SketchUcation Premium Membership
Download Plug-In
Download Plug-In
Postby felipe.sabino » Thu Mar 08, 2012 11:19 pm
Hi all!
First, sorry about my english.
So, i have a site with some zipped components (.tar.gz) and i want to make a plug-in for download this components.
Actually my plug-in make the component download, but it's instable.
I using the follow code:
Code: Select all
def download_product_http(param_1,param_2,param_3,param_4,dialog,param_5)
Net::HTTP.start(RESTRICTED_HTTP_SERVER) { |http|       # SET HTTP SERVER FOR DOWNLOAD
response http.request_head(URI.escape(LINK))    # SET THE LINK AT THE HTTP SERVER
file_size response['content-length'].to_i       # FOR PROGRESS BAR
open(product_tar_gz_name"wb") { |file|
http.get(URI.escape(temp_link)) do |str|
file.write str
# CODE FOR INCREMENT PROGRESS BAR AT WEBDIALOG
This code works well for tar.gz files until 1 mb, when the size of the files exceeds 1 or 1.5 mb SKU crashes... i really dont know why...
I've tried using the "model.definitions.load_from_url(url,handler)" but this works only for SKP files.
I've looking for something more simple, someone with any idea?
Thanks.
Felipe
Reason: Wrapped the code sample in a [code] block
felipe.sabino
Re: Download Plug-In
Postby Dan Rathbun » Thu Mar 08, 2012 11:51 pm
Have you tried the new rbz (zip format,) to put the components in a subdir of "Plugins", then move them to another folder after the extension installer unzips them ??
User avatar
Dan Rathbun
Top SketchUcator
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: education
Level of SketchUp: Advanced
Postby felipe.sabino » Fri Mar 09, 2012 12:09 am
Dan Rathbun wrote:Have you tried the new rbz (zip format,) to put the components in a subdir of "Plugins", then move them to another folder after the extension installer unzips them ??
I do not know if I understand What you said, but here we go.
1 - I cant change the compress format of the components, there is to many components and is the default of my company.
2 - I've tried to download the file in the subdir "...\Google SkethUp8\Plugins\Components" for then move them to the correct folder, but the SKU still crashes while download is in progress..
felipe.sabino
Postby Dan Rathbun » Fri Mar 09, 2012 1:38 am
Have you tried using FTP protocol ??
See the Net::FTP standard library.
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby TIG » Fri Mar 09, 2012 11:04 am
Instead of trying to deflate the compressed file as it arrives and finding it exceeds some size limit for this... why not download the compressed files into a temporary folder then use a 'command-line' cmd type file to extract their contents [most decompression apps have command-line options]... finally move the extracted files to their final destination, and tidy up by erasing the unneeded compressed files and their temporary folder...
User avatar
Global Moderator
License type: Pro
SketchUp use: architecture
Postby felipe.sabino » Fri Mar 09, 2012 1:35 pm
Dan Rathbun wrote:Have you tried using FTP protocol ??
I have ftp implemented too.
I always try do download from http, if it fails then i try to download from ftp and it fails too. ( i cant use always ftp because in some client machines the ftp is blocked.)
The weird is because during the download, SKU crashes in a feel machines, not in all... In my machine for example its always well succeed
felipe.sabino
Postby Dan Rathbun » Fri Mar 09, 2012 2:16 pm
    Since he is using the extended Ruby libraries, with a full Ruby install...
    TIG wrote:Instead of trying to deflate the compressed file as it arrives ... why not download the compressed files into a temporary folder ...
    Net::FTP
    TIG wrote: ... then extract their contents ...
    Zlib
    TIG wrote: ... finally move the extracted files to their final destination, and tidy up by erasing the unneeded compressed files and their temporary folder...
    FileUtils
    User avatar
    Dan Rathbun
    Top SketchUcator
    License type: Pro
    by Ad Machine » 5 minutes ago
    Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
    Ad Machine
    Robot
    Return to Developers' Forum
    Who is online
    Users browsing this forum: Bing [Bot], bomastudio and 6 guests
