SketchUcation Premium Membership
[Plugin] 2D Tools v5.3 20120929
Re: [Plugin] 2D Tools v5.0 20100927
Postby Michaelv » Wed Mar 16, 2011 6:28 pm
amsketcher wrote:I installed 2D tools (thanks TIG) on my OS X SketchUp Pro trial version but I can't get dashed lines to stay dashed.
I select dashed line style, draw the 2D line (and it looks dashed) but as soon as I double-click to end the line, the line is laid down as solid.
What am I missing?
If what you're trying to do is draw thing as construction lines, it doesn't work on the Mac.
Here are some tools that will let you use clines on the Mac.
You need to replace the original tools inside the 2DTools folder by these (make backups of the originals!). They are however based on version 4.6 of TIG's tools, but they work fine as far as I know. I don't know of any core modifications done between version 4.6 and 5.0 of these tools and I haven't checked the script to make sure, but it shouldn't be an issue. For Mac users they give you access to all options. For PC users you don't need them (I don't know how the modifier behave, and haven't checked).
Michaelv
Postby SketchUpNoobie » Thu Apr 28, 2011 10:32 pm
Hmmm. I've used this great plugin many times before but I'm experiencing issues now.
I have a rectangle that I want to fillet. I select the fillet tool, enter the fillet radius, and select my first line. Everything is normal. Then when I select my second, perpendicular line, *poof* everything disappears. :? It deletes everything in the model.
TIG, am I doing something wrong? Has anyone else experienced this issue? Are there any known workarounds? I am running Windows XP SP2 and SketchUp 7 if that makes a difference. The weird thing is, chamfer works fine.
It's no big deal if I just fillet it manually. I'm just wondering what I'm doing wrong and what I can do to fix it.
SketchUpNoobie: the complete noob in all things SketchUp.
SketchUpNoobie
Operating system: Windows
SketchUp version: 8
License type: Free
SketchUp use: hobby
Level of SketchUp: Beginner
Postby TIG » Fri Apr 29, 2011 5:09 pm
SketchupNoobie wrote:Hmmm. I've used this great plugin many times before but I'm experiencing issues now.
Nothing's changed recently with the code.
It should work fine with your OS & SUp version too...
A mystery :?
I don't think it's deleting everything in the model - rather some 'corrupted' geometry is made miles away and the model's extents are knackered...
There's no known workaround because it's not a problem I knew of till now :roll:
What size is the rectangle?
What size is the fillet radius?
What units are you using etc ?
Can you post an example SKP where the problem occurs etc...
Without more to go on I can't yet help :(
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby SketchUpNoobie » Fri Apr 29, 2011 5:29 pm
3'6" by 4"
1"
Imperial. (feet and inches)
fillet_test.skp
TIG wrote:I don't think it's deleting everything in the model - rather some 'corrupted' geometry is made miles away and the model's extents are knackered...
No, sorry. You're right. It only deletes the rectangle I am working on. About corrupted geometry, I don't know. If I make the rectangle a component first, and edit that, the component boundaries shrink to the size of one that has no entities. I hope I made sense there. :? What I mean is, if I go into the model info box after the geometry is deleted, no entities show up. It is truly deleted.
SketchUpNoobie
SketchUp version: 8
License type: Free
SketchUp use: hobby
Postby TIG » Fri Apr 29, 2011 5:39 pm
As you can see I have no issues with 2d filleting - Vista + v7 or v8
Have you tried reinstalling the 2Dtools in case one is somehow corrupted [I can't think how it might be though!].
Have you tried repairing your Sketchup installation in case it's corrupted in some minor way ?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby SketchUpNoobie » Fri Apr 29, 2011 5:43 pm
TIG wrote:Have you tried reinstalling the 2Dtools in case one is somehow corrupted [I can't think how it might be though!].
Reinstalling 2Dtools now. How would I go about repairing my SketchUp installation? :?
SketchUpNoobie
SketchUp version: 8
License type: Free
SketchUp use: hobby
Postby TIG » Fri Apr 29, 2011 5:47 pm
No exactly sure on XP - perhaps someone else can chip in too - on Vista... Exit all apps... Then Control Panel > Programs & Features...
Find Google Sketchup v7 in the list, highlight and click UnInstall/Repair button. When prompted choose Repair and it should run and repair the installation.
If that doesn't work you might need to do a full install - it shouldn't affect any Plugins etc you have installed already...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby SketchUpNoobie » Fri Apr 29, 2011 5:53 pm
I found how to do it but it can't find the installer for SketchUp. I must have deleted it. How could I completely reinstall SketchUp 7.1? Is there some place you know that I could download it from?
SketchUpNoobie
SketchUp version: 8
License type: Free
SketchUp use: hobby
Postby TIG » Fri Apr 29, 2011 5:55 pm
Luckily it's linked here viewtopic.php?p=315903#p315903 :o
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby SketchUpNoobie » Fri Apr 29, 2011 5:57 pm
TIG wrote:Luckily it's linked here viewtopic.php?p=315903#p315903 :o
Thanks. :D And do I have to do anything to keep all my plugins, styles, templates, etc.?
SketchUpNoobie
SketchUp version: 8
License type: Free
SketchUp use: hobby
Postby TIG » Fri Apr 29, 2011 6:18 pm
If you do a 'reinstall' it should keep all of the already added stuff and simply renew the required program files.
To be on the safe side you could always make copies of your Templates, Components, Materials, Styles and Plugins folders etc and then reinstall, after that check if the custom Templates, Scripts etc are still there, if not you have copies to move over.
It's a good idea to have a back-up copy of your custom files/folders in case of a disaster anyway - I suggest you burn a CD/DVD of them and keep it safe for unforeseen problems...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby SketchUpNoobie » Fri Apr 29, 2011 6:24 pm
TIG wrote:If you do a 'reinstall' it should keep all of the already added stuff and simply renew the required program files.
But I'm not really reinstalling am I? I'm going from v.7.1 to v.7.1pro trial. I have all the files backed up on DropBox so I should be good.
SketchUpNoobie
SketchUp version: 8
License type: Free
SketchUp use: hobby
Postby TIG » Fri Apr 29, 2011 6:27 pm
The difference between Free and Pro is minimal on the install - they are very similar and the core program parts are the same - it's just that after the time limit is up some v7.1 features no longer work, unless it's fully licensed...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby SketchUpNoobie » Fri Apr 29, 2011 7:08 pm
I reinstalled both 2Dtools and SketchUp but I'm still getting the same thing. Is the plugin conflicting with another plugin or program? Weird thing is, every other part of the plugin works. It's just the fillet tool that I'm having problems with. :?
SketchUpNoobie
SketchUp version: 8
License type: Free
SketchUp use: hobby
Postby TIG » Sat Apr 30, 2011 10:18 am
As all of the 2Dfillet's methods are wrapped in a class, and it only uses built-in API calls... I'd expect no clashes.
Have you tried resetting hardware acceleration etc in preferences to see if that is affecting anything [clutching at straws here!]
To check if script that loads after 2Dtools IS messing something up you could try and copy/paste this into the Ruby Console + <enter>
load '2Dtools/2DfilletTool.rb'
Then try to use the 2Dfillet tool - if it works we know something is clashing if not we are no worse off...
If it's still bust try temporarily renaming 'Plugins' as say 'Plugins_Disabled' and then make a new 'Plugins' folder; now copy into that the following files/folder that are needed for the 2Dtools to work:
    2Dtools folder with all of its contents intact
    2D#.rb
    deBabelizer.rb
Restart Sketchup.
If 2Dfillet now works we know there's a clash with something that's now not loading.
If you've recently added some scripts try copying those over a few at a time and restart/test to see if you can still use 2Dfillet.
If you get a culprit let me know
Remember to copy the scripts so the origin set of plugins is not changed.
Swap the Plugins folders' names around so the origin is now called 'Plugins' again...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby SketchUpNoobie » Sat Apr 30, 2011 1:10 pm
TIG wrote::? Have you tried resetting hardware acceleration etc in preferences to see if that is affecting anything [clutching at straws here!]
No luck.
TIG wrote:To check if script that loads after 2Dtools IS messing something up you could try and copy/paste this into the Ruby Console + <enter>
When I use the tool, the same thing happens. I get this error in the console. Error: #<NoMethodError: undefined method `explode' for nil:NilClass>
C:/Program Files/Google/Google SketchUp 7/Plugins/2Dtools/2DfilletTool.rb:404:in `create_geometry'
C:/Program Files/Google/Google SketchUp 7/Plugins/2Dtools/2DfilletTool.rb:197:in `onLButtonDown'
TIG wrote:If it's still bust try temporarily renaming 'Plugins' as say 'Plugins_Disabled' and then make a new 'Plugins' folder; now copy into that the following files/folder that are needed for the 2Dtools to work
Wahoo!!! It works! :ecstatic: I'll add stuff back in and let you know when I find out what plugin it is that was causing the problem.
I should have tried this first. :oops: I will in the future.
SketchUpNoobie
SketchUp version: 8
License type: Free
SketchUp use: hobby
Postby TIG » Sat Apr 30, 2011 1:24 pm
The error you [eventually] reported occurs after some grouping and copying etc - it's obviously failing.
We seem to be looking for something that overwrites base classes like group methods. I know SketchyPhysics has caused some problems in the past - try re-enabling that if you have it, and see what happens...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby SketchUpNoobie » Sat Apr 30, 2011 2:56 pm
TIG wrote:The error you [eventually] reported occurs after some grouping and copying etc - it's obviously failing.
Sorry for not checking that sooner. :oops: Not sure what you're saying about grouping . . . :?
TIG wrote:I know SketchyPhysics has caused some problems in the past - try re-enabling that if you have it, and see what happens...
Re-enable? Like reinstall? If I copy over all the plugins except for SketchyPhysics and it's components, the fillet tool works so SketchyPhysics seems to be the guilty plugin. Should I just reinstall it? I don't really use it so I could just delete it.
SketchUpNoobie
SketchUp version: 8
License type: Free
SketchUp use: hobby
Postby TIG » Sat Apr 30, 2011 3:06 pm
Many complex tools do some temporary 'grouping' in the back ground, although by the time you see the result they've been erased or exploded etc.
2Dfillet is one of them.
Some tools rewrite some base classes' methods which can mess up other tools using them.
If the error only occurs with SketchyPhysics 'loaded' then move it back into the disabled 'set' and then try all the rest.
If you still have a working 2Dfillet tool and you don't need SketchyPhysics so much leave it disabled...
You can always swap back briefly when you need it.
When I said 'reinstall' I just mean move from the disabled set into then Plugins folder...
You could also check you have the latest version of SketchyPhysics as it might have fixed this issue... :?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby SketchUpNoobie » Sat Apr 30, 2011 3:37 pm
Alright, I just disabled SketchyPhysics for now. If I need it I'll go download the newest version.
Thanks a ton for taking the time to help me out TIG. And thanks again for this awesome plugin. :sketchstatic:
SketchUpNoobie
SketchUp version: 8
License type: Free
SketchUp use: hobby
Postby TIG » Sat Apr 30, 2011 7:22 pm
That's why we are here... to try to help those that try to help themselves... :enlight:
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby SketchUpNoobie » Sat Apr 30, 2011 7:40 pm
TIG wrote:try to help themselves...
