[Plugin] QuadFaceTools
Postby thomthom » Sun Aug 14, 2011 5:39 pm
Overview
Quads and Topology
A big deal of organic modelling workflow spin around good topology of quads (faces with four vertices/edges). Quads allows for many very useful mesh operations, such as selection rings and loops. Quads are predictable which is why they are so useful.
Many applications let you work with non-planar quads. In SketchUp however, it is not so easy. When you modify a vertex of a quad in SketchUp it auto-folds and breaks the quad into two triangles - where as other 3d applications might leave it as one unit.
At the core of every 3d applications, everything consists of triangles - the only difference is how they expose the triangles to the user. However, there is no reason why SketchUp users can't work with non-planar quads - it's just that the tools need to be aware of them.
Quads in SketchUp
This toolset is an attempt to begin on such a suite of tools to let SketchUp users work with quads. My approach is conceptually simple: When two faces are separated with a soft edge (smooth only affects shading) then the two faces are treated as one Unit. Click one and you select both and the Entity Info window says you have selected a Surface. Based on that, here is how I define quads in SketchUp:
QuadFace Definition
The definition of a QuadFace was changed again in version 0.6 because the previous versions relied on the Hidden property. The Hidden property is affected by a model's Scenes, so when you copied quad mesh into a new model you would loose the Hidden property of the diagonals.
To update a mesh from the older versions, use:
Tools > QuadFace Tools > Convert > Sandbox Quads to QuadFace Quads
  • Native quad face, face with four vertices.
  • Two triangles, joined by an edge with the following properties:
    • Soft = true
    • Smooth = true
    • Cast Shadows = false
  • Border edges can have any property, just not all of them.
  • Faces that makes up a QuadFace cannot have holes in them.
(Updated in 0.6.0)
Call to Developers
I'd encourage all plugin developers of plugins that generate geometry if what they generate can be made compatible with my definition of a QuadFace so we can expand the toolset for dealing with QuadFaces. QuadFaces is key to working with good topology in 3D modelling.
Project Hosting
This project is now hosted on BitBucket where the downloads and documentation exists.
Download
Download
Videos
UV Mapping
UV Transferring
UV Unwrap
UV Mapping Example
16
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] QuadFaceTools (0.1.0) — 14 August 2011
Postby thomthom » Sun Aug 14, 2011 5:41 pm
I meant to make some videos explaining quads in SketchUp, but I had no time this weekend. But I figured I'd still push it out there for the brave guineapigs who like to punish themselves with new unknown tools.
6
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] QuadFaceTools (0.1.0b) — 14 August 2011
Postby Gaieus » Sun Aug 14, 2011 5:49 pm
Holy crap, TT. I saw you post in the (other) forum to Pete and was wondering. Good news is that I seem to have some spare space in my toolbars...
:sketchstatic:
User avatar
Postby thomthom » Sun Aug 14, 2011 6:00 pm
It has been a wee little distraction from Bezier Surface, but not completely. As I need the same selection routines in both plugins. This has been a playground experiment. ;) Win-win!
User avatar
PluginStore Author
PluginStore Author
Postby Rich O Brien » Sun Aug 14, 2011 6:07 pm
I'd pay for this :thumb:
Excellent tool!
User avatar
Rich O Brien
Administrator
Postby Gaieus » Sun Aug 14, 2011 6:18 pm
Rich O'Brien wrote:I'd pay for this :thumb:
You said it - go ahead then!
(I also owe you a ton of cookies, TT!)
:D
User avatar
Postby EarthMover » Sun Aug 14, 2011 6:39 pm
SWEET! This has been a long time dream finally realized. :sketchstatic: Thanks for all your amazing contributions Thomas! We are lucky to have you in our community! :thumb:
Content Creator at Skapeup
User avatar
EarthMover
Premium Member
Premium Member
Postby fredo6 » Sun Aug 14, 2011 7:08 pm
Tom,
All my support for your initiative, which is, I believe a big undertaking.
As a contribution, I'll include an option to generate quads (under your definition) in Curviloft (the preview display is based on quads, precisely).
User avatar
Premium Member
Premium Member
Postby thomthom » Sun Aug 14, 2011 7:22 pm
Fredo6 wrote:As a contribution, I'll include an option to generate quads (under your definition) in Curviloft (the preview display is based on quads, precisely).
:thumb: :thumb:
That's great Fredo! :sketchstatic: The more tools we get that generate geometry like this the better topology we can create in SketchUp with better tools.
User avatar
PluginStore Author
PluginStore Author
Postby Pixero » Sun Aug 14, 2011 7:32 pm
This will be most useful. Thanks!
User avatar
Pixero
Postby Booman » Mon Aug 15, 2011 1:27 am
Awesome plugin... will definitely try out for some organic modeling
Booman
Postby EarthMover » Mon Aug 15, 2011 4:51 am
Been playing with it and it's really great. Thanks again. Been playing with Artisan meshes with some mixed results, but after a few Make Quad operations, I can get the whole mesh to quadrify.
Any plans on adding a Ring Connect option as a way to add additional loops?
User avatar
EarthMover
Premium Member
Premium Member
Postby thomthom » Mon Aug 15, 2011 7:31 am
EarthMover wrote: Been playing with Artisan meshes with some mixed results, but after a few Make Quad operations, I can get the whole mesh to quadrify.
I meant to make a whole video tutorial for that. It's best not to make the starting point at the edge of a mesh. That might yield some odd results. And holes in the mesh might also produce unexpected results. And I suspects meshes where the quads are not uniformly laid out, but need star connections could throw some odd results as well.
If you find that the quadification of a mesh yields odd results it might help if you manually quadify some of mesh first. A couple of quads around holes and star connections.
Got any sample models to share by the way. I did not have any organic models with regular mesh to test on.
EarthMover wrote:Any plans on adding a Ring Connect option as a way to add additional loops?
What is a Ring Connect?
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Mon Aug 15, 2011 8:36 am
EarthMover wrote:Been playing with Artisan meshes
Perhaps an idea to request Dale to add an option to generate the mesh as quads? That'd be pretty sweet.
User avatar
PluginStore Author
PluginStore Author
Postby Rich O Brien » Mon Aug 15, 2011 9:14 am
What's the icon at the end of Vertex Tools? I don't have it in mine?
User avatar
Rich O Brien
Administrator
Postby thomthom » Mon Aug 15, 2011 9:33 am
Rich O'Brien wrote:What's the icon at the end of Vertex Tools? I don't have it in mine?
Cursed your keen eyes! Now I have to kill you!
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Mon Aug 15, 2011 9:35 am
Gaieus wrote:Holy crap, TT. I saw you post in the (other) forum to Pete and was wondering. Good news is that I seem to have some spare space in my toolbars...
:sketchstatic:
By the way Gaieus, with meshes build from quads, making UV tools becomes easier.
It was in fact one of the biggest challenges I had/have with UV Toolkit, being able to sort the geometry into predictable chunks. Now I can build upon the requirement that the mesh is quads, which makes the traversing of the mesh and mapping much easier. ;)
User avatar
PluginStore Author
PluginStore Author
Postby Rich O Brien » Mon Aug 15, 2011 9:36 am
Mwah ha hah hah hah haaaaaaa :twisted:
User avatar
Rich O Brien
Administrator
Postby thomthom » Mon Aug 15, 2011 9:39 am
Rich O'Brien wrote:Mwah ha hah hah hah haaaaaaa :twisted:
Just for the sake for retaliation and mute your excitement, it's simply a Collapse function. So there! Hah! No magic!
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Mon Aug 15, 2011 9:42 am
In reality it's a function to call upon all my killer robots to home in on Rich - as you can see from the iconic representation. Yes, that is right, I'm giving everyone who buts Vertex Tools this mighty power! muhahahah!
User avatar
PluginStore Author
PluginStore Author
Postby Rich O Brien » Mon Aug 15, 2011 10:03 am
I'll use my Chuck Norris plugin :knockout:
Too extreme to release on this forum it's only for double hard bastards :thumb:
User avatar
Rich O Brien
Administrator
Postby EarthMover » Mon Aug 15, 2011 1:55 pm
It's fundamental for creating support edges for hard subdivision surfaces and to model organic surfaces while still maintaining quads. In Max, the Edit Poly Connect, gives you options to also slide and spread the loops along the width of the edge ring in order to "weight" the edges, define creases, etc. In Sketchup, you could always move a copy of a loop, but on an organic surface it doesn't always line up right. Even a simple option to connect edge rings at the midpoints would be helpful.
User avatar
EarthMover
Premium Member
Premium Member
Postby thomthom » Mon Aug 15, 2011 2:24 pm
Ah - Edge Connect - gotcha!
Yea, that would be a nice function.
User avatar
PluginStore Author
PluginStore Author
Postby boofredlay » Mon Aug 15, 2011 2:30 pm
Thanks for this Thomas.
User avatar
boofredlay
Global Moderator
Postby daniel s » Wed Aug 17, 2011 9:42 pm
Thank you Thomas!!!
A question: Is there a way to force the vertices of the quad to be coplanar?
If a quad consist of two triangles rotate this two triangles until they lay on the same plane and then delete the shared edge. Is that possible?
Daniel S
daniel s
Postby thomthom » Wed Aug 17, 2011 10:26 pm
Daniel S wrote:A question: Is there a way to force the vertices of the quad to be coplanar?
Yes, though, it'd also distort the connected faces.
(Vertex Tools let you do that - Make Planar)
User avatar
PluginStore Author
PluginStore Author
Postby mitcorb » Thu Aug 18, 2011 2:24 am
Elementary question:
What is the difference between a ring and a loop? I couldn't seem to figure out the images, or why one is called a ring and one is called a loop.
User avatar
mitcorb
Top SketchUcator
Postby thomthom » Thu Aug 18, 2011 6:19 am
mitcorb wrote:Elementary question:
Ring selects the next opposite edge in the connected quadfaces.
Loop selects the next connected edge at each vertex with a valence of 4 and does not share a face with previous face.
User avatar
PluginStore Author
PluginStore Author
Postby ken28875 » Thu Aug 18, 2011 8:07 am
You're a genius, Thomas!
Thank you so much. :thumb: :thumb:
_KN
Sketchup for Fantasy Art:
http://forums.sketchucation.com/viewtopic.php?f=81&t=27028&p=349117#p349117
Sketchup for Sci-Fi Art:
http://forums.sketchucation.com/viewtopic.php?f=81&t=27030&p=337096#p337096
My interview with Sketchupartists.org:
http://www.sketchupartists.org/spotlight/artists/sketchup-art-in-the-online-game-industry/
Follow Your Dreams.
User avatar
ken28875
Postby thomthom » Thu Aug 18, 2011 9:05 am
Daniel S wrote:Thank you Thomas!!!
Daniel S
I added a function that projects the selected faces ( any face ) to a best fit plane. ( Best fit plane is based on the selection ). It also ensures that quads connected to the selection are triangulated so they don't break due to SketchUp's AutoFold feature.
Then I added a separate Remove Triangulation function.
Both will be present in the next release. (Among other updates/changes)
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: AgungAsmara, coconm, Piac, tsb yuki , valdy and 11 guests
