SketchUcation Premium Membership
mini-challenge
General discussion related to SketchUp. No off topic threads please.
Re: mini-challenge
Postby Jeff Hammond » Fri May 04, 2012 5:50 pm
CHARLIE__V wrote:I took one more stab at it...........hopefully more worthy than my first attempt.
Please see attached SKP's
Charlie
hey Charlie.. that's gilles' second (i think second) solution.. it does get it very very close and to me, it's acceptably close since i'll be working in inches like you.. if you tried that while working in metric with the highest precision setting allowed in sketchup then the error would show up..
basically, you rotate the end to 90º which is fine and what needs to happen.. however, when you rotate the other end to 90º it throws off the first end's 90º..
User avatar
Jeff Hammond
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: mini-challenge
Postby CHARLIE__V » Fri May 04, 2012 6:00 pm
Charlie
Apologies to Gilles :oops: ..............somehow I missed that.......I now see it on pg 7.... :shock:
And thanks Jeff for pointing that out.
Charlie
CHARLIE__V
Re: mini-challenge
Postby gilles » Fri May 04, 2012 6:05 pm
Be my guest.
User avatar
gilles
Top SketchUcator
SketchUp version: 8
License type: Free
SketchUp use: other
Level of SketchUp: Intermediate
Re: mini-challenge
Postby CHARLIE__V » Fri May 04, 2012 6:30 pm
Oh, and Jeff...........thanks for binging this to light.
A few months ago I was working on a Zipline project.......and making all the X bracing was making me nuts.
I was "brute forcing it" as you say. (see attached)
Charlie
CHARLIE__V
Re: mini-challenge
Postby Jeff Hammond » Fri May 04, 2012 6:35 pm
CHARLIE__V wrote:Oh, and Jeff...........thanks for binging this to light.
Charlie
wow!.. that's a perfect drawing to show to the developers as a case for why this needs to be fixed in sketchup..
:enlight:
[edit] and really? you're building ziplines that high? looks fun. :)
User avatar
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Re: mini-challenge
Postby Pilou » Sat May 05, 2012 1:19 am
The last Fredo method (some simple indeed) without plug gives with apparently no problem of top tangency vertices :enlight:
1.3239127 Nurbs (height of brace cut vertically) Pilars are 1 * 1 * 10 , brace 1 * 1 * x : unity meter
1.323908 SU
13.2391273 Nurbs (length of brace between the pilars)
13.239127 SU
14.1421356 Nurbs diagonal
14.142136 Su
Does this acceptable ? Accurate or not? ;)
PS
(i don't reload the Fredo's file due V8 against V6 ;) So remake my own version of Fredo's Method! :)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
Operating system: Windows
SketchUp version: 6
License type: Free
SketchUp use: hobby
Re: mini-challenge
Postby CHARLIE__V » Sat May 05, 2012 3:03 am
Jeff Hammond wrote: :enlight:
Jeff,
I composed a longer/detailed reply...........but? I got timed out I guess.
So, in short........yes........towers for the ZL are high here (~90' AFG)..because the grade is relatively flat like pancake. (contours @ 1' intervals are typical).
Attached screenshot depicts my participation in the project. (plan/execute pre assembly components @ grade)...............hoist by crane to place.
Beast,
Charlie
CHARLIE__V
Re: mini-challenge
Postby fredo6 » Sat May 05, 2012 10:58 am
Pilou wrote:The last Fredo method (some simple indeed) without plug gives with apparently no problem of top tangency vertices
Unfortunately, although the method is mathematically correct, it suffers from the lack of precision of Sketchup for rotation and parallelism of guides (even with circles of 512 segments).
One way to check that is to split the right post and the board and check the intersectio. As shown in the video, it may not be clean in certain cases.
So you need an extra step, with the Move tool, to adjust the intersection. You can do this step accurately because the SU Move tools inferences differently the intersection points (cross) and the endpoints (circular dot).
Strangely, Ruby does not suffer this inaccuracy issue and gives a correct intersection, although the FredoScale Rotate script uses the same method (i.e. calculate the offset angle and substract it to the rotation angle).
Top SketchUcator
Re: mini-challenge
Postby fredo6 » Tue May 08, 2012 10:18 pm
For info, I just published the script updates for supporting the two problems featured in this mini challenge. See this post for detail and video.
This comes in FredoScale, but you just need to download LibFredo6 4.5a.
Top SketchUcator
Re: mini-challenge
Postby utiler » Wed May 09, 2012 12:32 am
You are a crazy man, Fredo!!!!! :berserk:
purpose/expression/purpose/....
User avatar
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Re: mini-challenge
Postby Pilou » Wed May 09, 2012 2:47 am
Yep! :fro:
Classieux! :thumb:
And no problem in the Big Zoom! :enlight:
1.323913m SU
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Re: mini-challenge
Postby CHARLIE__V » Wed May 09, 2012 12:42 pm
Bravo Fredo..............Bravo!
Thanks lots,
Charlie
CHARLIE__V
by Ad Machine » 5 minutes ago
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
Previous
Return to SketchUp Discussions
Who is online
Users browsing this forum: archheni, Archibum, Bing [Bot], cotty, ireneadler, JuanV.Soler, RichH, seven.sides, sm501212, tedvitale and 12 guests
