I invite for acquaintance with Russian plug-in
Re: I invite for acquaintance with Russian plug-in
Postby jorge2011 » Sun Apr 01, 2012 2:16 pm
thanks for the update. But still generates the same error, when using the tool "tube":
Error: #<ArgumentError: Not enough edges - at least 3 required>
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:569:in `add_face'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:569:in `cp_create_pipe_geometry'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:110:in `onLButtonDown'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:247
you can fix it?
I use:
windows xp in Spanish
sketchup 8 pro in Spanish
jorge2011
Postby ken » Sun Apr 01, 2012 3:23 pm
I receive the following error code after installing.
Thanks you in advance for your help.
Ken
User avatar
ken
Premium Member
Premium Member
Postby jorge2011 » Sun Apr 01, 2012 3:51 pm
Ken wrote:I receive the following error code after installing.
Ken
You must copy the file "iconv.so" in the folder:
windows/system32
jorge2011
Postby ken » Sun Apr 01, 2012 3:57 pm
Jorge
Will thanks for the advice, however I still have the same error code.
Ken
User avatar
ken
Premium Member
Premium Member
Postby guanjin » Sun Apr 01, 2012 3:59 pm
Site not open
User avatar
guanjin
Postby yad2000 » Mon Apr 02, 2012 12:51 pm
jorge2011 wrote:thanks for the update. But still generates the same error, when using the tool "tube":
you can fix it?
I use:
hmm ...
very strange ...
I was not able to repeat that mistake, I can recommend:
Line number 569 is:
Code: Select all
face = entities.add_face circle
Try replacing the line number 557:
Code: Select all
circle = entities.add_circle pt1, vecbegin, radius, numsegs
on the line
Code: Select all
circle = entities.add_circle pt1, vecbegin, radius, 24
or if not, then the line
Code: Select all
language is not involved, but rather a problem of API in your version of SketchUP, although the design:
Code: Select all
works with the version of SketchUp 6.0+, can you have an earlier version, not 8.0 PRO? in a previous version of the plug CoolPipe 1.2.0 you have the same problem was, nobody else it is not repeated
User avatar
yad2000
Postby jorge2011 » Mon Apr 02, 2012 2:14 pm
This solution does not work.
the list of error:
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:570:in `add_face'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:570:in `cp_create_pipe_geometry'
Error: #<NoMethodError: undefined method `bounds' for nil:NilClass>
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/ReducerTool.rb:90:in `creategeometry'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/ReducerTool.rb:67:in `onLButtonDown'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/TeeTool.rb:90:in `creategeometry'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/TeeTool.rb:68:in `onLButtonDown'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:90:in `creategeometry'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:67:in `onLButtonDown'
Objeto elegido CoolPipe =
Error: #<NoMethodError: undefined method `[]' for nil:NilClass>
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:594:in `getparams_frompipe'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:327:in `reset'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:296:in `initialize'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:3070:in `new'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:3070:in `cp_edit_coolpipe_elements'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:21:in `cp_add_toolbar_button'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:90:in `call'
Error: #<NoMethodError: undefined method `layer' for nil:NilClass>
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/CopyOptionsTool.rb:67:in `onLButtonDown'
Error: #<NoMethodError: undefined method `length' for nil:NilClass>
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:2819:in `cp_get_length_tube'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:2931:in `generate_CoolPipe_specification'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:2925:in `each'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:2925:in `generate_CoolPipe_specification'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:25:in `cp_add_toolbar_button'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/CopyOptionsTool.rb:67:in `call'
jorge2011
Postby Dan Rathbun » Mon Apr 02, 2012 5:34 pm
yad2000 wrote:
Line number 569 is:
Code: Select all
try:
face = entities.add_face( circle.edges )
    I'm not here much anymore. But a PM will fire email notifications.
    User avatar
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby yad2000 » Mon Apr 02, 2012 5:38 pm
    That's right, because you're not going to work. This plugin is targeted to the appropriate users. You have added a new document and a new tube without any parameters, of course anything you do will not work. The parameters necessary to specify everything: nominal diameter, outside diameter, wall thickness, the name of the pipeline, etc. All that is required.
    So that promote your cause, or assist in the development or discourage new users
    User avatar
    yad2000
    Postby yad2000 » Tue Apr 03, 2012 5:55 am
    Please bring a list of documents for which you want to add elements. Now used only 2 Russian document on the piping. If you write a number of documents that you use and you can download them somewhere, I'll add them to the database to avoid similar mistakes.
    User avatar
    yad2000
    Postby tony bombata » Mon Apr 23, 2012 8:48 pm
    Ken
    windows/system32
    i use x64 windows and i had the same problem
    copied iconv.so and iconv.dll to win2, wow64, sketchup plugins and coolpipe folders
    don't know which worked out but it's working
    tony bombata
    Premium Member
    Premium Member
    Postby Dan Rathbun » Mon Apr 23, 2012 10:12 pm
    Well which one of those paths are in the $LOAD_PATH array ??
