SketchUcation Premium Membership
How to render huge (like 300dpi) images?
Postby AcesHigh » Sat May 19, 2012 7:28 am
Whenever I try to render in like 8000x6000, sometimes even smaller (like 5000x3000) or something like that, I get error messages...
Tried to render smaller areas but not much success. Isnt a way to render directly to a file?
Does rendering multiple channels (diffuse, alpha, etc) overburdens the memory thus creating the error?
AcesHigh
Re: How to render huge (like 300dpi) images?
Postby Rich O Brien » Sat May 19, 2012 9:36 am
Can you update your profile so that we can know which OS you are using and what SU Version you have installed?
Also you don't mention what version of Vray you are using?
:::Blog:::
I'm a Trimbler now!
User avatar
Rich O Brien
Administrator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Level of SketchUp: Advanced
Postby thomthom » Sat May 19, 2012 10:25 am
+1 Rich. This information is important.
AcesHigh wrote:I get error messages...
But what is even more important is what the error messages say. They explain exactly what is going on. Without knowing these it is just guesswork. )Like going to the doctor and saying "I'm sick! Fix me!")
User avatar
Global Moderator
Name: Thomas Thomassen
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Postby n3v » Sat May 19, 2012 6:00 pm
AcesHigh wrote:Whenever I try to render in like 8000x6000, sometimes even smaller (like 5000x3000) or something like that, I get error messages...
I'm guessing that your computer is running out of RAM, if you want to avoid this you need to render directly to vrimage, this can be found in the output drop down menu, and you are going to want to select .exr as the save type.
the downside of this is that vfb channels are not stored or saved but I think are still processed annoyingly (someone might have to correct me on that) but generally yes using the extra channels will slow your render down.
n3v
Postby valerostudio » Mon May 21, 2012 6:30 pm
You need the latest SU 8 and VR 1.49.01 and render directly to EXR.
Go to Options - Output - Under VRAY Raw Image File, click Render To VRImage box, Then under file name make sure you save as an EXR file. I usually VFB mode is on preview so you can see whats going on. This will eleviate some RAM issues.
Also, you need to turn your settings down on displacement if you are using it. A high res file will not need edge length of 4 or less like the defaults. I use 30 or higher. If you can get away with no displacement, even better. This is a memory killer.
valerostudio
SketchUp version: 8
License type: Pro
Postby thomthom » Mon May 21, 2012 6:58 pm
Why the need for SU8? Thought VfSU worked the same across versions...
User avatar
Global Moderator
License type: Pro
Postby Ecuadorian » Mon May 21, 2012 7:01 pm
You don't need to render at such huge sizes:
viewtopic.php?f=18&t=38373
To get the final printing size @300dpi, use Smilla Enlarger:
http://sourceforge.net/projects/imageenlarger/
Ecuadorian
SketchUp version: 8
License type: Free/Make
Level of SketchUp: Intermediate
Postby valerostudio » Mon May 21, 2012 7:31 pm
thomthom wrote:Why the need for SU8? Thought VfSU worked the same across versions...
My understanding was that the latest update for SU8 allowed for allocation of 4GB of RAM. Gives ya a little more to work with. Am I wrong?
valerostudio
SketchUp version: 8
License type: Pro
Postby thomthom » Mon May 21, 2012 8:45 pm
Ah, yes! SU8 M1 added LARGE_ADDRESS_AWARE support - so if you are under 64bit Windows you can address up to 4GB of memory. You're absolutely right.
User avatar
Global Moderator
License type: Pro
Postby valerostudio » Tue May 22, 2012 2:47 pm
Every little bit counts. ;)
I am on a 64 bit Windows 7 machine with SU 8 Pro and 1.49.01 VR and rendered a 10,000 pixel wide image to EXR and it did not crash on me.
valerostudio
SketchUp version: 8
License type: Pro
Postby andybot » Tue May 22, 2012 5:27 pm
valerostudio wrote:rendered a 10,000 pixel wide image
:shock:
how long did that take?
User avatar
andybot
Premium Member
Premium Member
SketchUp version: 8
Postby Pilou » Tue May 22, 2012 5:58 pm
DPI as nothing to see, it's just the number of pixels! :)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby eidam655 » Fri May 25, 2012 9:44 pm
thomthom wrote:Ah, yes! SU8 M1 added LARGE_ADDRESS_AWARE support - so if you are under 64bit Windows you can address up to 4GB of memory. You're absolutely right.
WHY DON'T I EVER UPDATE :o
sorry for the rude off-topic interruption
User avatar
eidam655
SketchUp version: 8
License type: Pro
Postby thomthom » Sat May 26, 2012 11:48 am
eidam655 wrote:WHY DON'T I EVER UPDATE :o
Yes, why not? Updates aren't there to annoy you - they include fixes and improvements. It's always best to ensure you are up to date before debugging a problem with a software.
User avatar
Global Moderator
License type: Pro
Postby eidam655 » Sat May 26, 2012 1:44 pm
thomthom wrote:Yes, why not? Updates aren't there to annoy you - they include fixes and improvements. It's always best to ensure you are up to date before debugging a problem with a software.
while i usually enjoy watching the progressbar of an update taking place (srsly, i do), i had had some issues when i was updating to the latest vray and hence have decided that if it works, i'm not going to mess with it until some major new release (like SU 9) comes along. but now i've updated and there were no problems so far, yay 8-)
User avatar
eidam655
SketchUp version: 8
License type: Pro
Postby shri » Sat Jul 21, 2012 7:35 am
valerostudio wrote:Every little bit counts. ;)
:o :o :o what was the file size of your skp file.and how long it took to render an image of that size.my computer would rather faint or take a week to render.i guess. :lol: :lol:
shri
Postby thomthom » Sat Jul 21, 2012 12:03 pm
File has means very little for model complexity. Textures often take up a large portion of a file, and watermarks - especially if you don't resize them for your needs and just leave them in their original sizes. You can have a model of a cube and fill the model with large images so the SketchUp file is 200MB+. If you want to compare model complexity you must look at polygon - or more accurately number of triangles.
User avatar
Global Moderator
License type: Pro
Postby sanjeevkmishra » Sun Apr 28, 2013 3:51 pm
HI,
I'm a newbie here. recently I'm facing the same problem. I ve done all the suggestion made above but all in vein. My skp file size some where around 250mb. Either SU is crashing or vary is not starting at all once I hit render. I'm using mountain lion on mac with 8GB ram. Pls advise. thnx.
Rgds,
Sanjeev
sanjeevkmishra
Operating system: Mac
SketchUp version: 8
SketchUp use: interior design
by Ad Machine » 5 minutes ago
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
Return to V-Ray
cron
Who is online
Users browsing this forum: No registered users and 4 guests
