SketchUcation Premium Membership
Dimensions in rendered models
Welcome! Ask and get answered - or just introduce yourself.
Postby giorgio78 » Fri May 18, 2012 12:06 pm
Is it possible to render models with IDX renditioner or any other rendering software having dimensions seen also in the rendered file?
giorgio78
Re: Dimensions in rendered models
Postby Dave R » Fri May 18, 2012 2:57 pm
If I want dimensions in a rendered scene I make an export direct from SketchUp that is the same size as my rendered image and lay it over the rendered image in an image editor.
Inspecting mirrors is a job I could easily see myself doing.
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Level of SketchUp: Advanced
Postby giorgio78 » Tue May 22, 2012 6:59 am
Clever idea..........
giorgio78
Postby giorgio78 » Mon Jun 11, 2012 7:16 am
I've tried to do this but no success. Can you just explain me in short how to do this and what editor do you use?
giorgio78
Postby massimo » Mon Jun 11, 2012 7:50 am
1) Do the render;
2) Export from SU the 2d image, at the same size of the render, setting the style to "hidden line" (it's in the "default styles" folder);
3) Open both the render and the SU's exported image for example in Photoshop. Right click on the SU's image layer-->"duplicate layer" and choose the name of the rendered image under "destination". In this way you're sure that the two images will match perfectly;
4) Select the SU's image layer and set the blending to "multiply".
That's all.
User avatar
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
Postby Dave R » Mon Jun 11, 2012 10:34 am
Massimo beat me to it but his is almost the same process I used. If you don't want the edges of the model as mine shows, after setting the Face Style to Hidden Line, edit the style to turn off edges leaving only the dimensions visible.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
by Ad Machine » 5 minutes ago
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Ad Machine
Robot
Return to Newbie Forum
Who is online
Users browsing this forum: Rose123 and 3 guests
