SketchUcation Plugin Store
plugin for model comments/notes?
To access this forum when logged in, please, sign up to the Woodworking User Group in your User Control Panel.
Postby fishboat » Sat Jan 28, 2012 5:17 pm
I've looked around a little and haven't found anything...is there a plugin (I assume) that allows you to make notes about details of a model inside a model? I'm thinking an option under the Plugins menu "Notes" that pops up a small text box where you can type in some comments..."this version of the model updates/changes the side apron length to......etc.."
thx..
fishboat
Re: plugin for model comments/notes?
Postby Dave R » Sat Jan 28, 2012 6:09 pm
Welcome FB.
Are you looking for something that would show up on screen in the model? For that you could use leader text or screen text. Or you could add text in the Description section for components or groups in the Entity Info box. I don't know of any specific plugins for this sort of thing.
Inspecting mirrors is a job I could easily see myself doing.
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Level of SketchUp: Advanced
Postby fishboat » Sat Jan 28, 2012 7:06 pm
Hi Dave, thanks..
I'm thinking just a general text box that you could get to popup within the model to enter/display notes about the model. I typically have(make via save as) serial versions of models as I make changes, but don't want to lose the previous model-version. I suspect you do the same. Obviously a new version was needed due to making some changes..but what were the changes? This is the text I'd enter in the text box within the model, rather than rely on memory over 5-6 versions(which doesn't work when time passes..like a day :-).
Other software I use at work has general "notes" options and I've gotten use to using them. I'm not seeing the option in SU..anyone want to write a script? (not I skill I have at the moment)
fishboat
Postby TIG » Sat Jan 28, 2012 7:09 pm
ToDoList http://www.smustard.com/script/ToDoList
For $8 could do what you want... and more ?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby fishboat » Sat Jan 28, 2012 8:25 pm
Says it only works for SU6..I'd hate to spend $8 to find out it doesn't work in SU8 & beyond (not a lot of money, but a rather pointless way to flush $8)
fishboat
Postby Gaieus » Sat Jan 28, 2012 9:07 pm
It's an old plugin. When it was made, that notice meant that it only works with SU 6 (not earlier versions). True that they should update the site once in a while.
You can send a Private Message to Rick, the author, and ask about it.
User avatar
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Postby david. » Sun Jan 29, 2012 6:06 pm
The feature you're looking for is already included. From the menu, select "Window->Model Info". From the list in the dialog, click on "File". Then, you'll see a "Description" box. This text will be saved with the model.
david.
Postby Box » Sun Jan 29, 2012 6:10 pm
Not to mention simply inserting text into your model with the text tool.
Opinions are like wives.
Those found on the internet have been known to contain varying traces of nuts!
User avatar
SketchUp version: 8
License type: Free
SketchUp use: other
Level of SketchUp: Intermediate
Postby fishboat » Sun Jan 29, 2012 7:12 pm
Everything is easy if you know how. I see how it works now..thx for the help!
(I've only been using SU for a couple weeks.)
fishboat
Postby Dave R » Sun Jan 29, 2012 9:58 pm
And what I've seen of what you've done has been pretty good.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
by Ad Machine » 5 minutes ago
Artisan Organic Toolset - a set of powerful organic modeling tools.
Premium Members get 20% discount!
Ad Machine
Robot
Return to Woodworking
cron
Who is online
Users browsing this forum: No registered users and 2 guests
