Help! How to make a spiral like a paper?
• Page 1 of 1
Re: Help! How to make a spiral like a paper?Maybe concept like this
Draw helix by P Brawn explode it (because it is a group) length as you want ( Draw 2 Straight lines Curves normaly in your case similar (minimum 2 Segments) inclined as you you want In your case redraw 2 spirals against the 2 lines a & d Call Extrude Edge by Rail by TIG Click b & Clik c are on the same curves Et voilà Ps In fact your model is 4 spirals Please, register (free) to access all the attachments on the forums.
Re: Help! How to make a spiral like a paper?Scratching head... hmmm, this is a challenge in SU.
Re: Help! How to make a spiral like a paper?You can draw a rectangle, divide it on the diagonally a bunch of times. figure out how many degrees around total the finished paper will be. The yellow one is about 28 sections bent at approx 15 deg. Bend in at a bigger angle alittle as you go will tighten the spiral at the end.
Re: Help! How to make a spiral like a paper?Again Extrude by 2 rails
2 Spirals, 2 arcs Just increase the number of turns of the spiral and adapt radius size for have that you want Please, register (free) to access all the attachments on the forums.
Re: Help! How to make a spiral like a paper?Why not use shape bender?
Re: Help! How to make a spiral like a paper?I think shape bender is more likely to be closer to the original paper size and shape.
OK gilles I have to ask, what IS that avatar supposed to be? Pilou you have to say how you made the spiral. Last edited by pbacot on Thu Apr 12, 2012 8:04 pm, edited 1 time in total.
Re: Help! How to make a spiral like a paper?and BTW why is name in green as with Pilou others in blue?
Curios as to who figures out the spiral
Re: Help! How to make a spiral like a paper?Green names are "Top SketchUcators", distinguished forum members.
They can, however, choose to remain a bit "under cover" and do not set that usergroup as their default so some of them are blue as regular members. Gai...
Re: Help! How to make a spiral like a paper?With FredOscale Free bending tool. I just like using it for the fun of it. Way more fun than doing my taxes.
Start with rectangle. Make component. Put another rectangle vertical along direction of curl (I drew corner to corner) for setting the rotation. You have to bend a portion (I used 1/3). take off the straight portion (using edit component, choose flat face and edges, make component, cut, exit component, paste in place), bend that-- and repeat for total of three or more times, because you can only go 180 in each bend. Probably faster other ways? But this feels more "realistic" and you can adjust procedure for the curl you want.You explode and rejoin the portions at the end. "distinguished"? Now I'll have to grow a mustache. Please, register (free) to access all the attachments on the forums.
Re: Help! How to make a spiral like a paper?Manual SU by my above method. I'm sure it's a little slower than fredoscale and probably a little harder. Took about 25 min. and I should be doing something else, but this is more fun.
It's a dog.
Like the first post with the draw Helix Draw any Helix / Copy Move then Scale it The beauty of the thing is all that take 5 seconds to make!
Re: Help! How to make a spiral like a paper?Super cool! You guys just save me!
I'm confused. I see what might be a tail, an organ, and an orifice but at that point my imagination can't hack it. EDIT: Now I get it. Before, I could not hear the splashing. Great tips on the model, folks. First I'm going to try Pilou's 5 second method. Be back in the morning sometime when I finish. I'm back but for me the use of TIG's tool is not intuitive. I don't doubt that that is more a reflection of my limitations but one might need reminding that TIG's tool needs curves for the rails, as Pilou mentioned. So you need to draw even a straight edge as multiple sections or divide it and then weld it into a curve. Please, register (free) to access all the attachments on the forums. ~ Brooke
Re: Help! How to make a spiral like a paper?Definitely Shape Bender:
We never listen.
Off-Topic: Oh. Can not be unseen.
Re: Help! How to make a spiral like a paper?Very conceptual avatar!
Re: Help! How to make a spiral like a paper?Thanks for learnin' me a little, after which, for me, extrude edges by rails works best, simply because I could not make the length of the helix and the diagonal to match so shape bender had an annoying error (the little projecting tab). How to make these equal? Note also the disagreement about the length of the scaled helix curve info=112', label=245'. I assume the scaling threw a wrench in the works?
Re: Help! How to make a spiral like a paper?#1 draw the path ( helix )
#2 select it, open entity info to get the length #3 draw the line the same length #4 draw the diagonal sheet the same length #5 draw the sheet with circle tool set to 4 segments ( if you want a square sheet ) #6 erase the diagonal #7 group the sheet #8 run shape bender.....wait.... #9 resize the model with tape tool. done it takes five minutes.
Re: Help! How to make a spiral like a paper?Thanks for that.
Sly:
Perhaps that method it is more accurate than 'extrude edges by rails' even if a little slower. ~ Brooke
Re: Help! How to make a spiral like a paper?If your paper is square it's fast as you already have the diagonal.
Re: Help! How to make a spiral like a paper?I like your way because it has the rotated sheet (corner up). I cannot do it faster than EEbyR, though.
~ Brooke
Re: Help! How to make a spiral like a paper?Anybody tried Spirix on this? I am not sure if it can be applied here. Some more info, I think is in a thread back about 4months. As far as I know, the author doesn't post here.
SketchUcation One-Liner AdvertsKeyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Premium Members get 20% discount!
• Page 1 of 1
