by fredo6 » Mon Dec 19, 2011 11:27 pm
 FredoTools groups a number of my standalone plugins, some already published, some new. By delivering them as a single package, it reduces the footprint on Sketchup: - A single folder in the Plugins directory (FREDOTOOLS_Dir_xx)
- A single menu entry (by default in Tools > FredoTools)
- A single contextual menu
- A single toolbar, with control of the icons displayed
- A Quick Launcher
- Also, only a small part of the plugins is loaded at Sketchup startup (only the menus). The rest of the code is loaded the first time you launch the plugin
Plugins currently included in FredoTools are: By default, these plugins are not shown in the toolbar, but they are available from the menu. FredoTools Menu.png FredoTools provides a Quick Launcher from the main icon: FredoTools_Main_24.png FredoTools Quick Launch.png
No User manual currently. This may come for some plugins. In the mean time, goto to the web page of each plugin and watch the video, if provided, or the Quick Start section. - Sketchup versions: 6 and above (Free and Pro)
- Language: English, French, Spanish Spain (by Oxer), Spanish Latin America (by Defisto), Chinese (by guanjin)
- Menus: by default, it is installed in Tools > FredoTools
- Icon toolbar: Fredo6 Tools
1) Download and Open the archive 2) Select All (Ctrl A) 3) Extract into the Sketchup Plugin Directory 4) Answer YES to OVERWRITE all existing files if any The footprint in the SU Plugin Directory must be: Fredotools Footprint 2.png On Mac the SU plugin directory should be: Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/pluginsCAUTION: NEVER rename or move files from their folders. If you are unsure of your unzip operation, do it in a neutral folder and check that you reconstruct the right footprint. Then transfer the folders and files to the SU Plugin Directory.NOTE: If you use an Alternate Plugins directory, make sure that the folder FREDOTOOLS_Dir_xx is in the same location as LibFredo6.rb
FredoTools 1.2a - 08 May 12.zip IMPORTANT: Requires to download LibFredo6 4.5 or higher if not already installed.
No video for the time being  FredoTools is just the shell to host my standalone plugins. Please refer to the main thread for each individual plugin for more information. The Quick Launcher shows the list of Plugins available. Just click on the plugin name in the list to launch it. For convenience the Quick Launcher Window can be pinned and remain visible on the Desktop if you activate the option. The Wrench icon gives access to the Default Parameter dialog box, which contains default options for the standalone plugins. If you wish to display some or all icons for the Plugins, or enable / disable the use of contextual menus, go to the Default Parameters... dialog box and check the plugins names. FredoTools Config Icons and Context Menus.png Once you have installed FredoTools, you may want to remove the old versions of the standalone plugins. Use the Purge utility at Windows > LibFredo6 Settings... > Purge Obsolete Files. FredoTools Purge.png  FredoTools 1.2a – 08 May 12: Update for ThruPaint 1.2a (Paint components and groups and bug fixing). See this post. FredoTools 1.1n – 21 Apr 12: Small update for ThruPaint 1.0n (keep track of scaling and rotation factors by material and support of initial selection) FredoTools 1.1m – 14 Apr 12: Small update for ThruPaint 1.0m fixes and to integrate the Translation in Spanish (Oxer, Defisto) and Chinese (guanjin) FredoTools 1.1j – 11 Apr 12: Release for ThruPaint and ReverseOrientFaces FredoTools 1.0b – 20 Dec 11: Contextual Menu entries can be individually removed (via the Default Parameter dialog box) FredoTools 1.0a – 19 Dec 11: Initial Release
- Top SketchUcator
by Rich O Brien » Tue Dec 20, 2011 12:02 am
Thanks Fredo ThruPaint is very useful.
Rich O Brien
- Administrator
- Name: Rich O'Brien
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: engineering and mechanical design
- Level of SketchUp: Advanced
by fredo6 » Tue Dec 20, 2011 12:13 am
Rich O'Brien wrote:ThruPaint is very useful.
Oooops!! ThruPaint is not ready yet. It was in the release by mistake. Fredo
- Top SketchUcator
by Ken » Tue Dec 20, 2011 12:21 am
Is there anyway to prevent the loading in the contextual menu? I try to keep as much as I can away from the contextual menu.
Thanks in advance
Ken
Government rushes to help the irresponsible and does little for the responsible.
Ken
- Premium Member
- License type: Pro
by Rich O Brien » Tue Dec 20, 2011 12:23 am
I won't use it
Rich O Brien
- Administrator
- License type: Pro
by driven » Tue Dec 20, 2011 12:41 am
the pin is a great idea...
all seems to work on mac... from additional folders on and off...
john PS. I had to manually remove .._DIR_42, it wouldn't 'purge' from the additional folder, should it?
driven
- Top SketchUcator
- Name: John
- Operating system: Mac
- SketchUp version: 2013
- License type: Pro
- Level of SketchUp: Intermediate
by fredo6 » Tue Dec 20, 2011 12:44 am
driven wrote:PS. I had to manually remove .._DIR_42, it wouldn't 'purge' from the additional folder, should it?
Normally you don't need to remove it. It should work even if present, as 43 > 42. Did you see it in the Purge Obsolete Files... dialog box? Fredo
- Top SketchUcator
by driven » Tue Dec 20, 2011 12:53 am
I saw it there, and tried both 'delete all' and then individuals 'delete' when it was the only one left.
the standalone rubies all purged fine. john
driven
- Top SketchUcator
- Name: John
- License type: Pro
by fredo6 » Tue Dec 20, 2011 1:24 am
Ken wrote:Is there anyway to prevent the loading in the contextual menu? I try to keep as much as I can away from the contextual menu.
Sorry for that. I usually do it for the other plugins. So, try version 1.0b and go to the Default Parameters dialog box. FredoTools Config Icons and Context Menus.png Fredo
- Top SketchUcator
by MALAISE » Tue Dec 20, 2011 10:01 am
Nice Fredo,  ........  So we have more space for drawing. Pierre
MALAISE
- Name: Pierre
by Pilou » Tue Dec 20, 2011 10:38 am
Un petit cadeau de Noël  A little Chrismas gift
Pilou
- Top SketchUcator
- SketchUp version: 6
- License type: Free/Make
- SketchUp use: hobby
by erikB » Tue Dec 20, 2011 10:59 am
Very handy fredo !!! thanks ( and happy holidays !) erikB
erikB
- Name: Erik Bosquet
by Panga » Tue Dec 20, 2011 11:37 am
Thanks a lot Fredo, nice addition.
Panga
- Premium Member
by RichardCherry » Tue Dec 20, 2011 3:40 pm
Thanks for the nice Christmas present  Wonderful set of tools
RichardCherry
- Name: Richard Cherry
by vicspa » Tue Dec 20, 2011 3:54 pm
vicspa
- Name: victor
- License type: Pro
- SketchUp use: illustration, cartoons
by irwanwr » Tue Dec 20, 2011 4:01 pm
no curviloft?
irwanwr
- Name: irwanwr
- Level of SketchUp: Beginner
by boilingsnow » Wed Dec 21, 2011 10:46 am
Can you tell why I can't load the plugin? I have already installed the latest version of LibFredo6.
boilingsnow
by fredo6 » Wed Dec 21, 2011 11:12 am
boilingsnow wrote:Can you tell why I can't load the plugin? I have already installed the latest version of LibFredo6.
Can you check the footprint of the files. In the Plugins directory, you should have the Folder FREDOTOOLS_Dir_10 with all the files in it. It looks like you have the rb files directly in the Plugins directory, not in this folder. Fredo
- Top SketchUcator
by boilingsnow » Wed Dec 21, 2011 2:02 pm
Fredo6 wrote:boilingsnow wrote:Can you tell why I can't load the plugin? I have already installed the latest version of LibFredo6.
Thanks for your explanation. It works!
boilingsnow
by halroach » Wed Jan 25, 2012 9:10 am
Hi Fredo,
very nice plugin! I've been thinking of a similar plugin, which you could incorporate into this one:
1. For planning and adjusting areas of a house (to suit program requirements) - it would be nice to have the option to save a selection of faces, and see how the areas update as you change them in sketchup. You have the "areas report" window on ALL THE TIME. You select the faces and components you want once - which gives you the areas. After that you can continue editing the model and the numbers change as you drag lines and change areas - kind of like a set of "entity infos" open all the time for a specific set of pre selected faces. If it cannot be updated "live" you could have an update button (with a keyboard shortcut of course) that would update the info in the box + the different tags.
see attached mockup image (numbers are just gibberish for illustration)
2. you could have selection sets in pre selected colors for interiors, exteriors etc... kind of like the areas by material, but rather by custom selection.
3. you could have sub-totals for faces that were marked together.
4. selecting a face or faces in the list will mark them in the model
5. I noticed that if I use the standard tool for marking the area of a face in a scaled component, it will show the same area for the component in each of it's differently scaled instances (which makes sense). By what I've noticed, your plugin knows how to over come that, right?
halroach
- Name: Halroach
by fredo6 » Wed Jan 25, 2012 7:32 pm
Halroach wrote:1. For planning and adjusting areas of a house (to suit program requirements) - it would be nice to have the option to save a selection of faces, and see how the areas update as you change them in sketchup. You have the "areas report" window on ALL THE TIME. You select the faces and components you want once - which gives you the areas. After that you can continue editing the model and the numbers change as you drag lines and change areas - kind of like a set of "entity infos" open all the time for a specific set of pre selected faces. If it cannot be updated "live" you could have an update button (with a keyboard shortcut of course) that would update the info in the box + the different tags.
This is possible, but this requires a slightly different design, especially because you need this information to be persistent across Sketchup sessions. I may give it a try whenever I have time, either as an extension of the plugin or as a new plugin. Halroach wrote:5. I noticed that if I use the standard tool for marking the area of a face in a scaled component, it will show the same area for the component in each of it's differently scaled instances (which makes sense). By what I've noticed, your plugin knows how to over come that, right?
Yes, the plugin counts the real areas within each component, taking into account the scaling factor and shear factor. Fredo
- Top SketchUcator
by halroach » Wed Jan 25, 2012 8:06 pm
Fredo6 wrote:This is possible, but this requires a slightly different design, especially because you need this information to be persistent across Sketchup sessions. I may give it a try whenever I have time, either as an extension of the plugin or as a new plugin.Fredo
That would be really cool Fredo! I'd be glad to contribute with the conceptual design whenever you get around to it. I may have some further ideas as to how this tool could be useful, more effective and easy to use.
halroach
- Name: Halroach
by fredo6 » Wed Jan 25, 2012 8:43 pm
Halroach wrote:That would be really cool Fredo! I'd be glad to contribute with the conceptual design whenever you get around to it. I may have some further ideas as to how this tool could be useful, more effective and easy to use.
Your comments are welcome. I am not really user of the tool, and it's good to hear from users who have practice and requirement about areas in Sketchup. Fredo
- Top SketchUcator
by DesignerPro » Tue Feb 28, 2012 3:25 am
Tried the new curveloft tool set. This is all the errors it generates when I open SketchUp. Now WHAT? Error Loading File bootstrap_Curviloft.rb uninitialized constant Curviloft::T6Error Loading File CurviloftAlgo.rb uninitialized constant Curviloft::T6Error Loading File CurviloftCurveMover.rb uninitialized constant Curviloft::T6Error Loading File CurviloftPalette.rb uninitialized constant Curviloft::T6Error Loading File CurviloftTool.rb uninitialized constant Curviloft::T6Error Loading File FredoTools.rb uninitialized constant FredoTools::T6Error Loading File FredoTools__ConstructFaceNormal.rb undefined method `register_plug' for FredoTools:ModuleError Loading File FredoTools__CountFacesBySides.rb undefined method `register_plug' for FredoTools:ModuleError Loading File FredoTools__CurviShear.rb undefined method `register_plug' for FredoTools:ModuleError Loading File FredoTools__MarkVertices.rb undefined method `register_plug' for FredoTools:ModuleError Loading File FredoTools__RemoveLonelyVertices.rb undefined method `register_plug' for FredoTools:ModuleError Loading File FredoTools__ReportLabelArea.rb undefined method `register_plug' for FredoTools:ModuleError Loading File FredoTools__RevertCurve.rb undefined method `register_plug' for FredoTools:ModuleError Loading File __loader.rb undefined method `effective_load' for nil:NilClass
DesignerPro
by fredo6 » Tue Feb 28, 2012 11:56 pm
@DesignerPro
This seems to be a problem of installation, probably coming from an erroneous unzip operation. The right footprint is indicated in the first post: - file LibFredo6.rb - Folder LIBFREDO6_Dir_43 - Folder FREDOTOOLS_Dir_10
- Top SketchUcator
by niks » Thu Apr 05, 2012 1:39 pm
thank you very much fredo
niks
- Name: charles
by hebeijianke » Thu Apr 12, 2012 6:49 am
thanks fredo chinese language
hebeijianke
by guanjin » Thu Apr 12, 2012 7:15 am
What a powerful tool, too practical, easy language conversion, love you Fredo6
guanjin
- Name: XIAOLONG
- SketchUp use: interior design
by JClements » Thu Apr 12, 2012 5:37 pm
"Show Box Lines" setting for Area Labeler.
What does this mean?
John Illustrator Beaverton, Oregon
JClements
- Premium Member
- Name: JClements
- License type: Pro
by fredo6 » Thu Apr 12, 2012 8:18 pm
JClements wrote:"Show Box Lines" setting for Area Labeler.
When you mouse over or select components, it shows the box of each subcomponents (instead of just showing the faces). Fredo
- Top SketchUcator
Return to Plugins
