! I don’t have enough time to do the ‘proper’ tutorial, but I have listed the software and steps taken. You need the following: • AutoCAD (LT is fine) • PDF Creator • Any PDF to DWG Converter • SketchUP PRO Step 1 – Open DWG, explode all objects, change all fonts to simplex.shx Step 2 – Draw rectangle around the drawing – would be used to scale the drawing in SU Step 3 – Print to PDF – I used PDF Creator Step 4 – Save the drawing as exploded DWG – we will use the drawing as ‘Scale Reference’ in SU Step 5 – Download ‘Any PDF to DWG Converter’ Step 6 – Open the PDF with 'Any PDF to DWG Converter', set in ‘Options - Centreline’ and ‘Convert Now’ – it could be converted to DWG or DXF – I used AutoCAD 13 • I didn’t manage to have the right scale but, the rectangle from Step 2 would come to the rescue later (see Step 10) Step 7 – Open SU PRO, import ‘exploded DWG from Step 4’ and make group Step 8 – Open 2nd session of SU PRO and import ‘converted DWG from Step 6’ and make group Step 9 – You could copy one of the drawings (Select and Ctrl+C) and paste to the other (Ctrl+V) Step 10 – Scale using ‘anchors’ – simply drag ‘edge to edge’ of previously drawn rectangle to match the converted drawing size Regards Regards, SU 'beginner'
SketchUcation One-Liner AdvertsArtisan Organic Toolset - a set of powerful organic modeling tools.
Premium Members get 20% discount!
• Page 1 of 1
