SketchUcation Plugin Store
Wipe Out - help
Wipe Out - help
Postby Roger » Sun Sep 11, 2011 2:52 am
I accidentally wiped out my basic set of colors and textures for SU8. Is it kosher to ask someone to mail me the folder that comes with SU8?
And what is the proper path to the materials folder?
Thanks.
Roger
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
Re: Wipe Out - help
Postby Gaieus » Sun Sep 11, 2011 7:51 am
I guess there's no real problem with sending the files although you can simply re-install Su and that will not "touch" any of your settings but replace all missing files.
Roger wrote:And what is the proper path to the materials folder?
What is your OS first of all? On my 32 bit XP it is
C:\Program Files\Google\Google SketchUp 8\Materials
User avatar
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Level of SketchUp: Advanced
Re: Wipe Out - help
Postby Roger » Sun Sep 11, 2011 3:12 pm
Thanks Gai. So if I reinstall 8pro, it will not affect my installation of Twilight. Is that correct?
Roger
SketchUp version: 8
License type: Pro
SketchUp use: other
Re: Wipe Out - help
Postby Dave R » Sun Sep 11, 2011 3:19 pm
Roger, the only thing that will happen if you reinstall SU8 Pro is that it'll replace anything that is missing from the original install. It shouldn't mess with anything else like toolbars or additional styles or material libraries you've installed.
Inspecting mirrors is a job I could easily see myself doing.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Re: Wipe Out - help
Postby Gaieus » Sun Sep 11, 2011 6:03 pm
It should not affect your Twilight installation. In fact, when SU 8 came out, I just copied all my plugins from SU 7 (including Twilight) and it worked. All its files (including license data) are additional files which are not affected by anything SU adds.
User avatar
Administrator
SketchUp version: 8
License type: Pro
Re: Wipe Out - help
Postby Roger » Mon Sep 12, 2011 5:01 pm
Thanks all, I am back and functional. FYI. When SU is first installed the materials folder is locked. So when you try to use the "options" screen in Twilight Render to change paths after doing an upgrade the new path will not take. Unlocking the folder made life a lot easier.
Roger
SketchUp version: 8
License type: Pro
SketchUp use: other
by Ad Machine » 5 minutes ago
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Ad Machine
Robot
Return to Components, Materials & Styles
Who is online
