SketchUcation Plugin Store
Filling a Space with Components.
General discussion related to SketchUp. No off topic threads please.
Postby David_H » Fri Apr 13, 2012 10:53 pm
Here's one for the gurus. . .
Im drawing a Lottery ball pin and want to fill it with ping pong balls, but I am not sure how to fill the bin with the balls in a random like way. I am not good with Compo Spray. But that is the first thing I thought of to use, and I am just not good with it. It kept asking me if I wanted to go ahead and add 8000 copies. . ..
uh. . .NO.
I need about 50 or so inside the bin. as you can see I am trying to find an easy way to give this a random look. Right now I just have them all lined up. dumb.
See image below. Any ideas?
thx,
David
If I make it look easy. . .rest assured--it probably is.
User avatar
David_H
Top SketchUcator
Re: Filling a Space with Components.
Postby Dave R » Fri Apr 13, 2012 10:58 pm
I'm not really up on Sketchy Physics but I wonder if it might be the way to go. Could you put a temporary opening on the top of the basket and set the balls up to drop into it when you say, "Go?"
Inspecting mirrors is a job I could easily see myself doing.
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: woodworking
Level of SketchUp: Advanced
Postby David_H » Fri Apr 13, 2012 11:04 pm
That would be terrific except for one little hiccup. I havent even looked at SuPhy in about 4 years. I wouldnt know how to begin.
thanks for the thought tho.
D
User avatar
David_H
Top SketchUcator
Postby Dave R » Fri Apr 13, 2012 11:09 pm
Sorry I can't tell you where to begin either. You might pose your question on the Sketchy Physics forum, though. One of those rocket scientists will probably have the answer for you.
User avatar
Global Moderator
License type: Pro
Postby David_H » Fri Apr 13, 2012 11:14 pm
good point, and therefore I shall do just that.
Thx
D
ps if anyone else has any thoughts on this. . please chime in
D
User avatar
David_H
Top SketchUcator
Postby Rich O Brien » Fri Apr 13, 2012 11:25 pm
:::Blog:::
I'm a Trimbler now!
User avatar
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby David_H » Fri Apr 13, 2012 11:33 pm
Hey Hey! Thanks Rich. I'll check this out.
D
User avatar
David_H
Top SketchUcator
Postby fransko » Thu Apr 19, 2012 6:50 pm
look like this?
fransko
Postby David_H » Thu Apr 19, 2012 8:16 pm
Not exactly . . .but thanks for the effort / response.
I think my image above was misleading. What I need is to show this bin (Image A) filled with ping pong balls like image B. I am just not sure how to make this happen in a fairly natural random way. . .
User avatar
David_H
Top SketchUcator
Postby Dave R » Thu Apr 19, 2012 8:45 pm
Did Sketchy Physics not work for this?
User avatar
Global Moderator
License type: Pro
Postby Rich O Brien » Thu Apr 19, 2012 8:53 pm
A few years back I did something similar with spray cans dropping out of a box.
It works fine if you use the earlier link as a base. I'd try again except I don't have it installed.
:::Blog:::
I'm a Trimbler now!
User avatar
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby Pilou » Thu Apr 19, 2012 10:35 pm
You can use that ;) (file linked)
Take any number of Spheres you want (groups or components) at any place above the SkateRamp ;)
Launch Sketchyphysics
Make a Pause at any time you want
Open the Outliner
Select Spheres inside the Oultliner else the animation go to the start!!!
Copy / Past balls in your project ;)
During the animation you can take and move any ball !
If you want another curvated form blocks : just make 2 separated blocks A & B! (groups or components)
StaticMesh / Convexhull
Have fun ;)
PS And if you want more sophisticated balls with Number : use the very tricky
Relplace random Component by Sdmitch ;)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Postby David_H » Thu Apr 19, 2012 11:29 pm
I guess I didn't understand that the attached model was a SUPhys model. I guess I am going to have to learn it in order to do what I need to do.
Thanks for the help.
D
User avatar
David_H
Top SketchUcator
Postby Pilou » Thu Apr 19, 2012 11:41 pm
I have replaced the file on the previous post ;)
Groups are now components so you can remplace them at the end by anything you want :)
Yes you must install SketchyPhysics else nothing will arrive ;)
Even you don't know Sketchyphysics : You have no more to make
Just Press Start and Pause and re read the post above :)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby David_H » Fri Apr 20, 2012 12:24 am
Merci Mon ami. Je vais le faire!
David
User avatar
David_H
Top SketchUcator
Postby David_H » Fri Apr 20, 2012 12:37 am
so I downloaded the latest and greatest of SP3 and on the start up I get this. . .
and when I press the Play button I get this. . .
any thoughts?
User avatar
David_H
Top SketchUcator
Postby Pilou » Fri Apr 20, 2012 12:52 am
Ah damned :shock:
I am affraid to say that I don't know why you have this sort of thing :?
Try to install a previous versions of Su
That I shown was done with a recent version of Sketchyphysics on an old SU 7 version :)
Another thing : seems Sketchyphics makes some interference with some other plugs
so disable it when you don't use!
I just change the name of its extension ".rb" as ".rbo" in the plugin folder :ugeek:
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby David_H » Fri Apr 20, 2012 3:30 pm
I was afraid of that. I've only got 1400 Plugins that could be the problem. Should be no problem going through all of them. :roll:
User avatar
David_H
Top SketchUcator
Postby Pilou » Fri Apr 20, 2012 5:55 pm
Save somewhere the folder Plugins
Create a new folder Plugins
Install Sketchyphysics
run it
but from you error messages I doubt that will be sufficient ;)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby David_H » Fri Apr 20, 2012 6:14 pm
it usually never is-- :mrgreen:
when it comes to me, but I will give it a try.
Thx,
d
User avatar
David_H
Top SketchUcator
Postby brookefox » Fri Apr 20, 2012 11:44 pm
I'd give component spray a whirl. It is fast and polite. Try it with a simple 3d tick of the same cross dims as your balls, then redefine the component as you wish if it works out.
~ Brooke
User avatar
brookefox
SketchUp version: 8
SketchUp use: architecture
Level of SketchUp: Intermediate
by Ad Machine » 5 minutes ago
Artisan Organic Toolset - a set of powerful organic modeling tools.
Premium Members get 20% discount!
Ad Machine
Robot
Return to SketchUp Discussions
Who is online
Users browsing this forum: No registered users and 4 guests
