by joergber » Thu Oct 20, 2011 8:20 am
Hi, I would like to share my plugin ... Just copy the dxf_export.rb file in your plugins folder. You'll find it in 'Tools->Export to DXF' It outputs polygons|polylines|cirles|arcs|lines to DXF (contours only) (2d orientation for circles and arcs  these do not have a 3d one but the centerpoint is positioned in 3d space) 3d rotated circles and arcs will be output segmented (lines) polygons, polylines, lines, 3d circles, 3d arcs as lines2d cirles, 2d arcs as circles and arcs (NOT lines) !!! I did this because I use the DXF with heekscnc to generate milling operations (G-Code). Milling a circle or an arc is much faster than several lines ... I had some trouble with the rotation of the arcs but I think I did it  dxf_export.rb History:*** v0.0.4 (2011-10-28) - fixed arc orientation (finally?) - model won't be exploded anymore - 3d rotated circles & arcs export to lines *** v0.0.3 (2011-10-22) - fixed arc orientation - improved objects assignment ( faster) - corrected calculations ( x/2 returned int and not float as needed  ) - automatic unit detection (to be tested  ) Any arc orientation testers online? Comments still welcome! Jörg
joergber
- PluginStore Author
- Name: Jörg Bergmann
by Bep » Thu Oct 20, 2011 4:57 pm
First quick test ,and it workt fine Thanks , Bep
"History is written by the winners"
Bep
- Location: Brunssum Netherlands 50°56'40.91"N 5°58'55.97"O
- Name: Bep van Malde
- Operating system: Linux
- SketchUp version: 2016
- License type: Pro
- SketchUp use: landscape architecture
- Level of SketchUp: Intermediate
by derei » Fri Oct 21, 2011 7:18 am
Thanks a lot for this plugin! I tested it and it seems to have some bugs as follows: -it explodes everything in model. -it doesn't export faces. -some arcs are oriented wrongfully. - funny fact is that the built-in SU8-PRO exporter does the same. -it behaves differently if everything in model is selected, or if nothing is selected. -what DXF version does it export? (most milling software need DXF2000) I also need DXF for CNC milling. I posted some request here: viewtopic.php?f=323&t=40311&p=357180&hilit=batch+dxf#p356582 . Maybe your plugin can be tweaked to batch export each Component Definition(/group?) in a different file, on same folder, using Definition's name? Beloy you have: -resulted (exploded) SKP file -DXF from ALL SELECTED -DXF from NONE SELECTED (it asked to export entire model) -Image from NC HOPS (software for CNC Milling) which shows the wrongfully oriented arc.
derei
- Name: derei
- Operating system: Windows
- SketchUp version: 2015
- License type: Free/Make
- SketchUp use: product design
- Level of SketchUp: Advanced
by joergber » Fri Oct 21, 2011 8:31 am
Hi, thanks for your comments! This is a quick and dirty release ... But I couldn't await to release it and see if anyone needs it's functionality. About the bugs ... -it explodes everything in model.Yes! It explodes everything and then it loops through all edges and get's each connected. That's the way I try to find 'Objects'. I will change it to respect Groups and Components! But first I have to get rid of the orentation problem of the arcs!!!!!! -it doesn't export faces.This plugin does not process any faces (by now  ). -some arcs are oriented wrongfully.I know  If anyone knows a solution ... ... ... - funny fact is that the built-in SU8-PRO exporter does the same.I didn't know -it behaves differently if everything in model is selected, or if nothing is selected.Not in my environment (but I changed the script a bit). Pls. try again with the next release! -what DXF version does it export? (most milling software need DXF2000)Ups! I didn't care about any DXFversion! Just took the first spec I found. But in future I'll use DXF2000! dereeei, thanks for all information! Stay tuned! Jörg
joergber
by derei » Fri Oct 21, 2011 8:53 am
I'm very happy that I could help !  Indeed, I'm very interested in the development of this script, I'll be glad to test the next releases. For now, it doesn't bother me if it doesn't export faces, because for milling purposes, all I need are contours, arcs, circles, correct orientation and Layers (name, color). Indeed, respecting components (and groups, but not necessary), it would be a great thing! But take care to not process each instance of a Component Definition, because that would be redundant. Also, as I mentioned in the earlier post, if the content of each component would be saved as separate file in a chosen directory, would be awesome
derei
- Name: derei
by joergber » Sat Oct 22, 2011 6:57 pm
Hi, new Version v0.0.3 available! I updated the text and the dl-link in the first post and added something like a version history. Still feel free to comment ... And use the plugin as often as you can Greetings Jörg
joergber
by blajnov » Sun Oct 23, 2011 10:39 am
joergber wrote:...new Version v0.0.3 available!........
Error persists arc oriented incorrectly.
blajnov
- Name: yura
by joergber » Sun Oct 23, 2011 1:53 pm
blajnov wrote:Error persists arc oriented incorrectly.
Hi blajnov, can you pls. provide the source .skp file? So that I can reproduce here ... I have drawn something similar and opened in heekscnc and freeCAD. Both seem to be fine! Kind regards Jörg 2011-10-23.jpg
joergber
by blajnov » Sun Oct 23, 2011 2:59 pm
joergber wrote:........ Hi blajnov, can you pls. provide the source .skp file? So that I can reproduce here ... I have drawn something similar and opened in heekscnc and freeCAD. Both seem to be fine! Kind regards Jörg
I opened the exported file in DraftSight. In AutoCAD 2008, similar. And when you export, create a file with no extension dxf Here skp files and dfx
blajnov
- Name: yura
by Bep » Sun Oct 23, 2011 6:01 pm
My drawing imported exploded and flipped also. I hope you get this fixed.
The audit report in Doublecad xt (free) reported:
AcDbArc(21). An invalid Normal direction (0 0 -2.54) was found. Validation: Invalid. Replaced by Normalized. AcDbArc(22). An invalid Normal direction (0 0 -2.54) was found. Validation: Invalid. Replaced by Normalized. AcDbArc(23). An invalid Normal direction (0 0 2.54) was found. Validation: Invalid. Replaced by Normalized. AcDbArc(24). An invalid Normal direction (0 0 2.54) was found. Validation: Invalid. Replaced by Normalized. AcDbCircle(25). An invalid Normal direction (0 0 2.54) was found. Validation: Invalid. Replaced by Normalized. AcDbViewportTable(8). An invalid Viewport *Active missing was found. Validation: . Replaced by Created. Audit recovered database. AcDbBlockTableRecord(1D). An invalid BlockBeginId was found. Validation: Invalid. Replaced by Created. AcDbBlockTableRecord(1D). An invalid BlockEndId was found. Validation: Invalid. Replaced by Created. AcDbBlockTableRecord(1B). An invalid BlockBeginId was found. Validation: Invalid. Replaced by Created. AcDbBlockTableRecord(1B). An invalid BlockEndId was found. Validation: Invalid. Replaced by Created. 54 objects audited Total errors found during audit 10, fixed 10
Greetings,
Bep
Bep
- License type: Pro
by TIG » Sun Oct 23, 2011 6:37 pm
The error report sounds like you are converting vectors from inches to cm when you should not - a vector [0,0,1] is normalized [0,0,2.54] is NOT. Only 'cm-ize' dimensions and leave vectors alone.
- Global Moderator
- Name: TIG
- SketchUp version: 2018
- License type: Pro
- SketchUp use: architecture
by joergber » Mon Oct 24, 2011 7:48 am
Hi, as mentioned above, the plugin does not export to correct DXF2000 format! By now (for example) arcs with startangle of 245° and endangle 13° can happen! I am not sure if this will be interpreted correctly by all importers or Autocad ... And there is no HEADER or TABLE section or any (ENTITIES only!) But I'll correct this in a future release! But I also noticed that my 'orientation-algorithm' was incorrect for arcs with odd number of edges ... I realized that the z-normal tells me if the arc was drawn cw or ccw ... Thanks to TIG, which gave me food for thought  Bep: Thank you for the report! I'll try Doublecad xt ...! (or let you generate the reports  ) TIG: Yes, I converted everything although normals shouldn't. Thank you! Give me a day or two to - 'fix' arc-orientation (again  ). - implement export of 3d oriented circles and arcs to lines ... - support Faces (however  ) - respect Components - not explode everything anymore! Thanks again to everybody! Jörg
joergber
by Dubman1013 » Fri Oct 28, 2011 2:04 pm
I imported this plug-in, when I select the items & export, it does not give me any file types to choose from, no DXF. Is there something I'm missing or is there another plugin to make this work? Thanks for any advice!
I just downloaded the new version, but it still does not give the dxf file type to save as. Any suggestion ?
Dubman1013
- Name: Jerry
by derei » Fri Oct 28, 2011 3:47 pm
Thank you, Jörg ! Today I had the occasion to use the updated version of the plugin, as I had to export some sketchup drawings as DXF for CNC. Despite it turns some arcs in AutoCAD, they are right oriented in CNC Software, and that is what I'm interested in. You made me very happy here! Good luck with the improvements
derei
- Name: derei
by joergber » Fri Oct 28, 2011 10:53 pm
new version v0.0.4 available ... I updated the first post.
Have fun! Jörg
joergber
by joergber » Tue Nov 01, 2011 12:41 pm
@Dubman1013 There is no filetype to choose from! The Plugin takes the current skp-filename and exchanges '.skp' with '.dxf' thats all! (For unsaved models the default filename is 'Untitled.dxf')
Just click 'Export to DXF' then choose the folder to save to and save the dxf. Before saving you may change the filename to your needs! (But don't forget '.dxf' at the end of the filename)
Have a nice day! Jörg
joergber
by Gumleguf » Sat Nov 05, 2011 10:04 pm
Thanks for a great plugin! I just sent a .dxf file to a friend and he could open it perfectly in SolidWorks. Next step is to CNC the part.  Edit: One thing. My friend just mentioned that when he opened the .dxf in SolidWorks it was in Inches even though I made it in mm. He could just change to mm, but still...
Gumleguf
- Name: Gumleguf
by joergber » Tue Nov 08, 2011 2:27 pm
Hi! Gumleguf: I can not reproduce here ... The only thing I could imagine is that you disabled the 'Display units format' setting (Window->Model Info->Units) but then there should have been a messagebox saying "Unable to detect the actual unit setting ...\nGenerate Output in inch?" and the whole DXF would have been 'inverted' because the units calculation factor is -1 in this case ... (will be fixed in next release!  ) Pls. let me know if the problem persists! And maybe you do have a screenshot that could help or the .skp file of your model ... ... ... Anyway, thank you very much for the feedback  More than 120 downloads and just this few problems/bugs/featurerequests/... Enjoy, Jörg
joergber
by Gumleguf » Tue Nov 08, 2011 2:36 pm
You are welcome, and thank you (!) for the plugin!  Here is an example of a sketchup that he says opens in Inches: GMaxx_bagplade1_1.skp
Gumleguf
- Name: Gumleguf
by joergber » Tue Nov 08, 2011 3:24 pm
Wohooo, that was fast I exported without any problems ... unitsProblem_001.jpg Here is my output ... unitsFactorProblem.dxf Could you pls. send this file to your friend to doublecheck? Could you pls. check the setting and try again?  If you select the measure tool in SU ... is the length displayed like '371,25mm'? Thank you! Cheers Jörg
joergber
by utiler » Tue Nov 08, 2011 11:46 pm
Hi joergber, Can you explain how this plugin differs to a standard SU export?
purpose/expression/purpose/....
utiler
- Top SketchUcator
- Name: Andrew
- SketchUp version: 2013
- License type: Pro
by joergber » Wed Nov 09, 2011 12:32 am
Hi, utiler: It might not have come out clearly ... I'm using SU 8 free (just updated my profile  ) And the standard dxf-exporter is for pros only ( as far as I know ) So ... I don't know how it differs to standard SU export  Is there a specific reason why you are asking? Respects Jörg
joergber
by utiler » Wed Nov 09, 2011 1:16 am
Only that I'm using PRO and wanted to know the difference; that's all.... thanks for the explain!
utiler
- Top SketchUcator
- Name: Andrew
- License type: Pro
by marcomartim » Fri Nov 11, 2011 8:18 pm
dereeei wrote:I also need DXF for CNC milling.
joergber wrote:I did this because I use the DXF with heekscnc to generate milling operations (G-Code). Milling a circle or an arc is much faster than several lines ...
