SketchUcation Premium Membership
[Plugin] 2D Tools v5.3 20120929
Re: [Plugin] 2D Tools v5.1 20111201
Postby 3dDetailer » Thu Dec 29, 2011 6:10 pm
For example you want to use 0.25 how would it know that you weren't done typing at 0.2 - it's waiting for an <enter>
DOH
!! :oops: As a long time detailer...I should have instinctively known that. I discovered it shortly after I posted my question. Sorry bout that TIG.
And btw, I don't have time to read this entire thread in one sitting.
And I probably couldn't remember everything even if I could. :mrgreen:
So that brings me to another question. I tried to find an answer by searching a few tags..but I didn't find it.
Question. When I "place" a 2d Text entity on a model face, just like if you draw an entity on the face of another, the entities are "co-planar". That results in a visual anomaly where, depending on how you view the entities, one or the other will be predominant, or one will partially show, but as you move your view, it changes. Is there something in the tool set or variables whereby when you "place" the text, it "removes" the same area on the face of the other entity within the boundaries of the Text, or something to that effect? When I place 3d text, it somehow hides the plane of the entity on which it is placed, within the boundaries of the text itself. AND, you can see it on both faces of the entity. I hope that makes sense.
Anyway, thanks for the reply.
fitZ
3dDetailer
Postby TIG » Thu Dec 29, 2011 7:48 pm
A piece of 2dText is actually made ~1mm above the face it glues onto.
This is to avoid 'z-fighting'.
Is there another problem ?
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby 3dDetailer » Fri Dec 30, 2011 1:18 am
Gotcha! I see that now. cool.
Well, there might be Give me a day or two to find one. :mrgreen: I'm learning this tool set slowly but surely.
Anyway, thanks Tig.
3dDetailer
Postby Fletch » Mon Jan 09, 2012 4:42 am
Fantastic job on this set of tools. They are an "essential set" IMHO for any architect using SU.
Thank you so much for sharing this.
Fletch
Twilight Render
Postby 3dDetailer » Mon Jan 09, 2012 6:52 pm
Ok, I admit it took longer than a day or two, but that's due to searching for an answer over the last week, and putting up with the problem until I could find a solution.
So, I beg your indulgence. When I fillet a set of lines, a "tic" mark appears at the center of the chosen radius. I can erase each one, but it's time consuming. Is there a way of either hide them, or erase all at the same time...or a tic "parameter" of some kind I'm not aware of yet? Again, I haven't had time to read the entire thread, but I did a search for a solution but didn't find any.
:thumb: Ditto. Thanks a mill for these tools. Just gotta learn to use them correctly. :oops:
Fantastic job on this set of tools. [/quote]
3dDetailer
Postby d12dozr » Mon Jan 09, 2012 7:12 pm
3dDetailer wrote:...When I fillet a set of lines, a "tic" mark appears at the center of the chosen radius. I can erase each one, but it's time consuming. Is there a way of either hide them, or erase all at the same time...
I have the "Delete Guides" shortcut command set to "D" on my keyboard...takes a split sec to delete all of 'em when you're done
"There is a man in the world who will never be turned down... he is the man who delivers the goods."
d12dozr
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: product design
Postby Dave R » Mon Jan 09, 2012 7:17 pm
And if you don't want to set a keyboard shortcut, go to Edit>Delete Guides. I have a keyboard shortcut set, too and use it frequently.
Inspecting mirrors is a job I could easily see myself doing.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Postby TIG » Mon Jan 09, 2012 8:38 pm
There are even specialist script-tools to erase cpoints, but not clines, and vice versa..
You can also hide [all] guide-geometry too using appropriate settings...
The reason the cpoint appears at the fillet-arc's center is that often you want a reference to it later on....
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby 3dDetailer » Mon Jan 09, 2012 9:48 pm
:shock: good grief. I guess I should spend more time exploring the default tools in Sketchup. Never saw that. :oops: AND setting up some shortcuts too.
Thanks a mill!
