[Plugin] FredoTools:RemoveLonelyVertices 1.2a - 20 Jul 11
Postby fredo6 » Mon May 30, 2011 12:12 am
RemoveLonelyVertices is a small standalone script which will remove (or mark with construction points) the vertices that joins consecutive and collinear edges.
RemoveLonelyVertices works on a selection or on the whole model recursively.
It normally preserves all faces and textures.
RemoveLonelyVertices is now installed as part of FredoTools.
See the main post for this plugin for Installation
No user manual (see section Quick Start below)
  • Language: English and French
  • Menus: by default, it is installed in Tools > FredoTools > Remove Lonely Vertices and also appears in the Contextual menu when there is at least one edge or face in the current selection
  • Icon toolbar: Fredo6 Tool. Icon is not shown by default
  • The plugin is free, for private and commercial usage.
  • Select edges that contain lonely vertices. You can also select faces, groups and components to act on them as a whole. If you select nothing, the plugin will apply the clean up of the lonely vertices to the whole model.
  • Call the Plugin on the selection (main menu or contextual menu “Remove Lonely Vertices”)
  • all lonely vertices are marked with a small green cube
  • a dialog box will appear, asking for action (remove or mark) and whether you wish to process recursively
  • Lonely vertices are removed
RemoveLonelyVertices 1.2a - 20 Jul 11: Part of FredoTools. No functional change
RemoveLonelyVertices 1.1a - 29 May 11: Initial public release
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] RemoveLonelyVertices - v1.1a - 29 May 11
Postby Rich O Brien » Mon May 30, 2011 12:47 am
Thanks Fredo. Great Tool
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby JClements » Mon May 30, 2011 3:09 am
+1. Thanks, Fredo.
This should have been built into SU in the first place ... as either an element of the Edit Menu or an option of Model > Purge.
User avatar
JClements
Premium Member
Premium Member
Postby mitcorb » Mon May 30, 2011 4:28 am
Thank you Fredo. This tool should come in handy as an analytical tool prior to using ArtisanSDS. Occasionally, Artisan will ding you about "lonely vertices" in the process of subdividing, although that's not what the error message says. And, point well made by JClements.
User avatar
mitcorb
Top SketchUcator
Postby rv1974 » Mon May 30, 2011 8:01 am
thank you, it'll help in sanitary state preserving.
rv1974
Postby pilou » Mon May 30, 2011 10:22 am
Tricky ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby JGA » Mon May 30, 2011 1:14 pm
Thanks very much, this will be a very handy tool.
Regards,
JGA
JGA
Postby Panga » Mon May 30, 2011 4:10 pm
Thanks for this plugin Fredo, it'll complete the Thomthom's Cleanup plugin. :thumb:
Panga
Premium Member
Premium Member
Postby putnik » Tue Jun 07, 2011 7:24 am
I've been wanting a tool like this forever. Thanks very much Fredo6! :berserk:
putnik
Postby Pherim » Tue Jun 07, 2011 8:13 am
Great plugin! Thanks!
Pherim
Postby abilio » Fri Jun 24, 2011 10:40 pm
Fredo u r hell awesome, thank u so much.
abilio
Postby dylan » Sun Jun 26, 2011 7:48 am
Thanks Fredo, impressive work again.
dylan
Postby thomthom » Sun Jun 26, 2011 11:47 am
Panga wrote:Thanks for this plugin Fredo, it'll complete the Thomthom's Cleanup plugin. :thumb:
CleanUp has the feature - it's the Repair Split Edges function.
User avatar
PluginStore Author
PluginStore Author
Postby fredo6 » Sun Jun 26, 2011 1:22 pm
@panga: Thomthom is right, this is part of the great suit of Cleanup tools. The only small difference is that RemoveLonelyVertices allows to visualize the lonely vertices before proceeding, and also to repair a selection of colinear edges on a full sequence of colinear edges (instead of replacing the whole sequence by a single edge). This is just very subtle (and not sure this is required in the real life), but I needed this feature for another script.
User avatar
PluginStore Author
PluginStore Author
Postby Ben Ritter » Fri Jul 15, 2011 2:44 pm
Thank you again, for your generosity and great work.
Ben Ritter
Re: [Plugin] FredoTools:RemoveLonelyVertices 1.2a - 20 Jul 1
Postby gokhan0322 » Wed Jul 19, 2017 7:35 am
thn xxxxxxxxx
gokhan0322
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
cron
Who is online
Users browsing this forum: CharlyAxams, janmarie0807, sjbrown, zzm and 11 guests
Visit our sponsors:
