SketchUcation Premium Membership
Model and render this: Glass brick/block
Postby solo » Thu Feb 09, 2012 8:24 pm
Just a whim of an idea to kick start an easy challenge, model and render a glass block, sounds simple right?
And it is, but there are many ways to do this and lets see which works best and looks best.
Feel free to try anything, go simple, or go crazy detailed, have a simple clear one or patterned, choose heavy glass, clear glass or even frosted glass, just have fun.
My site
Quod gratis asseritur, gratis negatur.
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
Re: Model and render this: Glass brick/block
Postby solo » Thu Feb 09, 2012 10:17 pm
First go, I did this with just mesh, no bump, used Artisan to create inside warped mesh.
Quick Thea render, crepe myrtle tree behind used to show glass warping effect.
Click on image for larger view
My site
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby chedda » Fri Feb 10, 2012 7:26 am
Looks excellent Solo. Although they do repeat. You also need the mortar around the block.I guess my other thread is my submission for this challenge.
Kraken Wrangler
User avatar
chedda
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby oganocali » Fri Feb 10, 2012 2:03 pm
User avatar
oganocali
Postby solo » Fri Feb 10, 2012 2:30 pm
Ogan, Those are great but they are not glass blocks, but glass panes.
These are glass block sizes:
Inch sizes (actual dimensions, in inches)
5¾ × 5¾ × 3 7⁄8
7½ × 7½ × 3¼ or 4
7¾ × 7¾ × 3 7⁄8
9½ × 9½ × 3 1⁄8
11¾ × 11¾ × 3 7⁄8 or 4 inches
Metric sizes (nominal dimensions, in millimeters)
160 × 160 × 30
190 × 190 × 80 or 100
240 × 115 × 80
40 × 240 × 80
My site
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby oganocali » Fri Feb 10, 2012 2:35 pm
Oppps :oops: sorry.
Here is 160x160x30 mm version. vray bumpmapped pure glass with texcloth.
User avatar
oganocali
Postby Cyberdactyl » Fri Feb 10, 2012 4:23 pm
Hi everyone. As you explore refraction with your rendering software, I urge you to look at it deeper than merely the image you want from behind the glass.
Cyberdactyl
Postby Hieru » Fri Feb 10, 2012 5:04 pm
That's really interesting and gives me an idea for a scene/model/render.
User avatar
Hieru
Premium Member
Premium Member
SketchUp version: 8
License type: Free
Postby chedda » Sat Feb 11, 2012 7:24 pm
Here you go Solo, i polished it up a little but i still see geometry in the corners, meh good enough.
Kraken Wrangler
User avatar
chedda
SketchUp version: 8
License type: Pro
Postby Hieru » Sat Feb 11, 2012 8:00 pm
Looking really good :thumb:
You know you've been overdoing it in Sketchup when the first thing you do when looking at a render is try and orbit to get another view - doh!
User avatar
Hieru
Premium Member
Premium Member
SketchUp version: 8
License type: Free
Postby chedda » Sat Feb 11, 2012 8:28 pm
Thanks Hieru , CG produces strange effects in operators, I get quite introverted I need the radio to stay sane. I had strange scenarios in the outside world after too much battlefield (PS3)
Kraken Wrangler
User avatar
chedda
SketchUp version: 8
License type: Pro
Postby jpalm32 » Sun Feb 12, 2012 3:09 pm
Pittsburg Glass has SU components & SW for this.
jpalm32
Premium Member
Premium Member
Postby dale » Mon Feb 13, 2012 2:31 am
Took a stab at it, and it had some definite challenges.
But it was fun.
Glass block via Artisan. Rendered in Thea.
Just monkeying around....
User avatar
dale
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby stefanq » Mon Feb 13, 2012 11:32 am
I did a render long time ago, but I didn't used a glass brick model. It's just a wall( probably out of scale) but it worked for me. Here is the rendering, and the textures I used:
User avatar
stefanq
SketchUp version: 8
License type: Free
SketchUp use: other
Postby chedda » Mon Feb 13, 2012 11:37 am
Looking good Dale ! Stefanq also good considering it's only textures, is it just 2 faces or do you have internal faces ? Thanks for the textures.
Kraken Wrangler
User avatar
chedda
SketchUp version: 8
License type: Pro
Postby Hieru » Mon Feb 13, 2012 1:59 pm
I'm still working on mine - I got distracted modelling this - but there are some really ingenious texture only solutions over at the Thea forum.
User avatar
Hieru
Premium Member
Premium Member
SketchUp version: 8
License type: Free
Postby dale » Mon Feb 13, 2012 3:58 pm
Thanks chedda.
I also played with this diamond block, but abandoned it as I wanted to "suggest"the figure in the shower, and the diamonds just refracted the image too much.
Even the one posted above is not quite subtle enough.
Too me this is where it got interesting as using a straight thin glass was too clear, and using a clear glass material had mixed results. I ended up adding a thin film layer in Thea.
Hope I get more time to play on this as it is an interesting challenge depending on what you want too see through the refractions.
Here is the diamond block image, and the .skp if anybody can ever use it.
Glass Block Diamond.skp
And here is the wave style.
User avatar
dale
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby dale » Mon Feb 13, 2012 4:02 pm
Hieru wrote:I'm still working on mine - I got distracted modelling this - but there are some really ingenious texture only solutions over at the Thea forum.
Seriously cool lamp! Hope you finish the model.
I wonder how using textures v/s modeling mesh alters refracted images behind the block. hmmmm...
Hope to get some time to play.
User avatar
dale
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby solo » Thu Feb 16, 2012 8:58 pm
Another one, this time I used a scene provided by TomDC, first is the original render (Thea BSD) with only one light source (open door) HDRI and second is when a wall is replaced with Glass bricks, incredible amount of light gets sucked through glass wall.
My site
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby TomDC » Thu Feb 16, 2012 9:10 pm
The first one has issues (then, so do I ;) ), but the second one looks great. How long did these render for?
Bill Maher on the French: "They invented sex during the day, lingerie and the tongue."
TomDC
Postby solo » Thu Feb 16, 2012 9:18 pm
The first one rendered for 12 minutes plus some change at 1200x600 default BSD settings
The second was 33 minutes with a different preset (one of my optimised for thick glass interiors)
My site
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby TomDC » Thu Feb 16, 2012 11:10 pm
I'm rendering this interior with TR1 as we speak. At 6000 pixels wide and supersampling set at 'High'. :mrgreen:
Wonder how long that one'll take. :shock: Ah, if only unbiased rendering were fast -we'd never have to worry about thresholds and the like again. ;)
TomDC
Postby solo » Thu Feb 16, 2012 11:17 pm
Yikes dude! That's an overkill, I'd suggest rendering at size needed and at normal super sampling, that will give a great result, or even high super sampling if you want perfection, but 6000 is crazy.
Unbiased is fast, if you have enough cores or a render farm. :mrgreen:
My site
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby TomDC » Thu Feb 16, 2012 11:26 pm
solo wrote:Yikes dude! That's an overkill, I'd suggest rendering at size needed (...)
That is the size needed. It's a test to see how fast TR1 can deliver me images for printing. And er, you're speaking to someone who's rendered as wide as 20000. :twisted:
TomDC
Postby solo » Thu Feb 16, 2012 11:31 pm
Have you got one of those pesky 24 core 100 plus GB ram rigs? as 20000 wide it beyond anything i could imagine, planning to put a render on the side of a building?
My site
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby TomDC » Thu Feb 16, 2012 11:36 pm
Nope, same old Mac Pro. A test I did a few years back.
TomDC
Postby Hieru » Thu Feb 16, 2012 11:40 pm
The other week I tried a 6000px by 3000px TR1 (high supersampling) render for a 360x180 panorama test. I gave up after 12 hours and realised that I needed to get my head around biased render settings.
Luckily your interior with thick glass preset worked really well Solo. And back on topic - really nice scene. Would be perfect if you randomly rotated and reversed some of the blocks for variation.
I can't wait to get back on track with my scene, but this week has been hell :cry: .
User avatar
Hieru
Premium Member
Premium Member
SketchUp version: 8
License type: Free
Postby notareal » Sat Feb 18, 2012 10:14 am
Supersamling high is good if you are going to render something to HD sizes or smaller. Not much use with high resolution renders used in posters or if you going to down scale them later. Perhaps some high precession printing can benefit from it.
notareal
Thea Render
Postby Hieru » Tue Feb 21, 2012 9:45 pm
I still haven't had chance to do much work on this, but here's a quick teaser of one of the elements I want to use in conjunction with the glass blocks.
User avatar
Hieru
Premium Member
Premium Member
SketchUp version: 8
License type: Free
Postby sepo » Wed Feb 22, 2012 10:18 pm
Very nice feel to the render...but what happened to caustics? Shouldn't be some on the floor, right?
sepo
SketchUp version: 8
License type: Pro
by Ad Machine » 5 minutes ago
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Ad Machine
Robot
Next
Return to Gallery
Who is online
Users browsing this forum: sfto1 and 2 guests
