[Plugin] RoundCorner - v2.3a - 26 May 11Re: [Plugin] RoundCorner - v2.3a - 26 May 11How do I get round corner to do this? I thought it would be easy but there are problems.
Not sure where you want to have the roundings. But it globally works for me (with 1/2"), except in the sharp angle where you may need to reshape locally a la mano. Fredo Please, register (free) to access all the attachments on the forums.
Re: [Plugin] RoundCorner - v2.3a - 26 May 11Thanks Fredo! I was tring to do a 1" radius initially them gave up. I selected the entire chair because I want all edges to be 1" radius. I see your back edge is not rounded. How did you get it to work? I get the red dot in the corner. How do you fix this?
Most probably, 1" is too large for the rounding in the sharp angle. Remember that this is pure geometry. If you wish to round the edges with any size, you should use another method, for instance Smooth & Divide in Artisan (by Whaat). Fredo
Re: [Plugin] RoundCorner - v2.3a - 26 May 11I keep getting this error message.
Error Loading File __loader.rb undefined method `effective_load' for nil:NilClass
Re: [Plugin] RoundCorner - v2.3a - 26 May 11This is what i was trying to attempt.
http://www.youtube.com/watch?v=3niDglAR ... re=related
Re: [Plugin] RoundCorner - v2.3a - 26 May 11im on a mac. i put it into the plugins folder also downloaded the Libfredo but still didnt have the panels even in s7 or s8.
pls help, where is the problem? thx
same issue for me on skp pro 6 & 7... any solutions ?
Re: [Plugin] RoundCorner - v2.3a - 26 May 11finally worked for me. I unzipped files in the wrong folder
Re: [Plugin] RoundCorner - v2.3a - 26 May 11How can i see the lines after rounding edges? Here in the pic i've rounded the circle edge but can't see the lines so i have no orientation.
Re: [Plugin] RoundCorner - v2.3a - 26 May 11These edges get automatically softened. You can see (and manipulate) softened (and hidden) edges if you turn on hidden geometry under the View menu.
Re: [Plugin] RoundCorner - v2.3a - 26 May 11Thanks a lot
Really an excellent plugin!
Re: [Plugin] RoundCorner - v2.3a - 26 May 11HI! I recently downloaded your plugin but cant seem to get it to work. the icons show in the menu and i can click them but i get an error in the ruby console. I have windows and sketchup 8.3117. I made sure i put the folders where they belong as I have with other plugins. is their a compatability issue? thanks!
Error: #<NoMethodError: undefined method `+' for nil:NilClass> C:/PROGRA~2/Google/GOOGLE~2/Plugins/MatchboxPlugin/Population.rb:174:in `+' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Config.rb:148:in `selected_folders' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:432:in `picture_selected_folders' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:1095:in `create_cursor' C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:66:in `initialize' C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:42:in `new' C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:42:in `launch' C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:33:in `action__mapping' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:132:in `call' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:132:in `launch_action' C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/bootstrap_RoundCorner.rb:143:in `launch_action' C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/bootstrap_RoundCorner.rb:159:in `startup' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:973:in `call' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:973:in `command_invoke' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:955:in `build_config_commands' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Traductor.rb:948:in `call' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Traductor.rb:948:in `add_command' C:/PROGRA~2/Google/GOOGLE~2/Plugins/MatchboxPlugin/Population.rb:174:in `call' C:/PROGRA~2/Google/GOOGLE~2/Plugins/MatchboxPlugin/Population.rb:174
Re: [Plugin] RoundCorner - v2.3a - 26 May 11There is a known conflict between Matchbox and other plugins (among which mine), because Matchbox redefines some basic Ruby classes.
There may be a version of Matchbox correcting this issue. Fredo
Re: [Plugin] RoundCorner - v2.3a - 26 May 11Hi there. I installed what I believe to be the most up to date version of the plugin. I'm using Sketchup 8 pro on a Mac Lion. I tried the plugin on what something that had around 50 edges. Sketchup froze. Tried it a few times actually and every time, it would get to a different point. 90%, 10%, 40% complete. I then tried it on a simple cube. Same problem. I then tried it on one face. 4 edges. same problem. sketch up freezes. does any one have any idea what the problem is and how i can fix it? thanks in advance?
Re: [Plugin] RoundCorner - v2.3a - 26 May 11What version of LibFredo6 are you running?
In which folders have you installed the plugin and library? Chris
Re: [Plugin] RoundCorner - v2.3a - 26 May 11I have the same problem with crash issue. I use Win XP SP 3 with skethup 8. I'm using 2 GB RAM. everytime I applied round corners, my sketchup always crash and shut down. I've tried every setting, it didn't work. Is there any way to solve this problem? I'm totaly confused, whether my XP had something wrong or my Sketchup? thanx for respond.
Jeem
Just happen to see this in passing: 1) The way the windows 32 bit memory manager works it splits the memory somewhat equally between the kernel and the program. In addition any device memory ( graphics etc) gets mapped into that a subtracts form the usable memory. Check you task manager and think you will find low memory. Check what you have set for the paging file size and the memory manager will use the hard disk to help that problem but then the PC slows down because of the slower disk. IMO you should install more RAM if possible and is not hard to do just make sure you use an anti static strap.
Just in case, could you open the Ruby console in case messages are displayed when running RoundCorner. There are a few plugins that create incompatibility problems (for instance some versions of Matchhbox and SunPosition). This may also be a source of problem. Fredo
Re: [Plugin] RoundCorner - v2.3a - 26 May 11I too have this problem. Lion 10.7.3 - SU v8. Latest Plugins too. Please help
Re: [Plugin] RoundCorner - v2.3a - 26 May 11 only one thing: thank you its amazing
I have found the fourth icon.I have found the fourth icon.
Download the attachment and think about. Please, register (free) to access all the attachments on the forums.
Re: [Plugin] RoundCorner - v2.3a - 26 May 11Hello, I have a problem.
Does the corner have to be at a 90 degree angle, or can it be any angle? Because when I try to do it at a non-90 degree angle it goes crazy and does this: I am running windows 7, 32bit. I have 2048mb RAM. All help is appreciated Please, register (free) to access all the attachments on the forums.
Re: [Plugin] RoundCorner - v2.3a - 26 May 11Could you post the model, so that we can find out. I guess this could be done piece by piece (plus duplication x6, as the wheel is symmetrical) Fredo
Re: [Plugin] RoundCorner - v2.3a - 26 May 11Yes, all parts of the model are symmetrical. All i need is to smooth every edge and make smooth transitions between parts.
here is a link: http://www.sendspace.com/file/1s2pol
There are several problems with the model: 1) you have hidden internal faces at the ends of the branches of the steering wheel. This is why you cannot select some edges. 2) most corners have 4 edges, and their configurations seems to reach the limit of RoundCorner (4 edges and more are supported, but the algorithm is not very robust) I think you have to either do the roundings manually or reconsider the design to have corners with 3 edges or try a subdivision with Whaat's Artisan. Fredo
Re: [Plugin] RoundCorner - v2.3a - 26 May 11Thank you Bro, i am going to fix it manually doing one branch separately and copy as you said. Could you tell me how can i check if my models have hidden internal faces?
Re: [Plugin] RoundCorner - v2.3a - 26 May 11If you make a group and in the entity info box, you cannot see "solid", there may be internal faces (but other errors can also cause this)
You can also use this plugin to remove them: viewtopic.php?t=12668 Gai...
Re: [Plugin] RoundCorner - v2.3a - 26 May 11It seems to be very useful plugin, thank you Gai. Im gonna try it out.
SketchUcation One-Liner AdvertsAre you a Premium Member? Get your freebies here. Are you not> a Premium Member yet? Upgrade your account to grab these freebies instantly.
