[Plugin][$] SketchUV
• Page 1 of 4 • 1, 2, 3, 4
[Plugin][$] SketchUVHi,
Just wanted to let you know that I have just released a commercial update to UV Tools called SketchUV. It adds some notable features including: - planar mapping - box mapping - tube mapping - Save/Load UVs - UV transformation (move, rotate, scale) - view-based projections at any orientation Also it improves on all of the previous features of UV Tools which included: - spherical mapping - cylindrical mapping - Export/Import UVs to external mapping software - OBJ export Thankyou very much to my testers and especially to Rich for the very nice review in CatchUp #9. The plugin can be purchased for $15 at Smustard Below is one of several video tutorials that I made for the plugin. You can see all of the tutorials and download the complete PDF user guide at the Smustard page. Thanks! Dale
Re: [Plugin][$] SketchUVAwesome, with this SU is just about as complete as any other 3d modeling application.
I just feel my money wanting to burst out of my pockets....urm paypal.
Re: [Plugin][$] SketchUVSmustard SketchUV PDF downloads doc for Profile Builder.
Yes I can comfirm that too.
Thank you! Fixed now.
Thank you for providing this fantastic plugin (and your others of course) for an affordable price so that hobbyists like me are able to use them...
Re: [Plugin][$] SketchUVWelcome to try Thea Render, Thea support | kerkythea.net -team member
Re: [Plugin][$] SketchUVI tried to use it on my sofa, but I could not get the result that I am looking for.
I used Box map and planner map, but it did not work. Can you please help me with this? I attached SKP file. Thank you. Please, register (free) to access all the attachments on the forums.
That are the results the tutorial videos from Whaat promises?!
Re: [Plugin][$] SketchUVI think I need to spend more time on this plugin.
Re: [Plugin][$] SketchUVTo properly map that sofa you need to unwrap it in an external app. Box map is a viewed based method that assigns textures from 6 views - top/bottom/left/right/front/back.
This is why there is a noticeable break in the texture. Did you try select the area that is misaligned and rotating/scaling the textures?
Re: [Plugin][$] SketchUVwow! great!
i think this will be my first paid plugin!
really?
Re: [Plugin][$] SketchUVwill this work for mapping cars? and will the maps transfer over to other programs well like Max?
can you optimize UVW maps with it? using all the area on a map for more than one piece of geometry?
Re: [Plugin][$] SketchUVTube mapping looks to be a especially nice new tool.
Best, Jason. I create video tutorial series about several 2D & 3D graphics programs.
Re: [Plugin][$] SketchUVIf only I have bucks I would buy that plugin!
Re: [Plugin][$] SketchUVWell done, Dale!! I'm going there now to purchase....
purpose/expression/purpose/....
Re: [Plugin][$] SketchUVWoohoo! Great job Dale! A MUST HAVE PLUGIN!
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
Re: [Plugin][$] SketchUVExcellent plugin, Dale...
I've always wondered why the Google SU team haven't made better UV-tools... Well... It's fortunate for you guys, who then have the option to work on various plugins and get some $$... Nevertheless, it should be a standard in SU IMHO...
Re: [Plugin][$] SketchUVLooking forward to see the models people make with this tool.
Re: [Plugin][$] SketchUVI just got the newsletter. No visible link to the review.
I can't find the review via google. (try putting "sketchuv" on there... no hits) http://news.sketchucation.com/ is a horrible indecipherable mess.
Re: [Plugin][$] SketchUVHere is the announcement, Agamemnus:
viewtopic.php?f=323&t=44500 The links are in big, fat letters at the bottom of the first post. Gai...
Re: [Plugin][$] SketchUVThanks.
That soldier example was very impressive...
i have tested the free demo but found it to be too slow and lagging for intuitive sculpting and it's still no subD-modeling so the geometry gets broken and the model becomes very large and unhandy... - i prefer subD-modeling in max and export it to sketchup or merge the geometry before rendering. Real SubD-modeling in sketchup would be incredible!!! Hope dies last... (maybe i'll integrate silo or voidworld into my workflow - quite nice little modeling apps, but this would be one import/export step more... which holds me back for now)
Hello, Box mapping will show seams at curving surfaces so it is not ideal for that part of the couch. I recommend using the exact same technique that I used in the tutorial video attached to the first post of this thread (first part of the video): 1) Separate the surface into smaller surfaces using the Path Select Tool 2) Use planar projections on each surface 3) Align them using the UV transformation tools In the attached video, I actually began with box mapping, and then used the seams as a guide to separate the surfaces. I didn't have to switch the material to the UV Texture but I thought it would help with the alignment.
Hi Kris, You can map cars by dividing the surfaces into separate panels and applying planar projections to it. I expect it would work very well. Any surfaces that were especially tricky could be easily unwrapped using Roadkill (a free UV unwrapping app) that you can export and import UVs with using SketchUV. You can not optimize maps with it directly. However, by exporting to another app, that can be done. Again, using Roadkill, the maps are automatically optimized by default as you unwrap the mesh. See this tutorial: The maps should transfer perfectly to Max as long as you first use the triangulation function prior to 3DS export. This is explained in this tutorial:
Re: [Plugin][$] SketchUVA kind of magic I´m willing to learn.
And how did you make your signature dissapear Gaieus? Comfortably numb...
Well, I do not know about Max itself (although why would it be different) but have tried a couple of 3rd party apps and indeed, with triangulation on, it exports perfectly. And Dale, you need to make a new video for this feature. This one shows the UV maps a bit distorted but the plugin does not distort them (any longer). Off-Topic:
It's there... ucp.php?i=profile&mode=signature Gai...
Re: [Plugin][$] SketchUVawesome... Thanks Whaat.
SketchUcation One-Liner AdvertsNeed SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Premium Members get 20% discount!
