[Plugin] Set Arc and Circle Defaults
Postby openhatch » Thu Sep 01, 2011 11:45 pm
Description : When SketchUp loads, this script selects the circle tool and changes the number of sides to the circle (to predifined user preference), then selects the arc tool and changes the segments in the arc (also to user preference). This way it effectively sets their "defaults" (to lower or higher numbers) according to user preference. As this script comes "shipped", it sets the sides of a circle to 12, and the segments in an arc to 6.
(The defaults for sides of a circle and segments in an arc could be directly set via SketchUp's Ruby API.. if it let you do that. It doesn't as of SU V8.)
This script requires the eventrelay plugin (windows only at this writing), or EventRelay.dll, and includes a version of that .dll known at this writing to work. eventrelay is available at http://code.google.com/p/eventrelay/
Author : Alex Hall (c) 2011
http://blog.openhatch.net/contact/
Released under the GNU GPL v2
Installation: At this writing, and unless eventrelay is ported to the Macintosh, this plugin is for Windows only. Copy these files into the Sketchup Plugins directory:
    EventRelay.dll
    SetArcCircleDefaults.rb
    setArcCircleDefaults-config.txt
(For example, Google Sketchup 8's plugin directory on Windows 7 defaults to: "C:\Program Files (x86)\Google\Google SketchUp 8\Plugins" - copy these files there in that case. Then, start Sketchup. For help finding the plugin directory look in the forums: search.php?keywords=plugin+folder+OR+directory )
Usage : To alter the "defaults" which the script sets for sides of a circle and segments of an arc, go to the "Plugins->Set Circle and Arc Segments Defaults", enter the desired values in the popup box, and click "OK".
POSSIBLE CAVEAT: If you select any window besides SketchUp while SketchUp is loading, it may type key-presses to change these settings into some document or web browser text box etc. It seems the script avoids that by typing an inert {TAB} key, but if your set "defaults" for the Circle and Arc tool don't load with SketchUp, make sure you don't select any other windows after starting SketchUp to load.
You could also modify the script to exploit any of the functionality of the eventrelay plugin.
For defaults, numbers divisible by four may be advisable, as they will provide vertices at right angles along the perimiter of the circle, which makes for easy rotation and geometric snapping/angular construction.
Future plans: possible exception handling for any errors related to config file.
Version history:
[UPDATE] 1.1 Revamped from scratch, incorporating suggestions by AlexMozg. Added config storage to setArcCircleDefaults-config.txt file in plugin directory (with setting via "Plugins->Set Circle and Arc Segments Defaults" menu.)
1.0 08/11 Planned updates : none. Could have menu option to alter and store "defaults"; not programming that. Anyone else is free to.
openhatch
Re: [Plugin] Set Arc and Circle Defaults
Postby Bob James » Fri Sep 02, 2011 6:46 am
Thanks, openhatch, I'll use this often.
User avatar
Bob James
Premium Member
Premium Member
Postby AlexMozg » Fri Sep 02, 2011 7:24 am
Without "EventRelay.dll"
Safer to use the method "send_action" to activate the tool, because that hot keys of these tools can be modified.
Code: Select all
require 'sketchup.rb'
unless file_loaded?(file_name = File.basename(__FILE__))
Kernel.require 'win32ole.so'
wscript = WIN32OLE.new("WScript.Shell")
Sketchup.send_action   "selectCircleTool:"
UI.start_timer(0, false){
   for key in %w|12 {ENTER}| ; wscript.SendKeys key; end
      Sketchup.send_action   "selectArcTool:"
         for key in %w|6  {ENTER}| ; wscript.SendKeys key; end
         UI.start_timer(0, false){Sketchup.send_action   "selectSelectionTool:"}
file_loaded(file_name)
AlexMozg
PluginStore Author
PluginStore Author
Postby thomthom » Fri Sep 02, 2011 8:30 am
AlexMozg wrote:Without "EventRelay.dll"
+1
User avatar
PluginStore Author
PluginStore Author
Postby Vicspa » Fri Sep 02, 2011 4:13 pm
Hope someone takes you up and does a menu option.
Vicspa
Postby Bob James » Fri Sep 02, 2011 6:14 pm
vicspa wrote:Hope someone takes you up and does a menu option.
+1
User avatar
Bob James
Premium Member
Premium Member
Postby openhatch » Fri Sep 02, 2011 10:12 pm
Ha!
Thanks to AlexMozg for rewriting it a better way! :D
(I have little idea what that code actually does, BTW)
That rewrite only ran after I found a copy of win32ole.so and dropped it into the plugins folder. The copy of the file I found was linked from this thread.
Is that file what I should use then (or is it safe)?
openhatch
Postby openhatch » Sat Sep 03, 2011 8:34 am
So.. okay.. I added a plugin menu option to alter and store "defaults". :)
And per suggestion, the code uses Sketchup.send_action to avoid problems of hotkeys changing.
I encounted an undesirable side effect with SendKeys via win32ole.so (and found the same limitation with eventrelay's SendKeyMacro): if Sketchup was loading for a while and I (for example) had a web browser open with a text box, while Sketchup was out of focus, SendKeys would type the macro (for example "12s") into the browser's text box! - appearing to make ghost typing (could be creepy for a user) but also not typing it into SketchUp's Value Control Box.. and so not changing any setting!
After quite a bit of frustration, and observing that strangely the second parts of the macro (for the Arc tool settings) didn't type into the web browser window, but in fact got in to SketchUp.. however those magic brackets and start_timer(s) work, they seem to alleviate it.. I finally got the error to apparently go away by placing an inert {TAB} before the macro for Circle Tool (as Circle Tool was to Arc Tool (whose settings worked), so Tab is now to Circle Tool).. blah blah :roll: but it apparently worked:
Code: Select all
    myEventRelay.SendKeyMacro("{TAB}")
      myEventRelay.SendKeyMacro(circleSides.to_s + "s{ENTER}")
        myEventRelay.SendKeyMacro(arcSegments.to_s + "s{ENTER}")
Sticking with eventrelay over win32ole; it seems to load and execute faster.
openhatch
Re: [Plugin] Set Arc and Circle Defaults 1.1 2011-09-03
Postby Involute » Tue Nov 22, 2011 1:59 am
I'd love to get this to work, openhatch, but I'm unfamiliar with plugins. Can you give me some pointers (cut and paste the code to a file, save it in plugins directory, etc.)? Thanks.
Involute
Postby openhatch » Wed Feb 29, 2012 1:10 am
Involute wrote:I'd love to get this to work, openhatch, but I'm unfamiliar with plugins. Can you give me some pointers (cut and paste the code to a file, save it in plugins directory, etc.)? Thanks.
Sorry I missed this reply. Added to usage notes in the post is this answer:
Extract the files in the .zip archive to your plugins folder (for example, in Windows 7, this is usually "C:\Program Files (x86)\Google\Google SketchUp 8\Plugins"), and start Sketchup.
[Edit:] no, that answer is already in there under installation instructions... ;)
openhatch
Postby Christmended » Fri Feb 27, 2015 9:14 pm
Any plans to make this work in SU2015? Mine doesn't work.
Christmended
Postby rustystumps » Mon Mar 02, 2015 6:51 pm
Dito on the Not working in V15 of SU. Really would like this.
rustystumps
Postby rustystumps » Wed Apr 13, 2016 7:29 pm
2016 and still waiting for a Ruby Script for this. The one mentioned previous is old and the required second file is not readily downloadable.
I manufacture models and use the SU files to print on my Form1+ 3D printer to make masters for RTV Silicone molds so finished parts are then cast in resin plastic.
I need smooth arcs and curves and most, if not all, of my models have plenty of these.
rustystumps
Postby Dave R » Thu Apr 14, 2016 1:53 am
You might want to set about writing your own script for this. The author of this plugin hasn't been active here for four years. He might have moved on to other things.
User avatar
Global Moderator
Postby thomthom » Thu Apr 14, 2016 2:37 pm
Might be good to try to reach out to the developer and see if he'd be willing to open source it and put it out on GitHub. IMO that would be better than rewriting from scratch.
User avatar
PluginStore Author
PluginStore Author
Postby driven » Thu Apr 14, 2016 5:39 pm
does this work in v14 and above?
I don't use PC's but I'm looking for code that does something similar to this...
Code: Select all
require 'win32ole'
val =  48
circle_first = UI.start_timer(1.0, true) do
   if Sketchup.active_model.tools.active_tool_name != 'CircleTool'
      Sketchup.send_action('selectCircleTool:')
   else # run the script
      WIN32OLE::new('WScript.Shell').SendKeys("#{val}{ENTER}")
      p "#{val}{ENTER}"
      UI.stop_timer(circle_first)
      arc_next = UI.start_timer(1.0, true) do
         if Sketchup.active_model.tools.active_tool_name != 'ArcTool'
            Sketchup.send_action('selectArcTool:')
            WIN32OLE::new('WScript.Shell').SendKeys("#{val/2}{ENTER}")
            p "#{val/2}{ENTER}"
            UI.stop_timer(arc_next)
driven
PluginStore Author
PluginStore Author
Postby TIG » Thu Apr 14, 2016 6:36 pm
Here is a v8...v2016 beta RBZ... of "TIG-CircleArcDefaulter"
It uses different methods across the various SketchUp versions...
Note that it's for Windows only...
I think it works OK... :?
The defaults.txt file contains the default [new] segment counts for circles and arcs [its shipped values are 48 and 24 respectively].
These are used to reset those defaults as SketchUp starts...
The Plugins/Extensions menu contains a new TIG-CircleArcDefaulter submenu...
Its items let you:
1. Edit the defaults.txt file to set new defaults [which are then reused thereafter].
2. Reset the defaults to the two values currently saved in the defaults.txt file [run this after saving your edit]...
If there is positive feedback I'll publish it as a new Extension in the PluginStore...
User avatar
Global Moderator
Postby TIG » Fri Apr 15, 2016 3:08 pm
Here's an update on my recent beta RBZ...
v2.0 of "TIG-CircleArcDefaulter"
It works on v8...v2016 and it now works on both PC and MAC :ugeek:
It uses different methods across the various SketchUp versions and OS...
As with the original PC only version...
The Plugins/Extensions menu contains a new "TIG-CircleArcDefaulter" submenu...
Its items let you:
If there is enough positive feedback I'll publish it as a new Extension in the PluginStore...
PS: I did a post a while back about 'versines' and how to consider faceting in 3d-printing etc...
viewtopic.php?p=577465#p577465
These simple snippets [" & mm] were written to let you input the radius, versine-tolerance [typically 1/1000"] and a swept-arc - and get back a corresponding segmentation suggested for the arc - since smaller radii are different from bigger objects etc...
PPS: As you know, @driven is a MAC guru, and he has pointed out in a PM that users with the latest OSX [my test MAC is one OSX behind!] might have Apple trying to protect them from the sort of operations need to circumvent SketchUp's segment-defaulting as it starts up... If you do get error messages and have some system knowledge you can probably set it to be allowed, alternatively let us know because @driven probably has a work around, but that does involve using a 3rd party app that'd need shipping for MAC uses...
User avatar
Global Moderator
Postby TIG » Sat Apr 16, 2016 4:32 pm
v3.0 of "TIG-CircleArcDefaulter"
It now has a trap [thanks to @driven] to ensure that the SketchUp viewport is foremost as the 'reset' is done...
As with the previous version...
Its items let you:
1. Edit: the "defaults.txt" file to set new defaults [which are then reused thereafter].
2. Reset: the defaults to the two values currently saved in the "defaults.txt" file [run this after saving your edit]...
I'll repeat the PSs [modifed]...
PPS: @driven, the MAC guru, has pointed out that users of the latest OSX might have their Apple trying to protect them from the sort of operations need to circumvent SketchUp's segment-defaulting as it starts up...
If it does this, then please follow this guidance to allow SketchUp.app access to your computer...
https://support.apple.com/kb/PH21504?locale=en_US
User avatar
Global Moderator
Postby TIG » Sat Apr 16, 2016 7:57 pm
v4.0 of "TIG-CircleArcDefaulter"
It uses different methods across the various SketchUp versions and OSs...
It now has a MAC trap [using 'cliclick' - thanks to @driven] to ensure that your OSX doesn't try and stop its system-level resetting.
Its items let you:
I'll repeat the various earlier PSs [modifed]...
PPS: @driven, our bestest MAC guru, has pointed out that users of the latest OSX might have their Apple trying to protect them from the sort of operations need to circumvent SketchUp's segment-defaulting as it starts up...
This version should circumvent this, if it does not please let us know, in the meanwhile see this...
User avatar
Global Moderator
Postby Bob James » Sat Apr 16, 2016 8:52 pm
TIG wrote:If there is enough positive feedback I'll publish it as a new Extension in the PluginStore...
My vote: :thumb:
User avatar
Bob James
Premium Member
Premium Member
Postby TIG » Mon Apr 18, 2016 10:14 pm
Here's another update of my recent beta RBZ files...
v5.0 of "TIG-CircleArcDefaulter"
If sidesteps a possible MAC-only issue - which could arise if someone else were using the same app in their own Extension's code.
But now it's been properly separated...
See the previous posts about its usage etc, which remains the same...
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: Anne O Grady, ifraheem0332, Lawlsboy, Michel Baie, Simon19140, THANH MY, TIG, zmzmssmsm and 21 guests
Visit our sponsors:
