[Plugin] View Parts (1.2) — Sept 13 2011
Postby cmd » Tue Aug 02, 2011 9:17 pm
The View Parts ruby script will build a scene for every unique component and group in a selection set.
The idea behind the ruby was to find a quick way to isolate and view each part of an assembly either for general viewing or to put into the SketchUp LayOut program for dimensioning and part arrangement.
Here is a video to see it in action:
UPDATE - 09-06-2011
Changed code to reflect best practices mentioned by TIG.
UPDATE - 09-13-2011
Menu load correction
Feel free to hack away at the ruby and improve it as you see fit.
Enjoy !
CMD
- CMD
User avatar
cmd
SketchUp Team
SketchUp Team
Re: [Plugin] View Parts
Postby Rich O Brien » Tue Aug 02, 2011 9:23 pm
Very useful. Thanks
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby EarthMover » Tue Aug 02, 2011 10:01 pm
Very cool. This should be very handy for presentation work. :enlight:
Content Creator at Skapeup
User avatar
EarthMover
Premium Member
Premium Member
Postby Dave R » Wed Aug 03, 2011 12:15 am
Very interesting indeed. Thank you.
User avatar
Global Moderator
Postby baz » Wed Aug 03, 2011 12:30 am
Useful, thanks.
Baz
I am both an early bird and a night owl, I am some form of permanently energized dragon.
User avatar
baz
Postby Chris Fullmer » Wed Aug 03, 2011 4:29 pm
Awesome, thanks for posting that Chris!
User avatar
SketchUp Team
SketchUp Team
Postby Ben Ritter » Wed Aug 03, 2011 6:21 pm
Thank you.
Ben Ritter
Postby Bob James » Wed Aug 03, 2011 7:09 pm
Thank you
User avatar
Bob James
Premium Member
Premium Member
Postby wyatt » Wed Aug 03, 2011 7:46 pm
This is great. Thank you!
wyatt
Postby spence » Wed Aug 03, 2011 7:53 pm
Oh this is fabulous, thanks Chris.
Spence
User avatar
spence
Premium Member
Premium Member
Postby Jean-Franco » Wed Aug 03, 2011 10:28 pm
Very useful, thank you !
Jean-Franco
User avatar
Jean-Franco
Postby studeag » Thu Aug 04, 2011 2:58 am
Extremely usefull,
Thank you!
studeag
Postby modelhead » Thu Aug 04, 2011 2:59 am
That revs things up...thanks very much!!
modelhead
Postby TIG » Thu Aug 04, 2011 12:13 pm
This is a very good idea. :D
I have a few points...
Please remember to parenthesize you arguments, for future Ruby compatibility - e.g. it's best like
model.pages.add("Initial State")
and NOT
model.pages.add "Initial State"
I know the API is full of 'wrong' examples and they do work... BUT with changes to the way Ruby works across versions, then if they aren't inside () you will get issues...
You should protect you code inside a module - someone else might have also defined hideAll too in their 'unwrapped' code... which might mess up you [or them] !
So let's call it
module CMD
### ALL code goes here
Then recast your three methods with a leading self. like this
def self.hideAll()
etc,
Also ensure that any calls of those methods then appear as
self.hideAll()
etc
The menu section also needs to use
...{self.viewParts()}
if it's within the module, but if it's outside of the module then it becomes
...{CMD.viewParts()}
Also you could replace the
if file_loaded?("viewparts.rb")
etc with
if file_loaded?(File.basename(__FILE__))
as __FILE__ returns the path to the script itself and doesn't rely on the file keeping a certain name.
Personally I'd also put this Tool under the 'View' menu rather than in 'Plugins'... but that's me...
Please don't take my comments as criticisms of a great idea, that's well executed - it's just that these minor tweaks would make it more 'robust'... :geek:
User avatar
Global Moderator
Postby MALAISE » Thu Aug 04, 2011 1:04 pm
Great tool for complex mechanisms
Thanks a lot
User avatar
MALAISE
Postby driven » Thu Aug 04, 2011 3:06 pm
hi,
does anyone have this working on a mac... [EDIT-the examples on a mac!!!]
I tried both standard and a version using TIG's mods, and although both create scenes, everything is hidden.
the only way to see any content is to use 'edit>>unhide>>all' but then 'ALL' are unhidden in 'ALL' scenes.
I tried using the hide 'other' feature to see the individual elements, but this gets zeroed when I switch pages[scenes].
does the model need to have separate layers for each group/component?
any ideas?
driven
PluginStore Author
PluginStore Author
Postby fastech370 » Thu Aug 04, 2011 9:39 pm
Awesome Plugin. This saves a lot of time!!!!!
User avatar
fastech370
Premium Member
Premium Member
Postby Jean-Franco » Wed Aug 24, 2011 4:07 pm
driven wrote:I tried both standard and a version using TIG's mods, and although both create scenes, everything is hidden.
I've the same situation under Windows XP 3.
If I select components within a group and launch Viewparts, it creates all the needed scenes but all is hidden. And no way to unhide anything.
Have a look at the attached file.
Driven, If you don't mind, I'd like to have your updated script with TIG's modifications to do a test.
I'm sorry but I'm really not a Ruby scripter.
Thanks.
cerificateur-scenes.skp
Jean-Franco
User avatar
Jean-Franco
Postby yellow peril » Wed Aug 31, 2011 12:44 pm
Hi has anyone any idea why this script seams to lock up my files while using the arc tool, I have unstalled this excellent script and found that all is working fine, maybe its a mac issue, some help would be much appreciated........
Thank You
User avatar
yellow peril
Re: [Plugin] View Parts (1.1) — Sept 06 2011
Postby rjhorky » Tue Sep 13, 2011 7:58 pm
for the life of me I cannot figure out why I cannot get this to work. I click on the link, save to the plugins folder within SU8. It does not show up anywhere but I can see it in the folder. Any ideas?
rjhorky
Re: [Plugin] View Parts (1.2) — Sept 13 2011
Postby Dave R » Tue Sep 13, 2011 10:10 pm
Did you restart sketchUp after installing the file in the Plugins folder? Did it install with the .rb extension?
User avatar
Global Moderator
Postby ksjoern » Wed Sep 14, 2011 7:57 am
The Plugin does not work with a Mac. I put it in the correct folder (Library/Application Support/Google SketchUp 8/SketchUp/plugins).
The required 'sketchup.rb' is included in the TT_Lib2. But the plug-in window shows no entry "Exploded View"
Any idea what I could change?
Could it be a problem not working with an english system interface?
ksjoern
Postby driven » Wed Sep 14, 2011 10:10 am
hi,
You need to have at least 1 group or component in your model,
you should have a 'Parts>> views ' entry in the Plugin Menu, [Edited following TT's comment..]
click on that entry, choose your options and it will make the scenes.
click on scene tabs to view.
group a square, then try it out.
if you open a drawing with lots of groups, it will make lots of scenes.
driven
PluginStore Author
PluginStore Author
Postby thomthom » Wed Sep 14, 2011 10:19 am
ksjoern wrote:The required 'sketchup.rb' is included in the TT_Lib2.
No - this plugin has no dependance on TT_Lib2.
The required sketchup.rb is located in SketchUp's Tools folder. (Where it should stay.)
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Wed Sep 14, 2011 10:21 am
driven wrote:You need to have at least 1 group or component in your model,
you will then get a 'Parts>> views ' entry in the Plugin Menu,
Menus in the top level menus (File,Edit,View,Plugins,etc...) does not hide or show based on selection. They are fixed. Only context menus are dynamic like that.
User avatar
PluginStore Author
PluginStore Author
Postby driven » Wed Sep 14, 2011 10:52 am
thomthom wrote:Menus in the top level menus (File,Edit,View,Plugins,etc...) does not hide or show based on selection. They are fixed. Only context menus are dynamic like that.
edited my post, your are correct, I loaded it from console to test, so it wasn't there before , but was after... dohh
driven
PluginStore Author
PluginStore Author
Postby ksjoern » Fri Sep 16, 2011 7:44 am
Great, now it works on my mac. - I've probably always have the downloaded previous (1.1) version.
ksjoern
Postby dannyver » Tue Oct 04, 2011 6:37 pm
Jean-Franco wrote:Hi,
Thanks.
i have the same problem is ther any one ho has a answer or solution for this problem already :?: :?:
dannyver
Postby dannyver » Sun Oct 09, 2011 6:52 pm
Thanks.
is there no one ho has a solution for this problem :cry: . this can make this plugin very useful :D
dannyver
Postby driven » Sun Oct 09, 2011 7:58 pm
hi dannyver,
I don't use SU 6 and I'm on a mac so it's hard to know what issues your having.
maybe you could re-cast your question to target your setup better.
e.g. "I've tried this plugin using SU6 on this skp and it doesn't seem to function, can someone check if it's my skp?
or "can someone post a skp that works with this plugin in SU6 so I can check my setup..."
With the first example you'll likely find out if your skp works or with the second you'll eliminate a wrongly setup skp...
sorry I can't be of more help. Personally I know it 'basically' works on mac using SU8, but I only tested the functionality for future use.
other than that I suggest checking you've got the latest version, and re-read any instructions or posts.
also, if you no longer use SU6 update your User Settings.
driven
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: bozfirmanboz, Devis, fernandotrianggoro, goul, Jinghibrid, kore, rl12345, samarya, ysaimuey and 9 guests
Visit our sponsors:
