[Plugin] Angular Dimension
• Page 1 of 3 • 1, 2, 3
[Plugin] Angular DimensionThis tool is an extensive rewrite and enhancement of the idea from Didier Bur's dim_angle.rb. It draws angular dimensions onto a SketchUp model. Changes from Bur's original include:
- user input of desired radius of angle arc, modifiable after drawing until next angle is started or another tool is selected - user selection of inside (<180) or outside (>180) angle, with cursor indication of mode, modifiable after drawing until next angle is started or another tool is selected - packaging of drawn elements into a named Group - undo capability - clockwise vs counterclockwise selection order does not matter To install, download and unzip the attached file in your Plugins directory. [edit] The original version works for Windows but has issues on a Mac. Michaelv and Driven worked on it to make it compatible. If you have a Mac, you should download the second version attached. [another edit] After finally getting my hands on a Mac, I discovered that the reason for all the struggling with the cursors is that on the Mac, SketchUp is not happy with the color profile info that my Windows pixel editor put into the png files. I opened them in an editor on the Mac, touched them and saved, and then they work. This is especially puzzling since other apps on the Mac are quite happy with these files, just not SketchUp! Anyway, those using Macs should load the final version that Michaelv attached to the last post in this thread. Get the latest version [PC/MAC] from the PluginStore Last edited by slbaumgartner on Mon Nov 19, 2012 3:41 am, edited 3 times in total.
Re: [Plugin] Angular Dimensionhi,
it's holding on to the 'Orbit' or 'Pan' cursor if I use either between angles. it's own cursor comes back and functions, but is hidden behind the hand. I'm on a mac otherwise it appears to be working, well done. no error messages... john learn from the mistakes of others, you may not live long enough to make them all yourself...
Hmmm...it doesn't do that on my PC. I don't have a Mac to test on. Maybe someone in the group who has a Mac can help sort this out?
Re: [Plugin] Angular DimensionHi,
I just read your script and your cursors use all UPPERCASE which was actually failing gracefully, ie. '@cursor' not defined, but the tool still works. I had a look at your cursor images and see that they had never appeared. I'm getting the 'snap to' squares... I'll downcase the cursor names and see if that works, but I suspect 'Tab' key will be an issue on mac. john learn from the mistakes of others, you may not live long enough to make them all yourself...
That seems unlikely...all uppercase is pretty typical convention for constants in Ruby, and should have nothing to do with Mac vs PC. If you are finding @cursor not defined, that seems more likely a problem with the path to the icon files. Are they installed in Plugins/draw_dim_angle? Try this: open the Ruby Console window and type DrawAngleDimTool::IN_ICON into the input space. The output space should then display the path for interior.png. If the path is mangled or isn't where you installed the png image, that is the problem. You can also type DrawAngleDimTool::IN_CURSOR and you should get a number back, probably somewhere a bit more than 50000. If that doesn't work, SketchUp failed to load the image file. If you look at onKeyDown, there is a code snippet to print the keycode you get on the Mac. Please let me know what value you get and I'll see if I can code in a trap for PC vs Mac.
on closer inspection, everything seems fine? except the onKeyDown. EDIT: swapped from Tab to Esc and I still can't get outside dims or cursors very few ' onKeyDown' work on macs. here's a list from today. PLATFORM = i686-darwin8.10.1 SEQUENCE 0 of 5 [Function Keys] DN F2 Key 50 flags 0 rpt 1 UP F2 Key 50 flags 256 rpt 1 DN F3 Key 51 flags 0 rpt 1 UP F3 Key 51 flags 256 rpt 1 DN F6 Key 54 flags 0 rpt 1 UP F6 Key 54 flags 256 rpt 1 DN F12 Key 63243 flags 0 rpt 1 UP F12 Key 63243 flags 8388864 rpt 1 SEQUENCE 1 of 5 [Modifiers Keys] DN Shift alone Key 131072 flags 131330 rpt 1 UP Shift alone Key 131072 flags 256 rpt 1 DN Ctrl alone Key 262144 flags 262401 rpt 1 UP Ctrl alone Key 262144 flags 256 rpt 1 DN Alt alone Key 524288 