SketchUcation Premium Membership
[Plugin] FredoScale 2.2a - 24 Jul 11
Re: [Plugin] FredoScale 2.1a - 12 Jan 11
Postby narayan » Mon Jun 06, 2011 5:57 am
Thanks Fredo!
That solution worked well. I hope SU8 does not let the toolbars escape once again (the Fredo6 collection toolbar seems to play truant often.)
BTW it is confusing to have window settings in two different menus:
* Tools>Fredo6 collection>plugInName>Default parameters and
* Windows>LibFredo6 settings > Default parameters
TIG, thanks for the tip; but I already follow what you described (that is what I posted earlier: I undock the toolbar; fold it in a two-column configuration, and dock it again.)
I actually described three possibly related problems.
One of them is resolved thanks to the settings.
The other two problems which are not yet resolved are-
1. The Fredo6 toolbar snaps back to a three-column configuration on its own.
2. ALL the toolbars escape their docking positions and pile up vertically (each toolbar takes up one line on its own). Then I have to drag each toolbar back to the top or left of the screen. This is a huge time-waster.
In fact, I face the toolbar problem even without restarting SU8 OR restarting the PC: It simply happens even while I am working SU8. All of a sudden the toolbars escape and occupy the top of the screen, leaving very small space for the canvas area.
I mentioned all three problems here because I am not sure whether the problem lies in SU8 or Fredo's plugin system. I somehow feel they are related.
Thanks.
narayan
Postby COSEDIMARCO » Tue Jun 07, 2011 5:42 am
Updated version of the Italian Translation
FredoScale_IT.zip
COSEDIMARCO
Postby dereeei » Wed Jun 22, 2011 7:19 am
narayan wrote:
Excuse me, I noticed some "strange looking buttons on the toolbar image posted by narayan.
I marked them with red in the image, please tell me what are they and where I can find them?
Thank you.
dereeei
Postby Gaieus » Wed Jun 22, 2011 7:25 am
The top left one is Pen tools by Rich:
viewtopic.php?t=37359
(I don't know the others either)
Rather messy toolbars however. :roll:
User avatar
Administrator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Level of SketchUp: Advanced
Great scale!
Postby Lorelalala » Fri Jun 24, 2011 10:07 pm
Thank you, Fredo!
Lorelalala
Postby Tinygrasshopper » Fri Jul 15, 2011 9:02 am
Hi!!
First of all : Muchas gracias! Super plugin!
Now... I have somme trouble with the plugin. Almost everything works fine, but "PlanarShear" and "Radial Bend" give me a bugsplat immediately, no matter the size or the form of the component, even with a single line :?:
I tryed everything i found on the forum, i updated the plugin, i updated de Fredo Lybrary, etc.
The bugsplat gives me : SketchUpP2JD3HV5.dmp, OG5T2D56.xml, SketchupUndo0.log
I work on Windows XP, SU 7.0.11018, 3Go of Ram, Intel Dual-Core E5300 (I know my PC s***ks, but is not mine, is my firm's).
Any ideas? Thanks in advance!
Tinygrasshopper
Postby fredo6 » Sun Jul 17, 2011 7:03 pm
Tinygrasshopper wrote:Hi!!
When do you get the blug splat
- when you select and start FredoScale
- When you generate the transformation.
Also, could you open the Ruby console, to see if you see something displayed just before you get the bug splat.
Thanks to be more accurate on the conditions
Top SketchUcator
Re: [Plugin] FredoScale 2.2a - 24 Jul 11
Postby fredo6 » Sun Jul 24, 2011 2:47 pm
NEW RELEASE: FredoScale 2.2a - 24 Jul 11
This release integrate a feature of Collapsing handles when dimensions are small on screen.
This was suggested in a request by Cunningham.
Kyyu also produced a plugin "Simple Scale Tool Handles" for the standard Scale tool.
The principle is to hide the handles on corners and edges when the dimension of a side appears too small on the screen (like this is usually the case for boards or for timbers). However, when you zoom in, all handles will progressively reappear.
By default a dimension is considered "small on screen" if its size appears to be under 30 pixels in the current view. You can change this value in the Default Parameters dialog box. Note that entering a value of 0 will disable the feature, i.e. all handles will always appear.
Note also that as of this release, the Dice option (activated by F4) is active by default
Please see main post for download
Top SketchUcator
Postby Rich O Brien » Sun Jul 24, 2011 2:54 pm
Thanks Fredo :thumb:
:::Blog:::
I'm a Trimbler now!
User avatar
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby thomthom » Sun Jul 24, 2011 3:03 pm
That is a really nice feature addon. :thumb:
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby jorge2011 » Sun Jul 24, 2011 4:12 pm
Thank you very much Mr. Fred for this new update. It is very good.
If possible, the next update adds the option to change the color and size of the nodes in the boxes?
and switch on or off the visualization of the axes
thank you very much
jorge2011
SketchUp version: 7
License type: Pro
Level of SketchUp: Intermediate
Postby dereeei » Thu Jul 28, 2011 11:28 pm
I have two major problems with the plugin: I can't see the new scaling icon on toolbar and I could not find it on settings webdialog.
Second problem is shown in the images below. It seems that stretching is made accordingly with global axis, not component's orientation.
I have the last plugin and LibFredo3.7
dereeei
Postby Rich O Brien » Thu Jul 28, 2011 11:33 pm
Hi Fredo,
I notice that this latest release isn't found via the 'Check for Update' feature within SU?
:::Blog:::
I'm a Trimbler now!
User avatar
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby fredo6 » Fri Jul 29, 2011 8:37 am
dereeei wrote:I have two major problems with the plugin: I can't see the new scaling icon on toolbar and I could not find it on settings webdialog.
1) There is no new scaling icon
2) you need first to orientate the scaling box. Just click on the long edge of your component.
Top SketchUcator
Postby fredo6 » Fri Jul 29, 2011 8:38 am
Rich O'Brien wrote:Hi Fredo,
Rich,
You are right. Thanks.
I just published the notice for the version 2.2a.
Fred
Top SketchUcator
Postby dereeei » Fri Jul 29, 2011 9:06 am
Fredo6 wrote:1) There is no new scaling icon
This post mislead me viewtopic.php?f=323&t=17948&p=344976#p343978 In the image are two scaling icons on toolbar
Fredo6 wrote:2) you need first to orientate the scaling box. Just click on the long edge of your component.
Strange, I haven't done that before... is it a new feature? Also it is possible that I never was into position to stretch rotated components :D
Thanks for the tip. What about components that don't have edges collinear with axis orientation, how do we orientate the scaling box then?
dereeei
Postby Rich O Brien » Fri Jul 29, 2011 9:21 am
@dereeei
You can have extra icons that are 'scale to target' enabled. Check the documentation to see what they care.
@Fredo
Your first post still has the January version as the current download version under the download icon. The file is correct but the text suggests an older version.
:::Blog:::
I'm a Trimbler now!
User avatar
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby fredo6 » Fri Jul 29, 2011 10:52 am
dereeei wrote:1) There is no new scaling icon
Just go to Fredo6 Collection > FredoScale > Default Parameters.... Scroll down the dialog box and you'll find check boxes to enable additional icons. Note that whether icons are visible or not, the menu entry for all commands is always available. The icons you talk about are Scale to Target and Stretch to Target
dereeei wrote:2) What about components that don't have edges collinear with axis orientation, how do we orientate the scaling box then?
First you can orientate the box by clicking on any line or face in the model. The line or face does not have to be in the component.
Second, you can also orientate the box along the local axes of the component. Just use the Arrows.
All details are explained in the documentation which is available from within Sketchup (Fredo6 Collection > FredoScale > Documentation...)
Top SketchUcator
Postby paddyclown » Fri Aug 05, 2011 1:46 pm
Hi, this is a lovely pugin, however there appears to be an issue concerning the context menu in other tools becoming greyed-out when it is enabled... http://sketchuptips.blogspot.com/2010/0 ... d-out.html
I don't fully understand the explanation at this above post link, but following the advice to disable FredoScale seems to fix the greyed out context menu...
Is there a fix in the pipeline ?
Anyway, it's a minor thing once one knows, & thanks for the good work.
paddyclown
Postby Jim » Fri Aug 05, 2011 1:58 pm
Hi Patrick,
That (my) blog post is over a year old, and I thought FredoScale had been updated to address the problem. I can not find a reference to it being fixed. Fredo will need to clarify.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby paddyclown » Fri Aug 05, 2011 2:21 pm
Hmm, thanks & meantime I found this : viewtopic.php?t=29032
which seems to sort the problem for me... so heh makes me happy as I have tons of things loaded that I use...
Hope one day Google gets 'round to making a loader/unloader for plugins that's easy to use...
Anyhow, thanks to all you clever people who know how to ruby script !
paddyclown
Postby meeta » Fri Aug 05, 2011 6:31 pm
A big thank you. This plugin will be saving me hours and hours of work!
Meet A
meeta
Postby The Pixel Artist » Sun Aug 07, 2011 11:42 pm
Dear Fredo,
FYI, I updated to 2.2a today and found that the radial bending tool seems to break the ability to use ThomThom's UV Toolkit remember/restore feature. It works fine with 2.1a and I've gone back to that version for now. Just thought I'd make you aware of it.
Here's the link to my post in the UV Toolkit thread that explains the problem better. The combination of Fredoscale and the UV Toolkit to do things like curved brick arches is terrific!!
LINK: viewtopic.php?p=346983#p346983
BTW, thanks for all of your hard work over the years! I've never had to chance to thank you. (I haven't posted here in a couple of years!)
The Pixel Artist
Name: Adrian Alan Brown
Postby fredo6 » Tue Aug 09, 2011 2:10 pm
Dear Pixel Artist,
The only difference between 2.2a and 2.1a is that FredoScale activates the Automatic Slicer by default in 2.2a (the slicer is toggled by key F4 and is shown with small orange ticks along the line of curvature).
If you bend a shape which is already sliced with enough granularity, you don't need the automatic slicer, and thus you would probably not alter the UV settings.
This may be the explanation. Thanks to advise if this is the case.
PS: I did the activation of Slicer by default in 2.2a because many users had problem to bend solid shapes like a simple cylinder and did not read the documentation to find out about the Slicer.
Top SketchUcator
Postby lapx » Thu Aug 11, 2011 7:29 pm
Hey Adrian,
You are a sketchup hall of fame'er. I have always admired your worked. Good to see you posting on the board.
No doubt you've kept busy in chi'town and abroad with all that talent.
lapx
Postby cunningham » Fri Aug 12, 2011 1:19 pm
Awesome, Sorry I've been away. But excellent work
Should increase workflow no end
cunningham
Postby dereeei » Tue Aug 16, 2011 7:51 am
Could you modify the Update-Check window? For now it just highlights with red the outdated plugins. It would be useful to link to plugin's forum page.
Thank you.
dereeei
Postby fredo6 » Tue Aug 16, 2011 8:10 am
dereeei wrote:Could you modify the Update-Check window? For now it just highlights with red the outdated plugins. It would be useful to link to plugin's forum page.
Thank you.
Not sure I understand.
In the check for update dialog box, the middle column ("info") is precisely the link to the Forum page.
Do you get it?
Best is maybe to post a picture of the dialog box.
Top SketchUcator
Postby dereeei » Tue Aug 16, 2011 3:26 pm
Fredo6 wrote:Not sure I understand.
Do you get it?
Thanks for pointing it to me. I only hovered on left column. I guess my I expected the entire line to be a link :mrgreen: So, when I saw that nothing happens, I never thought to try the underlined Info text.
dereeei
Postby dereeei » Fri Aug 19, 2011 1:23 pm
Is it a bug, or I do something wrong?
The inference for scaling don't work in certain situations. Please see the image. Is not the first time when it happens.
I tried to scale the door, to meet a line which was drawn in a group outside door component. The door scaled arbitrary.
Thank you very much.
dereeei
by Ad Machine » 5 minutes ago
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: alab925, buena, entity66, kbaba, monique99 and 7 guests
