Red and Green prism volumes are equal
Groove is constant
Click for all image
[REQ] Edge 2 Groove
• Page 2 of 3 • 1, 2, 3
Re: [REQ] Edge 2 Groovelike this
Red and Green prism volumes are equal Groove is constant Click for all image Please, register (free) to access all the attachments on the forums.
Re: [REQ] Edge 2 GrooveThat only works for parallel faced boxes - it won't work if it has non-parallel facets or only some faces are to be grooved...
Re: [REQ] Edge 2 GrooveThat is the case of the EartMover example asked
Just angle change between elements so the prism will be not always the same
Sorry Pilou, I forgot I deleted the bottom faces while playing with Profile Builder. Forgot to add them back. If you close the bottom face, you can add the edges back using "Split Sausage". The shape was made by drawing 2 curves, then using BZ Convert to Polyline Divider to regulate the segments. (Or SDMitch's EqSegCurve would work) I think I then used Extrude Edges by Vector in the Z direction and JPP to add volume. (Or you could go Extrude Edges by Offset, JPP) Thus maintaining the segments throughout the process. Not sure why select edges by length doesn't work for you. Quad Face tools, select loops and rings should work fine as it's all quads. Also , with Selection Toys > Selected Quad Face Loops to select the faces in loop. Also easy to drag select all and Selection Toys > Select only edges or faces. A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
I see. The distance changes between the perpendicular offsets. I guess ideally would be to move the offset edges via their verticies, essentially moving four verts and connecting them, instead of four edges and trying to align them. Of course I have no idea if this is possible, just thinking out loud! What if the top and sides were run with separate operations? Or if corners were restricted to only 90 degrees? My example is a bit extreme for most users who would need a tool like this. Things like furniture, buildings and other wood structures are typically square. I do a lot curved step treads, curved knee walls, pool copings, brick banding, arches, etc. However, what I do might be too generalized for what would benefit the masses. I just don't want to put my needs ahead of others. A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
Re: [REQ] Edge 2 GrooveWhat is the "Split Sausage" function and where i can find it ?
No problem for push the top and botton face with normal PushPull Joint Push Pull don't make these vertical faces Pushed The Smart Puspull make the good internal Push face alas it don't make the erasing! Please, register (free) to access all the attachments on the forums.
Re: [REQ] Edge 2 GrooveMany thanks : An another one that I had missed when i was absent
Re: [REQ] Edge 2 GrooveSeems easy
Just code the repeat process Please, register (free) to access all the attachments on the forums.
Re: [REQ] Edge 2 GroovePilou... you faked the image !
Tinker! Please, register (free) to access all the attachments on the forums. TIG
Re: [REQ] Edge 2 GrooveI think Pilou is suggesting first and second push both on the Z. The second push requiring another offset first.
Some of my 3D crap
Re: [REQ] Edge 2 GrooveAll PushPulls are made perpendicular to their the face... BUT if the original faces of the edge defining the second groove are non-coplanar then PushPull will be square to each of them NOT align with the 'vertical' sides of the first groove we've made, so that PushPull is blocked by the impending geometry clash; if we were to 'force' it in code then the perpendicular sides of the different grooves would not be guaranteed to align where they meet, and we then need either 'mitered' angles at their junctions, or awkward 'ledges'... I see that Pilou is PushPulling the second groove in the length not the depth, BUT if the base of the groove is not parallel with the top then it won't form a clean hole either It needs more of a JPP solution... TIG
Yes Line of the left element is an offset or a copy move along the side of left element Line of the right element is an offset or a copy move along the side of left element then you can push down on Z
the jpp don't make negative push Smart PushPull yes as shown above but don't erase the inside ! Last edited by Pilou on Sun Apr 29, 2012 10:57 pm, edited 2 times in total.
Re: [REQ] Edge 2 GrooveBut as I closed... That's fine only if the second groove's faces have no further faces at their end OR the further faces are in the same plane as the base of the first groove. These are special cases.
The general case where there are other face angles etc will NOT PushPull cleanly and fail to end the groove neatly... Please, register (free) to access all the attachments on the forums. TIG
That is not the case of the EarthMover example But i believe that will be the same in the no coplanar face of elements I come back with an example And no problem for make the groove with normal push Ps Crossing posts your example is a double non coplanar face element but I believe that another will be the same I come back with your vicious example Please, register (free) to access all the attachments on the forums.
Re: [REQ] Edge 2 GrooveIt's relatively easy to make the special case orthogonal grooves but the general case is more tricky...
Re: [REQ] Edge 2 GrooveIn fact that is more easy than all previus!
Must have internal faces for make the Offset Pulling and close faces! And must work in any cases not too vicious There is an optic effect on the result on this image : groove and section seem sometime slaloming! Please, register (free) to access all the attachments on the forums.
Re: [REQ] Edge 2 GrooveA clever solution... IF grooves are wanted on all faces [but it could even be adapted with coding a custom offset on selected edges only]...
IF the object is a solid group then you could simply made a sacrificial over-sized block group that is the groove thickness wide and aligned on the edges' plane, and then in pro use the solid tools to subtract it from the original form, leaving the full slot; then we'd apply the offset around the newly through cut face and pushpull it by the groove width [no mid-line is needed] to fill the gap - erasing the extra inner face left behind to maintain 'solidity' for the next groove set to work... BUT again this only works if the selected edges are all coplanar; 'skewed' grooves will not work. TIG
Re: [REQ] Edge 2 GrooveIf it is a "Solid" object, the offset seems like an unnecessary step. Could you just isolate the edge itself and take a box the size of the desired groove and "follow me" it around the edge to create the cutting (Subtracting) component, thus only taking away what was necessary for the groove? Similar to Jeff's technique in this thread - viewtopic.php?f=15&t=41095&p=365238&hilit=groove#p364287
I would be okay if the tool only worked on solid objects. A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
Re: [REQ] Edge 2 GrooveUsing the Edge 2 Groove model supplied, I have been able to create a plugin for this unique situation.
Re: [REQ] Edge 2 GrooveThanks Sam. DL'd. Can't wait to see how it works! Peter
Re: [REQ] Edge 2 GrooveWoops. Crashes SU on my Mac. Peter. No messages to report.
Have you an example of that ? I will try the new SAM plug Last edited by Pilou on Tue May 01, 2012 4:25 pm, edited 1 time in total.
Re: [REQ] Edge 2 GrooveWorks great on the example I provided which are created via "curves" where some of the edges are supporting non planar faces.
Thanks for the work so far. I wonder can the tool be further tweaked to work on a variety of different situations where grooves would be needed? (i.e. single face grooves, grooves to define cabinet drawers, grooves for concrete building facades, etc.) Thus being more useful for a variety of different users. Also, can the width and depth be defined separately?Thanks again Sam for solving the first part of the riddle. What was the logic you ended up using for the code? I tried to decipher it, but it's a little over my head. A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
Re: [REQ] Edge 2 GrooveYes I'm sure much more can be done but, as I stated in the post, the plugin attached was developed and tested on that one example alone.
I just looked at it as a sidewalk, with at flat top and curved sides. I examined each edge to see if it was between coplanar faces, normals parallel, to indicate it was on top and calculated the boundary points of the three faces that I could pushpull to create the top and side grooves. In addition to the normals parallel, I need to require the the normal.z is pointing up or down. This will allow sides to be straight as well. Adding grooves to a four sided column poses the additional problem of trying to determine "which" way is up". Last edited by sdmitch on Tue May 01, 2012 5:14 pm, edited 1 time in total.
Re: [REQ] Edge 2 GrooveHi,
I have tested the groove tool. The results are unusual. I do not know why. Charly Please, register (free) to access all the attachments on the forums. More dangerous than ignorance is the illusion of knowledge
Re: [REQ] Edge 2 GrooveCharly, Please see my last post. I knew it was a mistake to post the alpha version because people always think that, no matter what bazaar situation they can create, the plugin should be able to handle it.
Re: [REQ] Edge 2 Groove@ Charly : for the moment you must don't take solides volumes, only open surfaces as the first example shown
This makes sense. Thanks for posting the Alpha version. It is a very promising start. I definitely understand it was adapted to a specific situation. Hopefully it will continue to evolve into a more universal solution! A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
Please provide an example of each.
SketchUcation One-Liner AdvertsArtisan Organic Toolset - a set of powerful organic modeling tools.
Premium Members get 20% discount!
