SketchUcation Plugin Store
[Plugin] 2D Tools v5.3 20120929
Re: [Plugin] 2D Tools v5.0 20100927
Postby David_H » Tue Oct 11, 2011 6:47 pm
Im just loaded the 2D tools myself. Fillet doesn't work very well for me as well. I get one corner to work (after some effort) but then when I try to get the 2nd one to work. . .BUG SPLAT> has happened to me about 1/2 dozen times.
OTherwise, great tool set.
Thanks.
D
If I make it look easy. . .rest assured--it probably is.
User avatar
David_H
Top SketchUcator
Postby TIG » Tue Oct 11, 2011 7:12 pm
David_H wrote:Im just loaded the 2D tools myself. Fillet doesn't work very well for me as well. I get one corner to work (after some effort) but then when I try to get the 2nd one to work. . .BUG SPLAT> has happened to me about 1/2 dozen times.
Thanks.
D
Never had a Blugsplat report on 2dFillet - ever! :?
Can you supply a SKP that does it - or PM it if it's not for public-gaze!
:roll:
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby David_H » Tue Oct 11, 2011 7:13 pm
No. . it's not a big deal. I was just trying it on a simple rectangle as a test. Not any specific model.
User avatar
David_H
Top SketchUcator
Postby TIG » Tue Oct 11, 2011 7:50 pm
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby David_H » Tue Oct 11, 2011 9:21 pm
Yeah. .it's pretty weird. If I have a chance, I'll post a screen shot at least. I wonder if 2D tools is clashing with another plugin? ya think??? maybe? I only have 400. Should be no trouble checking to see which one. :mrgreen:
D
User avatar
David_H
Top SketchUcator
Postby MartinK » Wed Oct 19, 2011 3:00 pm
I'm having a problem with the 2dLinestyle tool. When I choose <Custom Style>,I don't get the new dialog window where you can set up the Custom Style. The Linestyle just remains whatever it was before I picked <Custom Style>. I have the latest version installed and everything else works, at least the tools I've tried. Thanks in advance for any help.
MartinK
SketchUp version: 8
License type: Pro
Level of SketchUp: Intermediate
Postby TIG » Wed Oct 19, 2011 7:42 pm
MartinK
It works fine for me [and everyone else as far as I know]...
To reiterate...
Right-click in 'empty space' to get the options main-dialog.
Select <Custom Style>, and then OK...
Another dialog appears for you to name and also design your own custom-style, and then OK...
The original main-dialog now reappears...
Scroll through the style-list to find your newly made custom-style... select it and also set other options for the LineStyle and OK...
Style the lines as desired...
[Custom Styles should also be saved with the Model??]
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby ingeh » Tue Oct 25, 2011 12:18 pm
Does this plugin work on Mac too ?
ingeh
Postby TIG » Tue Oct 25, 2011 12:24 pm
Yes.
Although some of the MAC modifier key options have different names than the guide...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby ingeh » Tue Oct 25, 2011 12:34 pm
TIG wrote:Yes.
Great ! I'll try it asap... Looks like a wonderful tool.
Many thanks,
Inge
ingeh
Postby marziaf » Thu Dec 01, 2011 12:12 pm
if I press the <0> key in 2D Line tool the Z-plane resetting function starts, so I can't type all the lengths containing a "0".
I've noticed that in the 2DlineTool.rb, line 306, the key 48 is linked to the <TAB> function (" if key == 9 or key == 15 or key == 48### TAB sets Z, 9 for PC 15 for MAC ?"...).
I'm not a programmer but if I change this line and delete the string " or key == 48" the command works well.
Is it a needed change to the plugin or I'm doing something wrong?
(sorry for my English)
marziaf
Postby TIG » Thu Dec 01, 2011 3:35 pm
I think some linux versions have key 48 as tab ?
I hadn't realized that it was the main keyboard '0' !
Feel free to disable the key press test as
if key == 9 or key == 15 ###or key == 48
I'll issue an update shortly...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby marziaf » Thu Dec 01, 2011 3:42 pm
Thanks for your reply and also for your plugin, very useful!
marziaf
Re: [Plugin] 2D Tools v5.1 20111201
Postby TIG » Thu Dec 01, 2011 3:53 pm
Here's v5.1 viewtopic.php?p=185760#p185760
It fixes the recently reported glitch whereby on a PC the 2dLine tool jumped into the Z-height tool IF you typed a '0' from the main keyboard while typing a dimension, this was because the 'key codes' for 'TAB' for PC/MAC were messy [pressing TAB activates the Z-height tool]... :roll:
If the three and a half thousand or so of you who have previously downloaded would like to get the updated toolset then please form an orderly queue ;)
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby justinhough77 » Fri Dec 09, 2011 2:37 am
Running a MacBook Pro...I cannot get this plugin to work. I have had success with other plugins but cannot get this one or the cline tool to work properly. Any help is appreciated.
justinhough77
Postby Dave R » Fri Dec 09, 2011 4:29 am
You really haven't given us much to go on in order to help you. I can tell you that I have this plugin installed on my MacBook Pro and it works as expected. This would lead me to believe you've not installed it correctly. Why not throw us a bone and post a screen shot of your Plugins directory to show us how you have the plugin installed.
Inspecting mirrors is a job I could easily see myself doing.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Postby TIG » Fri Dec 09, 2011 12:14 pm
I recall some reports about 'modifier-keys' being flaky on MACs, or them being the wrong-way-round or somehthing weird ?
If an experienced MAC user could chip I ?
I have been waiting to get some advice/fixes back on this issue for ages...
However, if you just want to draw some 'clines' there are already several other tools available for this too... There was a recent topic on it and some links...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Retaining and printing dotted lines
Postby emjay125 » Wed Dec 14, 2011 11:41 am
I set a 2d line style and draw a series of dashed lines (drains under and alongside a house). The lines are dashed until I stop drawing them. A single left click at the end of a line makes all the earlier ones in the set appear dashed. Then moving the mouse makes the whole set continuous. Another left click turns the set into dashed lines. A double click to end the line-set makes the set solid lines.
What is going wrong, what edge settings or other factors do I have to set ?
emjay125
Re: Retaining and printing dotted lines
Postby TIG » Wed Dec 14, 2011 12:51 pm
emjay125 wrote:I set a 2d line style and draw a series of dashed lines (drains under and alongside a house). The lines are dashed until I stop drawing them. A single left click at the end of a line makes all the earlier ones in the set appear dashed. Then moving the mouse makes the whole set continuous. Another left click turns the set into dashed lines. A double click to end the line-set makes the set solid lines.
You right-click in empty space to get the line-style dialog ? Thereafter any lines you 'style' match that [width/color/pattern].
Have you got view > hidden-geometry 'off' [should be]...
Can you post an example SKP ?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby emjay125 » Wed Dec 14, 2011 4:47 pm
Thanks TIG, for a quick response.
Here is a sample SKP. DashedLines1. I am using the Sketchup v 8.0.11752 here. There are no 2d layers that I can see. Seems to be the same in v8.0.4811.
What are the settings that could affect printing the dashed lines.
Is the deletion process that I describe on the SKP usual.
Emjay
emjay125
Postby TIG » Wed Dec 14, 2011 11:17 pm
Your lines' dims are quite large - if you have a line 100m long it probably needs to be 1000mm wide to be visible in meaningful views!
The 'dotted-ness' depends also on the line's width...
I found that adjusting the width/style produced acceptable results :?
Your 'guide-lines' are not relevant to this as it only works on lines/edges...
Also you example face is 'upside down', so the 'styled edges' appear below it...
[correctly oriented to the face... but 'upside down' for what you hoped for - facing 'down' !] !
Reverse the face and you get an acceptable result... :roll:
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby davidterry » Fri Dec 16, 2011 4:45 am
Neither the line color or style is working for me. I am using SU version 8. Is there a line scale function somewhere? Didn't notice.
davidterry
Postby TIG » Fri Dec 16, 2011 12:43 pm
davidterry wrote:Neither the line color or style is working for me. I am using SU version 8. Is there a line scale function somewhere? Didn't notice.
How isn't it working ?
Can you please be more specific...
The styled-line's width affects the spacing of any pattern's dots/dashes - so on very large scale lines you need them to be wide to get a meaningful pattern, on very short lines there might be no room to fit in any pattern if the width is too great.
The color is whatever you set it to in the dialog...
You have been right-clicking in open-space to get the style-settings dialog ?
This let's you set these values...