Hmmmm, "cpoints". So that's what you call them huh. Cool. I searched for "tic" marks. Should have known they'd be called something related to Cartesian space ...or something to that effect. Ok, thanks for the info guys. I know all these solutions are probably in the thread, and I hate asking you to spend more of your time to explain something that you've already explained somewhere. So, I mucho appreciate it!
3dDetailer
Postby TIG » Mon Jan 09, 2012 9:52 pm
In the 'early days' they were always called 'cpoints' and 'clines' [they still are in the API code!] but some Google genius a few versions ago decided to rename then 'guide-points' and 'guide-lines'... so watch for oldies/codies using the old names... ;)
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby 3dDetailer » Tue Jan 10, 2012 6:49 am
Ok, now I get it. And thanks for sharing your knowledge Tig.
fitZ
oh, btw, here's the reason I was looking for a solution. There were so many filets in this group all the cpoints were distracting. And this is only one of many sets of cables.
What's odd..is the cpoints disappear sometimes. Can't figure that one out either.
And btw, I would never done this had it not been for your filet tool, and the "Line into Tube" plugin. They work great together. :thumb: Thanks again for the info. Every little bit helps.
ooops. I completely forgot. Your 2d text works sublime. The only thing I was wondering is editing a copy of a 2d text. They act like components. If I change one..it changes the original. Can you "make unique" them somehow? That would be phenomenal. Then I could drag a copy along an axis..and edit it. Sure would save a bunch of time. Anyway, thanks a million for this one too!! :berserk:
3dDetailer
Postby TIG » Tue Jan 10, 2012 6:03 pm
You should be able to copy any 2dText Component Instance and then Select it and right-click context-menu > 'Make-Unique'... Thereafter it should '2dText Edit' as a separate thing...
It can also be useful to have several Instances, because you can Edit one to affect all; it depends on what you want.
The 'Entity Info' window will show the number of Instances of a Selected Component - useful in case you are unsure about its 'uniqueness'...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby 3dDetailer » Tue Jan 10, 2012 6:14 pm
:shock: OMG! I could have sworn I tried that. Ok cool, I'll check that out immediately!
I LIKE IT! :sketchstatic:
Dang I wish there was a "facepalm" smiley. :mrgreen: (note to self: file under.. "more reasons to spend some time looking at default Sketchup tools) :lol:
Ok Tig, you made my day. No more questions for at least a week. :D
oh, btw
er...isn't that an oxymoron? :mrgreen:
3dDetailer
Postby Edson » Tue Jan 24, 2012 11:18 pm
hi TIG,
forgive me if this question has been asked before but the only problem I have with 2D Tools is the win/mac equivalence (or lack of it) between some keystrokes. to be more precise, what keys should i press on my mac to get the same result as when pressing control and alt in windows?
best regards.
edson mahfuz, architect
http://www.mahfuz.arq.br
Anyone can get you more for more, but it takes genius to get you more for less.
User avatar
Edson
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby TIG » Tue Jan 24, 2012 11:26 pm
Edson wrote:hi TIG,
best regards.
There IS a MAC compliant set of tools posted by Michaelv - viewtopic.php?p=377902#p377902
It's NOT PC friendly... one day I will combine them both, but meanwhile his set is the best for you MAC users... It's currently identical to the PC version, BUT with different key-bindings...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Edson » Wed Jan 25, 2012 11:48 am
TIG wrote:
Edson wrote:hi TIG,
best regards.
tig,
many thanks to you for the tool and michaelv for the mac fix. it works beautifully now! :ecstatic:
User avatar
Edson
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Wed Jan 25, 2012 12:06 pm
I must around to merging them... one day :roll:
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby ygcl » Tue Feb 07, 2012 6:04 am
THANKS TIG,DOWNLOAD IT.
ygcl
Postby jowers125 » Mon Feb 13, 2012 6:28 am
Great plugin! I am having trouble with the fillet tool though. Every time I click on the second line, it deletes the 2 lines and any objects connected to them. Can anybody help??
jowers125
Postby TIG » Mon Feb 13, 2012 11:38 am
jowers125 wrote:Great plugin! I am having trouble with the fillet tool though. Every time I click on the second line, it deletes the 2 lines and any objects connected to them. Can anybody help??
Every time ??? :?
Can you try it with the Ruby Console open and report any errors.
What have you set the fillet radius to ?
Do the lines meet at a corner as an L or a T or have a gap?
Are the lines Coplanar?
Are the lines forming a Face?
etc
Without details it's difficult to say what's up.
Can you post a simple SKP where you are having this issue, and explain exactly the steps you take to get this disastrous result...
It works fine for me - see this rectangular 'donut' - the only extra step I needed to sort this were on the 'hole' - erasing the inner face that was made automatically as those corners were filleted...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby 3dDetailer » Thu Feb 16, 2012 8:37 pm
I'm not sure, but it seems to me the first time I tried using the plugin, I didn't realize the "radius" input was defaulted to ZERO, and if memory serves me, my lines disappeared too. Might check it out.
3dDetailer
Postby TIG » Thu Feb 16, 2012 8:46 pm
With a zero radius the lines should trim or extend à la ACAD...
Nothing should disappear [except the unwanted lines parts] !
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby huckrorick » Sat Feb 18, 2012 1:14 am
Wow! This is really a great set of tools. Just now testing them out. I'm trying to think of some way to tell you how neat these are.
Thanks. Congratulations.
Huck
huckrorick
Postby guanjin » Fri Feb 24, 2012 7:21 am
Hello!2D tool V5.1 is not continuous picture fill! You can not select another picture!
User avatar
guanjin
SketchUp version: 8
License type: Free
SketchUp use: interior design
Level of SketchUp: Intermediate
Postby TIG » Fri Feb 24, 2012 11:16 am
When the 2dHatching tool is active right mouse-click in open space [away from any objects] and the dialog should pop-up to let you change the PATTern...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby horst_horst_horst » Fri Feb 24, 2012 12:39 pm
This is really great! thanx so much!
horst_horst_horst
Postby guanjin » Fri Feb 24, 2012 4:31 pm
TIG wrote:When the 2dHatching tool is active right mouse-click in open space [away from any objects] and the dialog should pop-up to let you change the PATTern...
TIG Thank you, I see! :berserk:
User avatar
guanjin
SketchUp version: 8
License type: Free
Re: [Plugin] 2D Tools v5.2 20120228
Postby TIG » Tue Feb 28, 2012 4:06 pm
Here's v5.2 viewtopic.php?p=185760#p185760
The 2dFillet tool has its segment range adjusted, >=2 <=999.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby brookefox » Sat Mar 10, 2012 12:01 am
(My) Bad case of the stupids, perhaps. I tried to scale the hatch jpgs larger so as to fit my larger scale project but am having no success...
Image shows your original size on the right and two attempts to enlarge it, the wrong one having the higher DPI (300) and the one I thought would work which looks the same as the other two. As can be seen, they all look alike. Note 'print size' from DPI varies from 2 to 9.7 to 30.4 inches.
~ Brooke
User avatar
brookefox
SketchUp version: 8
License type: Free
Postby TIG » Sat Mar 10, 2012 12:11 am
The Hatching materials made that use the PATT files always use the same standard size texture, ignoring the actual resolution of the image file itself, so changing it has no affect.
If you want a bigger texture repeat you must edit the material after it's been made... and change the size of the texture in the edit window.
Then double the size, doubles the repeat size...
Once you have some materials with the size of repeats you want save those as external SKMs into a 'library' in the 'Materials' folder...
NOW later on when you want to use that size textured material in a new SKP use that SKM from the 'library' and they'll have the size you've set...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
by Ad Machine » 5 minutes ago
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: Esan256, Gábor, kalespace, mbouchard, nicasiojoel, tosiharuk, wvularc, zabzabou and 12 guests
