SketchUcation Premium Membership
Full Size Patterns for Templates [Updated]
To access this forum when logged in, please, sign up to the Woodworking User Group in your User Control Panel.
Postby Dave R » Wed May 02, 2012 2:45 pm
While it is possible to print full size patterns directly from SketchUp, if you've done it, you know it isn't really all that intuitive. If you've got SU Pro, it's easy enough to send the SKP file to LayOut and create the pattern there as a PDF file. Now there's a way to get full size patterns that is easy and works with the free version of SketchUp, too. See my blog post about it, here.
This plugin was updated on 4 June, 2012. There were some script changes to make it load better and it is now Mac compatible..
Inspecting mirrors is a job I could easily see myself doing.
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Level of SketchUp: Advanced
Re: Full Size Patterns for Templates
Postby kingsi » Wed May 02, 2012 8:13 pm
Something I will probably never use, but I see the application for joiners and carpenters as being really handy.
Many thanks for uploading this and your blog
Noobtastic
User avatar
kingsi
Postby Humpmetwice » Wed May 02, 2012 9:31 pm
I couldn't get it to work but thanks anyway.
User avatar
Humpmetwice
Postby Dave R » Wed May 02, 2012 10:24 pm
What do you mean you couldn't get it to work?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Humpmetwice » Wed May 02, 2012 10:25 pm
Once install nothing shows up in the tools menu.
User avatar
Humpmetwice
Postby Dave R » Wed May 02, 2012 10:31 pm
How did you install it? Did you make sure the box for it is ticked under Preferences>Extensions?
It will work if installed correctly.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Humpmetwice » Wed May 02, 2012 10:41 pm
This is how everything is set up and still nothing in the tools menu.
User avatar
Humpmetwice
Postby Dave R » Wed May 02, 2012 10:50 pm
What's in the gk_plugins folder?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Humpmetwice » Wed May 02, 2012 10:58 pm
This is whats in the folder
User avatar
Humpmetwice
Postby Dave R » Wed May 02, 2012 11:17 pm
So you still don't find anything starting with 'gk' anywhere in the Tools menu?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Humpmetwice » Wed May 02, 2012 11:28 pm
Nothing
User avatar
Humpmetwice
Postby Dave R » Wed May 02, 2012 11:33 pm
Weird.
Did you open SketchUp after installing?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Wed May 02, 2012 11:36 pm
No 'compatibility files...' button on the PC's windows pane ?
Perhaps you don't have proper full access-rights and you haven't really installed them where you think they are..... :?
Post their full path... :!:
User avatar
Global Moderator
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Postby Humpmetwice » Wed May 02, 2012 11:41 pm
Hope this is what you needed Tig and yes Dave I open Sketch up after installing.
User avatar
Humpmetwice
Postby Dave R » Wed May 02, 2012 11:58 pm
Kurt, do you have administrative rights to install plugins to the Plugins folder?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Humpmetwice » Thu May 03, 2012 12:49 am
Yes Dave I have installed many plugins before maybe to many.
User avatar
Humpmetwice
Postby John Msrk Power » Mon May 14, 2012 11:44 am
Dave,
This looks like an extremely useful tool. However, I have installed it correctly I think and what I get is a blank sheet in Ghostview. Actually, I get the template isolated in my screen at the origin of the red and blue axis, I set the camera to parallel projection. Next I scroll down the tools menu until I find "gk Postscript plot" and click on it. The next pop up screen asks me for a paper size. There is no pop up screen explaining the markers. a second screen tells m the directory that the file has been saved in. I then go to that file and open it. It opens up the Ghostview program. I have attached a screen shot to this post of the results. If you or anyone else can help me solve my problem that would be great. Also, how did you get the double shadows seen in the image of the tilt top table? Is that a plugin as well? Thanks in advance for any help. Maybe I should try reinstalling everything. I did install Gk postscript plot first. Perhaps it was the order I installed the software.
Thanks,
John Mark
John Msrk Power
Name: John Mark Power
Postby Dave R » Mon May 14, 2012 11:55 am
Could you post the SKP file you're using for this?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby John Msrk Power » Mon May 14, 2012 1:26 pm
Dave,
Sorry for the delay. I had problems uploading the SKP file using mozilla and had to use explorer instead. I hope this helps and than you for your time and expertise.
-John Mark
John Msrk Power
Postby Dave R » Mon May 14, 2012 1:38 pm
John, I'm happy to help if I can.
Try exploding the components and see if that helps. If you don't need the rectangles around the edges, you might as well delete them. You could probably also stack the smaller template above the larger one and get them both on the same sheet. Try it with the attached file. I'm on my Mac and don't have access to my PC at the moment so I can't try it.
By the way, you have the components nested although it doesn't appear that there's any reason for the multiple levels of components for each of them.
And you asked about the multiple shadows in my images. Somewhere I did a tutorial on how to do that. It is not a plugin but rather the combination of images. I export the shadows separately from the faces and edges. For the final image of the tables, I have the edges, faces and two different shadows in four images.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby John Msrk Power » Mon May 14, 2012 1:52 pm
Dave,
Thanks as always. Exploding it seemed to solve the problem. The SKP File is a work in progress. I have attached a model that is more or less complete. Thank also for the info on multipe shadows. I will look for that post on this site or the click design build site.
John Msrk Power
Postby Dave R » Mon May 14, 2012 1:57 pm
Glad that worked for you.
I'll have to hunt up that tutorial. I think I did it here.
Good work on the chair.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby John Msrk Power » Mon May 14, 2012 2:08 pm
Thanks Dave,
The chair is a model of some chairs made locally in the 19th century. I have beeb drawing different examples in hopes of making some reproductions. The templates will be great when turning the posts and making the slats.
-John Mark
John Msrk Power
Postby baz » Fri May 25, 2012 7:12 am
I'm having the same problem as Kurt. I would find this very useful.
The GK plugin folder etc is in my plugins folder but no GK command appears in the 'Tools' menu.
"What do we want?...Time travel... When do we want it?... Irrelevant"
Thanks to Funny Pics
baz
SketchUp version: 8
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
Re: Full Size Patterns for Templates [Updated]
Postby Dave R » Mon Jun 04, 2012 9:19 pm
There's an updated version of the plugin now. It has had some rewriting to avoid the problems some folks had with it loading properly and it is now Mac compatible.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Humpmetwice » Tue Jun 05, 2012 2:04 am
Its working great for me thanks all to Dave's help!
User avatar
Humpmetwice
Postby baz » Tue Jun 05, 2012 3:49 am
humpmetwice wrote:Its working great for me thanks for all Dave's help!
+1 :thumb:
baz
SketchUp version: 8
License type: Pro
SketchUp use: other
by Ad Machine » 5 minutes ago
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Ad Machine
Robot
Return to Woodworking
Who is online
Users browsing this forum: No registered users and 0 guests