Thanks for the plugin! I also use SketchUp to create files for CNC cutting. There is an excellent plugin to do the right Gcode in Sketchup, Phlatscript (SketchUcam) For more information, visit the site: http://www.phlatforum.com/viewtopic.php?f=15&t=38150&p=337062&hilit=phlatscript#p337062Hugs
marcomartim
- Name: marcomartim
by derei » Mon Nov 14, 2011 2:17 pm
I just found a bug in the program. As seen in image below, the unit format is disabled (to not show it in dimension lines). But, the exporter doesn't recognize the units that I used and wants to export by default in inch. My suggestion: if there is a program limitation for this situation, to replace the YES/NO message box with a list box with all units available. So, if the exporter doesn't recognize the units, to let the user choose. Another thing... I selected only the contour lines from a 3d object (the lines that formed one face), the exporter reported "one shape",but in DXF I had all lines exported of the solid. Is it possible to export ONLY what is selected? I mention that I was inside a component when I selected the outer shape of the face. One more thing: it would be useful to have the possibility to export in XY plane for all 2D shapes, regardless they are oriented on a different plane. This is the most useful DXF exporter I ever used. Actually, is the only one that is helping me  Thank you.
derei
- Name: derei
by joergber » Tue Nov 15, 2011 11:25 pm
dereeei: I recognized too that my unit detection was not fool proof and added a listbox ... It seems that we are working on similar tasks ... since I came across the same problems than you. Currently the exporter exports all connected entities of the current selection. So selecting a contour of a object will export the whole thing I am in the process of developing some kind of peprocessing tools ... The first one will be a drop tool where you can select any face of a model and it will be copied to z=0 and rotated to ground plane. But I'm neither familiar with Ruby nor Sketchup toolbars ... So this will take some time  Thanks again for your feedback! We read! Jörg
joergber
by derei » Wed Nov 16, 2011 12:09 am
@joergberWhy don't you simply use selected entities to build the dxf? Is more simpler for start... You can iterate trough all selected and check what are they. If there are edges only, use them to build a dxf. If there are also faces, add to dxf the edges that build that face. Because selecting a face is simple by double clicking. Usually a tool that selects a face, will select only a planar face, not a curved one (like a cylinder). To select that, I think you have to take into consideration the edge smoothing angle. So, I'm guessing that double click on a smooth face is pretty fast to not require a select tool (for now, at least). Thanks for still working on it
derei
- Name: derei
by Gumleguf » Fri Nov 18, 2011 7:53 pm
Sorry for the late reply. No, I haven't disabled "Display units format" and it still opens in inches: units.JPG
Gumleguf
- Name: Gumleguf
by Gumleguf » Mon Feb 20, 2012 1:23 pm
Hi Jörg,
Maybe I'm doing something wrong but here's one problem I have.
1. I create a 100mm x 100mm rectangle with some random circles, see attached file "Untitled.skp".
2. Using your fine tool I export it as "Untitled.dxf".
3. To print out my drawing I open the .dxf file in eDrawings (from Solidworks, version 12.2.0.110) and press the print button. I then see a windows where the drawing is scaled to 1:18.3926?
4. If I change the "Active sheet" setting "To scale (1 to 1)" the result is that the drawing get's massive big - you can only just see a small corner of a circle on an A4 sized paper.
Isn't that strange? And by the way, if I print out from step 3 the actual rectangle on paper is something like 137mm x 137mm and *not* 100mm x 100mm.
/Greg
Gumleguf
- Name: Gumleguf
by cgprosjekt » Tue Apr 17, 2012 10:33 pm
Hello Jörg! Just wanted to thank you for a wonderful plugin. We have struggeled alot with exporting .dxf files with true circle to our CNC machine software. And yours works perfect so far. You really made my day! Thanks
br Lars
cgprosjekt
- Name: Lars Aas Kjebekk
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Plugins