      User avatar
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby guanjin » Tue Apr 24, 2012 3:08 am
      yad2000 wrote:Please bring a list of documents for which you want to add elements. Now used only 2 Russian document on the piping. If you write a number of documents that you use and you can download them somewhere, I'll add them to the database to avoid similar mistakes.
      I can not open the page, to download, why not posted on the website
      User avatar
      guanjin
      Postby yad2000 » Wed Apr 25, 2012 5:50 am
      guanjin wrote:I can not open the page, to download, why not posted on the website
      Coolpipe.ru site - located in the ucoz.com - if none of the sites of ucoz you can not read - then the problem is with your provider.
      User avatar
      yad2000
      Postby guanjin » Thu Apr 26, 2012 6:04 am
      yad2000 wrote:
      irwanwr wrote:if the plugin will be available in English version and shared here too.
      if it is true.
      this is true, but it will probably not soon. Will take some time to create a fully functional version of the native language, only then do the translation. It is possible I will ask for help - if you do not mind
      Finally downloaded, loaded error
      User avatar
      guanjin
      Postby yad2000 » Thu Apr 26, 2012 10:18 am
      guanjin wrote:
      if it is true.
      in the file that you changed - Error!
      you must:
      "沿线 管道 目录 列表,
      replaced by
      "沿线 管道 目录 列表",
      should work
      User avatar
      yad2000
      Postby guanjin » Thu Apr 26, 2012 1:33 pm
      Successfully translated into Chinese, but has not been used successfully, the of plumbing tools?
      :roll: :roll: :roll:
      User avatar
      guanjin
      Postby yad2000 » Thu Apr 26, 2012 5:17 pm
      guanjin wrote:Successfully translated into Chinese, but has not been used successfully, the of plumbing tools?
      Normative documents only Russian. To broaden the base of the elements - I need to know what documents you use. They are very much, all I add one can not afford
      User avatar
      yad2000
      Postby guanjin » Thu Apr 26, 2012 7:25 pm
      I do not know that you mean ,the file is a common indoor plumbing components
      User avatar
      guanjin
      Postby yad2000 » Fri Apr 27, 2012 5:20 am
      I also do not understand what you want)))
      User avatar
      yad2000
      Postby yad2000 » Fri Apr 27, 2012 6:20 am
      I will say this: I have now developed a new version of the plugin, which will not appear on [iconv] and [web dialogues]. The most interesting thing to come, as the plugin will look - still a secret. When will the release of do not know. Work to be very much as I want to do everything in Ruby without any HTML and JavaScript
      User avatar
      yad2000
      Postby yad2000 » Mon May 21, 2012 8:37 am
      who knows how to use the database MongoDB in Ruby for SketchUP :?:
      here...
      User avatar
      yad2000
      Postby yad2000 » Mon May 21, 2012 10:17 am
      Time is now developing a new interface for plug-in.
      Here is a screenshot
      I want to abandon HTML, JavaScript, CSV. I am looking for ways to solve problems with the database.
      Who share the standards DIN / EN / ISO / API / ASTM / ASME?
      User avatar
      yad2000
      Postby yad2000 » Mon Oct 01, 2012 1:38 pm
      Who shares the standards DIN / EN / ISO / API / ASTM / ASME?
      For further development of the plugin. Interest standards for all items, not just on the tube. At least to start with 2 pcs. You can share the standard is not complete, but only the image and style options.
      Google Translator gives terrible translations)))
      In Russia, the translation is: "Your - my not understand"))))
      User avatar
      yad2000
      Postby ken » Fri Feb 01, 2013 1:56 am
      Hello
      I have tried and tried to get this program to work. I keep getting the attached error. I have the file, iconv.so in the correct directory as shown.
      So what is wrong, and can it be fixed? I deal with pipes diagrams and would like for this to work.
      So thanks in advance for your help.
      Ken
      User avatar
      ken
      Premium Member
      Premium Member
      Postby driven » Fri Feb 01, 2013 2:05 am
      Ken wrote:Hello
      Ken
      Start.rb is not finding iconv.so is what your message says, and it needs it so it reports an error....
      I'm on mac, but it looks like you need to put the missing file into your plugins folder >>> iconv.so
      driven
      PluginStore Author
      PluginStore Author
      Postby Frederik » Fri Feb 01, 2013 11:49 am
      Looks like a very interesting plugin... :thumb:
      Unfortunately I seem to share the same issue as Ken...
      I've never had any issue installing a plugin - before now... :?
      I even tried to copy the iconv.so to the plugins folder, but to no avail... :|
      Cheers
      Kim Frederik
      User avatar
      Frederik
      Thea Render Support
      Thea Render Support
      Postby Frederik » Fri Feb 01, 2013 12:14 pm
      OK... Tried to see if I could see something in the coolpipe_Start.rb
      (yep - it's dangerous when having a very limited knowledge when it comes to coding... :lol: )
      The original code looked like this:
      Code: Select all
      #encoding: utf-8
      # Cool Pipe Engine 2011-2012
      # Cool Pipe Engine 2011-2012 to the SketchUp interface
      # version 1.2
      # Software Author:     Borisov Denis Vladimirovich (yad2000@rambler.ru)
      # Design:              Borisov Denis Vladimirovich (yad2000@rambler.ru)
      # ©2012 by Borisov Denis Vladimirovich (yad2000@rambler.ru)
      #История версий
      #-v1.2.1
      #-Мультиязычность проекта (русский,английский,французский,итальянский,испанский,немецкий), возможность выбора языка в процессе работы с плагином
      #-Расчет массы отвода (стального), расчитыватеся по геометрическим параметрам (может не соответствовать с заводским изделиям)
      #-Структура кода измененена: отсутствует изменение стандартных классов, весь код объединен в классы и модули
      #-внесено исправление по загрузке iconv.so: на MAC не загружать, только на Windows
      #-редактирование элементов вынесено за пределы Observer при выделении на отдельную командную кнопку
      #-исправлен принцип сортировки элементов спецификации на стандартный .sort (для избежания утечки памяти в процессе подсчета и зависаний SketchUP)
      #-v1.2
      #-Изменение структуры работы с базой данных элементов
      #-Рисование и редактирование трубопроводов
      #-Рисование и редактирование отводов
      #-Рисование и редактирование переходов
      #-Рисование и редактирование тройников
      #-Рисование заглушек
      #-Рисование фланцев
      #-Создание спецификации
      #-Функция копирования свойств (слой+материал) для объектов CoolPipe и групп
      #v1.1
      #-Следующие публикации по адресу: http://coolpipe.ru/load
      #-Кардинально изменен дизайн диалога с пользователем
      #-Дополнена база ГОСТов трубопроводов
      #-Рисование трубопроводов мышью
      #-Накладывание слоев, собственный редактор "быстрых" слоев
      #-Накладывание материалов (боевая раскраска трубопроводов)
      #-Накладывание теплоизоляции + редактор стандартных толщин изоляции
      #-Функция "Прилепить отвод"
      #-Функции редактирования трубопроводов (задание уклона или отметок трубопровода)
      #-Функции редактирования отводов при выделении самих отводов мышью (экранное меню)
      #-Функция "Составление спецификации"
      #--разработка прервана
      #v1.0
      #Пробный плагин (в виде тулбара) рисующий трубы, отводы, переходы, тройники, заглушки, фланцы по известным ГОСТам
      #Первая публикация по адресу: http://forum.abok.ru/index.php?&showtopic=30806&st=160
      require 'sketchup.rb'
      require 'CoolPipe/cp_Lang.rb'
      require 'CoolPipe/Service_proc.rb'
      require 'CoolPipe/PipeTool.rb'
      require 'CoolPipe/ElbowTool.rb'
      require 'CoolPipe/ReducerTool.rb'
      require 'CoolPipe/TeeTool.rb'
      require 'CoolPipe/CapTool.rb'
      require 'CoolPipe/FlangeTool.rb'
      require 'CoolPipe/cpCSVBase.rb'
      require 'CoolPipe/CopyOptionsTool.rb'
      pform = (Object::RUBY_PLATFORM =~ /mswin/i) ? :windows : ((Object::RUBY_PLATFORM =~ /darwin/i) ? :mac : :other)
      platform = pform.to_s
      if platform == "windows"
        require 'CoolPipe/iconv.so' #  применяем iconv
      elsif platform == "mac"
         #  не применяем
      CoolPipe_number_version = "1.2.1" # Текущая версия плагина
      coolpipe_plugin = CoolPipePluginApp.new
      coolpipe_plugin.run
      So I deleted the two spaces in line 62 in front of "require"
      Code: Select all
      Now I get this Load Error message:
      Cheers
      Kim Frederik
      User avatar
      Frederik
      Thea Render Support
      Thea Render Support
      Postby yorik1984 » Fri Mar 01, 2013 3:56 pm
      Copy iconv.co to C:\Windows\system32
      User avatar
      yorik1984
      Postby Dan Rathbun » Sat Mar 02, 2013 12:06 am
      yorik1984 wrote:Copy iconv.so to C:\Windows\system32
      NO.. DO NOT !
      It does not belong in the OS system directory !
        User avatar
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        by Ad Machine » 5 minutes ago
        Ad Machine
        Robot
        PreviousNext
        Return to Plugins
        Who is online
        Users browsing this forum: Engin BAKIR, Ferdiandaris, Google Bot, jim4366, OSN58, REDpink2307, Twipzz and 19 guests
        Visit our sponsors:
