SketchUcation Plugin Store
introduction+some help needed:)
Welcome! Ask and get answered - or just introduce yourself.
Postby lamesh99 » Mon Feb 20, 2012 12:36 pm
hello, everyone! my name is marko, i am from croatia. i normally use SU for my hobby, which is CNC machining. now, since it is only a hobby, i use the free version of the software. nevertheless, i am VERY satisfied with the simplicity, intuitiveness and usefulness of the SU.
i am having some trouble, though. i have been trying to model myself a small lathe chuck for the past few days, but with little luck. the item i am having problems with is the screwplate, the part which turns and contracts or expands the jaws. essentialy, the screwplate is the round plate with a central hole, one side is made like a gear, and the other one as a screw (photo will explain this a bit better, circled in red). can someone explain this, please? or even make a model, if not too much a problem.
lamesh99
Re: introduction+some help needed:)
Postby TIG » Mon Feb 20, 2012 1:20 pm
You need to get a Helix making script - try DrawHelix14...
The make a face perpendicular to the start of the helical curve and use FollowMe to make the spiral form...
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby lamesh99 » Mon Feb 20, 2012 2:12 pm
wow, that was fast. thanks for your reply! another thing, if i may bother you a bit further, how do i make the other side? other side needs to be like a horizontal screw, essentially lines (teeth) spread across the circle in an equal manner, if you understand me.
thanks again for your help! :thumb:
lamesh99
Postby lamesh99 » Mon Feb 20, 2012 2:31 pm
not sure if i made a mistake somewhere, or posts need to be approved :?:
anyways, thanks for a quick reply, You helped A LOT. if you can help me with one more thing: other side of the plate: how do i make a pattern like this? this is, essentially, a number of lines (extrusions) spread evenly over the circle, or the rim, not sure how to describe it (pic will say more).
thanks again!
lamesh99
Postby Gaieus » Mon Feb 20, 2012 2:46 pm
Best is to make a component of a "tooth" there and make a radial array.
If you hide some inner faces and matching edges, you can even get a smooth transition between the wheel and the teeth.
User avatar
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Postby lamesh99 » Tue Feb 21, 2012 8:20 am
thanks for all the help, guys! i made a model of my screwplate, i'll post it here so someone else can use it. one more question, how can i taper the top of the gears? i tried a bunch of plugins, but none of it seemed to work for me.
anyways, thanks for the help!
lamesh99
Postby TIG » Tue Feb 21, 2012 11:15 am
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby lamesh99 » Tue Feb 21, 2012 11:38 am
this looks great. how did you apply the tapers? i can't really tell from the pics. Thanks!
lamesh99
Postby TIG » Tue Feb 21, 2012 1:48 pm
I edited the one 'two-teeth-component' part.
I drew the edges and PushPulled the 'teeth' up - much as you had inside your groups.
I then used the Tapemeasure tool to offset guidelines [seen dotted] from the 4 edges inwards by 1mm [you choose what dimensions you want].
I then drew another line over each guideline on the top surface.
I then 'reformed' the teeth with tapers, one at a time.
I selected the unwanted edge [at the right-angled corner] and use the Move tool to relocate the edge over the line draw where I want the taper to end on the top face.
The vertical face slopes over with the moving edge that it's attached to, the end faces of the teeth also distort to follow the new tapered form as it then narrows near the top.
Completed the tapering for all 4 edges.
Note that there are several other ways of making these 'tapers', but this one is quite simple...
Finally Erased the guidelines and then exited the component edit.
Used Rotate+Ctrl x23 to make the copies of the component around the circle, snapping to the start/end of the two-teeth-component.
Note how adjusting one instance will change all the others at this stage...
Finally Explode the components into one collection [if you want]...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby lamesh99 » Tue Feb 21, 2012 8:32 pm
i did it like that exactly, but i obviously got it wrong somewhere. when i used move on the top lines, a part of the small plane on the outside rim of the tooth was erasde. i'll just keep trying:)
Thanks again for the help!
lamesh99
Postby lamesh99 » Tue Feb 21, 2012 9:21 pm
i got it right, finally:) thanks, again!
lamesh99
Postby Jean Lemire » Tue Feb 21, 2012 10:04 pm
Hi folks.
See this SU file for ideas.
The same principle could be used for tapered teet instead of pointed ones.
Jean (Johnny) Lemire from Richelieu, Quebec, Canada.
User avatar
Jean Lemire
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby lamesh99 » Tue Feb 28, 2012 2:10 pm
thanks for all the help!
one more thing is very interesting to me: SU physics. i would like to make a model with moving parts, hinges etc. any advices?
lamesh99
Postby mitcorb » Tue Feb 28, 2012 2:33 pm
Hi, lamesh:
You asked for advice regarding Sketchyphysics. My advice: Persevere. ;) Read the SP subforum, check out the FAQ, Watch the YouTube videos. Dive in, and ask questions. There are several folks with plenty of insight there.
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Level of SketchUp: Intermediate
by Ad Machine » 5 minutes ago
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
Return to Newbie Forum
Who is online
Users browsing this forum: dworki and 4 guests
