SketchUcation Plugin Store
Move points to a '3D grid'
Postby rossthompson » Mon Mar 26, 2012 12:10 pm
I am trying to write a script for cleaning up geometery created from another program (IES VE). Essentially what I want to achieve is to move each vertex so it sits on a '3D grid'. I believe this could be achieved by applying a rounding function to the X,Y and Z coordinates of each point.
The attached image hopefully illustrates what I am trying to achieve. Ideally the degree of rounding would be a user input variable.
Any help on this would be greatly appreciated.
Ross
rossthompson
Operating system: Windows
SketchUp version: 7
License type: Free/Make
SketchUp use: architecture
Level of SketchUp: Advanced
Re: Move points to a '3D grid'
Postby gilles » Mon Mar 26, 2012 12:51 pm
You can use the scale tool: begin to scale then type 400mm;400mm;400mm + enter.
Note that the separator may be "," for you .
User avatar
gilles
Top SketchUcator
Operating system: Mac
SketchUp version: 8
SketchUp use: other
Level of SketchUp: Intermediate
Postby thomthom » Mon Mar 26, 2012 12:57 pm
gilles wrote:You can use the scale tool:
rossthompson wrote:I am trying to write a script
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Mon Mar 26, 2012 1:01 pm
This is a nice idea - I might implement such a feature in Vertex Tools.
Of the top of my head, something like this:
pt = Geom::Point3d.new( 3.976879, 3.970209, 1.002568 )
grid_pt = pt.to_a.map { |n| n.round() }
v = pt.vector_to( grid_pt )
You can do something like that - iterate the vertices of a mesh, for each vertex find the nearest grid position to the vertex, collect the vertex and adjustment vector to each their array and use Entities.transform_by_vectors https://developers.google.com/sketchup/ ... by_vectors
Note that this simple example rounded to nearest whole number. Modifications is needed to account for grids fitted to decimal precision.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Actually, that example will round to nearest inch - which is SketchUp's internal unit...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Mon Mar 26, 2012 1:15 pm
Code: Select all
pt = Geom::Point3d.new( 3.976879.m, 3.760209.m, 1.002568.)
tolerance = 0.25.m
grid_pt
= pt.to_a.map { |n|
  b = ( n / tolerance ).to_i * tolerance
  r
= n % tolerance
(> tolerance / 2) ? b + tolerance : b
grid_pt = Geom::Point3d.new( *grid_pt )
puts "Original: #{pt}"
puts "Tolerance: #{tolerance}"
puts "Grid Point: #{grid_pt}"
Output:
Original: (3976,879mm, 3760,209mm, 1002,568mm)
Tolerance: 250mm
Grid Point: (4000mm, 3750mm, 1000mm)
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Mon Mar 26, 2012 1:35 pm
Test module - adjust the vertices in the active context to grid.
Code: Select all
module GridSnap
  def self
.round_pointpointtolerance )
grid_pt point.to_a.map { |n|
= ( tolerance ).to_i tolerance
      r
tolerance
(tolerance 2) ? tolerance b
  def self
.test_it
    pt
Geom::Point3d.new( 3.976879.m3.760209.m1.002568.)
tolerance 0.25.m
    grid_pt
self.round_pointpttolerance )
  def self
.adjust_verticestolerance 0.25.)
model Sketchup.active_model
    vertices
# Collect vertices.
for e in model.active_entities
      vertices
<< e.vertices if e.is_a?( Sketchup::Edge )
    vertices
.flatten!
vertices.uniq!
# Calculate grid adjustments.
vectors = []
entities = []
    for
vertex in vertices
      pt
vertex.position
      grid_pt
vector pt.vector_togrid_pt )
next unless vector.valid?
entities << vertex
      vectors
<< vector
# Apply transformations
model.active_entities.transform_by_vectorsentitiesvectors )
puts "#{entities.size} adjusted to grid."
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Dan Rathbun » Mon Mar 26, 2012 1:54 pm
How about that ??
... from concept to module in under a hour. :thumb:
User avatar
Dan Rathbun
Top SketchUcator
SketchUp version: 2013
License type: Pro
SketchUp use: education
Postby TIG » Mon Mar 26, 2012 2:02 pm
Could this then be a tiny step towards a poly-reducer?
As the vertices are 'rationalized' onto a 'grid' some faces could become coplanar and therefore the superfluous shared edges could be removed.
The fineness/coarseness of this 'grid' removes less/more 'detailing'... :?
User avatar
Global Moderator
License type: Pro
Postby thomthom » Mon Mar 26, 2012 2:09 pm
Cubificator?
I was thinking it might be usable to repair troublesome model imported from CAD drawings. Occasionally I run into models where splitting a face with an edge results in duplicate faces. I suspect its due to some precision errors. Maybe if the vertices where adjusted to fit to a finely grained 3D grid the troubles would go away... ?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby rossthompson » Mon Mar 26, 2012 3:13 pm
ThomThom thanks so much for your support! I have had a go at running your test module. My understanding is that it should shift the points in the active selection to a 0.25m grid as specified in the code.
However I am having problems running the module. I have attempted to add it to the tools menu as below, but I am not 100% sure how to 'call' the routine. Appologies if I'm being an idiot - I am new to ruby scripting!
Code: Select all
    module GridSnap
      def self.round_point( point, tolerance )
        grid_pt = point.to_a.map { |n|
          r = n % tolerance
          (r > tolerance / 2) ? b + tolerance : b
      def self.test_it
        pt = Geom::Point3d.new( 3.976879.m, 3.760209.m, 1.002568.m )
        tolerance = 0.25.m
        grid_pt = self.round_point( pt, tolerance )
      def self.adjust_vertices( tolerance = 0.25.m )
        model = Sketchup.active_model
        vertices = []
        # Collect vertices.
          vertices << e.vertices if e.is_a?( Sketchup::Edge )
        vertices.flatten!
        vertices.uniq!
        vectors = []
        entities = []
        for vertex in vertices
          pt = vertex.position
          vector = pt.vector_to( grid_pt )
          entities << vertex
          vectors << vector
        model.active_entities.transform_by_vectors( entities, vectors )
# Menu Entry:
UI.menu("Tools").add_item("GridSnap") { GridSnap } if not file_loaded?("GridSnap.rb")
file_loaded("GridSnap.rb")
I think this could be a very useful tool for cleaning many types of imported geometry.
Ross
rossthompson
SketchUp version: 7
Postby Dan Rathbun » Mon Mar 26, 2012 3:21 pm
thomthom wrote:Cubificator?
Polyhedronizer ?
Orthogonizer ?
Orthographizer ?
OrthograFixer ?
:lol:
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby TIG » Mon Mar 26, 2012 3:24 pm
In case TT is away...
Inside the code making the menu use
{GridSnap.adjust_vertices(1.cm)}
It affects the whole model.
This example uses 1cm grid
Use another 'tolerance' if desired...
If you use () it defaults to 0.25m anyway...
It's only some example code and could be better assembled into something working on a selection with warnings and an 'undo' ???
User avatar
Global Moderator
License type: Pro
Postby TIG » Mon Mar 26, 2012 3:43 pm
Not sure this reduced poly rock is so good ?
'Cuboidalizer' is another name idea too... that or 'Discombobulizer' :shock:
User avatar
Global Moderator
License type: Pro
Postby Dan Rathbun » Mon Mar 26, 2012 3:49 pm
Here's a beta version with an inputbox and undo operation...
It seemed to only change a cubes vertices in the Z axis ??
Code: Select all
module GridSnap
  @@last_tolerance = 0.25.m
  class << self # PROXY CLASS
    def round_point( point, tolerance )
        r = n % tolerance
    def test_it
      tolerance = @@last_tolerance
      grid_pt = round_point( pt, tolerance )
    def adjust_vertices( tolerance = @@last_tolerance )
      vertices = []
      # Collect vertices.
      vertices.flatten!
      vertices.uniq!
      vectors = []
      entities = []
        entities << vertex
        vectors << vector
    def menu_command()
      title   = 'Adjust Vertices'
      prompt  = 'Tolerance'
      default = @@last_tolerance
      result = UI.inputbox([prompt],[@@last_tolerance],title) rescue @@last_tolerance
      if result
        begin
          Sketchup.active_model.start_operation("#{title} (#{Sketchup.format_length(result[0])})")
          adjust_vertices( result[0] )
          Sketchup.active_model.commit_operation()
        rescue
          Sketchup.active_model.abort_operation()
        else
          @@last_tolerance = result[0]
  end # PROXY CLASS
  #{# RUN ONCE
  unless file_loaded?("GridSnap.rb")
    # Menu Entry:
    UI.menu("Tools").add_item("GridSnap") { menu_command() }
  end #}
end # module
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby thomthom » Mon Mar 26, 2012 7:53 pm
Dan Rathbun wrote:It seemed to only change a cubes vertices in the Z axis ??
Should apply to X,Y and Z... Seemed to work correctly in my quick test...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby daiku » Tue Mar 27, 2012 2:47 pm
Polyhedronizer ?
Orthogonizer ?
Orthographizer ?
OrthograFixer ?
:lol:
It's like Autotune for cad! They can make you sound good, even if you can't sing.
If you are editing digital music, and you need to make the drum beats perfect, you can move the beats to the nearest sixteenth note, or whatever. It's call "quantizing".
daiku
Postby Dan Rathbun » Tue Mar 27, 2012 4:00 pm
daiku wrote:It's called "quantizing".
TRUE !!
Restriction to discrete values (or multiples thereof,) rather than any values in the set of possibles (real numbers, in this case.)
So.. the long term:
Vertex Positional Quantization
The short form:
Vertex to Grid
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby rossthompson » Wed Mar 28, 2012 2:30 pm
Hi guys, I have had a play with Dan's Beta version and for me it works really well. The verticies are adjusted in X,Y and Z directions and the undo function works fine!
The only slight problem: it adjusts all the geometry in the model, rather than just the active selection. The original module just adjusted the active selection.
Any ideas?
Again thanks for the support - this script should be a realy time saver!
Ross
rossthompson
SketchUp version: 7
Postby Dan Rathbun » Wed Mar 28, 2012 3:27 pm
Well .. I did not think I changed the context of what Thomas' code did... just tried to wrap the code properly and added the menu_command() method to handle an inputbox.
I'll have a look at it.. again.
(And it's not really MY edition just because I added the inputbox.. it's still Thomas' thing.)
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby Dan Rathbun » Wed Mar 28, 2012 3:56 pm
OK... added support for a selection. (Pssst! ... there was no selection support from the beginning Ross.)
This utility should probably be wrapped in Thomas' toplevel author module, and reside below his author directory in some manner.
I'll leave those choices up to him, and when he releases version 1.0.0, we'll delete these beta versions in this thread and put in a link to the release thread.
Code: Select all
#  GridSnap.rb
#  by Thomas Thomassen
#  THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
#  IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
#  WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
#  This utility quantizes the vertex locations, of the current selection,
#    of the model, or just the current context, to a 3D grid, whose interval
#    can be set via a popup inputbox.
#  Revisions:
#   0.1.0 : 2012-03-26 : by Thomas Thomassen
#   initial beta release
#   0.2.0 : 2012-03-26 : by Dan Rathbun
#   + Added menu_command() method for inputbox and undo operation.
#   0.3.0 : 2012-03-28 : by Dan Rathbun
#   + Revised the menu_command() method to pass a selection set to the
#       adjust_vertices() method as a 2nd argument.
module GridSnap
        r = n % tolerance
    def test_it
    def adjust_vertices( tolerance = @@last_tolerance, ents = nil )
      vertices = []
      # determine the context:
      ents = model.active_entities() if ents.nil?
      # Collect vertices.
      for e in ents #model.active_entities
      vertices.flatten!
      vertices.uniq!
      vectors = []
      entities = []
        entities << vertex
        vectors << vector
    def menu_command()
      if result
        begin
            if model.selection.empty?
            else
              adjust_vertices( result[0], model.selection.to_a() )
        rescue
        else
  end # PROXY CLASS
  #{# RUN ONCE
    # Menu Entry:
  end #}
end # module
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
by Ad Machine » 5 minutes ago
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Premium Members get 20% discount!
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: m1985p and 9 guests