flags 524576 rpt 1 UP Alt alone Key 524288 flags 256 rpt 1 DN Cmd alone Key 1048576 flags 1048840 rpt 1 UP Cmd alone Key 1048576 flags 256 rpt 1 SEQUENCE 2 of 5 [Arrow Keys] UP UP Key 63232 flags 10486016 rpt 1 UP RIGHT Key 63235 flags 10486016 rpt 1 UP DOWN Key 63233 flags 10486016 rpt 1 UP LEFT Key 63234 flags 10486016 rpt 1 SEQUENCE 3 of 5 [Validation Keys] DN RETURN Key 13 flags 0 rpt 1 UP RETURN Key 13 flags 256 rpt 1 UP TAB Key 9 flags 256 rpt 1 UP DEL Key 127 flags 256 rpt 1 UP BACKSPACE Key 63272 flags 8388864 rpt 1 DN ESCAPE Key 27 flags 0 rpt 1 UP ESCAPE Key 27 flags 256 rpt 1 SEQUENCE 4 of 5 [Numbers Keys (Numpad not common)] UP 1 Key 49 flags 256 rpt 1 UP 2 Key 50 flags 256 rpt 1 UP 3 Key 51 flags 256 rpt 1 UP 4 Key 52 flags 256 rpt 1 UP 5 Key 53 flags 256 rpt 1 UP 6 Key 54 flags 256 rpt 1 UP 7 Key 55 flags 256 rpt 1 UP 8 Key 56 flags 256 rpt 1 UP 9 Key 57 flags 256 rpt 1 UP 0 Key 48 flags 256 rpt 1 UP - Key 45 flags 256 rpt 1 UP = Key 61 flags 256 rpt 1 UP / Key 47 flags 256 rpt 1 UP [ Key 91 flags 256 rpt 1 UP ] Key 93 flags 256 rpt 1 SEQUENCE 5 of 5 [Alpha keys (do not use Shift)] UP s Key 115 flags 256 rpt 1 UP c Key 99 flags 256 rpt 1 UP r Key 114 flags 256 rpt 1 complements of a Fredo script c.2007 with a slight update. john learn from the mistakes of others, you may not live long enough to make them all yourself...
Based on this, it looks like maybe it would work if you rename onKeyDown to onKeyUp, as it looks like the up is reported for TAB as key 9. Could you try that and let me know if it works? Thanks Steve
No cursor, no outside dims Pressing Tab just strobes the 'Input Box' john learn from the mistakes of others, you may not live long enough to make them all yourself...
The responses to IN_CURSOR and OUT_CURSOR say that the cursors were created, though I'm not sure that means they found the image files. The response of nil to @cursor indicates nothing, since @cursor is an instance variable not a global. So, the problem still seems to be that the keypress is not toggling the mode to outside. Please try the attached, which looks for the up key event (will not trigger until tab key is released) and let me know if it works.
the path is fine, I just didn't have that in the log I posted, so it's included here.
with the latest file the Dim Angle itself is switching, but still no custom cursors. because Tab also toggels focus on the Inputbox, I changed that to use VK_ALT || 524288 which is more in line with the standard tools and avoids the focus toggling issue. so the tool functions fully now, just no curors... john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: [Plugin] Angular DimensionI have to admit that I am lost and without a Mac I don't know what else to suggest...sorry! If anyone else can figure this out, I'd love to hear.
Re: [Plugin] Angular DimensionSame as John,
Substituted VK_ALT on line 350 for == 9 so that option key toggles. I have no cursor, but I'm working on it. Also I will include a text to outline what key toggles. Otherwise functions great. Thanks Re: [Plugin] Angular DimensionThe mode key seems to be a no-win situation! Maybe I should think of a different mechanism to change the mode. On a PC the TAB key is unassigned, but the VK_ALT activates the File menu! On a Mac, the TAB key is preassigned, but not VK_ALT! By the way, when I try to use VK_ALT on the PC, the cursor alternately disappears and reappears as I press the key! Something similar may be what is happening on the Mac.
Re: [Plugin] Angular Dimension@Michaelv,
the key generator is on the forum, but if you want a slightly updated version, that's easy to add to... I'll PM it to you. BTW. if you use either one VK_ALT or 524288 it toggles from the Alt key, but if you use the ruby either/or VK_ALT || 524288 then not only does ALT toggle, so does RETURN!! which shows as 13 when I ran the test. SU key mapping needs checking. as for the icons, they work on toolbars, so the file and path are ok (but I made new ones as well), their just not being seen by ruby, I'm having a similar problem in another script where only the 'before' half an if not block being seen. Is this a Ruby 1.8.5 (mac SU ruby) issue? john learn from the mistakes of others, you may not live long enough to make them all yourself...
Have you set that as a system shortcut?... do you have assistive devices activated? Does Alt open the File Menu when you use 'move' or 'scale' tools? are your Plugins still all on? [I turn mine off to test new rubies on there own] john EDIT: did you try 524288 that work here as well. learn from the mistakes of others, you may not live long enough to make them all yourself...
Alt key opening a menu is a standard PC shortcut - I didn't do anything special, no assistive devices. Interestingly, ALT seems to affect just about every tool *except* move, on which it does nothing that I can see! And with the Paint Bucket it displays a dropper icon to let you select a Material to match so long as you hold the ALT key depressed. Goes back to the paint bucket when released. You gotta love consistency and portability! I didn't turn off other plugins, but on my PC the tool functions ok so I didn't think that would add anything to this mix. Regarding the cursors, is there any chance that the problem is with png files? Do you have other tools with custom cursors from png files that work?
Re: [Plugin] Angular Dimensionthought you were taking mac... it should 'move' a copy [with an added + symbol] ohhh yerrr All of SU's cursors are png's so that's not the problem. I want them to work now because I made new ones.... damm didn't really need the cursor before. john learn from the mistakes of others, you may not live long enough to make them all yourself...
I'm on a PC but trying to help get this tool to work for people with Macs... On a PC, the CTRL key toggles the move tool to copy, not ALT! Re the cursors, do you have any examples of a tool with custom cursors that do work? I'd like to look at the Ruby to see what it does. I thought I was following the documented code... steve
Re: [Plugin] Angular Dimensionsome progress...
if I use either of these changes, I get the inside cursor and a one-off toggle.
not sure what to look for next... john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: [Plugin] Angular DimensionChris Fulmars 'shapebender.rb' come easily to mind, in the Plugin section here.
I got one step more with trying versions of this, I can switch from inside to out logos once... could you split this into 2 separate actions, holding down the Alt is common for SU tools, as apposed to toggling...
Re: [Plugin] Angular Dimensionhere's some I made earlier.
so we have to get them working.... john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: [Plugin] Angular Dimensiongot it...... could be tidier but it's working
Re: [Plugin] Angular DimensionHow strange! The key feature seems to be the assignment of nil before assignment of the new cursor. I can't imagine why that would be necessary, but if it works...
Re: [Plugin] Angular DimensionThis is something I was looking at today for the other ruby issue, and I just thought I'd play around with the assumption that
having Booleans and conditionals mixed together Can cause issues like false = false ==> true http://stackoverflow.com/questions/3783483/odd-ruby-if-statement-question john learn from the mistakes of others, you may not live long enough to make them all yourself...
hi Steve I missed this earlier, but that could explain the problem... there are so many gotcha's... one thing that happens now is the to icon switches on button up but the @inside changes on next mouse click, could a conditional delay the icon? you should probably move 'cursor bits' of this to the developers forum, tidier for plugin browsers and you might get some answers from people who know what their doing.... I just try and make other peoples scripts work on mac's, and write a few applescript/shell/su type helpers.. and bets test for anyone really... john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: [Plugin] Angular DimensionWell at this point in regard to the mod keys for scripts, I'm figuring that the easiest way is to have a Mac and a PC version of the script. Not only it's the easiest from the point of view of scripting, but it allows to use different modifiers, which is more within the usual practice of each machine.
I have a version ready for you, including text but there is still the cursor issue. I worked on the cursor issue yesterday and it's a tough nut. I changed the cursor scripting to make it similar to the API example and to another script I have (in progress) where it works. And it still doesn't work ![]() Re: [Plugin] Angular Dimension@Michaelv
hi, the cursors work on OSX 10.5.8 with the script above if inserted into the original. did you try it? john learn from the mistakes of others, you may not live long enough to make them all yourself...
Sent you a PM Re: [Plugin] Angular DimensionAll Right, done.
So here is my final script for MAC: Thanks John I used your mod (and changed it a bit, no more onkeyup), cursor works great now. And option toggles everything, text display and cursor, try it! Re: [Plugin] Angular DimensionOK the plot thickens.
I tried the original icons for the cursor, and it doesn't work. Only John's Icons work, now that's weird, they have the exact same name and extension and location. Also when the option key is pressed the icon only switches when the mouse moves on my version. I'll see what can be done. EDIT: Only when I toggle as the dimension is already drawn, if I toggle while it is being drown, icon switches instantly. ![]()
