SketchUcation Plugin Store
[Plugin] SuSolid -Check-Repair-Intersection-Weight-
Postby voljanko » Tue Nov 15, 2011 4:52 pm
After months of testing and debugging here it is the SuSolid plugin.
What it can do? Really a lot:
-Check your model for "mistakes" that prevents it to be a solid model.
-Repair all (in most of the cases) "mistakes" and make you model a solid model (close holes,divide by inside faces,delete single edges,delete inside faces,group all ungrouped, delete coplanar edges, adjust distorted faces).
-Check for intersections between solids.
-Weight your model in base of the assigned material (wood,water,iron...)
-All the tools and commands affects entire model or selection.
-All the tools and commands affects all subgroups and subcomponents.
-You can add other materials by inserting material name and density.
There is a free version that includes the Analyse tool and the Delete Single Edges tool.
The full version is for sale for 22 EUR.
http://www.SuSolid.com
SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
voljanko
Re: [Plugin] SuSolid -Check-Repair-Intersection-Weight-
Postby driven » Sun Nov 20, 2011 1:22 am
looks interesting, let me know when you need a mac tester.
driven
Top SketchUcator
Operating system: Mac
SketchUp version: 2013
License type: Pro
SketchUp use: engineering and mechanical design
Level of SketchUp: Intermediate
Postby voljanko » Sun Nov 20, 2011 12:05 pm
Hello Driven,thanks I would really appreciate the help for testing the plugin for mac.
I'm preparing the files now and will send you on your p.m..
voljanko
Postby Oxer » Mon Nov 21, 2011 2:38 am
Hi voljanko!
I'm a mac user too for testing, and if you want, i can translate the plugin to spanish language.
User avatar
Oxer
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Level of SketchUp: Advanced
Postby Oxer » Mon Nov 21, 2011 4:23 pm
I have probed the plugin and it's very useful, it works fine on Mac.
User avatar
Oxer
SketchUp version: 8
License type: Pro
Postby Ken » Wed Nov 23, 2011 5:11 am
OK, I order the plugin by paypal and I have a receipt sent to my email account. However, darn if I know what to do next. Is there a download site or will they send something in the email telling me what to do.
This may just be a language problem, however the site is not clear about the process.
So has anyone ordered this plugin? And what should I expect in delivery?
Thanks in advance
Ken
Government rushes to help the irresponsible and does little for the responsible.
User avatar
Ken
Premium Member
Premium Member
Operating system: Windows
License type: Pro
Postby voljanko » Wed Nov 23, 2011 7:39 am
Hello Ken,
Thank you for buying the plugin.Sorry for letting you wait for it.I'm working on the automatic plugin delivery.It is a little bit tricky because every plugin is licensed to the owners name,so unique.I will announce it here when ready.
Till then is maybe better to order it at day time (CE time),to avoid waiting me to wake up :)
voljanko
Postby voljanko » Wed Nov 23, 2011 11:06 am
Pete wrote:[I like the idea of having an intersection check while designing in sketchup. I looked at the model again and the cabinets sit adjacent to each other but do not overlap. Is your graphic showing the cabinets are intersecting? I use the dimensioning built into the cabinet components to check for overlaps. When the cabinets sit next each other but don't overlap the dimensions look as they do in the sample model. If I overlap them the dimensions overlap and look strange. I also have construction points below the edges of the cabinets that make aligning cabinets easy. I borrowed this method from sketchdata.
I have checked all the intersections and have discover that the 4 intersections on picture 1 are with the hidden component.I don't know if live the plugin to check the intersections with hidden components or only visible components or to make it selectable in the menu.
The other intersections are with visible objects, mostly caused by extra component that I have moved out (picture2).
Two intersections are real overlaps (picture2).
voljanko
Postby Ken » Wed Nov 23, 2011 11:58 am
voljanko wrote:Hello Ken,
Thanks for your reply. Got the plugin.
Ken
User avatar
Ken
Premium Member
Premium Member
License type: Pro
Postby driven » Wed Nov 23, 2011 12:21 pm
Hi Voljanko,
been testing on some old models, and the only real problems so far seem to be operator error:)
One thing that could limit 'this' for me is re-ordering the 'toolbar' to reflect the 'recommended' sequence of tools.
Better yet if it was dynamic, so you keep using green until green is finished...
driven
Top SketchUcator
License type: Pro
Postby voljanko » Wed Nov 23, 2011 7:56 pm
Hello John,
I'm not shore to understand your meaning.Do you suggest me to reorder the tools on toolbar like the suggested order?
The suggested order is only the most usual way that I found after testing more than 100 models.But is not the rule,there are a lot of different situations so the flexibility is needed.So about "using green until green is finished" I think is better if the user do it step by step,because there can be an unwanted result and the user simply undo one step(after undo command you have to refresh with the analyse tool to see the result).
David
voljanko
Postby Pete » Wed Nov 23, 2011 10:23 pm
Those intersections are probably caused by my vertical dimension components. Each cabinet has a vertical dimension that is offset to a set distance left of the wall the cabinet is attached to. This causes the overall bounding boxes of each cabinet component to be larger than the cabinet alone. Would this be the cause of "intersections"?
The components on the left that are truly intersecting the adjacent wall are fillers that I purposely oversize so they can be scribed to the wall.
Pete
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Postby voljanko » Wed Nov 23, 2011 10:50 pm
Hello Pete.
The plugin is only checking the intersections between solid components,so cannot intersect with dimensions.
Check your model at the area in the picture.Make it colored,not monochrome and move the camera a little.When moving,you should see the area flickering.That also mean that are some overlapping.And please don't think that I'm criticizing your work,just testing my pugin ;)
voljanko
Postby jgb » Fri Dec 02, 2011 9:41 pm
To me, the more useful part is the material density and weights portion. Are they part of the free version, or the pay version?
__________________
jgb
User avatar
jgb
SketchUp version: 8
License type: Free/Make
Postby voljanko » Fri Dec 02, 2011 11:04 pm
jgb wrote:To me, the more useful part is the material density and weights portion. Are they part of the free version, or the pay version?
The parts are very dependent of each other.Because you have to be shore to have all solid entities if you want to weigh it.Also if you have intersections between solids,the weight will be wrong.For example if you have 2 swimming pools at the same place,the calculated weight will be double.
The free version will show you all you have to correct in your entire model (included all nested components) and the tool to delete all single edges (edges that are not connected to any face).All the tools can be applied to entire model (or selection) so you don't have to edit every single component.The weights portion is a part of pay version.
voljanko
Postby jgb » Sat Dec 03, 2011 6:56 pm
"The weights portion is a part of pay version."
I guessed as much.
But, the solids weight calculation is based on valid solids only, so anything leading up to creating and correcting a valid solid is moot. Whether or not there are intersecting solids is not important, except in total model weight, and even then, intersecting or co-resident solids is the modelers responsibility.
I have many models with multiple co-resident/intersecting solids as part of the intended design. For example in my big airplane design I have the landing gear in 5 positions, each position on separate layers. Full up, full down, down but compressed, and 2 in-transition. I do not expect the total weights calcs to know I only want the weight for 1 set. But I do want to know the weight of each solid part that makes up 1 set. For total model weight I rely on an EXCEL spreadsheet.
So, if you can cleave the weights portion out from the total script, having only the code that defines the material density and weight of any solid (based on a single material for all faces), that would be really useful. Most of the work is already done.
And if it were free to use in true SU spirit, it would go a long way to advertise your full function paid script.
__________________
jgb
User avatar
jgb
SketchUp version: 8
Postby voljanko » Sat Dec 03, 2011 10:22 pm
The whole idea of SuSolid plugin is coming from my need to draw a metal cabinet for production.So, step by step I realised that is good to draw everything in base of solids that can be manipulated with the Solid Tools and also to have the weight information always available.So I had to deal with a lot of small mistakes hidden deeply in sub components.The next need was to check for potential overlaps that already cost me some money for correcting the cabinet sample.
So this set of tools are proven to be very efficient for the real production job and I don't have any intention to break them apart.
voljanko
Postby driven » Sun Dec 18, 2011 5:46 pm
it would be very useful if the loader was a plain .rb file.
at the moment it can't be launched from a separate directory which limits it's usability for a lot of 'ruby' uses who organise there rubies in sub or separate directories/folders.
I also get this on a normal load with only this [+ the debug ruby's] in plugins and although it runs it may cause issues for SU or other rubies.
Error Loading File /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/susolid
no such file to load -- /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/susolid
driven
Top SketchUcator
License type: Pro
Postby voljanko » Tue Dec 20, 2011 5:55 am
Thanks John for pointing this out.I will check it and include the solution in the next version(expected this year).
voljanko
Postby jonorman » Mon Sep 03, 2012 10:47 am
ERROR MSG..
Never seen this before. My favourit tool, never had an issue with it. now this after reinstalling SU 8 PRO. any idea
jonorman
Postby voljanko » Mon Sep 03, 2012 12:29 pm
jonorman wrote:ERROR MSG..
Hello,
no problem,you just need a newer version.
Please send me an email to info@susolid.com an I will send you a new version.
David
voljanko
Postby jonorman » Thu Sep 06, 2012 6:50 am
Thank you.
New version works just fine. This is a great plugin and I`m still hoping for a COG feature ;)
jonorman
Postby tomot » Wed Mar 13, 2013 1:03 am
Its important to revive this thread, in light of David's ruby, which is capable of removing interior faces from solids. This can become a big deal if you import 3d geometry from other programs into SU. In addition its a requirement to remove interior unwanted faces if you intend to create 3D printed output of your geometry.
For additional discussion, here is my initial inquiry about this topic:
viewtopic.php?f=323&t=22920&start=705#p462200
cheers!
tomot
SketchUp version: 8
SketchUp use: architecture
Postby iantyson » Fri May 17, 2013 9:41 pm
The susolid free 1_1 version caused massive bug splats on my HP laptop. Windows 7, separate video card, i7 processor and lots of ram. I had to go through all my plugins to locate this one as the culprit. Next time I will load one plugin at a time and utilize sketchup to see if the latest plugin addition is not compatible. Instead I loaded plugins like crazy only to have this one give me bugsplats. Hope someone avoids the bug hunt like I had.
iantyson
by Ad Machine » 5 minutes ago
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: fswar, HAL, lila, uncu and 9 guests
