Fredo6 wrote: But it may not be true with other unzip utilities.
it's empty, but in there on the mac as well, Stuffit Expander...
Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17Re: [Plugin] Joint Push Pull - v1.8a - 01 May 11
it's empty, but in there on the mac as well, Stuffit Expander... john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: [Plugin] Joint Push Pull - v1.8a - 01 May 11I use 7-zip and there is an empty JPP_Dir_17 folder once unzipped.
Oh and ![]() ![]() ![]() Re: [Plugin] Joint Push Pull - v1.8a - 01 May 11I just used Windows to open the file. I don't use third party applications for zip files. No need.
Re: [Plugin] Joint Push Pull - v1.8a - 01 May 11Here's a screenshot of the current archive which I just opened in AlZip - the v1.7 folder IS still there...
![]() TIG
Re: [Plugin] Joint Push Pull - v1.8a - 01 May 11Fredo6,
Thanks so much for upgrading already useful toy! Have a nice day! Re: [Plugin] Joint Push Pull - v1.8a - 01 May 11I see the same folder structure in WinZip v14.5...
The JPP_Dir_17 is empty, but it's there... Any way... Thanks A LOT for this... ![]() Cheers
Kim Frederik
Re: [Plugin] Joint Push Pull - v1.8a - 01 May 11I can confirm that the unwanted empty v17 folder is no longer in the zip file
![]() TIG
Re: [Plugin] Joint Push Pull - v2.0a - 16 Jul 11NEW RELEASE
version 2.0a - 16 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom. Note that the parameter "angle of influence" is no longer used. See main post for download. Fredo
Re: [Plugin] Joint Push Pull - v2.0a - 16 Jul 11Thanks Fredo. Much appreciated
![]() There's a frontroom and a backroom....reverse faces
Re: [Plugin] Joint Push Pull - v2.0a - 16 Jul 11Great stuff Fredo, thanks.
Baz I am both an early bird and a night owl, I am some form of permanently energized dragon.
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11NEW RELEASE
version 2.0b - 17 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom. Note that the parameter "angle of influence" is no longer used. Version 2.0b also includes the Italian translation See main post for download. Fredo
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11![]() ![]() Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11Will this plugin allow me to perform a 1/2" roundover on perpendicular intersecting edges?
Example of desired finished result: Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11Hi, BBLV:
You will want to try Fredo's Round Corners, which will do that, plus chamfer, plus radiused corner and edges. Joint PushPull is a multiface simultaneous extrusion tool. I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11using this plugin when i push pull a curved surface i have to manually delete the original surface that was push pulled. is there any way that this plugin jointpushpulls just like a normal push. and not like a ctrl+pull that makes a new face? For example i just want this yellow extrusion to be a part of the whole solid.
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11With face and tool selected...
Press TAB to open dialogue box Choose Finishing Options Pick option There's a frontroom and a backroom....reverse faces
I chose thickening, then erase original faces, then keep original faces. All the options are giving the same results with the lines :? Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11What is your question? Your image doesn't show anything useful as far as a problem is concerned.
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11It's not a telepathic tool - just erase lines and faces that YOU don't want!
yes it works like a Ctrl+pull. Actually, doing like the native push pull is much more complex for: - creating holes - merging the surfaces after push pull Note however that in most cases, JPP is used for complex surfaces where the standrad push pull would not be effective. So the continuity of surface won't really happen. I suggest you simply erase the unwanted lines. Fred
In the case shown above is it possible that the pulling is like a normal pull? My shape isn't complex enough :lol: Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11
If I understood well can't you just use the "vector pushpull"? Anyway here you have the behaviour of the three tools. Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11Feature request: Option to disable the Context Menu.
+1 ![]() [I have already tweaked my copy so that there's no context-menu, as there are already too many things clogging mine up!] TIG
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11Yea - I use to tweak it myself. But for each update I need to do it all over again.
