SketchUcation Premium Membership
[Plugin] Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)
Re: Caleidos4D Ribbon Pubblic Beta 1
Postby Krisidious » Sun Oct 24, 2010 10:08 pm
Majid,
the plugins only work if you have that particular plugin already installed. these are shortcuts to other author's plugins. so if one is not working, you should check to see that you have that plugin. there is a rtf file or readme within the zip that lists the plugins that are used by the bar.
let's see which one's you have that are not working?
Kristoff Rand
Home Designer
Custom House Plans with a Point of View
User avatar
Krisidious
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby Krisidious » Mon Oct 25, 2010 3:23 am
hmmm... so you have the plugins installed that you're trying to use in the ribbon and it's not working?
do you have organizer.rb running?
have you checked to see that you have the
/caleidos4d
Caleidos4D_Ribbon.rb
in the plugins folder?
Kristoff Rand
Home Designer
User avatar
Krisidious
SketchUp version: 8
License type: Pro
Postby iwanwidjaja » Mon Oct 25, 2010 7:11 am
Hi Caleidos4D,
Its a great plug in, thanks for share it :berserk:
Just a little curiosity, will it possible to make some option to choose between portrait and landscape configuration of the ribbon? As many of us use wide screen monitor, the modeling space begin to shrink in a very wide proportion when the ribbon is active :lol:
Regards'
Iwan
iwanwidjaja
Postby majid » Mon Oct 25, 2010 5:11 pm
thanxs mates for your kind helps :) .the question is that it doesn't display anything ( I mean that I have installed the plugs..etc... and also created a simple qube) ... I can't see anything...any red-green-blue axes ...etc...
درصورتيكه به مساله اي برخورديد(مثل وارد نشدن به سايت، فراموش كردن پسورد و غیره با ما تماس بگیریدhttp://sketchucation.com/contact
User avatar
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Level of SketchUp: Intermediate
Postby EarthMover » Mon Oct 25, 2010 6:40 pm
Majid, I believe you Caleidos4D Ribbon is covering your Sketchup window. You have to minimize it and then resize both the Sketchup window and the Ribbon to fit on the screen together. You can put the Ribbon above the Sketchup window or below, or on a second monitor, but the ribbon does not dock within Sketchup. It is a floating web dialog that overlaps Sketchup, so some resizing is necessary for it to all fit in your monitor.
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
User avatar
EarthMover
Top SketchUcator
Postby majid » Tue Oct 26, 2010 5:15 am
thanx again.... I was thinking that it will cover my sketchup screen , so that I get rid of all plugin toolbars... :( (as I saw a black screen on some screenshots above) . maybe it could be an option for next update ,plz . :) it workes fine in way you described. thanx again
User avatar
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Postby Caleidos4D » Tue Oct 26, 2010 6:53 pm
thank to all friends for help in topic :up: my english is very bad....
this is a .gif for usage and preview features in next release
Caleidos4D
Postby troyhome » Tue Oct 26, 2010 8:29 pm
Caleidos4D wrote:thank to all friends for help in topic :up: my english is very bad....
can't wait to try this out- in English :)
Etch-A-Render
SU Pro 8.0.4810 Mac/ SU Pro 8.0.4811 PC
Thea: (MacOSX 32bit) RV481_v1.0.7 (SU2TH .86)/ (PC 64bit) RV481_v1.0.7 (SU2TH .86)
Vray: VfSU 1.49.01
troyhome
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby Jim » Tue Oct 26, 2010 11:52 pm
Caleidos4D wrote:For translate:
in the next version, I will translate the tooltips in English but I also accept suggestions :D
Well, I appreciate this because I only know English; but I was also trying to come up with a language translation strategy in order to provide translations to any language.
I think JavaScript can be used to iterate over the tooltips, and set the Text according to the tooltip id (for example.)
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Bob James » Fri Oct 29, 2010 5:42 am
troyhome wrote:
Khai wrote:all I'm getting at the link is
"alterVista
La risorsa richiesta è accessibile qui
you have to click "qui"
I'm afraid I can't even find "La risorsa richiesta è accessibile qui so I can click on "qui" :( :oops:
Update
I got it by pasting in "http://caleidos.altervista.org/Download/caleidos4d_Ribbon.zip" and it automatically downloaded.
"If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
"Bad is not good until worse happens" - Bob James
User avatar
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Re: Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)
Postby Caleidos4D » Fri Oct 29, 2010 8:05 pm
Update: 1.1 ;)
Caleidos4D
Postby EarthMover » Sat Oct 30, 2010 3:36 am
Nice update. English tooltips are perfect! Any plans to add FredoScale?
Some of my 3D crap
User avatar
EarthMover
Top SketchUcator
Postby Caleidos4D » Sat Oct 30, 2010 4:45 pm
I wanted insert SfedoScale and BezierSpline, already in this release, but I can not find the call for the plugins in various fredo's libraries ...
Caleidos4D
Postby tony bombata » Wed Nov 03, 2010 1:07 pm
renderplus rpedits copy selection tool bug splatted EVERY time i ran the command - so i started removing my most recent plugins - and caledios was the culprit :(
tony bombata
Postby kyyu » Tue Jul 12, 2011 8:48 pm
Caleidos4D,
Thanks for the plugin. Looks interesting. Got a question. When you select the major frames on the left side (Costruction[oops,btw spelling error], Projection, 2D, Modelurs,..etc), they change to a highlighted orange color. But when you select another, any previous ones are still hightlighted orange. Wondering if this is a bug?
Oh, and an off topic question. Is there a easy html editor for laying out buttons, like this, on a webpage? Or wondering what editor, you used? I mean, if a beginner wanted to make the html portion of a web UI, like this. I can make a simple one by hand, like a column of buttons, but not like this.
-Kwok
kyyu
Postby Caleidos4D » Fri Sep 23, 2011 9:42 am
Caleidos4D
Postby guanjin » Tue May 01, 2012 1:41 pm
This fun, I can be free to load the new plug-in, strong :fecstatic:
User avatar
guanjin
SketchUp version: 8
License type: Free
SketchUp use: interior design
Postby majid » Fri Jun 29, 2012 7:43 am
dear mate, I like your plugin , and here saw a request, that seems to be combined in your plugin:
viewtopic.php?f=10&t=46094
do you mind to play with your interface please? I guess it'd be a great step forward . :thumb: thank you again
User avatar
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Postby heglisonmarques » Wed Nov 21, 2012 10:33 pm
Como faço para instalar o Caleidos4d
heglisonmarques
SketchUp version: 8
License type: Pro
Re: [Plugin] Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010
Postby mitcorb » Thu Nov 22, 2012 3:29 pm
I think you are asking how to install this plugin?
I believe there is a link to an external website or hosting site and you must download from there. Looks like it may be "caleidos4d.blogspot.com"
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
by Ad Machine » 5 minutes ago
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: 84allison, ladoncella, moabut and 5 guests