The 'default' is a modest-width [this varies with model-units in "/mm], the pattern is 'continuous' and color is 'black'.
Choose another width, pattern or color as desired...
After you've styled a line, then later on you can select it and right-click to get the context-menu and 'Edit' the line-style: the dialog reappears and you can then change width/pattern/color as desired...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby 3dDetailer » Sat Dec 24, 2011 8:25 pm
Hello TIG. Just downloaded and install your great plugin. But I have a problem. I read the help file, but I can't find where you edit the FILLET tool parameters. I pick both lines...but nothing happens...like, the radius must be zero or something. Where do you set the radius? BTW, I didn't have time to read this entire thread...but I will, soon.
3dDetailer
Postby TIG » Sat Dec 24, 2011 11:10 pm
3dDetailer wrote:Hello TIG. Just downloaded and install your great plugin. But I have a problem. I read the help file, but I can't find where you edit the FILLET tool parameters. I pick both lines... but nothing happens...like, the radius must be zero or something. Where do you set the radius? BTW, I didn't have time to read this entire thread...but I will, soon.
Whilst the tool is active [before you have completed the two line picking] type in the fillet segments [e.g. 6s] if you want to change that, OR more usually just the radius [default is 0 so two line that already meet aren't affected] - e.g. 6.6 in current units, then press <enter> and the fillet has those settings, you can change parameters at any time until you confirm the fillet by doing the next one or selecting another tool; note that any fillet you make thereafter will use those same settings too until you change them - even across sessions of that SKP/model... :?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby 3dDetailer » Sun Dec 25, 2011 12:04 am
Wow! Now I get it. :mrgreen: Works great!! :ecstatic: I've been looking for that plugin for a long time~ Thank you so much! That's what I like about SketchUcation. Immediete HELP!
Ok, got another one for you. How do I change the TEXT size in the Window I am writing this, without changing the Text size in the actual post. Old age syndrome...I CAN"T read what I'm typing. Probably because my monitors are on my console, which are 4' from my eyes. You see, my monitors are part of my Recording studio console. Heres a pic so you see why. I have two computers and three monitors, and my Skethup computer is part of my Studio recording computer too. Anyway, thanks for any help.
fitZ
3dDetailer
Postby thomthom » Sun Dec 25, 2011 12:06 am
Increase the text in your browser. Usually you can do that by pressing Ctrl and Pluss / Minus
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby charly2008 » Sun Dec 25, 2011 2:50 pm
or Ctrl and Mouse wheel.
Charly
More dangerous than ignorance is the illusion of knowledge
User avatar
charly2008
SketchUp version: 7
License type: Pro
SketchUp use: historical reconstruction
Postby 3dDetailer » Tue Dec 27, 2011 3:51 am
thomthom wrote:Increase the text in your browser. Usually you can do that by pressing Ctrl and Pluss / Minus
OMG!!! How cool.
charly2008 wrote:Hi,
Charly
Good grief, that works great! Learn sompin new evra dey!
Thanks a million guys. Old farts need all the help they can get.:mrgreen:
Ok, now I've got a question regarding setting the radius in the fillet tool. when I pick the tool, the default value in the measurements window is 1". I can enter a smaller value like .5, but as soon as I pick Line1, it reverts back to 1". How do I change the value of the Fillet radius? You mentioned entering in the "segment value", but the Text in the measurement window is in INCHES. Got any ideas? I really like this tool set, especially the fillet. I"d use it all the time...IF I can set a value LESS than ONE INCH. Thanks for any insight.
fitZ
3dDetailer
Postby TIG » Tue Dec 27, 2011 11:39 am
Whenever you type in a value [into the VCB - for any tool] you must press <enter> to tell Sketchup you have finished typing - otherwise it won't know.
For example you want to use 0.25 how would it know that you weren't done typing at 0.2 - it's waiting for an <enter>
So if you want 0.5 type in 0.5+<enter> or 0.2 use 0.2+<enter> or 0.25 use 0.25+<enter>.
Remember with the fillet tool it remembers the last used fillet forever - so if you last used 1" that's what it'll use next time. You can also change the number of segments in the fillet using a 's' suffix so 6s [+<enter>] sets the fillets to use six segments...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
by Ad Machine » 5 minutes ago
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: Archistudent, Atex, Bing [Bot], ducaty, rxavi and 7 guests
