SketchUcation Plugin Store
SketchUp-Ruby Resources
Postby Jim » Sat May 31, 2008 6:02 pm
Official Google Sketchup API Documentation
Ruby Operator Precedence
The reserved words and, or and not have a lower precedence than &&, || and !. The tricky part is that their precedence is lower than the assignment operator = .
a = false or true evalualtes to (a = false) or true.
You probably meant one of:
a = (false or true)
a = false || true
Avoid using the typename method
In this discussion, user AlexMozg presents evidence that avoiding the object.typename can give your script a considerable performance increase.
Instead, use object.is_a? Class::Type.
He also says in a model that is less than 10 MB, there may not be a substantial increase, but for very large models the speed increase is considerable.
Installing Extensions
Here's a method that tells you right where your version of SketchUp is looking for extensions. Copy and paste the code into the Window > Ruby Console dialog, and press ENTER. It works for all versions of SketchUp, and on all operating systems, too.
Code: Select all
Sketchup.find_support_file("Plugins")
And in my case the location to install plugins is C:/Program Files/Google/Google SketchUp 7/Plugins
Links to important and notable Dev Forum posts past and present. Let me know if there is a topic that should be included here.
SketchUp & Ruby Development Discussions
Ruby Editor Suggestions
Ruby Challenges
  1. UI.play_sound jukebox (RickW)
  2. best fitting bounding box (Matt)
Ruby Docs
Ruby Books
Extension Collections
Resources
Reason: Added link to SketchUp Ruby C Extension tutorial
Jim
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
Re: SketchUp-Ruby Resources
Postby Heven7_floor » Tue Jan 20, 2009 10:14 am
Great Jim
Your suggestion is usefully to every newer like me .
Thanks :bounce:
Heven7_floor
Postby watkins » Tue Jan 20, 2009 1:23 pm
Dear Jim,
Many thanks for all your hard work. It is greatly appreciated.
Kind regards,
Bob
watkins
Postby sepo » Fri Jan 23, 2009 8:10 pm
Just found this depository of Plugins for SU. There a lot of known ones but nevertheless mayby useful.
http://www.accustudio.com/index.php?opt ... lect&id=23
sepo
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby OAHT » Tue Feb 10, 2009 11:10 am
Thanks for your effort. Cheers :thumb:
OAHT
Postby vashstamp3de » Sun May 17, 2009 1:30 pm
I hope this helps...(and not violating someone :( )
http://xoomer.virgilio.it/kites/program ... ugins.html
Good Luck!
vashstamp3de
Postby remus » Sun May 17, 2009 5:59 pm
I imagine a link to contact each plugins developer would be appreciated by the authors :thumb:
remus
Postby Pauline01 » Mon Oct 12, 2009 2:01 pm
thx again it's very very nice!
Pauline01
Postby Align » Sun Nov 08, 2009 4:15 am
thanx for this awesome thread! i give it a 10 :sketchstatic:
Align
Postby thomthom » Sun Nov 08, 2009 11:44 am
Jim, maybe include the path to install plugins on Mac as well. That one seem to be the most confusing amongst users it seems.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby RickW » Mon Jan 11, 2010 10:27 pm
vashstamp3de wrote:I hope this helps...(and not violating someone :( )
Good Luck!
Just point the Windowizer link to Smustard, please. It currently points to a broken link on RLD.
RickW
Postby thomthom » Sun May 09, 2010 4:29 pm
Might be worth noting that definition names can't be trusted to be unique: viewtopic.php?f=11&t=28094
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
RUBY PROGRAMMING REFERENCES
Postby Dan Rathbun » Thu Aug 26, 2010 10:53 pm
RUBY PROGRAMMING REFERENCES - CHM format*
Method References for Ruby Core and Extended Modules & Classes
~ Arranged by Ruby version and PatchLevel ~ Choose from 7z or Zip archive formats. ~
Ruby ver 1.8.6 p398
ruby-1.8.6-p398-doc-chm-2.7z
ruby-1.8.6-p398-doc-chm-2.zip
dl.txt
DL library documentation (from v1.8.6-p287)
Online version at ruby-doc.org
Latest ver 1.8.6 [framed webpage]
Online at Ruby-Doc.org
Core <> Libraries
Ruby ver 1.8.7 p302
ruby-1.8.7-p302-doc-chm.7z
Ruby ver 1.8.7 p330
ruby-1.8.7-p330-doc-chm.7z
ruby-1.8.7-p330-doc-chm.zip
Latest ver 1.8.7 [framed webpage]
Core <> Libraries
Ruby ver 1.9.1 p430
ruby-1.9.1-p430-doc-chm.7z
ruby-1.9.1-p430-doc-chm.zip
Ruby ver 1.9.2 p0
ruby-1.9.2-p0-doc-chm.7z
Ruby ver 1.9.2 p136
ruby-1.9.2-p136-doc-chm.7z
ruby-1.9.2-p136-doc-chm.zip
Latest ver 1.9.2 [framed webpage]
Keywords <> Core <> Libraries
* Compiled HTML Help Markup
NOTICE: CHMs for older patchlevels under each version may be deleted to save server space.
( Get 'em while they're hot! )
User avatar
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: education
Postby Dan Rathbun » Wed Sep 08, 2010 10:51 am
|--<<< RUBY RESOURCES >>>--|
Ruby Newbie's Guide to Getting Started
viewtopic.php?f=180&t=10142&start=15#p298780
TUTORIALS & PRIMERS
~ Ruby (Generic) ~
Introduction to Ruby
http://www.ruby-doc.org/docs/Tutorial/
Ruby User's Guide
by Mark Slagell, Iowa State University
http://www.rubyist.net/~slagell/ruby/
Ruby Study Notes
by Satish Talim
http://rubylearning.com/satishtalim/tutorial.html
Learn to Program
by Chris Pine
http://pine.fm/LearnToProgram/
~ Sketchup Specific ~
Edges to Rubies - The Complete SketchUp Tutorial
by Martin Rinehart
http://www.martinrinehart.com/models/tutorial/
Ruby Tutorials
SketchUcation Forums
http://forums.sketchucation.com/viewtopic.php?p=52665#p52665
Tutorial Index
http://forums.sketchucation.com/viewtopic.php?f=18&t=8767
BOOKS
~ Offline (PDF, CHM, TAR, etc.) ~
The Book of Ruby
by Huw Collingbourne
** PDF
http://www.sapphiresteel.com/IMG/zip/book-of-ruby.zip
The Little Book of Ruby
** PDF
http://www.sapphiresteel.com/IMG/pdf/LittleBookOfRuby.pdf
Mr. Neighborly's Humble Little Ruby Book
by Jeremy McAnally
** PDF
http://www.humblelittlerubybook.com/book/hlrb.pdf
Programming Ruby - The Pragmatic Programmer's Guide, 1st Ed.
(aka "The Old Pick-Axe Book" circa Ruby ver 1.6.x)
by David Thomas and Andrew Hunt
** TAR archive of website
http://phrogz.net/ProgrammingRuby/ProgrammingRuby_20061016.tar.gz
** CHM edition file is included w/ Win 1.8.6 One-click install
see your /ruby/doc directory OR
download from SketchUcation
Ruby Best Practices
by Gregory T. Brown
** PDF
http://sandal.github.com/rbp-book/pdfs/rbp_1-0.pdf
Automatic SketchUp
by Matthew Scarpino, Eclipse Engineering LLC
http://www.autosketchup.com/downloads/Automatic_SketchUp.pdf
~ Online ~
Ruby Essentials
Techotopia
http://www.techotopia.com/index.php/Ruby_Essentials
http://phrogz.net/ProgrammingRuby/frameset.html OR
~ Previews of Ruby Books for Sale ~
Learn to Program, 2nd Ed.
by Chris Pine
(expanded from the original tutorial)
http://www.pragprog.com/titles/ltp2/learn-to-program-2nd-edition
Programming Ruby - The Pragmatic Programmer's Guide, 2nd Ed.
(aka "The New Pick-Axe Book" circa Ruby ver 1.8.x)
by David Thomas, with Chad Fowler and Andrew Hunt
http://pragprog.com/titles/ruby/programming-ruby
Programming Ruby 1.9: The Pragmatic Programmers' Guide
http://pragprog.com/titles/ruby3/programming-ruby-1-9
The Ruby Programming Language
by David Flanagan and Yukihiro Matsumoto
http://books.google.com/books?id=jcUbTc ... GordbwjC...
TECHNICAL REFERENCES
Ruby Cheatsheet
http://www.zenspider.com/Languages/Ruby/QuickRef.html
Ruby Base Classes - circa ver 1.6.x
(but most still OK for 1.8.x which has more methods)
http://phrogz.net/ProgrammingRuby/builtins.html
Ruby Core Documentation
(may be ver 1.9.x)
http://www.ruby-doc.org/core/
RDoc Documentation
http://rdoc.rubyforge.org/
RubyGems User Guide
http://rubygems.org/read/chapter/1
RubyGems Manuals
http://docs.rubygems.org/
INDEXES
Resources
(SketchUp Sage)
http://sites.google.com/site/sketchupsage/resources
SKETCHUP SPECIFIC
~ API ~
SketchUp Ruby API Cheatsheet
by Alex Schreyer
http://www.alexschreyer.net/cad/sketchup-ruby-api-cheatsheet/
SketchUp Ruby API
http://code.google.com/apis/sketchup/
SketchUp Ruby API - Class Index
http://code.google.com/apis/sketchup/docs/classes.html
SketchUp Ruby API - Method Index
http://code.google.com/apis/sketchup/docs/methods.html
SketchUp Ruby API - Class Diagram
http://code.google.com/apis/sketchup/docs/diagram.html
Sketchup Ruby API Class Diagrams
by Jim Foltz
http://sketchuptips.blogspot.com/2008/08/sketchup-ruby-api-class-diagrams.html
Google SketchUp API Blog
http://sketchupapi.blogspot.com/
PickHelper - Visual Guide
by Thomas Thomassen
http://forums.sketchucation.com/viewtopic.php?f=180&t=30232&p=266685
WebDialogs - The Lost Manual
by Thomas Thomassen
http://forums.sketchucation.com/download/file.php?id=36664
~ Indexes ~
http://forums.sketchucation.com/viewtopic.php?f=180&t=10142
~ BBs / Forums ~
Developers Forum - Google Groups
http://groups.google.com/group/google-sketchup-developers
Developers Forum - SketchUcation Community Forums
http://forums.sketchucation.com/viewforum.php?f=180
~ Code Snippets ~
Code Snippets Index - SketchUcation Developers Forum
http://forums.sketchucation.com/viewtopic.php?f=180&t=28846
~ Plugins ~
Plugins Index (by author) - SketchUcation Plugins Forum
http://forums.sketchucation.com/viewtopic.php?f=323&t=28782
Plugins Visual Index - SketchUcation Plugins Forum
http://forums.sketchucation.com/viewtopic.php?f=323&t=16909
Trimble SketchUp - Plugins (Download Page)
http://www.sketchup.com/intl/en/download/plugins.html
Trimble SketchUp - Ruby Scripts (Download Page)
http://www.sketchup.com/intl/en/download/rubyscripts.html
ExtendSketchUp
http://extendsketchup.com/
Jim Foltz SketchUp Plugins
http://sketchuptips.blogspot.com/2007/09/plugin-index-page.html
Ruby Libray Depot
http://www.crai.archi.fr/RubyLibraryDepot/Ruby/en_sections.html
Smustard(TM) - Plugins and Scripts
http://www.smustard.com/scripts/
JohnJ - Plugins for Sketchup
http://www.johnj.com/drawing/sketchup/ruby-plugins-for-sketchup/
User avatar
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Sep 08, 2010 11:07 am
Very nice list Dan!
Dan Rathbun wrote:Ruby Best Practices, by Gregory T. Brown
** PDF
This one looks very interesting.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Dan Rathbun » Wed Sep 08, 2010 11:35 am
thomthom wrote:Very nice list Dan!
Thanks.. (but I didn't find all these myself.) I had it posted over at GG, but it kept getting farther down the topic stack. Over here I know right where it is, and can format it.
thomthom wrote:This one looks very interesting.
Jim found that one.
P.S. - @Jim your free to cut and paste anything from here to the top of the thread.
User avatar
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
Ruby Interpreter DLLs (Win32)
Postby Dan Rathbun » Fri Oct 01, 2010 7:06 am
Instructions: (Win32 ONLY)
Navigate (Explore) on your computer, to the Google Sketchup application folder, and ...
  1. Backup the current "Deceased" 1.8.0 dll, msvcrt-ruby18.dll by renaming it:
    • msvcrt-ruby180_p0.dll
    • or similar if it's a newer version. For example, if the old dll is v1.8.6-p287, then rename it msvcrt-ruby186_p287.dll
  2. Download your choice of a newer version Ruby Interpreter Win32 DLL (below)
  3. Make a copy of the new file and name it: msvcrt-ruby18.dll
      (Sketchup is hardcoded to load this DLL filename.)
1.8.0
OBSOLETE
ruby-1.8.0-p0-i386-mswin32-dll.zip
1.8.1 .. 1.8.4
OBSOLETE
1.8.1 thru 1.8.4 are obsolete (no sense posting them.)
1.8.5
OBSOLETE
ruby-1.8.5-p0-i386-mswin32-dll.zip
ruby-1.8.5-p231-i386-mswin32-dll.zip
1.8.6
STABLE (but aging.)
ruby-1.8.6-p287-i386-mswin32-dll.zip
ruby-1.8.6-p369-i386-mswin32-dll.zip
1.8.7
STABLE (current)
ruby-1.8.7-p299-i386-mswin32-dll.zip
ruby-1.8.7-p302-i386-mswin32-dll.zip
ruby-1.8.7-p330-i386-mswin32-dll.zip
User avatar
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Dan Rathbun » Wed Dec 29, 2010 6:48 am
UPDATES / ADDITIONS (in this topic.)
Edited Instructions to be more clear and precise.
Added DLL for:
  • latest Ruby v 1.8.7 p330
Added CHMs for:
  • latest Ruby v 1.9.2 p136
User avatar
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Dan Rathbun » Wed Jan 05, 2011 10:28 pm
Go to this post... Ruby Resources
(1) make a checklist of all the Tutorials, and go thru them 1 by 1, and check them off the list as you do.
(2) make a checklist of all the free downloadable books, and down load them one by one. Put them in a folder on your Desktop (or whereever you can find them easily.) And read them.
(3) For Standard ruby Reference, get the CHM for Ruby 1.8.6 here, put it in this same folder.
Get comfortable with Standard Ruby. When your ready to script for Sketchup:
(4) On the Reference list (link above,) go to the Sketchup Specific section, and download Alex's Cheatsheet, and bookmark the Google Sketchup API document website. (You'll be referencing it a lot.) It has the methods for the modules and classes for 'talking' to Sketchup, and manipulating it's models.
(5) Go through all the available Sketchup Ruby tutorials (on the list.)
(6) Read the code examples in your plugins/Examples folder.
(7) Have fun. Start fooling around with Ruby under Sketchup. Usually the best thing is to start by customizing the examples.
(8) Whenever you have questions, come back to this forum, and first do a search (it's likely your question has already been asked.) If not.. start a new topic (make the the topic title simple but informative... a shortened version of your question. Don't make it "Help Me!", that does not work well.)
(9) Before going into advanced Sketchup scripting, download more advanced plugins from the plugins forum (or other websites.. see the Resource list,) and examine them. See how they did things. This the best way to learn how to do things right. If you have a question about why an author did something a certain way... you can either Private Message them, or see if there is a discussion topic specific to their plugin, here in the Developer's forum, and post a question at the end of that topic. If no topic exists, create one by putting the plugin name in square brackets following by 'coding questions.' Please don't ask coding questions in the Plugin distribution topic of the Plugins forum. Ask them here in the Developers forum.
And ... welcome to the world of Ruby !
User avatar
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Jim » Sun Oct 30, 2011 12:30 pm
This site has many videos of Ruby talks recorded at various Ruby Conferences - http://confreaks.net
Some good stuff there - if you can find them...
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby rricon » Sun Dec 18, 2011 5:23 am
Hello,
Where to find the .h file of msvcrt-ruby18.dll file ?
Regards,
rricon
Postby Dan Rathbun » Sun Dec 18, 2011 8:54 am
rricon wrote:Where to find the .h file of msvcrt-ruby18.dll file ?
In the source:
ftp://ftp.ruby-lang.org/pub/ruby/1.8/ruby-1.8.6-p287.zip
User avatar
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
[doc] Programming Ruby (The "Pick-Axe" Book)
Postby Dan Rathbun » Sat Sep 29, 2012 3:29 am
    book: "Programming Ruby - The Pragmatic Programmer's Guide"
    Copyright © 2000 Addison Wesley Longman, Inc.
    ProgrammingRuby.zip
    Released under the terms of the Open Publication License V1.0.
    :ugeek:
    User avatar
    Dan Rathbun
    Top SketchUcator
    SketchUp version: 8
    License type: Pro
    Postby Todd Burch » Wed Oct 24, 2012 5:48 pm
    Chunky Bacon. I didn't see a link for Why's Poignant Guide to Ruby. A true classic.
    http://mislav.uniqpath.com/poignant-gui ... ter-1.html
    Todd Burch
    Postby Dan Rathbun » Fri Nov 09, 2012 7:53 pm
    User avatar
    Dan Rathbun
    Top SketchUcator
    SketchUp version: 8
    License type: Pro
    Postby mptak » Mon Dec 03, 2012 3:07 am
    http://rubyjs.org/
    Javascript implementation of Ruby. For what its worth.
    mptak
    by Ad Machine » 5 minutes ago
    Not a Premium Member yet? Check out the great time-limited deal we are offering.
    Ad Machine
    Robot
    Return to Developers' Forum
    Who is online
    Users browsing this forum: timofee and 5 guests
