[Plugin] View Parts (1.2) — Sept 13 2011
• Page 1 of 2 • 1, 2
[Plugin] View Parts (1.2) — Sept 13 2011The View Parts ruby script will build a scene for every unique component and group in a selection set.
The idea behind the ruby was to find a quick way to isolate and view each part of an assembly either for general viewing or to put into the SketchUp LayOut program for dimensioning and part arrangement. Here is a video to see it in action: UPDATE - 09-06-2011 Changed code to reflect best practices mentioned by TIG. UPDATE - 09-13-2011 Menu load correction Feel free to hack away at the ruby and improve it as you see fit. Enjoy ! CMD Last edited by cmd on Tue Sep 13, 2011 9:10 pm, edited 3 times in total.
- CMD
Re: [Plugin] View PartsVery cool. This should be very handy for presentation work.
![]() 3D Artist at Clearstory 3D Imaging
Guide Tool at Winning With Sketchup Content Creator at Skapeup
Re: [Plugin] View PartsVery interesting indeed. Thank you.
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: [Plugin] View PartsUseful, thanks.
Baz I am both an early bird and a night owl, I am some form of permanently energized dragon.
Re: [Plugin] View PartsAwesome, thanks for posting that Chris!
Re: [Plugin] View PartsThank you
Re: [Plugin] View PartsThis is a very good idea.
![]() I have a few points... Please remember to parenthesize you arguments, for future Ruby compatibility - e.g. it's best like model.pages.add("Initial State") and NOT model.pages.add "Initial State" I know the API is full of 'wrong' examples and they do work... BUT with changes to the way Ruby works across versions, then if they aren't inside () you will get issues... You should protect you code inside a module - someone else might have also defined hideAll too in their 'unwrapped' code... which might mess up you [or them] ! So let's call it module CMD ### ALL code goes here end Then recast your three methods with a leading self. like this def self.hideAll() ... etc, Also ensure that any calls of those methods then appear as self.hideAll() etc The menu section also needs to use ...{self.viewParts()} if it's within the module, but if it's outside of the module then it becomes ...{CMD.viewParts()} Also you could replace the if file_loaded?("viewparts.rb") etc with if file_loaded?(File.basename(__FILE__)) as __FILE__ returns the path to the script itself and doesn't rely on the file keeping a certain name. Personally I'd also put this Tool under the 'View' menu rather than in 'Plugins'... but that's me... Please don't take my comments as criticisms of a great idea, that's well executed - it's just that these minor tweaks would make it more 'robust'... ![]() TIG
Re: [Plugin] View PartsGreat tool for complex mechanisms
Thanks a lot La Connaissance n'a de valeur que partagée
Re: [Plugin] View Partshi,
does anyone have this working on a mac... [EDIT-the examples on a mac!!!] I tried both standard and a version using TIG's mods, and although both create scenes, everything is hidden. the only way to see any content is to use 'edit>>unhide>>all' but then 'ALL' are unhidden in 'ALL' scenes. I tried using the hide 'other' feature to see the individual elements, but this gets zeroed when I switch pages[scenes]. does the model need to have separate layers for each group/component? any ideas? john Last edited by driven on Thu Aug 04, 2011 9:56 pm, edited 1 time in total.
Re: [Plugin] View PartsHi,
I've the same situation under Windows XP 3. If I select components within a group and launch Viewparts, it creates all the needed scenes but all is hidden. And no way to unhide anything. Have a look at the attached file. Driven, If you don't mind, I'd like to have your updated script with TIG's modifications to do a test. I'm sorry but I'm really not a Ruby scripter. Thanks. Jean-Franco
Re: [Plugin] View PartsHi has anyone any idea why this script seams to lock up my files while using the arc tool, I have unstalled this excellent script and found that all is working fine, maybe its a mac issue, some help would be much appreciated........
Thank You Re: [Plugin] View Parts (1.1) — Sept 06 2011for the life of me I cannot figure out why I cannot get this to work. I click on the link, save to the plugins folder within SU8. It does not show up anywhere but I can see it in the folder. Any ideas?
Re: [Plugin] View Parts (1.2) — Sept 13 2011Did you restart sketchUp after installing the file in the Plugins folder? Did it install with the .rb extension?
Re: [Plugin] View Parts (1.2) — Sept 13 2011The Plugin does not work with a Mac. I put it in the correct folder (Library/Application Support/Google SketchUp 8/SketchUp/plugins).
The required 'sketchup.rb' is included in the TT_Lib2. But the plug-in window shows no entry "Exploded View" Any idea what I could change? Could it be a problem not working with an english system interface? Re: [Plugin] View Parts (1.2) — Sept 13 2011hi,
You need to have at least 1 group or component in your model, you should have a 'Parts>> views ' entry in the Plugin Menu, [Edited following TT's comment..] click on that entry, choose your options and it will make the scenes. click on scene tabs to view. group a square, then try it out. if you open a drawing with lots of groups, it will make lots of scenes. john Last edited by driven on Wed Sep 14, 2011 10:49 am, edited 1 time in total.
No - this plugin has no dependance on TT_Lib2. The required sketchup.rb is located in SketchUp's Tools folder. (Where it should stay.) Thomas Thomassen — SketchUp Monkey & Coding addict
Menus in the top level menus (File,Edit,View,Plugins,etc...) does not hide or show based on selection. They are fixed. Only context menus are dynamic like that. Thomas Thomassen — SketchUp Monkey & Coding addict
edited my post, your are correct, I loaded it from console to test, so it wasn't there before , but was after... dohh learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: [Plugin] View Parts (1.2) — Sept 13 2011Great, now it works on my mac. - I've probably always have the downloaded previous (1.1) version.
i have the same problem is ther any one ho has a answer or solution for this problem already ![]() ![]() Re: [Plugin] View Parts
is there no one ho has a solution for this problem ![]() ![]() Re: [Plugin] View Parts (1.2) — Sept 13 2011hi dannyver,
I don't use SU 6 and I'm on a mac so it's hard to know what issues your having. maybe you could re-cast your question to target your setup better. e.g. "I've tried this plugin using SU6 on this skp and it doesn't seem to function, can someone check if it's my skp? or "can someone post a skp that works with this plugin in SU6 so I can check my setup..." With the first example you'll likely find out if your skp works or with the second you'll eliminate a wrongly setup skp... sorry I can't be of more help. Personally I know it 'basically' works on mac using SU8, but I only tested the functionality for future use. other than that I suggest checking you've got the latest version, and re-read any instructions or posts. also, if you no longer use SU6 update your User Settings. john learn from the mistakes of others, you may not live long enough to make them all yourself...
Who is online
Users browsing this forum: 786shakir92, AL SHAWI, archmark1224, boy011761, Nawrocka, regina614 and 7 guests
