[Plugin] Chronolux for Sketchup
Postby kirill2008 » Sun Oct 09, 2011 9:33 am
Link to download Chronolux installer for Windows chronolux_1_1_beta.exe
Link to download zip archive chronolux_1_1_beta.zip
Description: Extension for Google Sketchup written on Ruby. Its goal is to test insolation duration and SVF.
Usage:
1) install the program using installer or unpack files from zip-file:
- "chronolux_ext.rb" and "Chronolux" folder unpack to Google Sketchup "Plugins" folder
- "chronolux.strings" and "chronolux" folder from "Resources/en-US" unpack to Google Sketchup "Resources/en-US" forlder
2) enable "LSS Chronolux Toolbar" Sketchup Main Menu>>View>>Toolbars>> LSS Chronolux Toolbar
3) open a Sketchup model, where insolation and/or SVF testing is to be made (model has to be geo-located)
3) add some test points to perform insolation and/or SVF testing
ver. 1.0. video:
Visit program web-site for more info.
Terms and Definitions
Duration of Insolation at a given point is the time period while direct sunlight reaches the test point.
Insolation is the solar radiation that reaches the earth's surface. It is measured by the amount of solar energy received per square centimetre per minute. (Note, that Chronolux does not calculate insolation, but only its duration).
SVF (sky view factor) is the extent of sky observed from a point as a proportion of the total possible sky hemisphere. (A Dictionary of Earth Sciences | 1999 | AILSA ALLABY and MICHAEL ALLABY).
WVF (window view factor) is the extent of sky observed from a point as a proportion of the total possibly observable sky from a point through a window (despite of shadowing objects outside the window).
ver 1.0 beta 1
fixes
- resource file (chronolux.strings) has a proper syntax now
- some patches were added in code to avoid encoding issues in localized versions
ver 1.1 beta
New features:
- Interactive Resize Tool
- Pick Test Surface Tool
- Pick Window Face Tool
Updates:
- Global Settings dialog
- Time Settings dialog
Fixes:
- Refresh command works properly even if test points were added inside a group
- Report maker generates report without duplicating information about SVF and WVF
ver. 1.1 video
kirill2008
PluginStore Author
PluginStore Author
Re: [Plugin] Chronolux for Sketchup
Postby watkins » Sun Oct 09, 2011 10:35 am
Dear Kirill,
The video link doesn't seem to be working when viewed here, but works if you go to your website.
This looks to be a very useful plugin for building design and the positioning of renewable energy systems. I will watch its development with interest.
Thank you for all your hard work.
Kind regards,
Bob
watkins
Postby Didier Bur » Sun Oct 09, 2011 11:27 am
ThaaaaAAAAAAAnnnnnNNNNk You ! :ecstatic: :berserk: :ecstatic: :berserk: :ecstatic: :berserk:
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
User avatar
Didier Bur
Postby toto ete » Sun Oct 09, 2011 12:10 pm
:enlight: thanks kirill :thumb:
:enlight:
toto ete
Postby mitcorb » Sun Oct 09, 2011 1:07 pm
Hi, kirill:
Long time, no see :)
User avatar
mitcorb
Top SketchUcator
Postby pilou » Sun Oct 09, 2011 1:22 pm
Fiat lux! :fro:
Speedy Galerie
User avatar
Top SketchUcator
Postby mitcorb » Sun Oct 09, 2011 1:28 pm
Hi, Pilou:
Long time, no see you, either. :mrgreen:
User avatar
mitcorb
Top SketchUcator
Postby pilou » Sun Oct 09, 2011 1:29 pm
@Mitcorb
I have made some translations for the French Section ! :mrgreen:
Next will be the "Doh Tread"!
In French "Aaaaaaaaaahhhh bon sang, mais c'est bien sûr!" :D (not yet started : sure next week! :oops:
Speedy Galerie
User avatar
Top SketchUcator
Postby kirill2008 » Sun Oct 09, 2011 4:51 pm
Hi to all! Thanks for kind words! It's so great to be here again! :thumb: :)
Did anyone try to install? Or demo video is the only reason to thank at the moment :)
I use free installer for Windows programs Inno Setup. It works well on my laptop :thumb: I'm going to test it tomorrow at work as well (yes, the whole thing is not tested yet too...).
kirill2008
PluginStore Author
PluginStore Author
Postby notareal » Sun Oct 09, 2011 7:44 pm
Wow! Welcome back, kirill!
notareal
Thea Render Support
Thea Render Support
Postby boofredlay » Sun Oct 09, 2011 8:11 pm
All I get is "Invalid Parameters" when trying to view the video.
User avatar
boofredlay
Global Moderator
Postby TIG » Sun Oct 09, 2011 8:15 pm
Boofredlay wrote:All I get is "Invalid Parameters" when trying to view the video.
I edited his video tag so it now works ;)
User avatar
Global Moderator
Postby boofredlay » Sun Oct 09, 2011 8:18 pm
Cheers TIG. :thumb:
User avatar
boofredlay
Global Moderator
Postby baz » Sun Oct 09, 2011 10:31 pm
'SVF and Insolation'.
I would like to learn more about this, I've done a google on the terms above but I can't find out what they mean, any pointers?
Ta, baz
I am both an early bird and a night owl, I am some form of permanently energized dragon.
User avatar
baz
Postby Panga » Mon Oct 10, 2011 8:52 am
Awesome tools !! Thanks a lot!!
Panga
Premium Member
Premium Member
Postby Pixero » Mon Oct 10, 2011 9:54 am
Is there any way it can take transparent materials in account?
In my tests it acts as if a glass surface is opac.
User avatar
Pixero
Postby kirill2008 » Mon Oct 10, 2011 10:18 am
Yes it is possible. It's necessary to set "Handle transparency" flag in "Global Settings" dialog to "Yes". It is also necessary to pay attention to "Transparency threshold" value.
This flag is set to "No" by default because it takes a little bit more time to handle transparency so when it's set to "Yes" it slows down script processing.
kirill2008
PluginStore Author
PluginStore Author
Postby Edson » Mon Oct 10, 2011 12:52 pm
have you tested it on mac? perhaps all one has todo for it to run on mac is to perform a manual installation. if this is the case, could you please instruct us on how to make a manual installation? should I place the whole thing in my plugins folder?
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
User avatar
Edson
Global Moderator
Postby driven » Mon Oct 10, 2011 1:55 pm
Edson wrote: should I place the whole thing in my plugins folder?
NO...
the manual installation requires placing different folders in different locations.
the 'Help' button in tools won't work from inside SU so I suggest you 'first' open the 'Help Pages' in safari to check if you want to instal it.
to do this 'unzip' Chronolux 1_0 beta.zip and you'll have a new folder Chronolux 1_0 beta,
follow the path to Chronolux 1_0 beta/Resources/en-US/chronolux/index.html and double click to open in Safari.
If you still want to instal manually he's a pic of the paths...
I haven't tested the whole thing yet, but you do need to turn on the toolbar in 'View' >> 'Tool Palates'
driven
PluginStore Author
PluginStore Author
Postby Edson » Mon Oct 10, 2011 2:14 pm
thanks, john. it seems easy enough o install. I will give it a try soon.
User avatar
Edson
Global Moderator
Postby mirale999 » Mon Oct 24, 2011 9:25 am
Wonderful thing! This is a good plugin for me to decide the shape of a building intuitively :lol:
"Test face results presenting" can give us one more choice: Pseudo-color map, like that in ecotect,
and in qpik's plugin: simple rays, the ray casting is more even and smooth. I think with this great plugin, we can get rid of the ecotect! haha~
paranoia is a higher form of awareness...
mirale999
Postby kirill2008 » Tue Oct 25, 2011 5:30 pm
mirale999 wrote: we can get rid of the ecotect! haha~
Well, actually solar radiation studies is not the only merit of ecotect ;) but thanks anyway :lol:
kirill2008
PluginStore Author
PluginStore Author
Postby urgen » Wed Oct 26, 2011 8:05 am
....супер! :thumb: :thumb: :thumb:
--pupil forever...------
User avatar
urgen
Postby georglorenz » Sat Nov 05, 2011 4:13 am
This is incredible. This is unbelievable awesome. I was amazed by simple rays but now years after. And working with Revit all the time. This is incredible.
georglorenz
Postby georglorenz » Sat Nov 05, 2011 4:35 am
Ok this is really interesting and the user interface is just great.
I do understand that it calculates the shading from a specific test point but could you elaborate a little bit on the difference between short rays and long rays and what exactly they do?
Thank you so much / gxl
georglorenz
Postby georglorenz » Sat Nov 05, 2011 4:36 am
Oh and then there are construction points and test points? I understand test points but what are construction points? Thank you / gxl
georglorenz
Postby EarthMover » Wed Nov 09, 2011 6:41 pm
Kirill, looks amazing. I am also trying to find a sketchup plugin method which will chart sun path and perform a reflection/glare study. I need it for solar panel applications to determine the amount of glare produced based on the angle of the panels per geolocation and it's affect on neighboring buildings in a given radius. I was wondering if something like this could be adapted from the tools you have created here, with a similar raytrace, but charting also a single light bounce for a visual representation? Or, if anyone is aware a software/plugin on the market that will accomplish this?
Content Creator at Skapeup
User avatar
EarthMover
Premium Member
Premium Member
Postby kirill2008 » Fri Nov 25, 2011 11:18 am
georglorenz wrote:Oh and then there are construction points and test points? I understand test points but what are construction points?
Well it is possible to place construction points using Sketchup "Tape Measure" tool instead of placing test points using Chronolux "Add Test Point..." tool. Then it is possible to select construction points and process all of them at once using "Make Ray Cluster(s)" or "Calculate SVF" commands. So it's just an optional usage scenario.
I think it could be more convenient sometimes to use construction points for some reason.
georglorenz wrote:I do understand that it calculates the shading from a specific test point but could you elaborate a little bit on the difference between short rays and long rays and what exactly they do?
Short rays and long rays are only for graphical representation of calculation results. It is possible to adjust their length if it is necessary for drawing layout.
EarthMover wrote: I am also trying to find a sketchup plugin method which will chart sun path and perform a reflection/glare study.
Adam, I think, it is possible to implement. I think, I need to read somewhere about how to calculate reflection/glare amount and then think of how to represent calculation results. I suspect, that glare amount depends on direct sunlight duration, but I don't know how exactly. I'm not sure but I guess the other thing, that glare amount depends on, is an angle between sunlight direction and panel plane. In short it is necessary to search for some additional information on this subject.
kirill2008
PluginStore Author
PluginStore Author
Postby boilingsnow » Wed Dec 28, 2011 8:38 pm
Hi,kirill2008
Thank you for your wonderful tools.
Just as brilliant as your earlier plugins such as ControlPoints...
It's sad that most of your earlier plugins dont work in Sketchup 8....Could you please update them? I would pay for these great tools.
boilingsnow
Postby kirill2008 » Thu Dec 29, 2011 5:07 am
boilingsnow wrote:It's sad that most of your earlier plugins dont work in Sketchup 8....Could you please update them?
Yes, I'm going to update "LSS Toolbar", but I don't know exactly when. I'll try to make it in the coming months.
kirill2008
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: badralpantera, ICH88, Mattsana, strmbr, tiagopc and 7 guests
Visit our sponsors:
