SketchUcation Premium Membership
[Plugin Library] LibFredo6 - v4.9b - 19 May 13
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11
Postby mitcorb » Sat Nov 12, 2011 2:18 pm
In my experience, it may be that the page? loads too fast to pick up the zip, so you get a php temporary placeholder. So, what I have done is cancel the call, wait a short while, and try again until I see the .zip This has worked for me. If you are getting persistent php, then perhaps your security settings are too strong? I am not sure.
User avatar
mitcorb
Top SketchUcator
Operating system: Windows
SketchUp version: 8
License type: Free
SketchUp use: architecture
Level of SketchUp: Intermediate
Postby Dave R » Sat Nov 12, 2011 2:21 pm
On my MacBook Pro, zip files don't display an extension. The just look like a folder. In fact the icon is a folder. Perhaps you could eliminate the extension altogether. Installing the files consists of simply opening the folder, copying the contents and pasting them into Plugins.
Inspecting mirrors is a job I could easily see myself doing.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Level of SketchUp: Advanced
Postby n000bie » Mon Dec 19, 2011 4:51 am
Hi guys, this is my first time posting here but I got a problem that I'm not sure if that's already solved or not, still I've just installed the new LibFredo6 - v4.2a days ago and this is what I get whenever I start Sketchup :
And this is the how my Plugin folder looks like :
I'm using Sketchup 8.0.4811, via Windows 7. Can someone plz tell me what I do wrong or just how to fix this, I've been using Joint Push Pull, Round Corner and Tools On Surface for times and there's no problem until this.
Thnx alot. I always appreciate you and your works, Fredo6.
User avatar
n000bie
Postby Fredo6 » Mon Dec 19, 2011 8:16 am
Not sure if this will solve the problem, but you have a very old version of FredoScale, called FreeScale.
Could you remove:
- ZLoader__Freescale.rb
- FreeScale_dir_20 folder
Thanks.
Fredo6
Top SketchUcator
Postby n000bie » Mon Dec 19, 2011 3:26 pm
My greatful thnx to you and your quick respond, problem solved :D . Looks like I have to update my Fredo Scale.
Thnx again, Fredo, you're the one. :thumb:
User avatar
n000bie
Re: [Plugin Library] LibFredo6 - v4.3a - 19 Dec 11
Postby Fredo6 » Tue Dec 20, 2011 7:22 pm
NEW RELEASE: LibFredo6 v4.3a - 19 Dec 11
LibFredo6 4.3 is a new release which essentially support the publishing of FredoTools suite of Plugins
Fredo6
Top SketchUcator
Postby tspco » Wed Dec 21, 2011 4:08 am
Don't know if this is a problem or not, just installed the 20dec11 update of fredo 6
tspco
Postby Fredo6 » Wed Dec 21, 2011 9:44 am
tspco wrote:Don't know if this is a problem or not, just installed the 20dec11 update of fredo 6
These are binary files.
It is strange that your unzip utility (I guess 7-zip) tries to open them. It should not.
Fredo6
Top SketchUcator
Re: [Plugin Library] LibFredo6 - v4.3b - 22 Dec 11
Postby Fredo6 » Thu Dec 22, 2011 11:52 pm
NEW RELEASE: LibFredo6 v4.3b - 22 Dec 11
Release 4.3b includes (on top of 4.3a)
  • a fix to the numeric buttons in Palettes (not visible in Curviloft)
  • the updated Spanish translation (thanks to Defisto)
Fredo6
Top SketchUcator
Postby eyffel65girl » Fri Dec 30, 2011 12:56 pm
Fredo your plugin is awesome, but I can't use it! I run Skethcup Pro 7 on my Mac Book Pro. I've installed your plugin (LibFredo6 first, and then RoundCorner) following your detailed instructions; I thought it were an easy things to do, but they don't work! :cry:
Can you please help me?? I'll always be graitfull !!
eyffel65girl
Postby oldswinger » Sun Jan 01, 2012 9:44 pm
Dear Fredo
I have downloaded the first 4 plugins from your Plugin Library list "Libfredo6 v4.3b - 22Dec11 but cannot get any toolbar icons appearing when I open my SU8Pro programme.
I note your Important Paragraph about the downloading of LibFredo6 in respect of the appearance of the plugin toolbars but inspite of following the download instructions precisely I can only access the 4 plugins via the entry "Fredo6 Collection" in the Tools menu.
I have ticked off the plugins Fredo Scale & Tools on Surface in the VIEW/TOOLBAR menu but Curiloft & Roundcorner are not shown in the dropdown menu.
I would be extremely gratefull if you could suggest where I am going wrong as without the plugin icons showing in the main toolbar it becomes rather difficult to use the plugins to their best advantage.
Best regards
OldSwinger
oldswinger
Postby Fredo6 » Sun Jan 01, 2012 11:33 pm
eyffel65girl wrote:Fredo your plugin is awesome, but I can't use it! I run Skethcup Pro 7 on my Mac Book Pro. I've installed your plugin (LibFredo6 first, and then RoundCorner) following your detailed instructions; I thought it were an easy things to do, but they don't work! :cry:
It might come from the Unzip operation, which is a frequent problem, especially on Mac.
Please make sure that in the SU Plugins directory you have the right footprint, that is:
- LibFredo6.rb
- LIBFREDO6_Dir_43 folder
- ROUNDCORNER_Dir_23 folder
Fredo6
Top SketchUcator
Postby rjjvirusx » Fri Jan 06, 2012 7:27 pm
:berserk: hooooory
rjjvirusx
Postby tspco » Sat Jan 07, 2012 3:24 am
Is the LibFredo6-34 supposed to stay in the di
rectory after extracting?
tspco
Postby Dave R » Sat Jan 07, 2012 3:40 am
You should have a folder called "LIBFREDO6_Dir_43" and a file called "LibFredo6.rb" If you installed the current version you shouldn't have "LibFredo6-34" at all.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby tspco » Sat Jan 07, 2012 4:37 am
Well it was there, not now now it just shows 4.3
tspco
Postby gullfo » Sun Jan 08, 2012 9:58 pm
not sure if it is the LibFredo 4.3b or the BezierSpline 1.4f plugin, but if the LibFredo 4.3b is enabled, the BezierSpline 1.4f does not work. i get a Ruby console error for line 592 cannot convert nil to float.
Error: #<TypeError: no implicit conversion to float from nil>
C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in `-'
C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in `onMouseMove'
Fredo tools works regardless of BezierSplines being enabled or not.
NOTE: I only encountered this error since updating to 4.3b and prior to that it was working correctly.
User avatar
gullfo
SketchUp version: 8
License type: Pro
Postby wt00320371 » Tue Jan 17, 2012 1:10 am
I can't download?
wt00320371
Postby TIG » Tue Jan 17, 2012 10:54 am
wt00320371 wrote:I can't download?
What file?
What problem/error messages?
More information, please...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby supercylon » Mon Jan 30, 2012 2:49 am
I think that I've installed LibFredo6 v.4.3 and the Round corner plugins correctly. But when I launch SketchUp (I'm using Version 7 on Mac OS 10.4.11) is get this error message: Error Loading File LibFredo6.rb
can't convert nil into String
What does this mean and how can I fix it? Can someone assist me.
supercylon
Postby supercylon » Mon Jan 30, 2012 5:48 am
I'm running SketchUp 7 on Mac OS 10.4.11. I've downloaded and installed both LibFredo6 v4.3 and Round Corner plugin and both are not working. When I start up SU7 I get the error message: "Error Loading File LibFredo6.rb
can't convert nil into String". I have no idea what this means. Can someone help?
Thanks a million!
Here is a screen shot of my plugins folder
supercylon
Postby Fredo6 » Mon Jan 30, 2012 1:36 pm
@supercylon
Just in case, can you type ENV["TEMP"] in the Ruby Console and tell me what you see.
Fredo6
Top SketchUcator
Postby TIG » Mon Jan 30, 2012 1:52 pm
I use
tempdir=ENV["TEMP"] ### it's a PC == 'TEMP' or 'TMP'
tempdir=ENV["TMPDIR"] if not tempdir ### it's a Mac
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Mon Jan 30, 2012 2:31 pm
This is what I use to detect temp path:
TEMP_PATH = File.expand_path( ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'] ).freeze
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Fredo6 » Mon Jan 30, 2012 4:50 pm
TIG wrote:Fredo
I use
TIG,
Actually, my mistake. Yes indeed, I use TMPDIR for Mac environment (or /tmp which may be more secure)
@supercylon
Can you type ENV["TMPDIR"] in the Ruby console
Fred
Fredo6
Top SketchUcator
Postby supercylon » Mon Jan 30, 2012 6:01 pm
Fredo6 wrote:@supercylon
Hello Fredo,
Thanks for your assistance. I did what you asked and here is a screenshot of the result.
Thanks Supercylon
supercylon
Postby supercylon » Mon Jan 30, 2012 6:07 pm
Fredo6 wrote:
TIG wrote:Fredo
I use
TIG,
@supercylon
Fred
I didn't notice this message, here is the screen shot of the result of your second request.
Thanks,
Supercylon
supercylon
Postby thomthom » Mon Jan 30, 2012 6:11 pm
And ENV['TMP'] ?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Fredo6 » Mon Jan 30, 2012 7:41 pm
@supercylon
Can you try withe attached file to see if your error disappear and SU starts OK.
EDIT: file removed. Now part of the release 4.3c, 31 Jan 12
Fredo6
Top SketchUcator
Postby supercylon » Mon Jan 30, 2012 10:22 pm
LibFredo6.rb
Fredo,
Thank you!Thank you! It works!
Supercylon
supercylon
by Ad Machine » 5 minutes ago
Artisan Organic Toolset - a set of powerful organic modeling tools.
Premium Members get 20% discount!
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: Beeeeeere, cgeorg77, Filipe Moody, Fredo6, Google Feedfetcher, jdcamc, noldo, rv1974, zecherus and 8 guests
