SketchUcation Premium Membership
Faces appearing from nowhere while working with .dwg import
Welcome! Ask and get answered - or just introduce yourself.
Postby Garuf » Thu Apr 19, 2012 12:35 am
Hello again.
So in the process of starting to flesh out the bare bones of my layout with which to work and face are appearing on the bridge without me drawing them, almost as though there's some "ghost" layer at play.
I tried to upload the file to demonstrate my issue but alas it won't load :?
Anyone have any ideas?
Garuf
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Level of SketchUp: Beginner
Re: Faces appearing from nowhere while working with .dwg imp
Postby Garuf » Thu Apr 19, 2012 12:47 am
And if I delete a single point once I have a face the face disappears and if I delete it before hand the face won't form?! What's going on? :?
Garuf
SketchUp version: 8
License type: Pro
Postby Gaieus » Thu Apr 19, 2012 9:55 am
You really need to add that file. Maybe it's too big?
User avatar
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Level of SketchUp: Advanced
Postby Garuf » Thu Apr 19, 2012 8:53 pm
Yeah, too big to attach. Any ideas on where I could upload it to?
I'm so sorry to keep posting like this, I feel such a newb after I thought I'd got sketchup basics cracked. I could really do with getting a book on the subject and learning some plug ins, I'm super slow when it comes to repetitions of things like trees and light standards etc. And awful at topography!
Garuf
SketchUp version: 8
License type: Pro
Postby TIG » Thu Apr 19, 2012 10:24 pm
Make a copy of the SKP.
Then use 'Model Info' > 'Statistics' > 'Purge Unused'
[and 'Fix Problems...']
If the file is still >4Mb [the upload limit] then ZIP it so it's smaller!
When zipped, if it's still > 4Mb then what is it is the model that is so enormous???
Upload something that is 'relevant'...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby Garuf » Sun Apr 22, 2012 10:57 am
I'm building up a site plan that's roughly 800mx800m-ish. I did think I'd got a topography layer from which to work with with having a spot height array layer in CAD but it's still in the "flat" format when I import it. I can't say I know a lot about cad though, in fact, pretty much nothing, how to scale images to print and that's about it. I use sketch up for just about anything for the sheer speed of it compared to CAD. I'll spend a part of the day today and try and figure out how to get it <4mb. I'm working on building components for repeating objects at the minute so it's no big deal that the master plan isn't fully sorted.
Garuf
SketchUp version: 8
License type: Pro
Postby Garuf » Sun Apr 22, 2012 5:53 pm
Still haven't managed to get it below 7kb. I did as suggested and purged layers but to no avail. Who'd have thought it so hard!
Garuf
SketchUp version: 8
License type: Pro
Postby Gaieus » Sun Apr 22, 2012 6:12 pm
You can always upload the model to the 3D Warehouse (10Mb limit) or even some file sharing place like Dropbox.
From what you say (just the contour lines being 7Mb+), they must be pretty complex. Sooner or later, you will need to consider simplifying them. Go to this place and grab simplify contours plugin (at the bottom of the page)
http://sketchup.google.com/intl/en/down ... ripts.html
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby Garuf » Sun Apr 22, 2012 6:19 pm
Refreshed the document, 9kb!
I don't think there is a terrain file in there, if there is I can't find it.
Rather than start a new topic and clog for forum. Once I've components drawn, what is the best way of rendering them so they don't look like 90's video games?
Garuf
SketchUp version: 8
License type: Pro
Postby Gaieus » Sun Apr 22, 2012 6:30 pm
OK, I seem to have been lost. Back to your original post you mention some "ghost layers". There are two layers there to which some (seemingly?) useless, faraway and stray geometry belongs (marked circled). You can delete those layers if you do not need that geometry safely and choose to "delete content" (I checked that no other geometry is on those layers).
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby Garuf » Sun Apr 22, 2012 6:39 pm
Yeah they are indeed "ghost" items. I'll clear them away now.
Should I include my CAD plan to see if the spot heights are tagged to a terrain layer or not, if not is there a way to access them and draw topography from it through sketch up?
Sorry to ask such newb questions. :oops:
Garuf
SketchUp version: 8
License type: Pro
Postby Gaieus » Sun Apr 22, 2012 7:22 pm
I am getting confused now. So there's another file with a terrain?
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby Garuf » Sun Apr 22, 2012 7:54 pm
Me too, sorry.
There's two files, the original .dwg and the .skp which is an import of the .dwg. In the original file there's a spot height array which I assumed would build into terrain when I imported it into sketch up ie, going from 2d to 3d so that when I start to lay out the terrain isn't flat but as set out by the spot heights.
Garuf
SketchUp version: 8
License type: Pro
Postby TIG » Sun Apr 22, 2012 10:07 pm
IF you have a set of spot-height points in a DWG... then there are several tools to convert these into a terrain mesh - once they have been imported into a SKP; but they don't magically convert when imported - you do need to do some work...
Also here's a lot of dross in a DWG that you don't need to import into the SKP, that can be deleted/purged first...
If you explained better what you have and what you want to end up with then we could perhaps help you better... :?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Garuf » Mon Apr 23, 2012 1:28 am
I see.
Well, I'm a landscape architecture student and I was planning on presenting my site design using sketchup or at least using it as point where I could try and turn it into some "proper" renders, add illumination get some proper textures in there, make it look less video game like etc.
I was also thinking I could export it through layout to avoid having to redraw things in CAD because I don't know how to use cad properly.
I've ordered a copy of this: http://www.amazon.co.uk/Google-SketchUp ... lh_ni_t_mi
But it's taking forever and a day to arrive so I've been trying to do what I can here and there so I'm not dead in the water as the deadlines creep up.
Garuf
SketchUp version: 8
License type: Pro
Postby Gaieus » Mon Apr 23, 2012 1:46 am
All right but what we are trying to squeeze out of you is what you have in hand. Without knowing the kind of the data, we keep stabbing in the dark.
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby TIG » Mon Apr 23, 2012 9:39 am
Gareth
As Gai pointed out the SKP you gave us only contains a 2d site plan imported from a CAD drawing.
There is no 3d info or 'spot-heights' etc in it...
Can you provide the original DWG/DXF file [r2004 or earlier]?
How do you hope to make this into 3d mesh?
What other information do you have? [that you are keeping to yourself and thereby stopping us helping you to solve this!]
If your CAD drawing contains 'text' as spot heights without 'points' then the import will not include them as 'text' is ignored. Also if the text is 'flat' you need to relocate it in the Z with a point so that an import into a SKP then includes it [cpoint-clouds can then be made into a mesh using one of several tools]. I have an AutoLisp routine that does this relocation on a DWG [it's not 'for public consumption', but I can probably help you out]...
However, we need to know what we have to work with here - the longer you keep us in the dark, the nearer the deadline comes; without a solution being at hand...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Garuf » Mon Apr 23, 2012 3:32 pm
Ahhh I see. I'll include my working rough master plan then. I was planning on creating the mesh as I had in the past by working out the lowest point in the model then treating this as the base then drawing an array of verticals where the spot heights on my plan were and then joining them up to create a terrain. I was always certain there was a better way though because it takes forever.
My .DWG came from Leeds city council originally and when the text is turned on has spot heights for the area.
stylistically his is my end goal: http://bp1.blogger.com/_Ymx9e66vrGc/SH7 ... _ready.jpg
http://www.cityfarmer.info/wp-content/u ... emfarm.jpg
http://archiculturefilm.com/director/wp ... s_1000.jpg
I was then planning on using layout to produce a master plan that could be overlayed on G.earth to look like this.http://t1.gstatic.com/images?q=tbn:ANd9 ... 17pT3hPXAQ
Garuf
SketchUp version: 8
License type: Pro
Postby TIG » Mon Apr 23, 2012 3:49 pm
First off, this is made with a more recent version of AutoCAD than I have.
I can't convert it using the free AutoDesk converter as it says the DWG has an 'Educational Use Only' stamp in it!
Can you save_as it to a r2004 version and reattach, or PM it...
This is 2d plan it can't be used to make a 3d mesh without running several processes on its data...
I do have tools to find its text entities, read their real heights and relocate them in the Z with points; for import into a SKP, where Ruby scripts can take these cpoints and convert them into a surface mesh.
You seem to be making heavy weather of solving this... :roll:
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Garuf » Mon Apr 23, 2012 4:07 pm
sorry. :( I'm a forum mod myself I know how frustrating it can be dealing with an idiot. :lol:
I run and education version of cad which is free but limited in what you can do with it, I'll see what I can do with regards back saving the file.
Garuf
SketchUp version: 8
License type: Pro
Postby Garuf » Mon Apr 23, 2012 4:14 pm
Here's a version saved in 2004 format. That's the oldest version I can save as.
Garuf
SketchUp version: 8
License type: Pro
Postby TIG » Mon Apr 23, 2012 4:26 pm
Thanks, I'll get back to you [I can go back to r12!]...
Why DXF rather than DWG ?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Garuf » Mon Apr 23, 2012 4:44 pm
It was the only format it would let me save as that was older that 2010.
Garuf
SketchUp version: 8
License type: Pro
Postby TIG » Mon Apr 23, 2012 4:47 pm
I've had to extract all of the levels '32.1m' mtext from the rest by filtering, now my tool fails with the trailing 'm' so I'm stripping those off...
Watch this space...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Garuf » Mon Apr 23, 2012 4:55 pm
Oh, you're a diamond! I'd be forever drawing vertical lines if it was left to me.
Garuf
SketchUp version: 8
License type: Pro
Postby TIG » Mon Apr 23, 2012 7:14 pm
Here you go...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Garuf » Mon Apr 23, 2012 7:44 pm
Just waiting for CAD to open the two files. Presumable I now take the mesh and drape my existing cad plan over it or snap to a landmark and I can then extrude the buildings and river etc?
I'm really sorry to ask so many questions this is the first I've used a grid shell terrain.
Garuf
SketchUp version: 8
License type: Pro
Postby TIG » Mon Apr 23, 2012 8:52 pm
You don't need to open the CAD files at all !
I sent you the SKP mesh - ready made !!
I'm unsure how you imported the CAD 'lines', so you might need to realign the two parts...
The 3d mesh is much bigger than the 2d line-work...
The site's pretty flat in the end so it's not that great :(
If you Drape [or SuperDrape] the 2d line-work down onto the 3d surface that's your first step...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Garuf » Mon Apr 23, 2012 8:58 pm
Thanks for all the help I'm entirely in your debt. What I did was import the .dwg using "import" then just deleted the areas of the site I didn't need. I'll be adding a lot of topography I should think so it's not time wasted as It all helps with working out drainage and disabled access/site levels. I suppose if I use the same cad file I sent you then crop it once I've draped it.
Garuf
SketchUp version: 8
License type: Pro
Postby Garuf » Tue Apr 24, 2012 11:33 pm
Okay. So I've spent the day tinkering and every time I try and drape my imported cad plan onto the mesh I get a "bug splat" crash. Any suggestions? :shock:
Garuf
SketchUp version: 8
License type: Pro
by Ad Machine » 5 minutes ago
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
Next
Return to Newbie Forum
Who is online
Users browsing this forum: No registered users and 5 guests
