SketchUcation Premium Membership
extrude and separate
General discussion related to SketchUp. No off topic threads please.
Postby zain01 » Sun May 06, 2012 11:07 pm
Hi Y'all
Can anyone tell me how to extrude a shape then save as a component but be able to pull the shape up again.
Or to put it another way i want to pull up a shape but separate it into separate components.
Regards
zain01
Re: extrude and separate
Postby Dave R » Mon May 07, 2012 2:29 am
I'm not sure I really understand what you're asking but why don't you make the shape a component before you extrude it. Save that shape into a local component library and then drag it out each time you want to make a new extrusion from it by editing it in the model space. This is a common practice for molding profiles so they don't need to be drawn every time they are needed.
Inspecting mirrors is a job I could easily see myself doing.
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Level of SketchUp: Advanced
Postby TIG » Mon May 07, 2012 11:33 am
If you already have a face shape that's part of something else... select the face and Edit>Copy.
Now edit another component/group [make it if you need to] and Edit>PasteInPlace the face is duplicated inside this other 'container'.
Now you can push pull it in that edit as desired and it's separate from the original geometry.
If you want yo 'remove' the original face from its original context and put it inside a component/group you can select it and make the component/group from it and a 'hole' will be left in the original geometry.
You can also use Edit>Cut + Edit>PasteInPlace on a face [do not select its edges as that might affect other geometry unexpectedly] to 'move' it into a new container, rather than replicate it...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
by Ad Machine » 5 minutes ago
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Ad Machine
Robot
Return to SketchUp Discussions
Who is online
