[Plugin] Sketchup Ivy 0.6.3 20110513Re: [Plugin] Sketchup Ivy 0.6.3 20110513you need to make reset button. i have made a lot of changes in numbers...and now my ivy don't grow on a wall, it grows in every direction...please can someone share default settings?
Did you mean, "it would be nice with" or "Could you please"? Just saying, the wording can make a difference. Making freeware stuff and you end up with lots of demands from your users, it can get a bit tiresome. (Spoken by someone who makes lots of freeware.) Thomas Thomassen — SketchUp Monkey & Coding addict
Now you do some work resetting your values manually... TIG
Re: [Plugin] Sketchup Ivy 0.6.3 20110513sorry for my english at first. not my native - in russian i mean that this option will be very usefull. and of course thanks for that plugin. sorry if i offend somehow someone of developers. sorry please
ps. in russian it's a little bit more words need to be said of simple -you need to make- Please, register (free) to access all the attachments on the forums.
Re: [Plugin] Sketchup Ivy 0.6.3 20110513No worries.
Re: [Plugin] Sketchup Ivy 0.6.3 20110513still not on the wall ((( picture above. where's my mistake?
I don't even have this tool installed ! The default adhesion seems to be 50 in the code I posted... Why is yours 0.2 [20?] ?? Presumably the higher the adhesion value the more it sticks to the wall ??? TIG
that's it ) maybe i know english - but no so good till that time. and 0.5 become working not from next ivy, from third. But problem is solved - thx. better to rename adhesion to -sticking-
Re: [Plugin] Sketchup Ivy 0.6.3 20110513it won't work properly again, with -adhesion- 0.5 it's still grow in every direction. what's wrong with me? please help me to understand.
ps. it's skp file in archive, my model in wich ivy goes crazy. maybe problem it it? Please, register (free) to access all the attachments on the forums.
Re: [Plugin] Sketchup Ivy 0.6.3 20110513Wow Ivy Generator is great, but im having a problem importing the file back into SU, i can export my model from SU into Ivy Gen but when i import it to SU it freezes SU and never recovers, im using free version of SU and using obj importer, any suggestions would be great
Re: [Plugin] Sketchup Ivy 0.6.3 20110513I dropped file into plugins folder but it is not showing up in sketchup...I noticed the file is .rar, not a rb file. What is the secret?
Doh! A .rar file is a compressed file - like a .zip file - just made by another application. So, like with a zip file you must extract its contents - i.e. the .rb file and intact subfolder[s] of miscellaneous files that then go into the Plugins folder. There's a sticky-post in the Plugins Forum about installing tools from zip files - read that - substituting 'rar' when it says 'zip'... TIG
Re: [Plugin] Sketchup Ivy 0.6.3 20110513momentary lapse of reason....got it.
Re: [Plugin] Sketchup Ivy 0.6.3 20110513I tried all 3 versions, none worked properly, but after reading all 25 pages of forum, and about an hour and a half of loading and re-loading plugins,
it's FINALLY working well for me, hope it stays that way. Rendering in Thea,but the alpha channels do not import, but no big deal, I do it manually, and renders just fine. Thank you Pierreden.
Re: [Plugin] Sketchup Ivy 0.6.3 20110513I didn't have your patience to get it to work. I did install it and the dialog worked fine. It just didn't seem to 'grow' the ivy, and it's not like I didn't check the installation and read up about it. The reality is that I didn't need the functionality enough to put the time and effort in.
The frustrating thing is that it looks like a really excellent plugin, but it needs sorting out before it's ready for most users. If a lot of people have to make a considerable effort to get it working after 25 pages of posts, it shows that more work is necessary. Sorry - I don't mean any criticism or disrespect to the author in the slightest, it seems to be a wonderful plugin and the effort you have made is very much appreciated!
Re: [Plugin] Sketchup Ivy 0.6.3 20110513I hear you Bigstick, it seems to be working on/off and can get frustrating, but it promises to be a great plugin, and I hope all the bugs will be worked out.
Re: [Plugin] Sketchup Ivy 0.6.3 20110513Agree 100%, I really hope these niggles can be fixed, because for lots of users it will be a 'must have'! The only reason I haven't persisted more is time unfortunately. All my spare time is taken up with SUPodium, and I would love to get the two to work together nicely.
