Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11
Postby paihwai » Wed Sep 14, 2011 8:45 am
Oh!!!
paihwai
Postby gtalarico » Thu Sep 15, 2011 11:19 pm
I keep getting an error when trying to extrude a few curved letters...
"General Error: cannot complete the transformation"
Can someone give it try it a try and see if maybe it is something on my end?
Steps to reproduce:
1. Open groud
2. Select All.
3.Click on JPP (J)
[ Erase Original, border on all, make group, 30 deg]
4.Click on edge, pull, type 2", Enter
>Error.
User avatar
gtalarico
Postby driven » Thu Sep 15, 2011 11:44 pm
try booleenhelper.rb or scale X 1000 enter 2000" and it works here
driven
PluginStore Author
PluginStore Author
Postby Dave R » Fri Sep 16, 2011 11:10 am
Interesting. I could do one letter at a time at the current size. I selected about half of them and tried it and got a Bug Splat. :(
I tried doing limited groups of letters. The center row went fine as did the first two thirds of the top row. When I tried to do the last batch of letters in the top row, Splat!
User avatar
Global Moderator
Postby Rich O Brien » Fri Sep 16, 2011 11:18 am
I got splats on the 'r 'in 'marian' and 'heart'.
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby TIG » Fri Sep 16, 2011 11:19 am
At original size it Bugsplats big time! [probably a 'tiny facets issue' on the small curved edges in the R - but why not the P or & ?]
But Scale x100 and then JPP 200" [on the whole thing at once], then Scale back down x0.01m to get this good/swift outcome
User avatar
Global Moderator
Postby gtalarico » Sun Sep 25, 2011 1:55 am
Scaling helped. Thanks! ;)
Never thought it make a difference... is because SU doesn't like expressions with number like 0.00000000000000000000000000000000002003 ? :roll:
User avatar
gtalarico
Postby ayan13 » Fri Sep 30, 2011 4:07 am
great plugins ! I use it a lot! Thank you !!!
User avatar
ayan13
Postby jgb » Fri Oct 14, 2011 4:36 pm
I just got that "transformation" error as well. :o
While the attached SKP is documented, here's what happened.
There are 2 errors depicted in the attached model.
1 - I tried to thicken (using JPP preset at 90 deg) the housing by .1 inch. Error.
I read this thread and scaled up 10X, same result.
If I do the hub and flanges separately, it works, but there is a mess to clean up.
2 - When I thicken any pair (or more) faces that are at an angle to each other, and any face has a hole in it, the hole thickens at some median angle, not perpendicular to its face. The circle on the thickened face is also distorted into an oval/ellipse.
There is one other transformation error I've noticed as well, but seems to happen in specific repeatable cases where the transformation logic is simply stumped for a good solution.
Ya kant code for every case.... bin-der dundat. :lol: (Well respected Indian explorer)
I'll post a separate model of that problem if wanted.
So now in those cases I know where to look and do a quick and simple fix.
Believe me, JPP is a Golden Ruby I cannot live without. :sketchstatic:
Apologies... First post I forgot the SKP file. :oops:
__________________
jgb
User avatar
jgb
Postby helios » Fri Oct 14, 2011 5:43 pm
My apologies if this was answered before, but is it possible to use this plugin to uniformly add thickness to a cylinder-like object? I created it by pulling a circle (and then scaling it at several points) and now would like to add some thickness to the currently hollow object, as it is going to be 3D printed. I am, in essence, trying to pull all the outside surfaces at a perpendicular angles.
Many thanks!
helios
Postby jgb » Fri Oct 14, 2011 7:34 pm
Yes. Use the Joint Push/Pull (not the Vector). Select the surface of the cylinder and using the JPP tool, click on any face in the selection. It will outline in red. Pull it up as thick as you want, or more accurately, pull up a short distance and type the thickness to the Measurements box. Press <Enter> to get a preview, then <enter> again to complete the thickening.
Depending on the defaults you have for JPP, it may or may not form a group of the thickened section.
You can explode the group if you want.
__________________
jgb
User avatar
jgb
Postby mitcorb » Sat Oct 15, 2011 12:35 am
@helios: Not to disparage such a fine tool as Joint Push/Pull, but a possible alternative is Pipe Along Path. Slightly different methodology, but similar result.
User avatar
mitcorb
Top SketchUcator
Postby jgb » Sat Oct 15, 2011 5:21 pm
mitcorb wrote:@helios: Not to disparage such a fine tool as Joint Push/Pull, but a possible alternative is Pipe Along Path. Slightly different methodology, but similar result.
Yes, but PAP is not a tool for this problem. I use PAP a lot and its main advantage is making a tube or pipe along an arbitrary path.
There are a few other solutions available to thicken the surface of a cylinder, or any shape, either in a straight line or a path. Follow-me is a so-so useful tool for a non-linear path. Making a circle with both inner and outer diameters then extruding the outer ring is probably best, but linear paths only.
However, JPP is the only tool I know of that will equally thicken all surfaces, linear or not, and even bent/wavy surfaces, which was the case indicated by @helios. Think of an hour-glass. :!:
__________________
jgb
User avatar
jgb
Postby helios » Wed Oct 19, 2011 12:38 am
Thank you for the quick replies! It looks like this plugin is what I am after.
helios
Postby ar_max » Thu Oct 20, 2011 10:29 am
Thank you very much.
