[plugin]Random replacement of components
• Page 1 of 2 • 1, 2
[plugin]Random replacement of componentsIn response to viewtopic.php?f=323&t=37434 and others, I have written a plugin to accomplish this given two sets of components, a source set and a target set. These sets are identified by giving all the members of the set the same component name. Components also have a definition name which is what is entered when the component is created. The component name is displayed and can be assigned in the Entity Info panel. The appearence of a component is determined by the definition assigned to it by the definition name. If a sub-set of target components are pre-selected, then only those will be randomly changed.
Re: [plugin]Random replacement of componentsA little tut
![]() No limite of number of any components source or target! ![]() You can name all your source components by hand but it's painfull when you have numerous! So a little trick ![]() Just select Components source and copy this in the ruby console Sketchup.active_model.selection.each{|c| c.name='Source'} Your source components are now named "Source" You can make the same for Target Component ![]() Just select Components source and copy this in the ruby console Sketchup.active_model.selection.each{|c| c.name='Target'} Edit : In fact for the rename Source and Target you can make the just with the Entity Info Box! ![]() You can now use the random plug ![]() Of course it's infinite possibilities ![]() You can fill the space with no periodic infinite volumes ![]() you can play with this speedy one ![]() Edit 31 May 2012 A new variant without random is integrated! Last edited by pilou on Thu May 31, 2012 11:50 am, edited 18 times in total.
Re: [plugin]Random replacement of componentsis it possible to use this script to create custom set of trees ?
Re: [plugin]Random replacement of componentsLike a building construction game yes
![]() just careful that all connections between parts is good managed But seems it's a painful work to divide a tree in small parts then create some variations for all these tree's parts ![]() But if you want remplace just all one tree by another tree no problem you will have different forest at each launch ![]()
Re: [plugin]Random replacement of componentsMan, that's great! Thanks to sdmitch!
Thanks to Pilou for this tut- even if i didn't really get it..yet. ![]() I'll give it a try asap. How are the components replaced? By replacing it a the origin of axis within each component? Is it possible to add random scale and orientation as well (like for scattering trees)? Looks nice already! still sketchin'
I believe Yes
I believe you can use some existing plugs for this at the end of the process ![]() Like Random select by TIG and then make some Scale or Rotation / Move + in the same time Scale and Rotate mutiple who has randomly feature inside by Chris Fullmer ![]() ![]() ![]() Or with only the plug make a familly of trees with different Sizes and Rotations ![]()
Re: [plugin]Random replacement of componentsThank you Sam
![]() so not to waste time on renaming. ![]() www.saurus.rs
Re: [plugin]Random replacement of componentsFirst, there is no reason the change the component.definition.name only the component.name which is the only thing that the plugin checks for. If you select those components that you want to use as the Source set then, from the ruby console, "Sketchup.active_model.selection.each{|c| c.name='Source'}" will properly identify them as the Source set. Substitute 'Target' for 'Source' to identify the selected Target set.
Re: [plugin]Random replacement of componentsI will change again my tut
![]() PS You can make the same for Target's Components ![]() "Sketchup.active_model.selection.each{|c| c.name='Target'}"
Re: [plugin]Random replacement of componentsPilou, Thanks again for providing the tutorial. It looks perfect!!!
Re: [plugin]Random replacement of componentsIn fact that is some redundant with the use of the Dialog box Info for rename a group of components!
Re: [plugin]Random replacement of componentsLittle teaser
![]() The 24 position Plug always by Sdmitch will be released in a few time! ![]() A very pleasant plug! ![]()
it would be great if the plugin's author could explain how to use it or, better still, post a tutorial showing it. sorry, pilou, but yours is not that clear to me.
Re: [plugin]Random replacement of components![]() select some components with different "Definition Name" in any position Give the "Name" Source to these selection with the Info Dialog box Draw another one component: Draw copy past it anywhere you want in any position Select all these copies Give the "Name" Target to the all selection copies with the Info Dialog box launch the plugin Random Replacement ![]() I can't be more clear ![]() (the 24 positions is another plugin not yet released ![]()
thanks, pilou. you are right: in writing, the explanation is very clear. I have been asking for a similar plugin for a long time but no one seemed willing to create one. for me it will be very useful to randomize vegetation and windows (closed, open, half this, half that, etc). a comment though: one does not necessarily have to name the source components source and the target ones target for the plugin to work. first I named them as you suggested and then I named them 1 and 2. the plugin worked in both situations. so, as long as there is a named source group and a named target group it works fine.
Re: [plugin]Random replacement of components@Edson
![]() No, Source and Target are not nescessary names ![]() It's just these given by default in the dialog box ![]() you can put any names you want ![]() ![]() But carreful it's sensitive cases !!!
Re: [plugin]Random replacement of componentsAnd here the 24 positions plug of Sdmitch
![]() With his autorisation! ![]()
Re: [plugin]Random replacement of componentsthere are many uses for this plugin.
for example... think of 3D tiles on a roof. Each tile is a component. But the roof gets so artificial, with all the tiles exactly the same color, no stains, etc. With this plugin, you would be able to, for example, create some 10 different roof tiles, each of them a slight different color variation, some stains, etc. And randomly replace the original components along the entire roof. another possibility: a building with a glass façade. Real such buildings will have curtains/blinds behind the windows. Make the the building with window components. The random replace them with OTHER window components, each window component with blinds in different positions (no blinds, blinds half way pulled, pulled down completely) there are so many uses!!! Re: [plugin]Random replacement of componentsSdmitch has made a new variant with no Random integrated!
![]() (see second post for more precsion of use ![]()
Re: [plugin]Random replacement of componentsThis is not working for me, Pilou can I send you a sample model by pm and you show how to do it?
Re: [plugin]Random replacement of componentsOf course yes you can!
![]() with a small file (sufficient for the concept) and a save as V7!!! ![]()
Re: [plugin]Random replacement of componentshttp://dl.dropbox.com/u/1129899/test%20tree.skp
Strange how the size of file increases 50% when saving as SU7 from SU 8.
Re: [plugin]Random replacement of componentsSorry it's always V8 when its arriving at home !!!
Re: [plugin]Random replacement of componentsThis is an awesome plugin... thank you both very much!!! Jo
![]() ...you send them to school, you give them books, and they eat the pages...
Re: [plugin]Random replacement of componentsmight it be possible that the plugin would work with grouped and nested components?! that would be übercool!!
Re: [plugin]Random replacement of componentsThis plugin is indeed great with so much potential. Do you think it could be possible to
make it able to replace child components that are inside mother componennts? You could do so many patterns just by replacing components inside components. Re: [plugin]Random replacement of componentscoty82
Please check Personal Messages.
Re: [plugin]Random replacement of componentsHello sdmitch
Thanks for the fast reply! I have installed it but unfortunatelly when i try to use it it just freezes Sketchup no matter if i choose to include child components or not. Is it working for you?
Who is online
Users browsing this forum: Karenjoselynr, veljkovulanovic and 16 guests
