SketchUcation Plugin Store
[Plugin] RoundCorner - v2.3a - 26 May 11
Re: [Plugin] RoundCorner - v2.3a - 26 May 11
Postby lapx » Fri Feb 03, 2012 11:59 pm
How do I get round corner to do this? I thought it would be easy but there are problems.
lapx
Postby Fredo6 » Sat Feb 04, 2012 9:31 am
lapx wrote:How do I get round corner to do this? I thought it would be easy but there are problems.
Not sure where you want to have the roundings. But it globally works for me (with 1/2"), except in the sharp angle where you may need to reshape locally a la mano.
Fredo6
Top SketchUcator
Postby lapx » Mon Feb 06, 2012 6:11 pm
Thanks Fredo! I was tring to do a 1" radius initially them gave up. I selected the entire chair because I want all edges to be 1" radius. I see your back edge is not rounded. How did you get it to work? I get the red dot in the corner. How do you fix this?
lapx
Postby Fredo6 » Mon Feb 06, 2012 9:51 pm
lapx wrote:Thanks Fredo! I was tring to do a 1" radius initially them gave up. I selected the entire chair because I want all edges to be 1" radius. I see you back edge is not rounded. How did you get it to work? I get the red dot in the corner. How do you fix this?
Most probably, 1" is too large for the rounding in the sharp angle. Remember that this is pure geometry. If you wish to round the edges with any size, you should use another method, for instance Smooth & Divide in Artisan (by Whaat).
Fredo6
Top SketchUcator
Postby Royal_RnR » Tue Feb 07, 2012 4:40 pm
I keep getting this error message.
Error Loading File __loader.rb
undefined method `effective_load' for nil:NilClass
Royal_RnR
Postby lapx » Wed Feb 08, 2012 5:30 am
This is what i was trying to attempt.
http://www.youtube.com/watch?v=3niDglAR ... re=related
lapx
Postby TitusKraken » Wed Feb 08, 2012 5:27 pm
im on a mac. i put it into the plugins folder also downloaded the Libfredo but still didnt have the panels even in s7 or s8.
pls help, where is the problem?
thx
TitusKraken
Postby Dimethil » Mon Feb 13, 2012 2:37 pm
TitusKraken wrote:im on a mac. i put it into the plugins folder also downloaded the Libfredo but still didnt have the panels even in s7 or s8.
thx
same issue for me on skp pro 6 & 7... any solutions ?
Dimethil
Postby Dimethil » Mon Feb 13, 2012 3:19 pm
finally worked for me. I unzipped files in the wrong folder
Unzip the folder you downloaded.
Move both things inside that folder (another folder called ROUNDCORNER_Dir_xx and a file called ZLoader_Roundcorner.rb) into your Plugins folder.
Make sure you have the latest version of LibFredo6 installed, too (there should be a link to it on the same download page.) It contains things that all of Fredo6’s scripts need to work. Download and unzip it, then move its contents (a folder called LIBFREDO6_Dir_xx and a file called LibFredo6.rb) into your Plugins folder.
Dimethil
Postby katarakt » Sat Feb 18, 2012 7:00 pm
How can i see the lines after rounding edges? Here in the pic i've rounded the circle edge but can't see the lines so i have no orientation.
katarakt
Postby Gaieus » Sat Feb 18, 2012 7:15 pm
These edges get automatically softened. You can see (and manipulate) softened (and hidden) edges if you turn on hidden geometry under the View menu.
User avatar
Administrator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Level of SketchUp: Advanced
Postby katarakt » Sat Feb 18, 2012 7:59 pm
Thanks a lot :)
Really an excellent plugin!
katarakt
Postby eyein12 » Wed Feb 29, 2012 3:45 am
HI! I recently downloaded your plugin but cant seem to get it to work. the icons show in the menu and i can click them but i get an error in the ruby console. I have windows and sketchup 8.3117. I made sure i put the folders where they belong as I have with other plugins. is their a compatability issue? thanks!
Error: #<NoMethodError: undefined method `+' for nil:NilClass>
C:/PROGRA~2/Google/GOOGLE~2/Plugins/MatchboxPlugin/Population.rb:174:in `+'
C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Config.rb:148:in `selected_folders'
C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:432:in `picture_selected_folders'
C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:1095:in `create_cursor'
C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:66:in `initialize'
C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:42:in `new'
C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:42:in `launch'
C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:33:in `action__mapping'
C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:132:in `call'
C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:132:in `launch_action'
C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/bootstrap_RoundCorner.rb:143:in `launch_action'
C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/bootstrap_RoundCorner.rb:159:in `startup'
C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:973:in `call'
C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:973:in `command_invoke'
C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:955:in `build_config_commands'
C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Traductor.rb:948:in `call'
C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Traductor.rb:948:in `add_command'
C:/PROGRA~2/Google/GOOGLE~2/Plugins/MatchboxPlugin/Population.rb:174:in `call'
eyein12
Postby Fredo6 » Wed Feb 29, 2012 7:13 am
There is a known conflict between Matchbox and other plugins (among which mine), because Matchbox redefines some basic Ruby classes.
There may be a version of Matchbox correcting this issue.
Fredo6
Top SketchUcator
Postby nwarner33 » Thu Mar 01, 2012 3:19 pm
Hi there. I installed what I believe to be the most up to date version of the plugin. I'm using Sketchup 8 pro on a Mac Lion. I tried the plugin on what something that had around 50 edges. Sketchup froze. Tried it a few times actually and every time, it would get to a different point. 90%, 10%, 40% complete. I then tried it on a simple cube. Same problem. I then tried it on one face. 4 edges. same problem. sketch up freezes. does any one have any idea what the problem is and how i can fix it? thanks in advance?
nwarner33
Postby chrisjk » Thu Mar 01, 2012 3:55 pm
What version of LibFredo6 are you running?
In which folders have you installed the plugin and library?
chrisjk
Postby kubusipit » Sun Mar 04, 2012 11:31 am
I have the same problem with crash issue. I use Win XP SP 3 with skethup 8. I'm using 2 GB RAM. everytime I applied round corners, my sketchup always crash and shut down. I've tried every setting, it didn't work. Is there any way to solve this problem? I'm totaly confused, whether my XP had something wrong or my Sketchup? thanx for respond.
Jeem
kubusipit
Postby mac1 » Sun Mar 04, 2012 6:50 pm
kubusipit wrote:I have the same problem with crash issue. I use Win XP SP 3 with skethup 8. I'm using 2 GB RAM. everytime I applied round corners, my sketchup always crash and shut down. I've tried every setting, it didn't work. Is there any way to solve this problem? I'm totaly confused, whether my XP had something wrong or my Sketchup? thanx for respond.
Jeem
Just happen to see this in passing:
1) The way the windows 32 bit memory manager works it splits the memory somewhat equally between the kernel and the program. In addition any device memory ( graphics etc) gets mapped into that a subtracts form the usable memory. Check you task manager and think you will find low memory. Check what you have set for the paging file size and the memory manager will use the hard disk to help that problem but then the PC slows down because of the slower disk. IMO you should install more RAM if possible and is not hard to do just make sure you use an anti static strap.
mac1
Top SketchUcator
Postby Fredo6 » Sun Mar 04, 2012 10:11 pm
Jeem
Just in case, could you open the Ruby console in case messages are displayed when running RoundCorner.
There are a few plugins that create incompatibility problems (for instance some versions of Matchhbox and SunPosition). This may also be a source of problem.
Fredo6
Top SketchUcator
Postby chalky » Wed Mar 28, 2012 10:30 am
I too have this problem. Lion 10.7.3 - SU v8. Latest Plugins too. Please help :(
chalky
Postby sketchdraw » Thu Apr 12, 2012 4:32 pm
:berserk:
only one thing: thank you
its amazing
sketchdraw
I have found the fourth icon.
Postby bagatelo » Sat Apr 14, 2012 3:13 am
Download the attachment and think about.
User avatar
bagatelo
SketchUp version: 8
License type: Pro
SketchUp use: interior design
Level of SketchUp: Intermediate
Postby janmakowka » Sun Apr 15, 2012 2:54 pm
Hello, I have a problem.
Does the corner have to be at a 90 degree angle, or can it be any angle? Because when I try to do it at a non-90 degree angle it goes crazy and does this:
I am running windows 7, 32bit. I have 2048mb RAM. All help is appreciated :)
janmakowka
Postby MaciejS » Tue Apr 17, 2012 4:35 pm
Hello Everybody
I tried that tool on my model but it doest work correctly, does anybody have an idea what should i do to make all edges and corners smooth ? Help please
MaciejS
Postby Fredo6 » Tue Apr 17, 2012 5:50 pm
MaciejS wrote:Hello Everybody
Could you post the model, so that we can find out.
I guess this could be done piece by piece (plus duplication x6, as the wheel is symmetrical)
Fredo6
Top SketchUcator
Postby MaciejS » Tue Apr 17, 2012 7:35 pm
Yes, all parts of the model are symmetrical. All i need is to smooth every edge and make smooth transitions between parts.
here is a link: http://www.sendspace.com/file/1s2pol
MaciejS
Postby Fredo6 » Tue Apr 17, 2012 8:37 pm
MaciejS wrote:Yes, all parts of the model are symmetrical. All i need is to smooth every edge and make smooth transitions between parts.
There are several problems with the model:
1) you have hidden internal faces at the ends of the branches of the steering wheel. This is why you cannot select some edges.
2) most corners have 4 edges, and their configurations seems to reach the limit of RoundCorner (4 edges and more are supported, but the algorithm is not very robust)
I think you have to either do the roundings manually or reconsider the design to have corners with 3 edges or try a subdivision with Whaat's Artisan.
Fredo6
Top SketchUcator
Postby MaciejS » Tue Apr 17, 2012 9:59 pm
Thank you Bro, i am going to fix it manually doing one branch separately and copy as you said. Could you tell me how can i check if my models have hidden internal faces?
MaciejS
Postby Gaieus » Tue Apr 17, 2012 10:18 pm
If you make a group and in the entity info box, you cannot see "solid", there may be internal faces (but other errors can also cause this)
You can also use this plugin to remove them:
viewtopic.php?t=12668
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby MaciejS » Tue Apr 17, 2012 11:22 pm
It seems to be very useful plugin, thank you Gai. Im gonna try it out.
MaciejS
by Ad Machine » 5 minutes ago
Artisan Organic Toolset - a set of powerful organic modeling tools.
Premium Members get 20% discount!
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: CrashZero81, dickh4rp3r, KlausM, Mallawere, rudran, slimwirotsi and 5 guests
