SketchUcation Plugin Store
frontside and backside colour
Postby ChrisKa » Sun Jan 15, 2012 9:33 am
Hello,
if I import a COLLADA-File I can change the (frontside) colour with the following Code:
Sketchup.active_model.active_entities.each{|e|e.material="green"};
I want to do the same with the backside of the areas, but this Code doesn't work:
Sketchup.active_model.active_entities.each{|e|e.back_material="green"};
Can somebody help me why this Code doesn't work?
Thanks,
ChrisKa
Re: frontside and backside colour
Postby thomthom » Sun Jan 15, 2012 11:54 am
You're getting errors, right?
Only faces have the .back_material method - so when you iterate a whole entity collection you're also iterating over edges, guides etc. You need to ensure you're applying back material to only faces.
If that is not the case - then you need to provide more info on what you are doing and exactly what "isn't working". (Errors or unexpected results. Sample models help.)
User avatar
Global Moderator
Name: Thomas Thomassen
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby ChrisKa » Sun Jan 15, 2012 12:15 pm
Hy thomthom,
this is my COLLADA-File: COLLADAfile.zip
The frontside colour I can change. This you can see on the file "change_frontside_colour.jpg".
And now my problem is that I can't change the backside colour!
"change_backside_colour_ERROR.jpg"
Thanks a lot for your help,
ChrisKa
ChrisKa
Postby thomthom » Sun Jan 15, 2012 12:27 pm
That is it - you are trying to call .back_material on a ComponentInstance.
You need to ensure you got a Face.
Sketchup.active_model.active_entities.each{|e|e.back_material="green" if e.is_a?(SketchUp::Face)};
But note that if the geometry of yours is inside a group or component your code won't dig into the nested groups/components. As you have the code now, the currently active context (open component) must be the one containing the faces.
User avatar
Global Moderator
License type: Pro
Postby ChrisKa » Sun Jan 15, 2012 12:46 pm
Sorry, but I don't understand.
Do you mean that I have to explode the component for working this code.
Is there a possibility that I can change the backside-colour inside the component like the frontside-colour?
ChrisKa
Postby thomthom » Sun Jan 15, 2012 12:55 pm
For that simple example you provided you only need to open the component before you run the script.
But I don't know the bigger context where you use this.
Here is a snippet that process the entire model:
Code: Select all
# Process entities in the root model context
for e in Sketchup.active_model.entities
  next unless e
  e.material="green"
# Process all groups and components
for d in Sketchup.active_model.definitions
  next if d
.image?
  for e in d.entities
    next unless e
    e.material="green"
User avatar
Global Moderator
License type: Pro
Postby ChrisKa » Sun Jan 15, 2012 4:23 pm
I would like to import the COLLADA-File with the "Ruby-Console".
The code should be in one line.
Do you have an idea?
Thanks,
ChrisKa
Postby TIG » Sun Jan 15, 2012 6:13 pm
Your code currently makes everything in the model.active_entities have the specified material.
Because the imported geometry arrives inside a component your code gives that material to the instance - NOT its contents.
Faces inside a component [or group] that have no material applied to them [front or back] will initially show in the default material.
Then if you give the 'container' a material then those faces will be displayed as if they had that material, BUT they are actually still in the default material.
If you want to give a material to the faces inside a component you need to use something like this.
Assuming that you want every face in the model to use that material...
Sketchup.active_model.definitions.each{|d|next if d.image?; d.entities.each{|e|next unless e.class==Sketchup::Face; e.material="green"; e.back_material="green"}}
To ALSO process any faces in the model's entities use this:
Sketchup.active_model.entities.each{|e|next unless e.class==Sketchup::Face; e.material="green"; e.back_material="green"}
You can obviously mess around with materials and so on...
You could even limit the change to the imported component [its component name ISN'T the same as the dae file so we must get all components before we start and then find which one was [or ones were] added by the import]...
ds=Sketchup.active_model.definitions.to_a; ###add your importer code here...; ds=Sketchup.active_model.definitions.to_a-ds;###ds is an array of just the imported component[s]; ds.each{|d|d.entities.each{|e|next unless e.class==Sketchup::Face; e.material="green"; e.back_material="green"}}
:geek:
User avatar
Global Moderator
License type: Pro
Postby ChrisKa » Sun Jan 15, 2012 8:26 pm
Thanks a lot for your help.
Now this code is very helpful for me!
ChrisKa
ChrisKa
by Ad Machine » 5 minutes ago
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: No registered users and 3 guests
