SketchUcation Plugin Store
Draping on TIN - how to select drape line only?
General discussion related to SketchUp. No off topic threads please.
Postby nickdk » Wed Mar 28, 2012 3:42 pm
Hello guys!
I'm trying to drape onto my TIN but my draped line ends up in many segments and can't be selected again, how can I select the lines only? Is there a way to keep the draped line inside a group or another method to keep the line and the TIN separated? :)
Thanks!! :)
nickdk
Re: Draping on TIN - how to selct drape line only?
Postby Gaieus » Wed Mar 28, 2012 3:47 pm
No, there's no way keeping it inside a group (after all, intersecting in the TIN's editing context is what drape is all about).
If you smooth the TIN before draping, you can then select the draped lines with a selection box however (triple click would select all soft, connected edges and faces too).
User avatar
Administrator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Level of SketchUp: Advanced
Postby Jean Lemire » Wed Mar 28, 2012 8:34 pm
Hi folks.
Once you have draped the shape on the TIN, double click on the face delimited by the shape, on the TIN. This will select the face and its perimeter.
Then, while holding the SHIFT key to add/subtract to the selection, single click on the face to deselect it. Only the perimeter or outline of the shape will remain selected.
You can then do whatever you want like grouping it or copying it, or whatever.
Just ideas.
Jean (Johnny) Lemire from Richelieu, Quebec, Canada.
User avatar
Jean Lemire
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Re: Draping on TIN - how to select drape line only?
Postby nickdk » Thu Mar 29, 2012 12:31 am
thanks to both of you! :) it works great :family:
nickdk
Postby Gaieus » Thu Mar 29, 2012 7:48 am
Jean, that's an obvious tip - if there is an enclosed shape draped on the terrain but if it is just a line (as Nick originally posted), selection is obviously more tedious.
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby TIG » Thu Mar 29, 2012 12:02 pm
Here's a way using ExtrudeEdgesByVectorToObjects...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby charevir56 » Sat Mar 31, 2012 5:00 am
Tig, your answer are so amazing, specially the once related with your work (plugins).
I've bookmarked all your post regarding with extrude thing, because is so dificult for us normal mind to follow the use of your plugin. They are so versatiles that we don't know how to use it or when (at lest me), but you are doing a good work "tigging" us your plugins. I barely give my answer but I give you my :thumb:
charevir56
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Ad Machine
Robot
Return to SketchUp Discussions
Who is online
Users browsing this forum: No registered users and 3 guests
