SketchUcation Plugin Store
[Plugin] Project Beam (Update)
Postby sdmitch » Sun Jan 15, 2012 6:54 pm
Yes, an update already. Made changes so that the face defining the cross-section of the beam is truly projected first. Faces projected to or from do not have to be vertical. If projection is not possible then the beam is made the length of the direction edge.
viewtopic.php?f=79&t=42527&p=378752#p378752
If you need to construct a beam between vertical faces along a inclined line, Followme insists on making the face perpendicular to the edge to be followed so the beam has square ends instead of the angled ones needed. Project Beam solves that problem by projecting the points of the face from one vertical face to the other using the edge to determine vector and distance.
http://sdmitch.blogspot.com/
User avatar
sdmitch
Operating system: Windows
SketchUp version: 8
License type: Free/Make
SketchUp use: hobby
Level of SketchUp: Beginner
Re: [Plugin] Project Beam
Postby Dave R » Sun Jan 15, 2012 7:57 pm
Sweet! I can see a number of uses for this. Thank you.
Inspecting mirrors is a job I could easily see myself doing.
User avatar
Global Moderator
SketchUp version: 2013
License type: Pro
SketchUp use: woodworking
Level of SketchUp: Advanced
Postby g_wilson » Sun Jan 15, 2012 9:10 pm
Oh Darn - only works in two cases for me. If two faces are parallel to each other and Z plane - one above the other and the "to be" projected shape is drawn on the lower face with line at any angle drawn to the higher face - then it works. Second case if lower face is parallel to Z plane but higher face is tilted at some angle;"to be" projected shape drawn on lower face;line drawn to higher tilted face - it works. Third case - two parallel faces one above the other - shape to be projected drawn on higher face - line drawn down to lower face - projected shape goes UP proper distance - not DOWN to lower face. Fourth case (actually two cases) - two vertical parallel faces - to be projected shape drawn on either vertical face - lines drawn between vertical faces - both of these draw projected shape (as face only but with shape at both ends as part of that face) perpendicular to vertical faces (same plane). SU 8 and XP SP3 if it matters - and all kinds of plugins - no sketchyphysics no driving dimensions plugin.
g_wilson
SketchUp version: 8
SketchUp use: engineering and mechanical design
Level of SketchUp: Intermediate
Postby g_wilson » Sun Jan 15, 2012 9:31 pm
Double darn - case 2 doesn't work - tried several times again to be sure - doesn't work. Confuses me.
g_wilson
SketchUp version: 8
Postby pbacot » Sun Jan 15, 2012 9:52 pm
Both end faces of the final shape will be parallel to the original face that is extruded. I don't find a restriction on the orientation to axes so far.
I think the direction the edge is drawn (away from the face) is the direction the beam is made.
User avatar
Top SketchUcator
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby sdmitch » Sun Jan 15, 2012 10:15 pm
The edge should always be drawn from the selected face to the opposite end of the beam. The faces projected from and projected to are assummed to be parallel in the current version.
User avatar
sdmitch
SketchUp version: 8
SketchUp use: hobby
Postby g_wilson » Sun Jan 15, 2012 10:46 pm
sdmitch wrote:The edge should always be drawn from the selected face to the opposite end of the beam. The faces projected from and projected to are assummed to be parallel in the current version.
Yes,that's what I am doing. Forgetting non-parallel faces;as far as parallel faces are concerned - it still does the same - even with an enormous horizontal offset. Only works with two parallel faces,one above the other;shape on lower face draw edge up to higher face. Does not work doing the opposite way - shape on higher face,draw edge down to lower face - result here is still shape is drawn up not down. It obviously works,but for whatever mystery,not for me. I start with "clean sheet" BTW. Tried in existing model as well - same thing.
g_wilson
SketchUp version: 8
Postby boilingsnow » Sun Jan 15, 2012 11:19 pm
Very nice. sdmitch.
But I have to say some other existing plugins do the same work. Such as "pushpull faces along vector" in the Projection toolbar of D. Bur (was a standalone plugin "pushpull tool" since sketchup 4).
Or "vector pushpull" in the "Joint Pushpull" toolbar of Fredo6...
boilingsnow
Re: [Plugin] Project Beam (Update)
Postby sdmitch » Mon Jan 16, 2012 1:51 am
g_wilson, Please download and try the new version. When I created the plugin, I tested it only to satisfy the criterior of the requestor. The new version corrects the problem caused by non-parallel faces. The only problem that I'm aware of at the moment is when the selected face only partially falls on the face projected to.
boiling, yes I am constantly re-inventing the wheel. Case in point TIG's Extrude Edges by Vector and Extrude Edges by Vector to Object.
viewtopic.php?t=25362
User avatar
sdmitch
SketchUp version: 8
SketchUp use: hobby
Postby g_wilson » Mon Jan 16, 2012 10:08 pm
sdmitch wrote:g_wilson, Please download and try the new version. When I created the plugin, I tested it only to satisfy the criterior of the requestor. The new version corrects the problem caused by non-parallel faces. The only problem that I'm aware of at the moment is when the selected face only partially falls on the face projected to.
Congratulations Sir. It works without fail.
All previous problems gone. Even tried - two faces at some compound angle two each other with one face "square" to the world and with edge at some compound angle - it works no matter which face you start from. Nastiest example I can manage - two faces both nonplanar to each other and the world and edge at some random angle in all planes- it still works. One little oddity cropped up - using a hexagon it works but tells you that it can't match opposite face,will draw to length given by edge - no problem. But with a circle it DOES cope into the finishing face as long as the edge is within some small angle to one plane (XYZ) - just bloody wonderful if working with pipe or similar!! Great job !! Thank you !!
g_wilson
SketchUp version: 8
Postby sdmitch » Tue Jan 17, 2012 3:35 pm
g_, the message you mentioned should only occur if the projected face does not completely fall on the face being projected to. It's an all or none.
User avatar
sdmitch
SketchUp version: 8
SketchUp use: hobby
Postby boilingsnow » Tue Jan 17, 2012 10:48 pm
sdmitch wrote:boiling, yes I am constantly re-inventing the wheel. Case in point TIG's Extrude Edges by Vector and Extrude Edges by Vector to Object.
We should thank you as all the other authors here for creating useful plugins and share them with us.
I also tried to download all your plugins on your website. :fecstatic:
But I find a problem as well. Did anyone tell you that you uploaded the video tutorial for "snappoint" twice and forgot to upload the plugin itself?
boilingsnow
Postby sdmitch » Wed Jan 18, 2012 3:45 am
No you're the first. Thanks.
User avatar
sdmitch
SketchUp version: 8
SketchUp use: hobby
Postby raineysky » Wed Jan 18, 2012 10:22 am
Awesome plugin!!! Thank You Sam
***Please keep, "re-inventing the wheel". Your plugins are great.***
raineysky
SketchUp version: 8
License type: Pro
SketchUp use: other
by Ad Machine » 5 minutes ago
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: adrianro, CADragon, Darkshining, Google Feedfetcher, mateoep and 11 guests