That rarely ever works. :roll:
SketchUpNoobie
SketchUp version: 8
License type: Free
SketchUp use: hobby
Postby ed1732 » Fri Jul 08, 2011 4:58 am
it might help a lot
ed1732
Re: [Plugin] 2D Tools v2.2
Postby define » Sun Aug 07, 2011 5:55 pm
EarthMover wrote:
define wrote:if one 'sotospeak' could make the 2dtools work with
your 'work-planes' too? This would make it into something even more versatile.
This would in fact be quite redundant. The work planes are used in a similar manner to the 2D tools, as they create a "shield" to prevent the inferencing of the native tools to the geometry on the opposite side of the plane. You can draw directly on it as it's a locked group and delete it at will. The 2D tools do much the same except they are restricted to the X,Y axis for 2D drawing, but still allow you set the Z, which creates an invisble 2D work plane on that height. The work plane plugin allows similar restriction, only it's not restricted to X,Y only and it works with the native toolset. You could technically set a work plan on the x,y axis at a Z height and use the native tools to draw in restricted 2D. Using the 2D tools to go the other direction would negate them from being 2D at all.
hello earthmover,
I came back to this task from one year ago, since I just searched the forum for my own entries on this issue.
You have to know, that I'm comming from the CAD-world with their 'sketch-planes' (solidworks and the like)
and it would come in handy in sketchup, if I could use the 'workplane command' like these too.
I would like to be able to constrain/project any points that I catch in 3d 'over' that workplane to the workplane.
Same like setting the z-elevation to zero or else with the 2d-tools..but to any given plane.
Only difference: projecting any snaps in 3d-space onto that plane in 'normal' direction.
If there's an option for this, please let me know. did'nt find it. best claude
define
Postby TIG » Sun Aug 07, 2011 7:38 pm
Seek out my WorkPlane tools...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby hc3 » Thu Sep 22, 2011 3:58 am
I'm having a bit of trouble getting the fillet tool to work. The other 2D tools functions I've tried seem to work.
I select line one, enter radius e.g. " 3" ", when I hover over the second line as soon as the "2 line box" appears the radius entry clears, this is before I click on the line.
I've tried different things over a two day period, maybe spent 4 hours on trying different jungle dances to get the thing to work. Almost for sure it is something lame I'm doing. Any suggestions appreciated. Thanks. -Henry
System is Vista and SU8. Downloaded 2D Tools 5.0, extracted all from the download folder to the plugins folder, the two files and a folder mentioned were there. I then started SU8. Made two lines 1' long joined at the origin and along two axes. Clicked on fillet icon, clicked on a line, entered " 3" " in the radius box, tried clicking on line 2 as mentioned above.
hc3
Postby hc3 » Thu Sep 22, 2011 4:16 am
I just posted was having trouble with fillet, now it is working.
Sorry, not sure what was going on. Seems OK now.
hc3
Postby hc3 » Thu Sep 22, 2011 3:17 pm
The issue is back - fillet not working again.
Looks like the issue is related to the fillet icon cursor hover and/or finding the second line.
The fillet cursor is now finding lines where there are none. Also as previously mentioned when the second line is identified, but not selected, by the "Line 2" box popping up the radius input box goes to zero. Even re-entering the radius doesn't work, when the radius is entered the "Line 2" box near the cursor goes away, this goes back and forth.
My machine is an ASUS K50IJ Series, SU8 free, Vista. I'll keep trying and see if I can identify when it works and doesn't. I have Center Point, PipeAlongPath, ToggleUnits running at the same time. Maybe Toggle Units is the culprit.
hc3
Postby TIG » Thu Sep 22, 2011 3:32 pm
Henry
What errors do you get if you try to run the tool with the Ruby Console open.
Are the two lines coplanar and in the same context ? :?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby hc3 » Thu Sep 22, 2011 4:01 pm
TIG wrote:Henry
This is very embarrassing. It appears the issue is I need to press enter after putting in numbers in the radius entry box. I think I'm OK now. Thanks, sorry to bother you.
hc3
by Ad Machine » 5 minutes ago
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: ahegdal, Fredo6, jac_1224, JRicard and 10 guests
