[Plugin] Pen Tool +
• Page 3 of 5 • 1, 2, 3, 4, 5
Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)The 'edge' tools doesn't form faces like the 'pen' tool [or for that matter the other line drawing tools].. The 'pen' tool is like native 'Line'... BUT it has some different inferencing etc... Try the different ones to see what I mean...
![]() TIG
Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)Hey, I've missed this so far!!!!! haven't you got enough to do, Rich?
Well done mate! purpose/expression/purpose/....
Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)hi Rich,
this is great, works on the mac except the
[this may be due to the slightly different RUBY_VERSION i.e. 1.8.5] however it does work if I cut and paste it to line 1175, directly under
tooltips, custom menu items and the tools themselves all work as advertised... well done john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)Thanks for the Mac feedback John. Glad you got it to work
![]() There's a frontroom and a backroom....reverse faces
Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)I have just downloaded your pen tool, i am working on mac, it appears to workfine but with no icons.....any ideas?
Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)hi,
if the icons folder named, rob_hsltool is in your plugins folder, then you might just need to turn on the menu in View >> Tool Palettes >> Pen Tool + john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)BTW, TIG solved my problem stated earlier in this thread. Thanks TIG.
It turns out if you click the "Compatibility Files" button between Burn and New Folder it showed up.
Re: [Plugin] Pen Tool + v1.3 (Update 18/5/2011)
Canadian beer will do that at sea level in less than a day. ![]() __________________
jgb Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)Hi:
Just trying out Pen Tool last night, I noticed that occasionally for one click I got 2 Cpoints. Also, one or two of the other pen settings doubled the endpoints which were placed short distances apart in a series of quick clicks randomly in the model space. Hard to explain. I did not save the file. This was in Sketchup 7. This mouse has shown no other misbehavior in other applications. Has anyone else seen this? I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)Mitcorb I think this is down to you keeping the mouse-button pressed and dragging.
Most of this kind of line tools allow for you to press+hold+drag+release to make the line, as well as more usual click+click to provide two ends. There's a short timer delay built-in to spot a real button-hold as that - obviously you're on the top limit time-wise and it's assuming a drag is wanted... Is your mouse-button sticky? For the cpoint tool if you don't do a clean click. but do more of a press. then it assume a drag and places a second cpoint at the release point - which might be only a short distance away if the mouse moves slightly. So to avoid this ensure a clean click with no holding down of the mouse button with a drag unless you want two points... ![]() TIG
Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)Yes, thanks, TIG:
It is obvious from only one test that I wasn't tuned in to the appropriate procedure. I am not usually what you would call a fast clicker, partly because of my system response, and partly because of my own internal wiring. ![]() A salute to you and Rich for this excellent concept. I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)Awesome. I joined this site specifically to get this plug-in. It's been a bane in my rear end that Sketchup couldn't simply draw dashed (or construction lines) that didn't go into infinity. Couldn't make a clean diagram that way. (And I know SU is more for 3D than CAD- but it makes sense to model something and then CAD it out in the same app. I also know Layout can draw them, but that gets messy too).
I literally just used the plug-in, but something I noticed right off I want to ask about: I see that drawing the Construction lines flags to SU they are indeed construction lines. When I "Delete Guides" they are deleted as well. I tried grouping them and locking, but they still get deleted if I use the command. Is there a way to makes these lines unique to SU so they won't get deleted when cleaning up my drawings with the Delete Guides command? Thanks again. This will cut down on a lot of cursing 'round here! ![]() Win XP, SU 7 Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)Unfortunately no. Guides are deleted even in locked groups. I'd call this a bug but officially it is called a "feature".
I am not really sure but as if in some earlier versions construction lines hadn't been deleted if they were in a group and you were outside that context. Just like how "unhide all" works now. You can always put these guides into a component (along with something else) however then right click and "Save as..." Later when you clean up your guides, right click on this component again and "Reload". I know it's a poor workaround but should do it. Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)There are several tools knocking around that I and others made ages ago...
Mine erases only those guide-lines or guide-points or both in the active context or current selection or 'all' if there's no selection - see here viewtopic.php?p=341048#p341048 [I just modernized it a bit] TIG
Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)Thank you Rich O'Brien!
But the weld draw doesnt work by me. It always start from the origin point so I can't draw the line I want. Can you tell how to fix it? Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)![]() Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)![]() It works fine for me. So, you must be missing something. There's a frontroom and a backroom....reverse faces
Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)Ian, I see you have just joined and this was your first post. It's not too late to start over: register another account and ask nicely. No-one will know it's you and you will find these gentlemen very helpful.
![]() Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)I was nice
Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)I know. Me too. I was even happy! (And Massimo even happier)
Lol I see you guys have a good sense of humor. I'm sorry for the harsh post. I model 3d trains for railworks 2012 train simulator and was interested in this pen tool. But for some reason it draws an edge from the origin everytime instead of a series like the pencil tool. do you guys know what is wrong? I have sketchup 8 pro. the newest patch too. Thanks for the help! ![]() Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)OK, now we are talking.
I cannot even imagine what may be going on there. Which tool are you actually using? (There are a bunch of them in here) Where are you starting the lines? I also have the latest SU build and have no issues at all. Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)
well I got this pen tool+ v1.4 found here http://rhin.crai.archi.fr/rld/plugin_de ... hp?id=854; is this the same as the one in this thread? I start my line just from the origin of SU to practice using this tool. but using the pen tool there are 6 different types of which only the guide pen works correctly. when i draw, it starts from the origin and ends at the endpoint, then it starts again from the origin rather than from the endpoint, unlike the pencil tool. Re: [Plugin] Pen Tool + v1.4 (Update 23/5/2011)Is your Template or Style setting part of the problem? Or is your precision set too high? Or are you modeling some really tiny items? I don't know, just trying to shake some ideas.
Who is online
Users browsing this forum: andre04415, Arzstudio, ChristianMorales, dantiniloko22, fnatic vector, Macigi, michellesegatto, noldo, Oscar Galero, SLDA, tomywong, vanessabulalla and 13 guests
