SketchUcation Premium Membership
'tricky' stamp? - try awhile then forget about it
Postby brookefox » Sat Mar 24, 2012 11:45 pm
I've been working pretty hard for two days to get a road stamped on real terrain. No luck, just a lot of re-dos. Here are a couple of pics, by no means the only kind of errors that have appeared. Whether the stamp is grouped or ungrouped, has vertical faces included or not. I feel so disenchanted that I'm not going to fully explain unless someone thinks I'm doing something wrong, can help, or has had similar experiences or something to share about this. Breaking the job down into multiple jobs to eliminate any loops works better but then there is the overwhelming task of matching the displacements since SU gives no way of specifying it, and should, or it should at least give a way of matching or repeating it.
~ Brooke
User avatar
brookefox
Operating system: Windows
SketchUp version: 8
License type: Free
SketchUp use: architecture
Level of SketchUp: Intermediate
Re: 'tricky' stamp? - try awhile then forget about it
Postby mitcorb » Sun Mar 25, 2012 3:52 am
Brooke:
I am not sure with the images what the difficulty is. I tried stamp and drape on a regular TIN using both a flat face curvy "road" and one with thickness and compound curve(left right and up down) Could the complexity of faces in your terrain maybe have something to do with it? Am I just not understanding the problem? Or, are you stamping/ draping sections of terrain to a base map?
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby Gaieus » Sun Mar 25, 2012 9:04 am
Brooke: that terrain mesh looks awful. Too long and thin facets therefore any kind of further manipulation will inevitably result in some even more awful appearance. I'd suggest "processing" it with terrain reshaper first: viewtopic.php?t=11320 then you get a much nicer distributed TIN which can then be manipulated much easier.
User avatar
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Level of SketchUp: Advanced
Postby mitcorb » Sun Mar 25, 2012 2:14 pm
But, Gaieus:
Notice the last post in the Reshaper thread you linked. Brooke has already been there, back on the 18th.
I suspect part of the problem is the size of the portion being processed by the Stamp tool. In my experiment, I noticed a delay at about 75% in the progress bar at the bottom of the screen.
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby Gaieus » Sun Mar 25, 2012 2:59 pm
No, I did not go through all the 18 pages. :D
(In fact, sometimes I also have issues with this plugin...)
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby brookefox » Mon Mar 26, 2012 11:47 pm
You have got your nerve, mister no-more-mister-nice guy.
The terrain is large and flat (600 acres; 50 feet Z) and was an unmanipulated result from sandboxing the contours. As can be seen in the first pic posted earlier, the redline offset does not include the subsequently erroneously shaped area within the loop. The contours were simplified in order to reduce the size of the result; without simplification I think the results would have been worse: longer, thinner triangles. I certainly agree they are not much to look at but that's what is produced with distant shallow contours, it seems. I had tried terrain reshaper but, as I recall, it resulted in large flat areas with a border of TINs near the contours; not smooth.
Thank you both for trying to help. Sniff...
Try these views, please. No road stamp, just drape (but the tannin rich creek was stamped previously; no loops, etc. there).
(How about that Component Sprayer!)
~ Brooke
User avatar
brookefox
SketchUp version: 8
License type: Free
Postby mitcorb » Tue Mar 27, 2012 2:05 am
Hi, Brooke:
All I can say is wow. I have not tried anything of this scale or scope--yet. I confess I still am not sure what the difficulty was.
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby Gaieus » Tue Mar 27, 2012 12:06 pm
brookefox wrote:You have got your nerve, mister no-more-mister-nice guy.
:D
What I meant by that was that a terrain with lots of very long and narrow triangles is very hard to work with nicely. Also that's why I suggested terrain reshaper as that would ("ideally" :?: )create more evenly distributed triangles.
That third (top) view with hidden geometry looks nice though. That's much evenly distributed than what I could see from that side view earlier.
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby brookefox » Tue Mar 27, 2012 4:51 pm
Gaieus wrote:What I meant by that was that a terrain with lots of very long and narrow triangles is very hard to work with nicely. Also that's why I suggested terrain reshaper as that would ("ideally" :?: )create more evenly distributed triangles.
I thought I knew what you meant, but on second thought... The long and thins were what 'stamp' produced. They were not a part of the original terrain, which is what you are now calling 'nice'. Fickle you! Please see my initial post: the original terrain is there as displayed hidden below the floating road in the upper, 'before' image. The image below that is the resulting stamp with the 'long and thins' (that I think you thought were my original). It is likely that I should have been more clear about those images.
That is the problem, Tim: 'stamp' just botched the thing badly. At least that is my story.
~ Brooke
User avatar
brookefox
SketchUp version: 8
License type: Free
Postby mitcorb » Tue Mar 27, 2012 7:42 pm
Well, the problem with drape for me was all the triangulation in the drape skinning where the road rose either above or below the adjacent sculpted terrain, and the vertices in the drape did not coincide in the least with the vertices in the terrain.
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
by Ad Machine » 5 minutes ago
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Ad Machine
Robot
Return to SketchUp Bugs
Who is online