Actually this could be the basis of a tree/plant generator, to make any kind of plant. Huge undertaking though I suspect...
Re: [Plugin] Sketchup Ivy 0.6.3 20110513at least from the description and exhibits showing what it might capable of.
Re: [Plugin] Sketchup Ivy 0.6.3 20110513I'm using sketchup 8
The leaf size outcome look nice at sketchup but everytime i render, it become standard value size (5) anyone can help me with this issue ? Many thanks
Re: [Plugin] Sketchup Ivy 0.6.3 20110513Great looking plugin. This would be immensely practical for a few projects i've got sitting around.
I gave the 0.6.3 and also the last stable version a try on my mac and can't seem to get it to work. I'm running Sketchup 8.0.11751 on a Mac. I'm having a similar issue to bigstick. It's creating the paths and generating spots for leaves, but wont actually create the volumes. Keep up the good work! This one's a winner.
Re: [Plugin] Sketchup Ivy 0.6.3 20110513I just realised that this plugin put components into a model right away after sketchup started.
Does it meant to work that way? Found Ivy's components in the comp browser when I check it. After seeing how a door model file size became around more than 1 MB. Still learning to use this plugin. Thank you Pierre
Re: [Plugin] Sketchup Ivy 0.6.3 20110513Yeah, it's not really ready for general use yet because there are far too many anomalies. The inserting leaves into every model is one example, which causes problems with other plugins.
I really don't intend any criticism of Pierreden (because he's been kind enough to share the results of huge amounts of work with us for free) because this plugin is almost spectacular, and we all owe him thanks for his time and generosity. I've tried for a long time to try to work out what the problem is, but I have failed to make it work. I don't have the time or need for the results to devote any more time to making it work, and if it requires hours of effort for at least some people, something doesn't seem quite right.
Re: [Plugin] Sketchup Ivy 0.6.3 20110513How Sad! the last time I used this Ivy generator all was well, I even recall posting a set of alternative IVY leaves, I don't know whats happened since. Perhaps the latest release of SU is at fault.
1. trying to open any of the 3 Ivyleaf files Ivyleaf_1.skp, Ivyleaf_2.skp, Ivyleaf_3.skp causes an instant SU Bugsplat! 2. opening the Ruby Console, run the Ivy generator and a list of errors scrolls by. 3. the stem is not created! 4. the leaves do not get attached! Argh!
Re: [Plugin] Sketchup Ivy 0.6.3 20110513Hey guys...
Ive been trying to go through all the posts and I realise that theres been some issues with MAC but some seem to have got it to work... Ive got SU8... I unpacked the 0.6.3 RAR file and put the files into my plugins folder. I can open the Ivy window with all the various options... but when I click on the model nothing happens. Ive tried various clicks and alt clicks cmd clicks... but nothing. There are no error messages, just nothing happens. Any ideas? Thanks! Tim
Hi Tim, i use Mac too see this viewtopic.php?f=323&t=36882&start=330 the las post.
Still can't get this plugin to work... Im on Mac, SU8 and using 0.6.3 Ivy. I can successfully open the parameters dialogue box and move sliders etc... However, this is all I can do. Clicking on my model does nothing, CMD clicking does nothing etc. any ideas? Thanks, Tim
Re: [Plugin] Sketchup Ivy 0.6.3 20110513Been enjoying the plugin a lot. Thank you very much Pierreden.
I've read through this massive thread and understand why half the leaves have the white background. But I'm curious why some leaves have a transparent square for the textures behind, yet has an edge that sees completely through a copy of the same texture?! Is there any more versions of this going to be released? I see it hasn't been worked on in 10 months.
Re: [Plugin] Sketchup Ivy 0.6.3 20110513i fkn love you! great work although i had to modify the leaves components in order to have transparency on my leaf backround, but it works really fine!
One more question, when are you planning to pull up a new version of the plug in? you should spread this worldwide, it is a fantastic idea. greetings from mexico.
Re: [Plugin] Sketchup Ivy 0.6.3 20110513can we see some people's settings for certain types of results and can we see the default settings?