Used to feel very good.
Sorry.
Not good at English. :D
ar_max
Postby derei » Thu Oct 20, 2011 1:22 pm
Is it JPP polygon-limited ?
I have a curved face and I wanted to add thickness to it. Unfortunately, JPP only affected a part of entire mesh.
See below.
DESIGNER AND ARTIST DEREI.UK
User avatar
derei
Postby mitcorb » Thu Oct 20, 2011 1:26 pm
Could it be that the faces were pulled internally because of the direction of your pull and the inference engine trying to snap to a vertex? I don't know, just asking.
User avatar
mitcorb
Top SketchUcator
Postby derei » Thu Oct 20, 2011 1:51 pm
mitcorb wrote:Could it be that the faces were pulled internally because of the direction of your pull and the inference engine trying to snap to a vertex? I don't know, just asking.
I'm not sure what you are asking...but if is what I think it is, it should be valid only for small distances and only for mouse movement. Or, I moved the mouse to avoid snapping and I input a value in VCB.
User avatar
derei
Postby fredo6 » Thu Oct 20, 2011 5:06 pm
dereeei wrote:Is it JPP polygon-limited ?
See below.
JPP has a limit for displaying the feedback wireframe (5000 faces) but I don'th think I put one for the processing.
I'll check that and come back.
User avatar
PluginStore Author
PluginStore Author
Postby Rich O Brien » Thu Oct 27, 2011 9:28 pm
Hi Fredo,
I've Joint PushPull assigned to 'J' shortcut. When I select all geometry and press 'G' to 'Make Component' then 'Set component axis' if I press 'J' during the placing of the axis SU will Bugsplat.
It doesn't do this for any other keyboard assigned plugin.
It doesn't do it if nothing is assigned to 'J'.
It doesn't do it if a native tool is assigned to 'J'.
It doesn't do it if another plugin is assigned to 'J'.
There are no messages in the Ruby Console. I'm using all the latest version of your plugins.
I know that not pressing 'J' solves it
User avatar
Rich O Brien
Administrator
Postby helios » Thu Oct 27, 2011 11:49 pm
After a few days, I'm still struggling to give one of my hollow models some thickness.
I created a model that looks sort of like this (i.e. a curve spun around the Z axis):
I then select everything, click Joint Push/Pull, and enter a distance that is my desired thickness (e.g. 10mm). Some sort of calculation happens, but when I check on the model's thickness, it appears unchanged:
What am I doing wrong? How can I get the walls to be thicker?
helios
Postby helios » Fri Oct 28, 2011 12:17 am
Here's the model in question itself (attached).
helios
Postby Dave R » Fri Oct 28, 2011 12:58 pm
It worked for me although I probably added the thickness in the wrong direction.
After you select the JPP tool, hit TAB and make sure you've selected "Thickening". If you have "Erase Original Faces" selected, the original faces will get erased and you won't get the thickness. Another thing I did was split the operation into several smaller ones by selecting sections of the shape. I started at the bottom and selected just the surface below the belt and ran JPP on it. Then I worked my way up from there.
User avatar
Global Moderator
Postby mitcorb » Fri Oct 28, 2011 1:19 pm
I would have guessed that faces need reversing, and overall size of the object would need scaling to produce the effect, but this may not apply here.
User avatar
mitcorb
Top SketchUcator
Postby Dave R » Fri Oct 28, 2011 1:23 pm
You're right. the faces were all reversed but that and the size of the thing didn't affect the operation in this case.
Helios, I did forget to mention the face orientation thing and that you ought not to work so far from the origin.
I updated the file to put the thickening on the inside so the little detail at the top shows correctly. The model could stand a bunch of cleanup but I'll leave that to you.
User avatar
Global Moderator
Postby helios » Fri Oct 28, 2011 7:19 pm
Wow, you guys are awesome. Thank you so much -- this is way beyond what I expected for help!
helios
Postby Gardentwine » Tue Nov 01, 2011 8:22 pm
hi This is great script and use it often in creating stuff for my Hammer editor(source), the only thing it takes a while cause i have to do each face separately, is there or is it posible for this script to allow me to select more than one face and then group each face separately and still get the same results, (not sure if this would cause overlaping solids)
Gardentwine
Postby fredo6 » Tue Nov 01, 2011 11:09 pm
Gardentwine wrote:hi This is great script and use it often in creating stuff for my Hammer editor(source), the only thing it takes a while cause i have to do each face separately, is there or is it posible for this script to allow me to select more than one face and then group each face separately and still get the same results, (not sure if this would cause overlaping solids)
JPP precisely works on group of faces (just select them and activate the script).
Unless I miss something.... :?:
User avatar
PluginStore Author
PluginStore Author
Postby ultrapom_79 » Thu Dec 29, 2011 3:57 am
thank you very much!
ultrapom_79
Postby fatcap » Fri Jan 06, 2012 9:51 am
Thank you so much Fredo! :enlight: :enlight:
fatcap
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: Realistic Renderer, Revitopoulos, rubyreloaded, TONYHUNG9899 and 8 guests
Visit our sponsors:
