SketchUcation Premium Membership
Help! How to make a spiral like a paper?
Welcome! Ask and get answered - or just introduce yourself.
Postby shahreza90 » Thu Apr 12, 2012 4:09 pm
Hi there, anyone knows how to make a model of a twisted spiral paper?
Here are some photos
shahreza90
Re: Help! How to make a spiral like a paper?
Postby Pilou » Thu Apr 12, 2012 4:37 pm
Maybe concept like this ;)
Draw helix by P Brawn explode it (because it is a group) length as you want (
Draw 2 Straight lines Curves normaly in your case similar (minimum 2 Segments) inclined as you you want
In your case redraw 2 spirals against the 2 lines a & d ;)
Call Extrude Edge by Rail by TIG
Click b & Clik c are on the same curves
Et voilà :)
Ps In fact your model is 4 spirals :)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
Operating system: Windows
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Level of SketchUp: Advanced
Postby solo » Thu Apr 12, 2012 6:03 pm
Scratching head... hmmm, this is a challenge in SU.
My site
Quod gratis asseritur, gratis negatur.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
Postby Don Burns » Thu Apr 12, 2012 6:34 pm
You can draw a rectangle, divide it on the diagonally a bunch of times. figure out how many degrees around total the finished paper will be. The yellow one is about 28 sections bent at approx 15 deg. Bend in at a bigger angle alittle as you go will tighten the spiral at the end.
Don Burns
Postby Pilou » Thu Apr 12, 2012 7:07 pm
Again Extrude by 2 rails
2 Spirals, 2 arcs
Just increase the number of turns of the spiral and adapt radius size for have that you want ;)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby gilles » Thu Apr 12, 2012 7:11 pm
Why not use shape bender?
User avatar
gilles
Top SketchUcator
Operating system: Mac
SketchUp version: 8
SketchUp use: other
Postby pbacot » Thu Apr 12, 2012 7:37 pm
I think shape bender is more likely to be closer to the original paper size and shape.
OK gilles I have to ask, what IS that avatar supposed to be?
Pilou you have to say how you made the spiral.
User avatar
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby mwm5053 » Thu Apr 12, 2012 7:55 pm
and BTW why is name in green as with Pilou others in blue?
Curios as to who figures out the spiral
mwm5053
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Postby Gaieus » Thu Apr 12, 2012 8:07 pm
Green names are "Top SketchUcators", distinguished forum members.
"Top SketchUcators" are known as exceptionally active and helpful as well as highly skilled members of the SketchUcation Community Forums. This is a closed group, new members can only join upon invitation of a group leader.
They can, however, choose to remain a bit "under cover" and do not set that usergroup as their default so some of them are blue as regular members.
User avatar
Administrator
SketchUp version: 2013
License type: Pro
SketchUp use: historical reconstruction
Postby pbacot » Thu Apr 12, 2012 8:38 pm
With FredOscale Free bending tool. I just like using it for the fun of it. Way more fun than doing my taxes.
Start with rectangle. Make component. Put another rectangle vertical along direction of curl (I drew corner to corner) for setting the rotation. You have to bend a portion (I used 1/3). take off the straight portion (using edit component, choose flat face and edges, make component, cut, exit component, paste in place), bend that-- and repeat for total of three or more times, because you can only go 180 in each bend. Probably faster other ways? But this feels more "realistic" and you can adjust procedure for the curl you want.You explode and rejoin the portions at the end.
"distinguished"? Now I'll have to grow a mustache.
User avatar
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Don Burns » Thu Apr 12, 2012 8:52 pm
Manual SU by my above method. I'm sure it's a little slower than fredoscale and probably a little harder. Took about 25 min. and I should be doing something else, but this is more fun.
Don Burns
Postby gilles » Thu Apr 12, 2012 9:01 pm
pbacot wrote:OK gilles I have to ask, what IS that avatar supposed to be?
It's a dog.
User avatar
gilles
Top SketchUcator
SketchUp version: 8
SketchUp use: other
Postby Gaieus » Thu Apr 12, 2012 9:02 pm
Ha. I can see now. In fact, a male dog. :D
User avatar
Administrator
License type: Pro
Postby pbacot » Thu Apr 12, 2012 9:27 pm
:lol: Sorry I asked.
User avatar
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Pilou » Thu Apr 12, 2012 10:45 pm
Like the first post with the draw Helix ;)
Draw any Helix / Copy Move then Scale it
The beauty of the thing is all that take 5 seconds to make! ;)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby shahreza90 » Fri Apr 20, 2012 9:28 pm
Super cool! You guys just save me! :berserk:
shahreza90
Postby brookefox » Fri Apr 20, 2012 11:08 pm
gilles wrote:It's a dog.
I'm confused. I see what might be a tail, an organ, and an orifice but at that point my imagination can't hack it.
EDIT: Now I get it. Before, I could not hear the splashing.
Great tips on the model, folks. First I'm going to try Pilou's 5 second method. Be back in the morning sometime when I finish.
I'm back but for me the use of TIG's tool is not intuitive. I don't doubt that that is more a reflection of my limitations but one might need reminding that TIG's tool needs curves for the rails, as Pilou mentioned. So you need to draw even a straight edge as multiple sections or divide it and then weld it into a curve.
~ Brooke
User avatar
brookefox
SketchUp version: 8
Postby gilles » Sat Apr 21, 2012 11:17 am
Definitely Shape Bender:
User avatar
gilles
Top SketchUcator
SketchUp version: 8
SketchUp use: other
Postby pbacot » Sat Apr 21, 2012 5:43 pm
gilles wrote:Definitely Shape Bender:
We never listen.
User avatar
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Jim » Sat Apr 21, 2012 5:48 pm
It's a dog.
Off-Topic:
Oh. Can not be unseen.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby TIG » Sat Apr 21, 2012 10:36 pm
Off-Topic:
Un chien mâle qui pisse, vu de derrière :shock:
User avatar
Global Moderator
License type: Pro
Postby Pilou » Sat Apr 21, 2012 10:52 pm
Very conceptual avatar! :mrgreen:
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby brookefox » Sun Apr 22, 2012 8:46 pm
Thanks for learnin' me a little, after which, for me, extrude edges by rails works best, simply because I could not make the length of the helix and the diagonal to match so shape bender had an annoying error (the little projecting tab). How to make these equal? Note also the disagreement about the length of the scaled helix curve info=112', label=245'. I assume the scaling threw a wrench in the works?
~ Brooke
User avatar
brookefox
SketchUp version: 8
Postby gilles » Tue May 01, 2012 9:23 pm
#1 draw the path ( helix )
#2 select it, open entity info to get the length
#3 draw the line the same length
#4 draw the diagonal sheet the same length
#5 draw the sheet with circle tool set to 4 segments ( if you want a square sheet )
#6 erase the diagonal
#7 group the sheet
#8 run shape bender.....wait....
#9 resize the model with tape tool. done
it takes five minutes.
User avatar
gilles
Top SketchUcator
SketchUp version: 8
SketchUp use: other
Postby brookefox » Tue May 01, 2012 11:25 pm
Thanks for that.
Sly:
Perhaps that method it is more accurate than 'extrude edges by rails' even if a little slower.
~ Brooke
User avatar
brookefox
SketchUp version: 8
Postby gilles » Tue May 01, 2012 11:35 pm
If your paper is square it's fast as you already have the diagonal.
User avatar
gilles
Top SketchUcator
SketchUp version: 8
SketchUp use: other
Postby brookefox » Fri May 04, 2012 12:33 am
I like your way because it has the rotated sheet (corner up). I cannot do it faster than EEbyR, though.
~ Brooke
User avatar
brookefox
SketchUp version: 8
Postby mitcorb » Fri May 04, 2012 1:19 am
Anybody tried Spirix on this? I am not sure if it can be applied here. Some more info, I think is in a thread back about 4months. As far as I know, the author doesn't post here.
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
Postby brookefox » Fri May 04, 2012 1:40 am
Heck, man. That thing looks real nifty.
http://sites.google.com/site/spirixcode/home
~ Brooke
User avatar
brookefox
SketchUp version: 8
by Ad Machine » 5 minutes ago
Artisan Organic Toolset - a set of powerful organic modeling tools.
Premium Members get 20% discount!
Ad Machine
Robot
Return to Newbie Forum
Who is online
Users browsing this forum: No registered users and 3 guests
