SketchUcation Premium Membership
Mysterious Bug [followme related]
Postby Chris88 » Tue Jan 17, 2012 1:35 pm
Hi all,
i have this code (i know it looks confusing, because i don't know
how to program the 'followme'-function, but it's not the problem)
Code: Select all
 module LineA
  def LineA.create_line
  unless Sketchup.active_model;
    until Sketchup.active_model.active_entities
    model = Sketchup.active_model
    entities = model.active_entities
    # Add the group to the entities in the model
    group = entities.add_group
    # Get the entities within the group
    entities2 = group.entities
    @width_small = 55 # 55
    @depth_small = 45 # 45
    @height_small = 30 # 30
    @width_big = 70 # 70
    @depth_big = 60 # 60
    @height_big = 70 # 40
    @height_line = (4/3) * @height_small
    @radius = 1
    @arcradius = 3
    @mat_linie=model.materials.add("Material_Linie")
    @mat_linie.color=Sketchup::Color.new(124,252,0)  # => LawnGreen
    @anzahl_arcs = ((@depth_small-6)/6).to_i
    @pts =[]
    @helpvar_depth = 3
    @helpvar_pts = 1
    @helpvar_baseline = 1
    @helpvar_basearc = 1
    1.upto(@anzahl_arcs) do |x|
      @helpvar2_pts = @helpvar_pts +1
      if (x%2 > 0)
        @pts[@helpvar_pts] = [((@width_big-@width_small)/2)+5.35, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
        @pts[@helpvar_pts+1] = [@width_small+((@width_big-@width_small)/2)-5.3, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
        # arc_point
        @pts[@helpvar_pts+2] = [@width_small+((@width_big-@width_small)/2)-5, ((@depth_big-@depth_small)/2)+(@helpvar_depth+3), @height_line]
        arc_circle_odd = entities2.add_circle @pts[@helpvar_pts+1], X_AXIS, @radius, 42
        arc_circle_face_odd = entities2.add_face arc_circle_odd
        arc_circle_face_odd.material = @mat_linie
        arc_circle_face_odd.back_material = @mat_linie
        line_circle_odd = entities2.add_circle @pts[@helpvar_pts], X_AXIS, @radius, 42
        line_circle_face_odd = entities2.add_face line_circle_odd
        line_circle_face_odd.material = @mat_linie
        line_circle_face_odd.back_material = @mat_linie
        @helpvar_baseline_odd = entities2.add_line @pts[@helpvar_pts], @pts[@helpvar_pts+1]
        @helpvar_basearc_odd = entities2.add_arc @pts[@helpvar_pts+2],[0,-1,0],[0,0,1],@arcradius,-5.degrees,185.degrees
        arc_circle_face_odd.followme @helpvar_basearc_odd
        line_circle_face_odd.followme @helpvar_baseline_odd
      elsif (x%2 == 0)
        @pts[@helpvar2_pts-1] = [((@width_big-@width_small)/2)+5.3, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
        @pts[@helpvar2_pts] = [@width_small+((@width_big-@width_small)/2)-5.35, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
        # arc_point
        @pts[@helpvar2_pts+1] = [((@width_big-@width_small)/2)+5, ((@depth_big-@depth_small)/2)+(@helpvar_depth+3), @height_line]
        arc_circle_even = entities2.add_circle @pts[@helpvar2_pts-1], X_AXIS, @radius, 42
        arc_circle_face_even = entities2.add_face arc_circle_even
        arc_circle_face_even.material = @mat_linie
        arc_circle_face_even.back_material = @mat_linie
        line_circle_even = entities2.add_circle @pts[@helpvar2_pts], X_AXIS, @radius, 42
        line_circle_face_even = entities2.add_face line_circle_even
        line_circle_face_even.material = @mat_linie
        line_circle_face_even.back_material = @mat_linie
        @helpvar_baseline_even = entities2.add_line @pts[@helpvar2_pts], @pts[@helpvar2_pts-1]
        @helpvar_basearc_even = entities2.add_arc @pts[@helpvar2_pts+1],[0,1,0],[0,0,1],@arcradius,-5.degrees,185.degrees
        arc_circle_face_even.followme @helpvar_basearc_even
        line_circle_face_even.followme @helpvar_baseline_even
      end # if
       if (x == @anzahl_arcs)
        @pts[@helpvar_pts] = [((@width_big-@width_small)/2)+5.35, ((@depth_big-@depth_small)/2)+(@helpvar_depth+6), @height_line]
        @pts[@helpvar_pts+1] = [@width_small+((@width_big-@width_small)/2)-5, ((@depth_big-@depth_small)/2)+(@helpvar_depth+6), @height_line]
        @helpvar_baseline_ende = entities2.add_line @pts[@helpvar_pts], @pts[@helpvar_pts+1]
        line_circle_face_odd.followme @helpvar_baseline_ende
      end # if
      @helpvar_depth = @helpvar_depth + 6
      @helpvar_pts = @helpvar_pts + 3
    end # upto - do
  end # def
end # module
LineA.create_line
When i execute it in SU there's no error, but if i load it in the plugins of SU,
the hole SU break down and show me a 'Bug Splat', however no significant error message.
I hope you can help me.
Chris88
Re: Mysterious Bug
Postby thomthom » Tue Jan 17, 2012 1:42 pm
Code: Select all
unless Sketchup
.active_model;
What is this strange loop?
Is it that you try to make it run when SU starts? I see you have this line at the end: LineA.create_line
Why do you have that strange loop?
Have you tried without it?
I'd be very surprised if that lop doesn't block up all processing of SketchUp.
If that isn't the issue - have you tried commenting out blocks of your code to see when it does not crash? When it doesn't then you know the offending line is within that block and you can narrow down further.
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: Mysterious Bug
Postby Chris88 » Tue Jan 17, 2012 2:10 pm
the strange loop ist an advice of TIG... http://forums.sketchucation.com/viewtopic.php?f=180&t=41767,
it makes sure that all services of SU are loaded succesfully.
it runs also without this loop.
And i have commenting out all loops and many lines, but i didn't found the failure.
It's strange that i can run the script succesfully in SU, this bug is only when loading the script out of the plugins or starting SU per cmd with the script as parameter.
(P.S. i have SU 8 free version)
Chris88
Re: Mysterious Bug
Postby thomthom » Tue Jan 17, 2012 2:14 pm
Chris88 wrote:this bug is only when loading the script out of the plugins
What you explain what you mean by this?
Chris88 wrote:It's strange that i can run the script succesfully in SU
I'm confused - is it when the script is located in another location? Or if you load the script manually via the Ruby Console?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Re: Mysterious Bug
Postby TIG » Tue Jan 17, 2012 2:17 pm
I can't start to guess why you might want always to do this weirdness at every startup - for example, why make geometry that might clash with existing stuff etc... why not simply load a premade component, or make a new template containing the desired stuff as the default for your new SKPs ???
Also do you have require 'sketchup.rb' at the very start of the script ?
It might be needed somewhere in your code :?
Your [my :oops: ] code
Code: Select all
is wrong.
It waits until the model.active_entities exist before continuing, BUT it only does the pause if there is NOT an active_model ?
Therefore it never pauses because the active_model always exists as it is loading the script's code, although the active_entities might not [on a MAC for example]...
Try
Code: Select all
    ### wait
which WILL wait until there's both an active_model and it has active_entities...
ALSO , as I suggested in that other thread... why not encapsulate your 'loose' code in a 'timer' which waits a few seconds before kicking off, like this:
UI.start_timer(2.0, false){LineA.create_line}
This lurks for 2.0 seconds after the script loads before doing its dirty deeds...
Then most things will have 'passed' before it works...
http://code.google.com/apis/sketchup/do ... tart_timer
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Re: Mysterious Bug
Postby Chris88 » Tue Jan 17, 2012 2:40 pm
@thomthom: i can start successfully the script in SU per Ruby Code Editor or per Sketchup Bridge in RDE to test it. The error appears when i copy my script in the plugin-folder, load it from ruby console in SU or start SU per cmd and assign my script as parameter in the cmd.
@TIG: thanks for your corrected code and suggestion, but it doesn't solve the bug. And i don't 'understand' your first lines: "make a new template containing the desired stuff as the default" ... and it shouldn't be premade components (that's was my first attempt :( )
Chris88
Re: Mysterious Bug
Postby TIG » Tue Jan 17, 2012 2:55 pm
Why make all of the complex geometry in a new group every time ?
Make it as a SKP, load that as a component, and add an instance of it inside a new group's entities, and explode the instance, then erase all of the just loaded component's definition's entities and it is removed from the model [provided there's a start/commit_operation around the actions]... That way you don't need to 'code' the making of the object and it's still inside a group as you have now AND there's no new component been added to the model...
IF you explained what it is you are attempting to 'automate' then we might have more insight... :?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Re: Mysterious Bug
Postby thomthom » Tue Jan 17, 2012 2:55 pm
Maybe we need to take a step back. What is the overall goal of what you are making?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Re: Mysterious Bug
Postby Chris88 » Tue Jan 17, 2012 3:12 pm
The course of action of my program, which conduces to woodworking:
in C#:
- read technical values out of xml-files
- generate a rubyscript for every object
(tool, wood, machining line,...) in .txt- format
- replace the wildcards (i.e: width,height,depth of a wooden box)
- put all rubyscripts together an name the file xy.rb
- start Sketchup with the file xy.rb as argument
... and my code is all but finished, when i start SU with the file xy.rb it crashes and SU reports a "bug splat"
http://images.wikia.com/sketchyphysics/images/6/63/BugSplat.png
Chris88
Re: Mysterious Bug
Postby Chris88 » Tue Jan 17, 2012 3:14 pm
So because i'm almost at the end of coding my program, i actually don't want to modify the rubyscript, that it loads premade components.
Chris88
Re: Mysterious Bug
Postby thomthom » Tue Jan 17, 2012 3:18 pm
Right. And I understand that it crashes when you start SU with an argument to execute that plugin? Correct?
But not if start SketchUp and use the Ruby Console to load it?
If the plugin is located in the plugin folder - does it crash then?
This is what is unclear to me.
<- I don't understand what you mean there. "out of the plugins"?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Re: Mysterious Bug
Postby Dan Rathbun » Tue Jan 17, 2012 3:20 pm
    Try it like this:
    Code: Select all
    module Chris88
      module LineA
        TIMER = nil
        def self.create_line()
          # delete lines 1-4 with loop
          begin
            model.start_operation( 'LineA' )
            # the rest of your method code
          rescue => e
            model.abort_operation
            puts("#{Module.nesting[0].name} Error #<#{e.class.name}: #{e.message}>")
            puts(e.backtrace)
          else
            model.commit_operation
        end # def
      end # module LineA
      # run when file loads
      if Sketchup.active_model &&
        LineA.create_line
      else
        LineA::TIMER = UI.start_timer(2.0, true){
            UI.stop_timer(LineA::TIMER)
            LineA.create_line
          end #if
    end # module Chris88
    Your modules need to be wrapped inside your "author" outer module.
    User avatar
    Dan Rathbun
    Top SketchUcator
    SketchUp version: 8
    License type: Pro
    SketchUp use: education
    Re: Mysterious Bug
    Postby Chris88 » Tue Jan 17, 2012 3:29 pm
    @thomthom: Correct. And yes, it crashes if it's located in the plugin-folder, too.
    And it doesn't matter, if i load the script with the Ruby Console or if i start SU normally and the script is in the plugin-folder.
    @Dan: Thanks Dan! I will test it in a few minutes...
    Chris88
    Re: Mysterious Bug
    Postby thomthom » Tue Jan 17, 2012 3:47 pm
    I tried the code you posted initially. I get no crash. I did however leave out LineA.create_line so that it would not execute when SU loaded.
    I called the method afterwards in SU.
    Sidenote - it seems that you create the profile for your shape (the circle) many times. Many small segments for what is in reality one single tube. As you can see- you end up with gaps where the straight sides meets the arced corners.
    You would avoid that by making the tube as you would in SU. Making one single path, and one profile - then using follow me only once for the whole shape.
    Should make a cleaner geometry, be faster and simplify the code.
    User avatar
    Global Moderator
    SketchUp version: 8
    License type: Pro
    Re: Mysterious Bug
    Postby thomthom » Tue Jan 17, 2012 3:48 pm
    Oh yea - as Dan suggested with his code. several operations should be wrapped in .start_operation - .commit_operation so it produces only one undo step. And if you use the disable_ui argument it should run faster.
    User avatar
    Global Moderator
    SketchUp version: 8
    License type: Pro
    Re: Mysterious Bug
    Postby Dan Rathbun » Tue Jan 17, 2012 3:53 pm
    thomthom wrote:I tried the code you posted initially. I get no crash. I did however leave out LineA.create_line so that it would not execute when SU loaded.
    Yea, it's dangerous to do stuff during SU load, as all the Google extensions are not yet loaded like Dynamic Components.
    User avatar
    Dan Rathbun
    Top SketchUcator
    SketchUp version: 8
    License type: Pro
    Re: Mysterious Bug
    Postby Dan Rathbun » Tue Jan 17, 2012 3:57 pm
    maybe a wait timer like this is safer...
    Code: Select all
        UI.start_timer(0.0, false){ LineA.create_line }
      else
            LineA.create_line
          end #if
    User avatar
    Dan Rathbun
    Top SketchUcator
    SketchUp version: 8
    License type: Pro
    Re: Mysterious Bug
    Postby Chris88 » Tue Jan 17, 2012 4:02 pm
    @Dan: Thank you. Now my code looks like:
    Code: Select all
    module Chris88
      module LineA
        TIMER = nil
           # alle Objekte die den entities2 zugeordnet werden, werden automatisch zu einer gemeinsamen Gruppe gemacht
          begin
            @radius = 1
            @arcradius = 3
            @pts =[]
            @helpvar_depth = 3
            @helpvar_pts = 1
           if (x%2 > 0)
            # arc_point
          elsif (x%2 == 0)
            # arc_point
          end # if
          end # if
        end # upto - do
          rescue => e
            puts(e.backtrace)
          else
        end # def
      end # module LineA
        LineA.create_line
      else
            LineA.create_line
          end #if
    Is this what do you mean?
    However it doesn't solve the bug.
    @thomthom: Thanks, that could help me. I know this, what you wrote in your sidenode, but it didn't work: When i draw a circle and a path, which starts at the central point of the cricle, Sketchup draw only the lines, but not the curves. This is why i decided alternatively to draw the lines and the curves seperately. Do you think the gaps could be the reason for the bug?
    Chris88
    Re: Mysterious Bug
    Postby Chris88 » Tue Jan 17, 2012 4:10 pm
    Dan, i have to correct myself: It works, when i load the script from the Ruby Console = step forward! :D [Edit:] i just noticed, this is what thomthom meant. :cry: [/Edit]
    But it doesn't work yet, when i want to load the script from the plugin-folder by starting SU normally and the script is located in the plugin-folder.
    Chris88
    Re: Mysterious Bug
    Postby thomthom » Tue Jan 17, 2012 4:21 pm
    Chris88 wrote:Do you think the gaps could be the reason for the bug?
    Don't think so. Just a sidenote. It is possible to create that shape in one operation.
    User avatar
    Global Moderator
    SketchUp version: 8
    License type: Pro
    Re: Mysterious Bug
    Postby Dan Rathbun » Tue Jan 17, 2012 4:32 pm
    Alright replace the load loop with this ...
    Code: Select all
      prevdir = Dir.getwd
      Dir.chdir Sketchup.find_support_file("Tools")
      tools = Dir["*.rb"]
      Dir.chdir(prevdir)
      if ( tools & $LOADED_FEATURES == tools ) &&
        UI.start_timer(2.0, false){ LineA.create_line }
      else
        timer_LineA = UI.start_timer(2.0, true){
            UI.stop_timer(timer_LineA)
            LineA.create_line
          end #if
      tools = nil
    User avatar
    Dan Rathbun
    Top SketchUcator
    SketchUp version: 8
    License type: Pro
    Re: Mysterious Bug
    Postby Dan Rathbun » Tue Jan 17, 2012 4:39 pm
    And here's a version that makes sure the Tool Stack is ready ...
    Code: Select all
      prevdir = Dir.getwd
      tools = Dir["*.rb"]
      Dir.chdir(prevdir)
      Sketchup.active_model.active_entities &&
      Sketchup.active_model.tools.active_tool_id != 0
      else
            LineA.create_line
          end #if
      tools = nil
    User avatar
    Dan Rathbun
    Top SketchUcator
    SketchUp version: 8
    License type: Pro
    Re: Mysterious Bug
    Postby TIG » Tue Jan 17, 2012 4:46 pm
    Let's step back to the very beginning...
    Do you need this script to run automatically EVERY time EVERY SKP opens?
    A. Yes.
    Why for goodness sake ???
    A. No.
    Then what's the problem?
    If it runs from a menu/toolbar then everything will be loaded by the time you think about using it anyway. Just do NOT include the code that runs it as it loads and everything is cushty!
    User avatar
    Global Moderator
    SketchUp version: 8
    License type: Pro
    Re: Mysterious Bug
    Postby Dan Rathbun » Tue Jan 17, 2012 4:52 pm
    Because he's generating ruby scripts (that build geometry,) from a C# program, which reads XML data.
    A batch mode use of Sketchup.
    He's not that good with Ruby, or else he could use Ruby's XML libraries directly.
    And I do have an API request in for an AppObserver "onReadyState" callback method.
    User avatar
    Dan Rathbun
    Top SketchUcator
    SketchUp version: 8
    License type: Pro
    Re: Mysterious Bug
    Postby thomthom » Tue Jan 17, 2012 4:56 pm
    Well, I tried the snippet - installed in my Plugins folder - now executing the command. It splatted. But wrapping the command in a timer that delay the operation with two seconds - no splat.
    User avatar
    Global Moderator
    SketchUp version: 8
    License type: Pro
    Re: Mysterious Bug
    Postby Dan Rathbun » Tue Jan 17, 2012 5:02 pm
    The processing of the Tools dir must complete, so that the menus and toolbars can all be built and displayed.
    User avatar
    Dan Rathbun
    Top SketchUcator
    SketchUp version: 8
    License type: Pro
    Re: Mysterious Bug
    Postby TIG » Tue Jan 17, 2012 5:06 pm
    Isn't he doing it arse-before-face as we say in the UK ?
    Open Sketchup.
    Start_operation.
    Run the external 'tool'...
    Load the objects in turn, each one as an individual component.
    When all objects are done Export those objects in turn as separate SKPs.
    Abort_operation.
    Close Sketchup [no save].
    That way nothing relies on something else 'opening in time' ?
    User avatar
    Global Moderator
    SketchUp version: 8
    License type: Pro
    Re: Mysterious Bug
    Postby Dan Rathbun » Tue Jan 17, 2012 5:54 pm
    TIG wrote:Isn't he doing it arse-before-face as we say in the UK ?
    We'll, he knows C#, and not much of Ruby.
    Instead of using Sketchup in a hacked batchmode... he or someone needs to wrap the C++ Interfaces for SKPWriter.DLL for C#. (Likely someone has already done it.) Any way it would be better to directly create skps.
    User avatar
    Dan Rathbun
    Top SketchUcator
    SketchUp version: 8
    License type: Pro
    Re: Mysterious Bug
    Postby Chris88 » Wed Jan 18, 2012 8:38 am
    THANKS to all for your efforts!
    Now it works!!! :berserk: it's slower than before, but it runs and that's the main thing!
    @Dan: Thank you, you're the best! ^^
    Chris88
    Re: Mysterious Bug
    Postby Dan Rathbun » Fri Jan 20, 2012 2:41 pm
    No problem...
    Just a note that the disposal of the tools filename array needs to be inside the conditional true blocks. (Otherwise we might get an error with the & method if tools gets set to nil, prematurely.)
    Code: Select all
      prevdir = Dir.getwd
      tools = Dir["*.rb"]
      Dir.chdir(prevdir)
      prevdir = nil
        tools = nil
      else
            tools = nil
            LineA.create_line
          end #if
    User avatar
    Dan Rathbun
    Top SketchUcator
    SketchUp version: 8
    License type: Pro
    by Ad Machine » 5 minutes ago
    Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
    Premium Members get 20% discount!
    Ad Machine
    Robot
    Return to Developers' Forum
    Who is online
    Users browsing this forum: bpl-rfe, imaeda, takashioda and 5 guests
