To access this forum when logged in, please, sign up to the Woodworking User Group in your User Control Panel.
by Dave R » Sat Mar 17, 2012 1:31 pm
I was poking around on the net and found this chair someone had made from a 10' length of 2 x 6 lumber. That'd be 3.048 m of 150mm x 50mm lumber (what's the metric word for lumber?) Another fellow did a video showing how he drew it in SketchUp so I thought I'd have a go, too.
Inspecting mirrors is a job I could easily see myself doing.
- Global Moderator
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: woodworking
- Level of SketchUp: Advanced
by Gaieus » Sat Mar 17, 2012 1:54 pm
These are typically the chairs that break/collapse when I sit on them.
- Administrator
- Name: Csaba Pozsárkó
- License type: Pro
- SketchUp use: historical reconstruction
by Dave R » Sat Mar 17, 2012 1:55 pm
I know what you mean.
- Global Moderator
- License type: Pro
by Mike Lucey » Sat Mar 17, 2012 2:02 pm
Nice job Dave  Maybe the bones of an idea for a competition there! What can be done with ?? of ?? x ??
Mike Lucey
- Mayor
- Name: Mike Lucey
- Operating system: Mac
- License type: Pro
- SketchUp use: architecture
by mitcorb » Sat Mar 17, 2012 2:07 pm
I can see how the wing parts might be splined or dowelled to the main sections. Would that be just an interlocking notch (maybe mortise) joint for the two mains?
mitcorb
- Top SketchUcator
- Name: Tim
- License type: Free
- Level of SketchUp: Intermediate
by Dave R » Sat Mar 17, 2012 2:11 pm
Thanks, Mike.
Those sorts of competitions come up every once in awhile on the woodworking forums. It is simply amazing what some folks manage to tease out of a single board. The problem around here is that construction lumber is usually so lousy, much of a board would be waste.
Tim, the wings are indeed attached with dowels and the two main pieces are connected with a "halving joint", the same notch cut in both pieces. I think that joint would be left unglued so the chair can be knocked down for storage.
- Global Moderator
- License type: Pro
by mitcorb » Sat Mar 17, 2012 2:17 pm
Then I would "gild the lily" with some Stanley hardware at that joint, in case Csaba comes over.
mitcorb
- Top SketchUcator
- Name: Tim
by TIG » Sat Mar 17, 2012 6:59 pm
This idea uses just under 10' of 6x2" to make a 'stool' for Csaba ! Glued and screwed together it'd be pretty indestructible...
Please, register (free) to access all the attachments on the forums. TIG
- Global Moderator
- Name: TIG
- License type: Pro
by brookefox » Sat Mar 17, 2012 7:33 pm
Those are nice, Dave. I would say the design should be for a portable, two or three piece assembly. Where's the video?
~ Brooke
brookefox
- Name: Brooke
by Dave R » Sat Mar 17, 2012 9:46 pm
TIG, that still might be a bit lightly built for Csaba.  Brooke, I agree with you. I wouldn't use any hardware to join the seat and backrest.
- Global Moderator
- License type: Pro
by EscapeArtist » Sat Mar 17, 2012 10:48 pm
Used to do Medieval recreation for fun, these chairs were popular. The 2 x 12 chair variant was very similar, and quite portable. Here's an example:
EscapeArtist
- Top SketchUcator
- Name: Jeff
- License type: Pro
- SketchUp use: hobby
by Dave R » Sat Mar 17, 2012 11:10 pm
Jeff, I like yours much better.
- Global Moderator
- License type: Pro
by Jonavery16 » Wed Mar 28, 2012 9:01 pm
EscapeArtist wrote:Used to do Medieval recreation for fun, these chairs were popular. The 2 x 12 chair variant was very similar, and quite portable. Here's an example:
Simple model of the picture. Not exactly accurate but it is made from 1 2x12x8 board
Jonavery16
- Name: Jon
by brookefox » Wed Mar 28, 2012 11:08 pm
Thanks for the model, Jon. Why not post a pic?
~ Brooke
brookefox
- Name: Brooke
by Jonavery16 » Thu Mar 29, 2012 3:16 am
honestly, because I don't know how
Jonavery16
- Name: Jon
by Jonavery16 » Thu Mar 29, 2012 3:29 am
I don't know what I'm doing wrong...
Jonavery16
- Name: Jon
by brookefox » Thu Mar 29, 2012 5:21 am
Jonavery16 wrote:honestly, because I don't know how
Easy enough. Check here. viewtopic.php?f=81&t=25217
~ Brooke
brookefox
- Name: Brooke
by Jonavery16 » Thu Mar 29, 2012 6:08 am
Indeed that was easy... I was trying to link to Flickr and the image wasn't loading correctly. Thanks
Jonavery16
- Name: Jon
by brookefox » Fri Mar 30, 2012 11:52 pm
The image saves lazy guys from DL'ing a model without seeing it. Yours looks nice; maybe a little thin in the scroll back rest members? You've got the important to me interlock for breakdown / portability that the master's original post lacked. Perhaps we'll hear from him.
~ Brooke
brookefox
- Name: Brooke
by Dave R » Sat Mar 31, 2012 12:56 am
brookefox wrote:You've got the important to me interlock for breakdown / portability that the master's original post lacked. Perhaps we'll hear from him.
Are you referring to me as "the master"? Surely you jest. If you are, then, whatchoo talkin' 'bout, Willis? Mine has that interlock you are so infatuated with.
- Global Moderator
- License type: Pro
by Jonavery16 » Sat Mar 31, 2012 4:46 am
brookefox wrote:The image saves lazy guys from DL'ing a model without seeing it. Yours looks nice; maybe a little thin in the scroll back rest members? You've got the important to me interlock for breakdown / portability that the master's original post lacked. Perhaps we'll hear from him.
Yea, you're probably correct. It is only 1" as drawn.
Jonavery16
- Name: Jon
by brookefox » Sat Mar 31, 2012 5:24 am
Ah, there it is, probably from one of his lackeys. Still, thanks be to him. That kind of side interlock, though, might be subject to more twist/torque wear. I dunno, ain't got sperienze wot u gize got.
~ Brooke
brookefox
- Name: Brooke
by Jonavery16 » Sat Mar 31, 2012 5:42 am
Revised version: better suited for a more substantial "load"
Jonavery16
- Name: Jon
by Ad Machine » 5 minutes ago
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Ad Machine
- Robot
Return to Woodworking
